Photos of what you've built with JH PCBs
Page 5 of 9 [215 Posts]
TekniK
PostPosted: Wed Nov 18, 2009 4:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
realy nice case peasant!
how do u gonna attach the pcb's to the front,or do u gonna fix them in the bases of the case?
The Peasant
PostPosted: Wed Nov 18, 2009 4:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you TekniK!
They will be attached to the bottom of the case. If you go to the first SynthCase project on my website you will see how I did that one, this one will be the same.
Take care,
Doug
The Electronic Peasant
www.electronicpeasant.com
TekniK
PostPosted: Wed Nov 18, 2009 5:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
oh yeah,i see,nice wiring job,and u use wires from old electronic devices like me hehe,indeed would be stupid to pay for it.
btw,am impressed by the front yard and just around the corner ,beautyfull!
The Peasant
PostPosted: Wed Nov 18, 2009 5:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, I really don't understand why anyone pays for hook-up wire. Even limiting yourself to old obsolete computer cables will give you more wire than you could ever use.
Most of the internal wiring is done with wires removed from "Kroschu Schaltflex" brand cables. This is very finely stranded cable, very flexible and easy to work with. But almost any obsolete multiconductor computer cable will work fine as a wire source. I use a lot of RG174 shielded cable as well, all from salvage.
Take care,
Doug
adambee7
PostPosted: Thu Nov 19, 2009 7:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Welcome EP. I've been on your site quite a few times and really like your style. Especially the midi banjo. Excellent. Very Happy Very Happy
Luka
PostPosted: Mon Dec 21, 2009 6:01 am    Post subject: Reply with quote  Mark this post and the followings unread
shown in thread before but since i officially finished it i might post some pictures
i love this phaser, but for some strange non-thought through reason it will be leaving my possesion tomorrow afternoon Sad but luckily i have another pcb on the way to build it again
it was such a tight fit inside the encolsure, i must say that i was lucky that it all fit in. i had to squash down some of the connectors, capacitors and regulators so they would sit under the box enclosing the panel mounted lamp, which conveniently fit between the main lamps and the heat sinks. such a fluke it all fit!
problemchild
melbourne australia
The Bad Producer
PostPosted: Fri Feb 19, 2010 5:01 am    Post subject: Reply with quote  Mark this post and the followings unread
I just finished a dual Polymoog resonator in eurorack format with banana sockets, thanks again Juergen for making these available!
I added VC control for frequency using vactrols, gives it a nice animation!
TekniK
PostPosted: Fri Feb 19, 2010 7:27 am    Post subject: Reply with quote  Mark this post and the followings unread
nice design and colors
norman phay
PostPosted: Sat Feb 27, 2010 5:34 am    Post subject: Reply with quote  Mark this post and the followings unread
the "Tau" phaser, which sounds great I must say:
(I put the switch writing a little closer-in than ideal, should have made it 1mm further apart but it's still OK I think)
dingebre
PostPosted: Sun Feb 28, 2010 8:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK! Got the Tau built and it's sitting next to my Frequency Shifter.
fpd's are in other threads...
Many thanks JH!
 Filesize:  708.37 KB
 Viewed:  525 Time(s)
 Filesize:  683.62 KB
 Viewed:  390 Time(s)
 Filesize:  615.65 KB
 Viewed:  404 Time(s)
dingebre@3dphysics.net
TekniK
PostPosted: Tue Mar 02, 2010 2:41 am    Post subject: Reply with quote  Mark this post and the followings unread
I like the i/o circles,gives some nice industrial machine look
The Bad Producer
PostPosted: Thu Mar 11, 2010 4:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Both those Tau's are great, its nice to see such differing designs!
I've just finished my first Living VCO panel, again eurorack with bananas:
StephenGiles
PostPosted: Thu Mar 11, 2010 4:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks very nice, you live at Hackney Wick? I lived in Victoria Park Road in the early 1970s - I bet it's changed a bit now!
The Bad Producer
PostPosted: Thu Mar 11, 2010 5:21 am    Post subject: Reply with quote  Mark this post and the followings unread
I'd imagine it has! Victoria Park Road is quite chi-chi now (maybe it was back then?) with delis and cafes in 'the village'. Hackney Wick has changed a lot since I've been here even, it was an industrial wasteland, with loads of artists and art studios and stuff happening but now they're knocking everything down in a rush to build poncy and expensive flats for 'executives' and such like, the olympic effect I guess... Actually the olympics has ripped the heart out of the place... that's progress!
Charlie
TekniK
PostPosted: Thu Mar 11, 2010 3:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Looks damn good Charlie
Luka
PostPosted: Thu Mar 11, 2010 5:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
mad stuff charlie!
i would post my living vco here but i spelt jurgen's name wrong on my panel.. hehe whoops, sorry JH
problemchild
melbourne australia
jhaible
PostPosted: Fri Mar 12, 2010 1:54 am    Post subject: Reply with quote  Mark this post and the followings unread
Luka wrote:
mad stuff charlie!
Don't worry. I've mixed up channel 1 and 2 on my synthi clone front panel, and (almost) no one ever noticed all the time they are on th eweb now! Smile
JH.
Luka
PostPosted: Fri Mar 12, 2010 6:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Smile
problemchild
melbourne australia
jhaible
PostPosted: Sat Mar 13, 2010 2:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Luka wrote:
Smile
Razz Ok, now I know what you mean!
Beautiful panel!
JH.
The Bad Producer
PostPosted: Sat Apr 24, 2010 4:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Just finished/finishing a couple more projects...
Named my band after the Solina - 'Solina Hi-Fi' !
http://www.myspace.com/solinasound
ericcoleridge
PostPosted: Thu Apr 29, 2010 6:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Beautiful work! Love these designs. Do you have a cabinet together yet? Would love to see a wide shot of modules side by side.
The Bad Producer
PostPosted: Sat May 01, 2010 12:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi, thanks man!
not yet, but maybe by the end of the week, I'm finalising a suitcase design at the moment, just can't decide how big it should be!
Girts
PostPosted: Mon May 03, 2010 10:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's my first steps into the DIY swamp Smile
http://www.flickr.com/photos/61349650@N00/sets/72157623859781645/
Thank you, JH!
emdot_ambient
PostPosted: Mon May 03, 2010 2:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you, JH!
Damn, that looks like a fortune in knobs...Love them, though!
2thick4uni
PostPosted: Fri May 14, 2010 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
A few of the JH modules I've built as stand alone 1U FX units. All of the inputs and outputs are duplicated on the rear so I can wire them into a patchbay. All are mains powered with IEC kettle plugs on the rear.
They all sound amazing, many thanks Jurgen! Very Happy Very Happy
