today> Twyndyllyngs Chez Mosc
The Thomas Henry Mega Percussive Synthesizer
Page 23 of 31 [763 Posts]
Goto page: Previous 1, 2, 3, ..., 21, 22, 23, 24, 25, ..., 29, 30, 31 Next
fadeddata
PostPosted: Sun Oct 11, 2009 7:33 pm    Post subject: Finally... Reply with quote  Mark this post and the followings unread
I finally found sometime to put this bad boy together Smile The wiring is intense.
 Filesize:  1.91 MB
 Viewed:  727 Time(s)
fadeddata
PostPosted: Sun Oct 11, 2009 9:19 pm    Post subject: 5Vpp Reply with quote  Mark this post and the followings unread
Anything special I should do to make this module 5Vpp? I was planning on changing R35.
papaver
PostPosted: Mon Oct 12, 2009 11:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Very Happy Thanks!
I was testing it last week with the Jomox Xbase 888 and a bit of swing and this is pure techno!
This week I will record some live sessions and I will post it.
oneoff
PostPosted: Wed Oct 14, 2009 7:24 am    Post subject: poblems hearing any effect when using the filter knob Reply with quote  Mark this post and the followings unread
Confused
completed the machine and it's sounds amazing!!!
but the only thing that isn't working good is the "filter center" 100k
knob it has maybe a tiny effect on the noise sound but thats it..
i checked the wiring, replaced the knob, and replaced q8 transistor , but still no effect...
could anyone tell me where to look for in order to finally close that case
and have fun with this beast?
thanks !
RKHobbs
PostPosted: Wed Oct 14, 2009 7:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Make mine a triple.
Triple MPS
 Filesize:  456.89 KB
 Viewed:  836 Time(s)
mph
PostPosted: Sun Oct 25, 2009 4:34 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello
I would like to build mine as stand alone unit, so I have choosen to build the power supply from Ken Stone:
http://www.cgs.synth.net/modules/cgs66_psu.html
I have a nice small transformer which I would like to use, but I don't know if it's suitable for a single MPS board.
This transformer is rated as 18V 8VA 0,5A.
Should I get a "bigger" one?
PostPosted: Mon Oct 26, 2009 1:34 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd say that one will do fine.
I'm pretty sure Scott has some current readings for it, but they don't get beyond 250mA per rail.
Thomas_Henry
PostPosted: Mon Oct 26, 2009 7:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello,
I couldn't tell from your description if this was center-tapped with 18V on each side (which would work very well), or just 18V single-sided (which wouldn't).
I haven't taken the current rating on the MPS, but it ought to be in the neighborhood of +/-50mA at +/-15V as a rule-of-thumb guess.
Hope this helps,
Thomas Henry
janvanvolt
PostPosted: Tue Oct 27, 2009 5:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi all,
just got 50% of the wiring done (on creatorlars's panel) and stuck with some questions (again):
(1) On my REV 107 board, there is no J21 to connect VC cutoff. any idea where to fine the right connect point ?
(2) Trigger Button: how to connect ? 15V+ 100nf switched to the TRIG IN ?
(3) the LEVEL pots for IMPACT, NOISE AND SHELL are replacing the on/on/on switch, so how to wire ?
(4) Send/Recv: How to wire ? To which pins ?
(5) Mix Out+ Pot: I would assume J17/7 to CW pin, Jack OUT to Middle and CCW = Earth ?
I am coming closer to a finished wiring and a ratsnest Smile
Thanks for any help
My dIY - http://diy.czmok.de
Film/Music - http://gfm.me
JargMarbin
PostPosted: Wed Oct 28, 2009 8:11 pm    Post subject: More recordings?
Subject description: interested in hearing more
I'm going to build the Thomas Henry Mega Percussive Synthesizer! Yeah! I love hearing the sounds it makes! Post more! And make some youtube vids! It sounds really great !
Listen to my album free here: http://JargMarbin.com
Sagi.s
PostPosted: Fri Oct 30, 2009 9:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello everyone
i'm into the building of the The Thomas Henry Mega Percussive Synthesizer,
for the front panel i use the panel wire instruction By "bugbrand"
(link file.pdf)
and in this design i could find out were is the "Master level" ??
im not that expert in DIY,i only have experience in "ken stone Super Psycho Lfo"
and "yusynth.net diode ladderVCF"
Thank's
Sagi.s
mps_connections_v1_133.pdf
 Filename:  mps_connections_v1_133.pdf
 Filesize:  931.23 KB
 Downloaded:  774 Time(s)
goiks
PostPosted: Mon Nov 09, 2009 12:48 am    Post subject: Reply with quote  Mark this post and the followings unread
i am also wondering how to deal with question #1 below.
i'm not sure about the other questions, but here's what i did for the send and receive jacks: i connected j14#1, j14#8 and j16#2 to their respective send jacks which are normalled to their receive jacks which go to the top of the noise, shell, and impact pots. this just puts the jacks in between the output and the level pots, and if nothing is inserted in them it's business as usual.
good luck with the rest.
unit-sound wrote:
Hi all,
Thanks for any help
mph
PostPosted: Sat Nov 14, 2009 5:28 am    Post subject: Reply with quote  Mark this post and the followings unread
Thomas_Henry wrote:
Hello,
Hope this helps,
Thomas Henry
Thank you Thomas & Unkle Krunkus
Yes it is center-tapped 18V with two windings (so I have one 18v and one 0v per side).
