 Forum index » Clavia Nord Modular » G2 Performances - Experimental
very fast bpm :-)
Page 1 of 1 [8 Posts]
PostPosted: Wed Apr 13, 2005 5:18 pm    Post subject: very fast bpm :-) Reply with quote  Mark this post and the followings unread
Things started in this thread about hard disk spin rates in BPMs.
For that I made the patch "rpm", it was changed a bit later, but not much (and I don't have the original anymore). From that patch I took some waves that I sculpted in Cool Edit. This can be heard somewhere in the OT part of the thread meantioned above.
Later I heard a piece from one of the Ton Bruynél CDs, the "six pack" I'm currently "doing" in my car, There is some beautifull stuff on it that I had heard before but never had, but anyway there also is some spoken text on one of the CDs in which the composer explains how he made a piece, more or less, from just four notes.
As I had just made a patch with three notes (the rpm one) I wanted to try this out with a similar patch, but using the same four notes. gis, cis, ais, b. With that patch I did the same thing, recorded it and sculpted it again.
Well, results are attached.
Jan.
rpm.pch2
rpm->bpm
 Filename:  rpm.pch2
 Filesize:  4.27 KB
 Downloaded:  2876 Time(s)
giscisaisb.pch2
four notes
 Filename:  giscisaisb.pch2
 Filesize:  7.19 KB
 Downloaded:  2798 Time(s)
mix-3.mp3
four notes, sculpted noodle
 Filename:  mix-3.mp3
 Filesize:  5.67 MB
 Downloaded:  2720 Time(s)
Audio files: 227
PostPosted: Wed Apr 13, 2005 8:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
I like the sculpted noodle very much. Reminds me of the music of the Once Festivals. Not that it sounds like that stuff, but the spirit is the same. Bravo, Jan, you can't escape the title composer any more... Smile
paul e.
PostPosted: Wed Apr 13, 2005 8:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
excellent...the dark, complex textures...and the shifting sands..a nice brain shower
Spiral Recordings
PostPosted: Thu Apr 14, 2005 4:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you guys.
When you like this, there is more of it on my web site (which seems to be up for a change).
Jan.
General Elektrick
PostPosted: Thu Apr 14, 2005 5:15 am    Post subject: Reply with quote  Mark this post and the followings unread
angel
A very nice one!!!
Best,
General Elektrick
"If something is boring after two minutes, try it for four. If still boring, then eight. Then sixteen. Then thirty-two. Eventually one discovers that it is not boring at all." --John Cage.
zynthetix
Audio files: 10
G2 patch files: 13
PostPosted: Thu Apr 14, 2005 11:27 am    Post subject: Reply with quote  Mark this post and the followings unread
This is cool stuff. thanks for easing my curiosity of what this sounded like too Wink
cebec
G2 patch files: 31
PostPosted: Sun Apr 17, 2005 3:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
wow, yeah, i like this one a lot, too. the spatial and spectral animation is fantastic!
monokit
G2 patch files: 8
PostPosted: Fri Dec 23, 2005 8:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Beautiful!!
