Bananalogue VCS diy board set available
Page 3 of 4 [86 Posts]
Sound
PostPosted: Thu Dec 18, 2008 4:56 am    Post subject: Reply with quote  Mark this post and the followings unread
helitron wrote:
same here, ...no idea why. I just found it out by chance while testing the VC functions using a joystic as voltage source.
however I still have no clue what the trimmpot is good for. I tried what sound wrote, but I couldnt get both outputs at the same level (6.4V).
I mean peak to peak. In the output is 0V to 6.4V, and in the AC output was anything like, -4V to + 2.4.
TekniK
PostPosted: Fri Dec 19, 2008 2:17 am    Post subject: Reply with quote  Mark this post and the followings unread
zthee wrote:
But from what I heard the guy who owns the rights to build Serge modules keeps everything on a tight leash? But I mean why are there practicly no Serge schematics online?
The schematics for the Serge VCS and a real CGS (2" x 6") board would be great though! Smile
You have all the schematics now!
Luka
PostPosted: Fri Dec 19, 2008 2:42 am    Post subject: Reply with quote  Mark this post and the followings unread
do you think the vcs differs much from the envylope?
problemchild
melbourne australia
zthee
PostPosted: Mon Dec 29, 2008 12:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
sduck wrote:
Here's the pcb in motm format -
Just realized - that your pcb has a bipolar out area. Something I don't have on my eurorack pcbs..
Though it's just a TL071 and a few other parts.. so I guess it's doable!
sduck
PostPosted: Sun Feb 08, 2009 9:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
So I just finished up building this motm format version. Seems to work ok - all the pots and jacks do things, although I'm not familiar enough with the thing to know for sure if they're doing the right things.
The led doesn't work. And I was getting this weird behavior on the fall of the slope where it would dip below zero and then rise back to zero. Upon staring at the pcb enough it looked like the led wires might be labeled backwards, so I switched the wires. The led still doesn't work (I checked the led - it's functional), but the weird end of cycle behavior is gone. So perhaps I just have a wrong led type.
Fun unit - I hooked up all the patches as described on the old bananalogue page to test it, and they all work as described. The knobs are really touchy - there's some pretty big range on these things.
VCSfront
VCSback1
andrewF
PostPosted: Sun Feb 08, 2009 11:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
I haven't seen this PCB, but if all the outputs work and just the LEd doesn't, the problem can't be too hard to sort.
would the transistor/diode/resistor near the LED holes be a LED driver subcct?
maybe it is something like Ken's LED driver PCB
edit
just found this image on P2 of this thread
it looks like the LED A&K markings are reversed. The led's cathode 'K' should go to the 1k resistor.
Also the hole marked 'K' should not be connected to 0V, that track should be cut and a connection made to +12V
this is just guesswork from looking at the PCB and Ken's led-driver. hope this doesn't blow it up
sduck
PostPosted: Mon Feb 09, 2009 7:28 am    Post subject: Reply with quote  Mark this post and the followings unread
That fixed it! I had already switched the wires, so cutting the anode wire from the led and running a wire from a 15+v rail to the cut worked. 100% working now! Thanks!
creatorlars
PostPosted: Sun Apr 12, 2009 9:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
I can confirm that I'm having an identical problem with the rise pot not working as it should -- I've double checked all my wiring and parts, everything's correct according to the board. This is pretty frustrating, with no schematics to look at. Sad
Any further developments with this, or anyone have theories? What exactly did you do to fix it? The module seems to work fine otherwise.
helitron
PostPosted: Sun Apr 12, 2009 11:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
try shorting V+ to the VC-rise socket. that helped...
hel
creatorlars
PostPosted: Sun Apr 12, 2009 11:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
I will try that, but won't it make the VC Rise jack/attenuator unusable? I am using banana jacks so I can't take advantage of a switched connection.
sduck
PostPosted: Wed Apr 15, 2009 7:11 am    Post subject: Reply with quote  Mark this post and the followings unread
I've seen that +15v to the rise jack mentioned several times, and it sounds bogus to me. If that was the way to fix it, then you'd have a useless jack - or one with +15v hitting everything that's plugged into it. My VCS (see above) doesn't have +15v coming out of the rise jack, and it works correctly. I'm going to have to sit for a while and compare the euro pcb against my working motm pcb and see what the difference is - I'm pretty sure it's some small error in the traces.