If the MPS is around 50mA, I will be able to use this power supply to feed some other modules which I will build in the future. Am I right?
Thanks again for your help.
dnigrin
PostPosted: Wed Dec 16, 2009 9:33 am    Post subject: MPS Bridechamber panel review Reply with quote  Mark this post and the followings unread
Scott at Bridechamber has posted his preliminary design for an MPS panel on the Modular Synth Panel Yahoo group. I repost it here for convenience. Since I haven't built or used an MPS yet, would those of you who have take a look and comment on completeness, etc..? I already mentioned that it's the Mega Percussive Synth, and not the Mega Percussion Synth...
Scott's planning to "probably start the ball rolling Friday for the metal order", so quick response greatly appreciated, either here or to the Yahoo group.
Thanks,
Dan
5U MPS.pdf
Scott Deyo's Bridechamber proposed MPS panel
 Filename:  5U MPS.pdf
 Filesize:  848.45 KB
 Downloaded:  776 Time(s)
Dan Nigrin - Defective Records
CycliC, M185 & Klee Sequencers / MC-202, MC-4 & DSX Hacks / Audio Plugin & General MIDI Players
http://defectiverecords.com
bridechamber
PostPosted: Wed Dec 16, 2009 9:58 am    Post subject: Reply with quote  Mark this post and the followings unread
The Bridechamber panel is going to change a bit:
1) 'Percussive' like Dan pointed out
2) 'www.electro-music.com' will be added
3) Noise CV jack and attenuator will be added
4) LED and switches will be moved
And other suggestions?
I'll post a new one hopefully tonight.
Thanks,
Scott
PostPosted: Wed Dec 16, 2009 2:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks,
Scott
This is good news and look forward to purchasing mine Wink
This will give me a very good reason to actually finish my drum synth. Very Happy
Thanks for the efforts !
Bill
Danno Gee Ray
PostPosted: Wed Dec 16, 2009 3:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
What format(s) will the Bridechamber panel be available in?
poppaneedsanap
PostPosted: Tue Dec 22, 2009 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm down for a panel
Krelnarb
PostPosted: Tue Dec 29, 2009 1:23 am    Post subject: Reply with quote  Mark this post and the followings unread
In Bridechamber (MOTM) format? Wink
Danno Gee Ray
PostPosted: Tue Dec 29, 2009 4:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Too bad. If it was FRAC or Eurorack I'd cosider buying one. Thumb down
llumen
PostPosted: Thu Jan 07, 2010 10:01 am    Post subject: panel design
Subject description: new design for MPS
Hi all,
I've been having so much fun soldering the parts together!
Now it's time to do the actual panel, I browsed the forum a bit to look at all the designs around (quite impressive!)
In any case I have a black 2 unit 19" enclosure that is going to be a stand alone'ishly MPS I made a design for it although it was kind of hard to fit everything on there, knobby knobs I guess Very Happy
Can anyone have a quick look and tell me if they think it is workable, I mean will this make realtime fiddling economical£/ergonomical or not?
best
llumen[/img]
 Filesize:  244.64 KB
 Viewed:  612 Time(s)
mph
PostPosted: Sun Jan 10, 2010 10:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello
It seems I have missed the info about that J21 connector on rev.107 boards...
But I have already drilled my front panel and I am currently wiring the pots.
And I have used Bugbrand's template with confidence, so I made a 20 pots (I have added the "main volume" pot) and 4 jacks version.
Should I forget the 100KB CV pot linked to the Noise CV Jack? Or is there a way to still use this pot?
Should I also let away this Noise CV Jack input?
Thanks for your help!
goiks
PostPosted: Thu Jan 14, 2010 4:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
On the REV 107 board, there is no J21 to connect the noise CV in. Is there another place? Should I be asking this question somewhere else?
Funky40
G2 patch files: 5
PostPosted: Sun Jan 24, 2010 7:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
there is no Noise CV IIRC.
I added the Noise CV jack to my first panel becase i thought i forgot something.
It's still unconnected........
IIRC there was disscussion about this early in this thread, and they left then the Noise CV out.
Thats all i can tell you
Floppy
PostPosted: Tue Mar 09, 2010 3:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
my rev 107 board has J11 to J18 but in the BOM i read J1 to J10 ?
im gazing at the board but cant find any clue...
