| Do you find a math module important? |
| Yes |  | 91% | [ 21 ] |
| dunno |  | 4% | [ 1 ] |
| math?? hey, I'm a MUSICIAN! |  | 4% | [ 1 ] |  |
| Total Votes : 23 |
| Author | Message |
| Tim Kleinert
 G2 patch files: 236
|  Posted: Tue Aug 17, 2004 4:10 pm    Post subject:
Math module |    |
| I think a module for mathematical operations belongs into every comprehensive digital modular system.
 A basic module could look like this:
 1) Two dynamic blue/red inputs for coefficients x and y
 2) a dropdown menu with mathematical operations to choose from, such as x/y, xth root of y, x modulo y etc. Also functions like tan(x) (the y input remains inactive)
 3) a dynamic blue/red output for the result
 4) a yellow/orange logic output, that works as an "error flag" and outputs a logic high signal whenever the result cannot be represented within the +/- 64 units range (division by zero, complex numbers etc.)
 Or maybe somebody has a better idea. Bring it on.
| Back to top |  |
| W.T.
 G2 patch files: 11
|  Posted: Tue Aug 17, 2004 4:24 pm    Post subject:
bang toggle |    |
| i think it is a verry good idea. also some + - x modules would be fine.
| Back to top |  |
| ian-s
 Audio files: 42
 G2 patch files: 626
|  Posted: Tue Aug 17, 2004 5:42 pm    Post subject: |    |
| Good idea I think. They could also do an invisible module which deals with the imaginary part of complex numbers
 ---- edit
 sorry, probably not the place for kidding around, it is a good idea even if it just does division.
| Back to top |  |
| elektro80 Site Admin
|  Posted: Tue Aug 17, 2004 5:52 pm    Post subject: |    |
| In that case ...perhaps it is already in there..    _________________
 Flickr
| Back to top |  |
| W.T.
 G2 patch files: 11
|  Posted: Wed Aug 18, 2004 8:57 am    Post subject: |    |
| Just division ?!
 don't be fooled by the powers of adding and subtracting!
 I am adding and subtracting
 I'm controlling and composing
 By pressing down a special key, it plays a little melody
| Back to top |  |
| 3phase
 G2 patch files: 141
|  Posted: Wed Aug 18, 2004 4:13 pm    Post subject: |    |
| Some math can help in certain situations... but i dont expect the G2 to be too accurat in this things... When i look at the errors Reaktor is able to produce even with the free scaleable controller resolutions... Math is defenetly something that has more options in a pure software enviroment...A PC is mainly a calculator.
 However it dont allways have to be precise and a division module might be usefull anyway.
| Back to top |  |
| Afro88
 Audio files: 12
 G2 patch files: 79
|  Posted: Wed Aug 18, 2004 8:18 pm    Post subject: |    |
|  	  | W.T. wrote: |  	  | Just division ?!
 Hehehe, we are the robots indeed, using our pocket calculators
 Addition and subtraction can be done with the mixer modules. They operate not only on audio, but also control signals. Use the mix4-1A or mix8-1A modules to add numbers (you can also use the other mixers if each channel's knob is set to full). Subtraction is the same, but the number to be subtracted should have it's polarity inverted before entering the mixer (or in the case of mix2-1, press the inv button of the input to be subtracted). Multiplication between 2 numbers is done with the level multiplier module (again, works with not only audio but control signals).
 It takes a while to get your head around, especially after coming from Reaktor where there are specific add, subtract, multiply and divide modules. The thing that I've found with the G2 is that each module has many other uses than the obvious - it's finding and utilising these other uses that makes it fun
  (and really really flexible). |  |
| Back to top |  |
| W.T.
 G2 patch files: 11
|  Posted: Thu Aug 19, 2004 5:47 am    Post subject: |    |
| thanks afrokid,
 I am certainly going to try this one!
 greetings,
 Jeroen
| Back to top |  |
| zynthetix
 Audio files: 10
 G2 patch files: 13
|  Posted: Thu Aug 19, 2004 9:25 pm    Post subject: |    |
| math modules are important in context...I would rather not see them in the nord.  Modulating an Osc with an LFO would require some math in reaktor, and I am thankful I can just run the patch cables and not think about those extra steps in the G2. |  |
| Back to top |  |
| Tim Kleinert
 G2 patch files: 236
|  Posted: Thu Sep 02, 2004 3:02 pm    Post subject: |    |
|  	  | Quote: |  	  | Modulating an Osc with an LFO would require some math in reaktor |
 No it doesn't. I think you mean Max/MSP. Reaktor is actually quite straighforward and conceptually strong. Only the UI is unintuitive (these ridiculous pixel-size inputs and straight line cables).
 Anyway -I'm not talking about "atomizing" the complete G2 architecture in a mathematical manner. I just like to have a module to perform mathematical functions, as described above.
| Back to top |  |
| mosc Site Admin
 Audio files: 227
|  Posted: Thu Sep 02, 2004 4:15 pm    Post subject: |    |
| It would be nice to have some sort of way to write code that could get compiled into a module. This would imply some programming language and a code compiler.
 I would think that if Clavia had any brains, they would avoid this suggestion because it would be so difficult to support. Still, it would be useful to the small percentage of programmers among the user community.
 Hmmm, why did I just suggest something I think should be avoided?
| Back to top |  |
| Tim Kleinert
 G2 patch files: 236
|  Posted: Wed Sep 08, 2004 2:09 am    Post subject: |    |
| Reaktor has such a "code" module, AFAIK.
 Anyway, I wonder if the G2 code is assembler or some higher language.
 For reasons of max performance, I just hope it IS assembler.
| Back to top |  |
| jksuperstar
|  Posted: Wed Sep 08, 2004 11:00 am    Post subject: |    |
| Typically, DSPs are programmed in C.  At first.  Once algorithms are tight, and register usage known, then they are moved over to assembler for optimization.  I don't see any reason why the G2 would be any different.  In fact, it'd be nice if much of it was still in "C", since there's room for improvement yet to be had!
 However, I think Howard is talking about something very different, where one of the modules would almost act like an interpreter, much like Perl or even DOS is.  The underlying program is in C (or even assembler), but YOUR code is written in some script like language.  This would certainly be VERY powerful, though DSPs are typically not conducive to this type of work, since most of the actual work is in interpreting, rather than than doing the math (though I would love to see this available!).  And expecting a built-in compiler to convert the script to machine code is probably too much.  It's almost like having an SDK (software development kit) for the G2!!
 I think a math module (div, sqrroot, etc) would go far, as would a look-up table.
| Back to top |  |
