Electro-Music Klee Sequencer Build and Applications Thread
Page 44 of 54 [1348 Posts]
Goto page: Previous 1, 2, 3, ..., 42, 43, 44, 45, 46, ..., 52, 53, 54 Next
Scott Stites
Audio files: 96
PostPosted: Fri Aug 01, 2008 7:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
Make sure the Klee shares signal ground with the 606 if you use that...
My Site
Luka
PostPosted: Fri Aug 01, 2008 7:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
thanks scott
yeah i have a scope and DMM, they are ready and waiting
i'm just using this excuse to clean and tighten up all my panel wiring.
i noticed that i had V+ shorting to analogue ground, so that is fixed
ill work on the panel wiring for another hour or so and check out the analogue pcb, so far the digi one looks ok.
what was the chip that everyone was having problems with?
problemchild
melbourne australia
Scott Stites
Audio files: 96
PostPosted: Fri Aug 01, 2008 8:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
The CD4034. Are you getting any of the pattern LEDs to light at all?
My Site
Luka
PostPosted: Fri Aug 01, 2008 9:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
im 9/10 through cleaning up my wiring scott
ill plug 'er all in soon and re-test once there is no more spagetti Smile
problemchild
melbourne australia
Luka
PostPosted: Fri Aug 01, 2008 10:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok we have LIFE! woot
but still problems
B's LEDs are permanenty ON (except 2 which are always off)
i swapped 4034 and i get the same behaviour for A
the load doesnt seem to do anything, it never corresponds with my pattern switches. the only way i can alter the amount of bits on is hitting Inv B or 8/2:16/1 which seems to me to randomly switch the bit ONs and OFFs and possions of those that are ON.
but..!!
other than that seems awesome
all the voltages are working, havent tested triggers and gates as there is only so much room on my bench. getting some wild sounds, my housemates all came in and had a go Smile
problemchild
melbourne australia
Scott Stites
Audio files: 96
PostPosted: Fri Aug 01, 2008 11:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks like the one CD4034 definitely is sour if it did the same thing in the A or B slot.
Here's something to try: put the good CD4034 back in the A slot. Go to 8X2 mode. Put the Random/Pattern Switch into Random position. Turn the ref level pot all the way over counter clockwise (normally, the Random Reference LED will light up even with no random input). If not, crank the reference pot the other way. If you still can't get the ref LED to light, put in an LFO or some other signal into the random signal input jack, and crank the random level all the way up and adjust the reference pot - the LED should light up in sync with the signal (flashing at the rate of an LFO for example). A DC voltage input will light the Random LED all the time, too, which would be preferable for this test.
The point is, we want to get the Random LED to light, which indicates that a random signal will feed the CD4034.
Get the Random LED to light and clock the Klee - as long as the random LED is lit, the pattern LEDs will light up one by one with each clock pulse. At the end of the eight, they'll stay lit. Adjust the random controls until the Random LED is off - now the LEDs should all turn off, step by step, with each clock pulse.
Clock the random input until only one LED is lit, then stop the clock. Flip the Random/Pattern switch to "Pattern" - this should cycle one bit through the eight LEDs of the 'A' section repeatedly.
This will ensure that the serial input of the CD4034 is good and that it will clock the bits correctly serially.
Next, stop the input clock. Punch the load switch and look to see if you get pulses on pins 13 and 14 of U6 (the 'A' CD4034). You should get some *really* fast pulses on those two pins each time you hit the switch.
If you don't see any pulses when you hit the load switch, connect an LFO to the external load input - with each clock of that LFO, you should see pulses on those pins - they're really fast, so look quick Very Happy . If you still don't see anything, suspect the area around the CD4013 or the circuitry before it. Without those pulses, the CD4034 won't load the pattern bits.
Also, check pins 16 to 23 on the CD4034 for highs where you expect the pattern bit to be high (as set on your pattern switches).
I'd help you more, but I have to get to bed - got an early drive to Manhattan tomorrow. Should be back in the evening, which will be your morning. In the meantime, if you detect a problem with the load pulses, I think I cover that in the theory of operation thread.
