M185 sequencer Project - NEW PCB VERSION
Page 45 of 46 [1139 Posts]
Goto page: Previous 1, 2, 3, ..., 43, 44, 45, 46 Next
nativeVS
PostPosted: Sun Jun 14, 2020 10:48 am    Post subject: Reply with quote  Mark this post and the followings unread
ryktnk wrote:
When you were using calibration test mode, did the Pots and Stage Count switches test ok.
Pots and Count switches are all testing fine.
ryktnk wrote:
Can you turn on the sequencer.
Stop the clock.
Select a stage with the NXT PRV buttons, and measure the voltage on the pin from the previous post, whilst adjusting the Gate Mode switch.
PS this is voltage that is sent to the processor for Gate Modes.
3.3V in the bottom position, 0.22V in any other.
Thanks for the help, Robert.
ryktnk
PostPosted: Mon Jun 15, 2020 8:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Stop the clock.
Hello
For the Stage Gate Mode voltage you should be seeing about out 4.3v
on the long gate setting, and 0.8v on the single gate setting, and 0v on the
no-gate setting, and aprrox 0.8v steps between each setting.
Please check carefully R19, make sure there is continuity to GND on the LHS leg.
Also check the following resistors carefully:
R20,R22,R26,R28,R30,R32.
These form the voltage dividers for the different switch settings.
ryk
nativeVS
PostPosted: Mon Jun 15, 2020 10:35 am    Post subject: Reply with quote  Mark this post and the followings unread
All resistor for the potential divider are correct; R19 measures around 210k without the main pcb, and 127R with it connected.
Other 'fun' things are best illustrated in the following table which shows the voltage across the various resistors of the divider depending on the switch position (all measured in test mode).
Code:
     R19     R20     R22     R26     R28     R30     R32
1   0.104   0.101   0.096   0.090   0.083   0.071   0.053
2   0.104   0.256   0.460   0.731   1.104   1.915   4.6
3   0.105   0.412   0.826   1.393   2.22    4.58    3.12
4   0.106   0.685   1.479   2.61    4.56    3.74    2.70
5   0.107   1.075   2.42    4.53    4.12    3.44    2.53
6   0.110   1.892   4.51    4.22    3.86    3.25    2.42
7   0.119   4.47    4.26    4.01    3.68    3.11    2.34
8   3.31    3.20    3.06    2.88    2.65    2.25    1.70
Whilst I can easily understand the open position, all others seem to suggest some current issues; sad.
Robert
ryktnk
PostPosted: Mon Jun 15, 2020 1:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Code:
Robert
Thanks for your meticulous measurements !
The change of resistance reading R19, when the Main PCB is connected appears
to be a problem.
The resistance of this should not change significantly, and certainly not as low as 127R.
Please check the tracks on the Main PCB for the connection of this voltage [ see atatched picture ]
 Filesize:  69.22 KB
 Viewed:  425 Time(s)
nativeVS
PostPosted: Tue Jun 16, 2020 5:13 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm measuring the same voltages as across R19 on the via and the pin of IC2. Sadly it appears the resistance across that pin and gnd without panel is 126R3; seems like I managed to bugger that one as well. Sad
ryktnk
PostPosted: Tue Jun 16, 2020 12:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello
Can you remove [ very carefully ] the PIC chip, and measure again the resistance from the previous highlighted PIN [ on the Pin header of the Main PCB ] to GND.
ryk
nativeVS
PostPosted: Thu Jun 18, 2020 11:12 am    Post subject: Reply with quote  Mark this post and the followings unread
That's around 206k with the panel PCB connected.
Spelunker
PostPosted: Fri Jun 19, 2020 1:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi, finished my M-185 build.
There is small weirdness however. I have only doepfer DIY kit power (1200ma +12, 1200ma -12v) if I remove all other modules and leave only M-185 it starts probably once in three restarts. When I connect it with other modules M-185 never boots up (other modules work fine) , unless I do ON -> OFF -> then very rapid ON again. Maybe because there is charge in capacitors and those together with fast power off -> on is enough to start module. When it starts however, everything works fine.
Does M-185 take lot's of power during startup and my Doepfer cannot supply it or is there something I screwed when I build module.. or maybe my Doepfer power has problems, unstable power at startup or something ?
ryktnk
PostPosted: Fri Jun 19, 2020 1:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello
Thanks for the reading.
Sounds like you may have fried, or have a defective PIC.
Can you PM your details, and I can send you a replacement.
ryk
ryktnk
PostPosted: Fri Jun 19, 2020 1:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello
There should be plenty of power from your Doepfer, the M185 only uses
approx 85-110mA [ depending on how many LEDs are lit ]
Can you use a multimeter to check how much current [ + and - ] the M185 is drawing when connected to your Doepfer power supply.
You can do this by measuring the current across the 1N5819 diodes [ D2,D6 ]
when the module is powered up.
If you are unsure how to do this, please ask first, to avoid any power supply accidents . . . . Shocked
ryk
Spelunker
PostPosted: Fri Jun 19, 2020 2:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello
ryk
I did small protoboard testrig to "break" powercable and measure current.
