Living VCOs
Page 15 of 21 [520 Posts]
Goto page: Previous 1, 2, 3, ..., 13, 14, 15, 16, 17, 18, 19, 20, 21 Next
Would you prefer one PCB with 3 VCOs a la JH-5A, or 1 VCO per PCB with more features
One PCB with Oscillator Driver and 3 VCO cores (like JH-5A - cheap!)
60%
 60%  [ 62 ]
1 PCB = 1 VCO (with many waveforms and inputs)
39%
 39%  [ 41 ]
Total Votes : 103
bennethos
PostPosted: Tue Feb 16, 2010 2:08 am    Post subject: Reply with quote  Mark this post and the followings unread
I solved my problem yesterday evening, as Juergen said "it's a silly problem most of the time" and he was right.
I actually inserted 1 wrong capacitor, the one between the base of the transistor and input of the comparator. 33KpF instead of 22pF
My saw waveform had a dip when it started and when my 10 turn was fully open (no resistance) I had a half trapezium :p .
on vco 2, pin 2 of the TL072 made no contact to anything this gave +14v at the first output of the TL which was not OK, made a little bridge and that solved it as well Smile
can't wait to test those *beasts* Smile
bennethos
PostPosted: Thu Feb 18, 2010 12:16 pm    Post subject: L vco Reply with quote  Mark this post and the followings unread
Hey Guys,
it's the noob again Smile .
I tested my L VCO'S yesterday evening but I only have 3v pk-pk on each L vco on my scope. My Analogue systems VCO has 10v pk-pk.
I have no CV source attached to the L vco though...
Is this normal ?
btw
the linear detuning is beatifull, I kept on my headphones for 15 min with that same sound just too hear them pound Smile (passed it through an EQ to pump up the low frequencies a bit, amazing)
numbertalk
PostPosted: Thu Feb 18, 2010 12:25 pm    Post subject: Re: L vco Reply with quote  Mark this post and the followings unread
Did you wire up the output amplifier section:
http://www.jhaible.de/living_vcos/living_vcos_wiring_opt3.pdf
bennethos wrote:
Hey Guys,
Is this normal ?
btw
bennethos
PostPosted: Thu Feb 18, 2010 1:16 pm    Post subject:
Subject description: l vco amplitude
Thx, first project for me so I'm overlooking a lot of things... but i'm a fast learner and this stuff is exciting Smile
Just wired it up, the scope shows 5v now, but it's still too quite when I pass it through the AS VCA.
What I don't get compared to my analogue systems VCO :
- the AS vco goes from -1,3 to +8,8v on the scope
- the L vco goes from -5 to +5 ... this probably explains the difference in volume I get...
nerdware
PostPosted: Thu Feb 18, 2010 2:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
±5V is normal for most VCOs, but the AS VCOs are different. Their website says
The output from the SQR-OUT socket is approximately ±5V.
It also says
The output from the SAW-OUT socket is -2V to +8V when a true sawtooth wave is produced, and ±2.5V when a triangle wave is produced.
So your LVCO looks good to me. Just accept that AS do it differently.
http://soundcloud.com/nerdware/
"render unto digital what is due to digital, render unto analogue what is due to analogue"
jhaible
PostPosted: Thu Feb 18, 2010 3:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
You can always change the gain of the amplifiers to get other levels. It's jut one resistor per VCO that would have to be changed.
With the values printed on the PCB, you get +/-5V, which is a widely used standard.
The VCO outputs themselves (without the amps) are approx. Moog Modular level.
JH.
bennethos
PostPosted: Fri Feb 19, 2010 12:59 am    Post subject: Reply with quote  Mark this post and the followings unread
thx a lot to you both ! I really have to do more reading Smile
sinneb
PostPosted: Thu Mar 11, 2010 4:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Just finished one living VCO core and the driver module. Sound great already but I have a question regarding the generated sawtooth. I connected a software oscilloscope and the sawtooth is showing spikes. Is that normal? Or should I check the various components? Since I'm a n00b Wink - could use some suggestions. TIA!
 Filesize:  23.8 KB
 Viewed:  29350 Time(s)
jhaible
PostPosted: Fri Mar 12, 2010 1:56 am    Post subject: Reply with quote  Mark this post and the followings unread
It's probably an artefact from your measurement setup.
My guess is: High bandwidth of the scope, connected with a long, un-terminated wire.
JH.
davebr
PostPosted: Fri Mar 12, 2010 10:01 am    Post subject: Reply with quote  Mark this post and the followings unread
I was going to suggest the same issue with this being an artifact of the probe. However, your ramp waveform looks like it is +8 to -10, or 18 volts pk-pk. Did you want your output that 'hot'. I would have expected something less.
jhaible
PostPosted: Fri Mar 12, 2010 2:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh - I didn't look at the scale. Should be +/-5V after the amp, not more.
