citric acid
vladosh
Audio files: 51
vladosh
Audio files: 51
Posted: Tue Aug 30, 2011 11:25 am Post subject:
| yes and mislabeled the 0.001 uF for 0.01 heh .. happens |
citric acid
Posted: Wed Aug 31, 2011 7:52 am Post subject:
| vladosh wrote: | | yes and mislabeled the 0.001 uF for 0.01 heh .. happens |
thankls a lot men.
is there a chance that you show me where this cap´s have to be ?
Or can i let them out of this ?
ill try to build it after that i will give feedback , and if it´s ok for you i will share this to some friends.
thanks. _________________ http://soundcloud.com/citric-acid-303 |
bubzy
Joined: Oct 27, 2010 Posts: 594 Location: United Kingdom
Audio files: 64
Posted: Wed Aug 31, 2011 8:04 am Post subject:
dont forget to cut the strip out in the middle of the IC  |
citric acid
citric acid
vladosh
Audio files: 51
vladosh
Audio files: 51
Posted: Wed Aug 31, 2011 12:40 pm Post subject:
here's a proper layout with the strips cut off in the back ..
cheers
about using it commercially if you think .. that's for MFOS to decide as for the layout you can use it as much as you want
90.36 KB |
| Viewed: |
1049 Time(s) |
110.59 KB |
| Viewed: |
869 Time(s) |
citric acid
Posted: Thu Sep 01, 2011 11:51 am Post subject:
thanks a lot men, nice work....no no idon´t wan´t to use it in a comercial way. i just wan´t to post it in our german forum at the diy section, there where some guys who also wan´t to have it.
its www.sequencer.de
thanks _________________ http://soundcloud.com/citric-acid-303 |
citric acid
vladosh
Audio files: 51
Posted: Thu Sep 01, 2011 3:19 pm Post subject:
I've tried a few times to browse thru that page it's huge and i give up fast .. as i gave up learning german
all best
vlad |
citric acid
Posted: Thu Sep 29, 2011 10:43 am Post subject:
your desighn was super...it works fine thanks alot men... so i saved another 60€ for buffered multiple....
so if i can help sometime please let me know!!! _________________ http://soundcloud.com/citric-acid-303 |
Paradigm X
Joined: Feb 15, 2011 Posts: 363 Location: Null and void
Posted: Sat Oct 01, 2011 4:45 am Post subject:
Seems a good place to ask; whats the difference between a passive and a buffered multiple
Thanks
vladosh
Audio files: 51
Posted: Sat Oct 01, 2011 4:53 am Post subject:
| I read someone comment once that when more than one vco is driven thru passive multi - there is a drop in voltage ..meaning out of tune , i don't care too much about such details for now as i'm using no tempco vco's anyway ,so i use a passive multi .. with buffered there should be no problems like that . |
Paradigm X
Posted: Sat Oct 01, 2011 5:27 am Post subject:
Ah, ok cheers  |
citric acid
Posted: Sat Oct 01, 2011 5:45 am Post subject:
| vladosh wrote: | | I read someone comment once that when more than one vco is driven thru passive multi - there is a drop in voltage ..meaning out of tune , i don't care too much about such details for now as i'm using no tempco vco's anyway ,so i use a passive multi .. with buffered there should be no problems like that . |
also i use it for clock pulses. when you have a lot of mudules to run with a clock its some times hard to run them all tight. with a passive they sometimes run out of sync with this active multiple never  _________________ http://soundcloud.com/citric-acid-303 |
vladosh
Audio files: 51
Posted: Sat Oct 01, 2011 2:14 pm Post subject:
Makes sense using it that way .. i should make one too .
cheers |
LektroiD
Joined: Aug 23, 2008 Posts: 1019 Location: Scottish Borders
Posted: Mon Nov 14, 2011 12:00 am Post subject:
What's the 20K resistor for? It doesn't seem to connect anywhere
citric acid
emdot_ambient
Joined: Nov 22, 2009 Posts: 667 Location: Frederick, MD
Posted: Mon Nov 21, 2011 2:09 pm Post subject:
| vladosh wrote: | | ...i don't care too much about such details for now as i'm using no tempco vco's anyway ,so i use a passive multi .. . |
That's a common misconception. Tempcos on VCOs are there to stop pitch drift due to temperature changes only. They have nothing to do with the tracking of the VCO.
Feed a constant CV to a non-tempco VCO, and set it in the sunlight. It will drift out of tune as the VCO heats up, even though the ptich CV hasn't changed. Do the same with a tempco protected VCO and the drift will be smaller.
But even the best temperature stablized VCO in the world will not play in tune if the incoming pitch CV has been split so much through non-buffered multis that its voltage has been degraded.
...of course if you're not making melodic/harmonic music, passive multis are totally fine. They're also usually fine for non-pitch related duties such as VCA or VCF Frequency modulation. _________________ Looking for a certain ratio since 1978 |
vladosh
Audio files: 51
Posted: Tue Nov 22, 2011 3:47 am Post subject:
Thanks Emdot for clearing that out ..
greeting s
Vlad |
rogerlatur
Nardu
Joined: Feb 28, 2011 Posts: 62 Location: Braila, Romania
Posted: Sun Dec 23, 2012 8:47 am Post subject:
Stripboards
190.8 KB |
| Viewed: |
824 Time(s) |
98.24 KB |
| Viewed: |
849 Time(s) |
102.74 KB |
| Viewed: |
764 Time(s) |