Cheerios,
Scott
My Site
Luka
PostPosted: Sat Aug 02, 2008 2:56 am    Post subject: Reply with quote  Mark this post and the followings unread
ok cool, well the ref light comes on without any dramas.
yup that worked
i use random ref, let one bit come up and then hit load, it locked in one bit
problemchild
melbourne australia
PostPosted: Sat Aug 02, 2008 5:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Luka, I will send you two CD4034's for your troubles. Just PM me your address and I will ship those out to you. You did buy a parts kit from me and there have been a bad lot of these chip going around. This is probably about the eighth of ninth time this happened.
Bill
Luka
PostPosted: Sat Aug 02, 2008 6:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
bill you are a champion, but in all seriousness, i dont want you to be out of pocket for this... shipping to australia is a expensive waste. i can buy some, no worries, you guys have done so much already.
i have to do a futurlec order soon anyway, and in all serousness, it is probably better if this thing isnt functioning for the next few weeks, only 3 months to go of uni and so much work to do Smile don't need any more flashy light show distractions
problemchild
melbourne australia
PostPosted: Sat Aug 02, 2008 7:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well OK, thanks Very Happy Just shout of you need anything by way of parts.
OK but if you still want to continue troubleshooting the LOAD problem, we can keep going on that. Sounds like Scott gave you some fine advice to go on. Report back your results and we can go from there. Wink
As far as the CD4034's, we have had many instances of one being bad in several of the forums builds. Mostly one particular chip from an Indian Semiconductor manufacturer and maybe one TI chip. They (4034's) may be VERY sensitive to ESD so be extremely careful handling them. I know I am now when I package them Wink
Bill
Luka
PostPosted: Sat Aug 02, 2008 7:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok cool will do
i had a look through the schematics last nite and it all makes sense, ill work off them and try probe for the load issues. if i have any dramas ill get back on here and voice my screams of pain Smile
problemchild
melbourne australia
Scott Stites
Audio files: 96
PostPosted: Fri Aug 08, 2008 11:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's the latest build doc with Luka's corrections and one from SDuck. Link will be in the docs thread for eternal reference...
How's it going, Luka?
em_klee_build_issue5.pdf
Issue 5 EM Klee Build Doc
 Filename:  em_klee_build_issue5.pdf
 Filesize:  1.81 MB
 Downloaded:  1768 Time(s)
My Site
sduck
PostPosted: Sat Aug 09, 2008 8:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
IT'S ALIVE!!!! Head for the hills!
After several months of careful assembly, I finally powered up my klee this evening. And nothing happened - in fact it browned out the rest of the synth, causing all sorts of indignation on my part. After about 15 minutes of staring at the thing dumbly, poking it with various test apparatus, finally found a chip I had put in backwards. Fixed that, powered it up again, and it seems to work perfectly! Only minor, cosmetic problems that I've discovered so far - the pattern switches work backwards than I thought they were going to, and one step led isn't working, but I can live with these minor points for the time being. The led will be easy to fix, and the switches aren't labeled with which way they're supposed to go, so having them backwards is no big deal.
Now it's off to bed - I've been working today, I'm tired, and don't want to get into the calibration thing yet, but it's very gratifying to have the thing working after all these months.
Luka
PostPosted: Sat Aug 09, 2008 11:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
good work sduck.
scott im still at the same point. had a quick look over the schems but that is about it, between uni and big party we organised i had no time. cant wait till the end of semester. Smile
problemchild
melbourne australia
sduck
PostPosted: Sun Aug 10, 2008 7:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ok, here's my only debugging question so far. It may just be a matter of me not understanding how this is supposed to work - it may be operating correctly.
Operating the klee in 16x1 mode, invert b off, pattern mode, with one bit on, the leds cycle through all 16 steps correctly, and output A puts out voltages according to the knobs on stages 1-8, but nothing on stages 9-16. Output B is similar, except the knobby output is steps 9-16, but nothing on stages 1-8. Output A+B is all 16 steps.
Is this how it's supposed to work? The "know the klee" doc indicates that in this mode both A and B are supposed to output 16 step unique patterns, not 8 and then 8, each half empty - or have I misread this?