When module succesfully powers up:
80-82mA +12v
12mA -12v
when it does not power up:
totally random 53mA - 180mA from +12v depending on power on cycle, it does not jump around. When I power up, it may stay on that 53mA or another power on cycle it may stay 70mA. Just once it was 180mA, usually around 53mA or 70mA.
-12v stays on 12mA like on succesfull power up.
ryktnk
PostPosted: Fri Jun 19, 2020 5:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Hello
ryk
80-82mA +12v
12mA -12v
Sounds pretty strange.
When the module powers successfully, are all the functions working ok ?
Can you repeat the test without the Panel PCB connected.
Please check carefully all the soldering around IC1 and IC100, these are the power
regulators.
Also the orientation of capacitors C1,C4,C6
Spelunker
PostPosted: Fri Jun 19, 2020 8:51 am    Post subject: Reply with quote  Mark this post and the followings unread
regulators.
Yep, when module powers up everything works. I calibrated both cv channels, no problems there, every switch works etc..
Without Panel PCB +12v current draw is sometimes 70mA and sometimes it is only 55mA
Orientation of all electrolytics is ok and there does not seem to be any obvious problems with solder.
ryktnk
PostPosted: Sat Jun 20, 2020 2:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
regulators.
What happens when the module doesnt power up ?
Any lights, any clock output, etc ?
Spelunker
PostPosted: Sun Jun 21, 2020 7:02 am    Post subject: Reply with quote  Mark this post and the followings unread
No lights, not even flash at startup, button pressed does not change anything. CV out gives some random voltage that is slowly rising OR falling, like 1.18V that is increasing 0.01V per sec. Or 2.8v that is decreasing 0.01v per sec.
ryktnk
PostPosted: Sun Jun 21, 2020 8:46 am    Post subject: Reply with quote  Mark this post and the followings unread
Can you measure the voltage regulators when you switch on.
IC1 & IC100
See pic for highlighted pins.
 Filesize:  69 KB
 Viewed:  231 Time(s)
Spelunker
PostPosted: Thu Jun 25, 2020 7:49 am    Post subject: Reply with quote  Mark this post and the followings unread
IC1 & IC100
Those pins show 4,96v. When working or when not working...
IC1 and IC100.
ryktnk
PostPosted: Sat Jun 27, 2020 4:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Spelunker wrote:
IC1 & IC100
IC1 and IC100.
Hello
Thanks, voltages sound ok.
Sounds like something weird happening with the PIC chip.
Can you measure the following voltages on the PIC; IC2 . [ Main PCB ]
Between PIN 8 [ black probe ] PIN 20 [ red probe ]
Between PIN 19 [ black probe ] PIN 20 [ red probe ]
Can you power up normally, and try and get a non-sucessful power up status[ no lights ]
Then turn the Tempo to max, and check if there is any clock output on the Clock IO. [ plug into known working gat/env module etc]
The seq normally boots up with the clock running.
If nothing, press the Start stop button [grey ]once, check again, press again once, check again.
If nothring, then perhaps the PIC chip is damaged.
PM your details and I can send a replacement.
ryk
nativeVS
PostPosted: Sat Jun 27, 2020 9:24 am    Post subject: All Working Reply with quote  Mark this post and the followings unread
Hi ryk,
thanks for sending the replacement PIC; it's all happy now and working without problems. Cheers.
Robert
ryktnk
PostPosted: Mon Jun 29, 2020 12:33 pm    Post subject: Re: All Working Reply with quote  Mark this post and the followings unread
nativeVS wrote:
Hi ryk,
Robert
Great ! Very Happy
Spelunker
PostPosted: Mon Jul 06, 2020 7:06 am    Post subject: Reply with quote  Mark this post and the followings unread
ryktnk wrote:
Hello
ryk
Hello,
Took some time as I was away from studio.
Anyway I picked up new power (Behringer CP1A) and after lots of repeats I simply cannot recreate this bug with Behringer power. M185 seem to work as expected on every power up Smile
So.. I believe there is something broken on my Doepfer power.
It gives stable +12/-12 according to my multimeter but maybe there is low/high/unstable voltages right after power up so M185's PIC goes to some weird faulty state. As I do not have oscilloscope it is hard to debug this further.
Thank You for passionate debugging!
ryktnk
PostPosted: Tue Jul 07, 2020 2:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Spelunker wrote:
Hello,
Hello
Thats good news all is working.
But a bit mysterious/worrying about the Doepfer supply . . .
Which model is it, and also roughly which manufacture date/purchase date ?
ryk
Spelunker
PostPosted: Thu Jul 16, 2020 10:26 am    Post subject: Reply with quote  Mark this post and the followings unread
ryktnk wrote:
Hello
ryk
It's Doepfer A-100 DIY kit power and it is old, I bought it 2016.
http://www.doepfer.de/a100_DIY_kits.htm
Muramasa
PostPosted: Sat Jul 25, 2020 9:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is there any plans for a buchla version?
ryktnk
PostPosted: Thu Jul 30, 2020 7:12 am    Post subject: Reply with quote  Mark this post and the followings unread
None at the moment.
