TekniK
Posted: Wed Nov 18, 2009 4:47 pm Post subject:
realy nice case peasant!
how do u gonna attach the pcb's to the front,or do u gonna fix them in the bases of the case? |
The Peasant
Joined: Nov 13, 2009 Posts: 114 Location: Sunny Alberta
Posted: Wed Nov 18, 2009 4:53 pm Post subject:
Thank you TekniK!
They will be attached to the bottom of the case. If you go to the first SynthCase project on my website you will see how I did that one, this one will be the same.
Take care,
Doug _________________ The Electronic Peasant
www.electronicpeasant.com |
TekniK
Posted: Wed Nov 18, 2009 5:39 pm Post subject:
oh yeah,i see,nice wiring job,and u use wires from old electronic devices like me hehe,indeed would be stupid to pay for it.
btw,am impressed by the front yard and just around the corner ,beautyfull! |
The Peasant
Posted: Wed Nov 18, 2009 5:47 pm Post subject:
Yeah, I really don't understand why anyone pays for hook-up wire. Even limiting yourself to old obsolete computer cables will give you more wire than you could ever use.
Most of the internal wiring is done with wires removed from "Kroschu Schaltflex" brand cables. This is very finely stranded cable, very flexible and easy to work with. But almost any obsolete multiconductor computer cable will work fine as a wire source. I use a lot of RG174 shielded cable as well, all from salvage.
Take care,
adambee7
Joined: Apr 04, 2009 Posts: 420 Location: united kingdom
Posted: Thu Nov 19, 2009 7:00 am Post subject:
Welcome EP. I've been on your site quite a few times and really like your style. Especially the midi banjo. Excellent.  |
Luka
Posted: Mon Dec 21, 2009 6:01 am Post subject:
shown in thread before but since i officially finished it i might post some pictures
i love this phaser, but for some strange non-thought through reason it will be leaving my possesion tomorrow afternoon but luckily i have another pcb on the way to build it again
it was such a tight fit inside the encolsure, i must say that i was lucky that it all fit in. i had to squash down some of the connectors, capacitors and regulators so they would sit under the box enclosing the panel mounted lamp, which conveniently fit between the main lamps and the heat sinks. such a fluke it all fit! _________________ problemchild
melbourne australia
http://www.last.fm/user/prblmchild |
The Bad Producer
Joined: Mar 08, 2009 Posts: 282 Location: The Manhole
Posted: Fri Feb 19, 2010 5:01 am Post subject:
I just finished a dual Polymoog resonator in eurorack format with banana sockets, thanks again Juergen for making these available!
I added VC control for frequency using vactrols, gives it a nice animation!
 _________________ http://loudestwarning.tumblr.com/ |
TekniK
Posted: Fri Feb 19, 2010 7:27 am Post subject:
| nice design and colors |
norman phay
Joined: Jun 29, 2007 Posts: 176 Location: North-East England
Posted: Sat Feb 27, 2010 5:34 am Post subject:
the "Tau" phaser, which sounds great I must say:
(I put the switch writing a little closer-in than ideal, should have made it 1mm further apart but it's still OK I think) |
dingebre
Joined: Aug 10, 2008 Posts: 270 Location: Salt Lake City, UT USA
Posted: Sun Feb 28, 2010 8:20 pm Post subject:
OK! Got the Tau built and it's sitting next to my Frequency Shifter.
fpd's are in other threads...
Many thanks JH!
| Description: |
| Filesize: |
708.37 KB |
| Viewed: |
509 Time(s) |
| Description: |
| Filesize: |
683.62 KB |
| Viewed: |
371 Time(s) |
| Description: |
| Filesize: |
615.65 KB |
| Viewed: |
386 Time(s) |
_________________ David M. Ingebretsen, M.S., M.E.
dingebre@3dphysics.net
http://www.xmission.com/~dingebre/Synthasystem.html |
TekniK
Posted: Tue Mar 02, 2010 2:41 am Post subject:
| dingebre wrote: | OK! Got the Tau built and it's sitting next to my Frequency Shifter.
I like the i/o circles,gives some nice industrial machine look |
The Bad Producer
Posted: Thu Mar 11, 2010 4:18 am Post subject:
Both those Tau's are great, its nice to see such differing designs!
I've just finished my first Living VCO panel, again eurorack with bananas:
StephenGiles
Posted: Thu Mar 11, 2010 4:47 am Post subject:
| Looks very nice, you live at Hackney Wick? I lived in Victoria Park Road in the early 1970s - I bet it's changed a bit now! |
The Bad Producer
Posted: Thu Mar 11, 2010 5:21 am Post subject:
I'd imagine it has! Victoria Park Road is quite chi-chi now (maybe it was back then?) with delis and cafes in 'the village'. Hackney Wick has changed a lot since I've been here even, it was an industrial wasteland, with loads of artists and art studios and stuff happening but now they're knocking everything down in a rush to build poncy and expensive flats for 'executives' and such like, the olympic effect I guess... Actually the olympics has ripped the heart out of the place... that's progress!
Charlie _________________ http://loudestwarning.tumblr.com/ |
TekniK
Posted: Thu Mar 11, 2010 3:17 pm Post subject:
| Looks damn good Charlie |
Luka
jhaible
Posted: Fri Mar 12, 2010 1:54 am Post subject:
| Luka wrote: | mad stuff charlie!
i would post my living vco here but i spelt jurgen's name wrong on my panel.. hehe whoops, sorry JH |
Don't worry. I've mixed up channel 1 and 2 on my synthi clone front panel, and (almost) no one ever noticed all the time they are on th eweb now!
JH. _________________ "I tell you the truth, if anyone says to this mountain, 'Go, throw yourself into the sea,' and does not doubt in his heart but believes that what he says will happen, it will be done for him. Therefore I tell you, whatever you ask for in prayer, believe that you have received it, and it will be yours." (Mk 11,23f) |
Luka
jhaible
Posted: Sat Mar 13, 2010 2:29 am Post subject:
| Luka wrote: |
Ok, now I know what you mean!
Beautiful panel!
The Bad Producer
ericcoleridge
Posted: Thu Apr 29, 2010 6:27 pm Post subject:
| The Bad Producer wrote: | Just finished/finishing a couple more projects...
Beautiful work! Love these designs. Do you have a cabinet together yet? Would love to see a wide shot of modules side by side. |
The Bad Producer
Posted: Sat May 01, 2010 12:11 pm Post subject:
Hi, thanks man!
not yet, but maybe by the end of the week, I'm finalising a suitcase design at the moment, just can't decide how big it should be! _________________ http://loudestwarning.tumblr.com/ |
Girts
emdot_ambient
Joined: Nov 22, 2009 Posts: 667 Location: Frederick, MD
Posted: Mon May 03, 2010 2:48 pm Post subject:
Damn, that looks like a fortune in knobs...Love them, though! |
2thick4uni
Posted: Fri May 14, 2010 10:10 am Post subject:
A few of the JH modules I've built as stand alone 1U FX units. All of the inputs and outputs are duplicated on the rear so I can wire them into a patchbay. All are mains powered with IEC kettle plugs on the rear.
They all sound amazing, many thanks Jurgen!