8x2 mode and all the others seem to be working as I understand they're supposed to. Because everything else is working, I'm strongly in favor of the option I presented in sentence 2 of paragraph 1.
bugfight
PostPosted: Sun Aug 10, 2008 7:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
sounds like it is working to me.
they are 2 unique 16 step patterns, just most of the steps are 0v...
add more active bits and you will see what's going on i think.
sduck
PostPosted: Sun Aug 10, 2008 7:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
I may have spoke too soon, I have other wierd stuff happening. When I switch invert B on (16x1 mode), as it clocks through the steps, I get all the stage leds coming on and staying on (and the pitch rising accordingly) until it cycles through the second time, where they turn off one by one. Very odd, and I've probably described it badly, but it doesn't seem right. Maybe it is?
Scott Stites
Audio files: 96
PostPosted: Sun Aug 10, 2008 7:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Bugfight's exactly right, and explained it in true Klee parlance. Cool
In 16X1 mode, though there are only eight pots assigned to A or B, the pots are reacting to the 16 bit pattern passing over them. If A goes low for half the time, it's still processing 8 steps of low. As Bugfight says, if there are more bits there, then you'll get more combinations of pot voltages, and thus more notes for each 16 step iteration.
And, BTW, congrats on finishing the Klee sduck!!!! Post a sample if you have a mind to.
Cheerios,
Scott
My Site
Scott Stites
Audio files: 96
PostPosted: Sun Aug 10, 2008 9:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very odd
But I'm thinking normal as well - depending on what your pattern is. If you have one bit programmed, or 0 bits, you'll see that. The bits are 0 when the pass out of Register B. Invert B simply inverts those bits before they're fed back into the B input (if in 8X2 mode) or the A input (16X1 mode). So, with 1 or 0 bits, in 16X1 mode with invert b on, they'll all sequence through 1 then 0 then one, because the invert every time they pass out of the B shift register.
If you have multiple bits programmed, of course you shouldn't see this - the bits will invert as they pass through, but you'll have more "holes" in the LEDs travelling along at any given time, rather than a solid bar/nothing/solid bar/nothing.
I'm thinking you're cool here.
Cheerios,
Scott
My Site
sduck
PostPosted: Mon Aug 11, 2008 7:20 am    Post subject: Reply with quote  Mark this post and the followings unread
OH!
That's just great. Here I am, finished with this huge build process, ready and willing to do the usual debugging I normally have to do, and the only thing that needs fixing is my expectations? Man. I guess it's peanuts to the syndicate, eh?
So I fixed the led, the thing works as it should - I'm happy! Now it's calibrate the ranges, which are seriously wacked currently, put the knobs on, and we're in business. (oh, and build that new cabinet for all the displaced modules) Yay!
And yes, I'll post samples when they occur. Thanks Scott and all!
Scott Stites
Audio files: 96
PostPosted: Mon Aug 11, 2008 8:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool!
And Bugfight, I saw the flicker of the DFW show - that is one frikkin' beautiful Klee. The offset is a very nice feature addition. Lots of times I wish I could just shift the whole Kahuna up or down easily. I have to use a mixer and a DC offset to do that.
Scott
My Site
bugfight
PostPosted: Mon Aug 11, 2008 1:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Scott Stites wrote:
Cool!
Scott
wow, props from the man himself...
thanks!
hehe that feature and the internal clock and noise are still yet to be added though, but i knew i would be wanting them...
and too bad i misspelled "coarse" wheeee
the klee was a hit at the meetup, i think.
i got to go through the "what does this do?" spiel several times.
PostPosted: Mon Aug 11, 2008 1:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
same at the german modular meeting this year Very Happy me saying: "predictible uncertainty or unpredictible certainty?"
it was a modulat meeting with lot of DIY but not necessary. many people just with readybuild systems. they did not know anything about the klee. it was fun explaining to them.
PostPosted: Mon Aug 11, 2008 1:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
what i am doing for a while now is feeding the klee's control voltages into my doepfer quantizer. the base frequency of this quantizer is then controlled by the baby10... fun ...
Scott Stites
Audio files: 96
PostPosted: Mon Aug 11, 2008 5:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
I feel for y'all - it's a lot of work just explaining the damn thing. Laughing
I saw the video of the DFW show - I think I caught a snippet of Bugfight explaining the gate outputs. Fonik - didn't know you'd showed up at a meet with the Klee!
And the idea of mixing with the Baby 10 into a quantizer - that would be fun...
My Site