JH.
sinneb
PostPosted: Sat Mar 13, 2010 4:37 am    Post subject: Reply with quote  Mark this post and the followings unread
thx! I connected the oscilloscope to the rightmost pin of the SAW_n connector so the graph should be showing the 0 ... 10V saw from the VCO core. Anyways, I'll start working on the other cores. compare the different outputs and report my findings back here.
sinneb
PostPosted: Tue Mar 16, 2010 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
As promised Smile
Everything's ok now! Borrowed a Tektronix TDS 210 scope from work and these are my results. First the pulse, then the saw and as last the 10V saw. Keep you posted on my progress!
 Filesize:  111.57 KB
 Viewed:  359 Time(s)
vtl5c3
PostPosted: Tue Mar 23, 2010 2:28 pm    Post subject: Fine vs. Detune? Reply with quote  Mark this post and the followings unread
I'm finally getting around to laying out a front panel. I'm used to VCOs having a 'Fine' frequency pot. What I'm not used to is 'Detune'. Is it redundant to have both?
R.
jhaible
PostPosted: Wed Mar 24, 2010 1:59 am    Post subject: Re: Fine vs. Detune? Reply with quote  Mark this post and the followings unread
R.
The Living VCOs use Multi-Turn potentiometers instead of separate coarse/fine tuning. (You could replace the multiturn with two pots and an extra resistor, of course.)
The Linear Detune knob is entirely different, and it's one of the main features of the whole thing. Smile
JH.
vtl5c3
PostPosted: Wed Mar 24, 2010 7:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, thanks. Just wanted to be sure before committing to a panel layout.
R>
davebr
PostPosted: Wed Mar 24, 2010 8:41 pm    Post subject: Re: Fine vs. Detune? Reply with quote  Mark this post and the followings unread
jhaible wrote:
R.
JH.
I did mine with coarse and fine controls and also the detune controls. As mentioned, the detune controls work differently from the fine and are a key feature. I did only implement detune on VCO2 and VCO3, though.
There is a video of the detune controls in operation on my site.
http://modularsynthesis.com/jhaible/lvcos/jhlvcos.htm
oozitron
PostPosted: Sun Apr 04, 2010 2:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello -
I'm ready to wire up and fire up my VCOs but suddenly realized I only have 3 100k pots! D'oh!!!
I have a bunch of 50k at the moment, and of course I'll order more 100k pots, but for *right now* are there any of the controls (vib rate, vib amt, pw, pwm, fm) that really have to be 100k, or can I use the 50k thingers until the correct ones arrive?
Desparately Seeking Sawtooths,
Drew
jhaible
PostPosted: Mon Apr 05, 2010 1:06 am    Post subject: Reply with quote  Mark this post and the followings unread
oozitron wrote:
Hello -
Drew
50k will be ok.
log pots will give a strange response, but will work electrically.
Make sure you replace them with lin pots eventually.
JH.
oozitron
PostPosted: Wed Apr 07, 2010 8:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
I am confused about the CVS and DRVOUT connections.
I have the CVS normalled (the CVS square hole to the CVS middle hole) since nothing is plugged into the CVS jack.
At the "round hole" of DRV OUT there is +13.5 volts, even if I insert a patch cable and apply at the CVS in jack. Is that normal?
From the wiring examples, I thought that the DRVOUT would take the voltage from the CVS in jack and distribute it to the CVs_1, CVs_2 and CVs_3. But it always is +13.5 volts (???)
huge thanks for any insight,
Drew
jhaible
PostPosted: Thu Apr 08, 2010 1:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Drew
Have you connected th eportamento pot already?
JH.
oozitron
PostPosted: Thu Apr 08, 2010 10:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, that was the issue Rolling Eyes
I lucked out today... the school where I work had a sewer line break so no school!!! A whole day of quiet empty house to work!
I hooked up VCO1 and it just sounds awesome. Currently working on the wiring for the other two. Can't wait to hear them all at once!
Thanks again Jurgen for the help and the amazing circuit Hail the Master
Drew
frenchyinmunich
PostPosted: Tue Apr 20, 2010 3:35 am    Post subject: Components list Reichelt Reply with quote  Mark this post and the followings unread
Hello,
Did someone already did the Reichlet's list for that module?
Best regards,
F
norman phay
PostPosted: Sun Apr 25, 2010 10:11 am    Post subject: Reply with quote  Mark this post and the followings unread
I got my first one of these all hooked up & running, couple of minor problems - one of the multi-turn pots I bought it faulty! I'll order some more next week. Also, the LFO depth knob only seems to have any effect in the last 1/4 turn of its travel (it is a lin pot, i checked) So I have to take a, look at that, but I must say, just running 2 VCOs, wow it does sound very rich and nice! Once again, many thanks for designing these and making them available to us all...
jhaible
PostPosted: Sun Apr 25, 2010 10:49 am    Post subject: Reply with quote  Mark this post and the followings unread
The behaviour of the vibrato depth pot is intentional - I think I have written about it earlier in this thread. Once you read about the idea behind it, you'll like it that way! Smile
JH.