Funky40
G2 patch files: 5
PostPosted: Fri Apr 17, 2009 3:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
that would be very nice
Luka
PostPosted: Fri Apr 17, 2009 5:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
perhaps just ask ken
he designed the pcb and is currently working on a new VCS pcb for his CGS range so he might give you some support
problemchild
melbourne australia
TekniK
PostPosted: Sat May 30, 2009 3:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Okay, a demo with this VCS,with VC control of rise & fall (only one VCS in this patch)
pristak
PostPosted: Sun May 31, 2009 7:04 am    Post subject: Reply with quote  Mark this post and the followings unread
I just finished one of mine last night. Mine are the MOTM single board version. It was 2am so I need to put it through it's paces today once the family wakes up but I confirmed it did some of what it is supposed to do last night.
koura
PostPosted: Fri Jun 19, 2009 6:35 am    Post subject: Reply with quote  Mark this post and the followings unread
unit-sound wrote:
>> I shorted V+ to the VC-rise socket
jan
Any update on this fix?
About to finish building a board a got and wanted to see how this has worked out. To be 100% clear you are shorting V+ to the VC-rise input which is a switched jack? If its not a switched jack I would assume this couldn't work as you would constantly have V+ going through regardless of the input.
thanks for any info as i know this is an old thread by now
TekniK
PostPosted: Fri Jun 19, 2009 12:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
The board where sold to us with an error,and those asses did know it very well,now u know why no support was given!,bastards.
just do this 'debug' and it will work like it should be:
e-grad
PostPosted: Fri Jun 19, 2009 2:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for sharing!
janvanvolt
PostPosted: Mon Oct 12, 2009 6:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
I still have issues (after having +/- 15V reversed at one time). Nothing seems to work Sad
Exchanged already are all IC's and Transistors.
The "kludge" has also been applied.
Any ideas on how to debug this lovely VCS ? It's sad it does nothing.
My dIY - http://diy.czmok.de
Film/Music - http://gfm.me
TekniK
PostPosted: Mon Oct 12, 2009 11:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
should work,re-check your wiring ,soldering and components
janvanvolt
PostPosted: Tue Oct 13, 2009 3:44 am    Post subject: Reply with quote  Mark this post and the followings unread
I've got one the "original" boards from Bananalogue, so this is a bit different from the CGS version...
TekniK
PostPosted: Tue Oct 13, 2009 5:02 am    Post subject: Reply with quote  Mark this post and the followings unread
am not talking abouth the CGS version either.
fadeddata
PostPosted: Tue Oct 13, 2009 4:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
unit-sound, I've got one of the original's as well Smile
I had to make one additional kludge to get it to work.
Before making this change verify that ~15V is hitting the cathodes on the Trigger/End/etc board diodes. If so you have a board like mine and maybe the attached pic will help.
Seems there were many different VCs boards made. Mine had pin 4 of the LM3900 going to the cathodes of the trigger section instead of coming off zener diode which I think holds the voltage at ~5V. After fixing this and adjusting the trimmer my VCs started working!
Also make sure to cut the traces before and after the diodes (you can see in the pic)
 Filesize:  1.79 MB
 Viewed:  251 Time(s)
janvanvolt
PostPosted: Tue Oct 13, 2009 4:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Okay, got it sorted out. It was the Inter-PCB wiring as well as two defective 2N's
TekniK
PostPosted: Wed Oct 14, 2009 3:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Like i told Wink
