KORG DW6000 hardware controller with Arduino nano
Page 3 of 3 [55 Posts]
Goto page: Previous 1, 2, 3
PostPosted: Thu Aug 08, 2019 11:26 am    Post subject: Reply with quote  Mark this post and the followings unread
oh svg2shenzhen looks very useful. I've never used inkscape though and I am not a big fan of KiCad but it works fine for panels.
zgba
PostPosted: Thu Jan 21, 2021 1:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great project, thanks a lot for making it available! I'm assembling my own one right now. Hope to post some pictures after I'm done with it.
Some time ago I made a small modification of my DW6000 which gives it 8 waveform banks instead of just one - take a look, maybe it's something for you. It uses the original patch layout, so maybe it would be a quick modification of your software to support it too, especialy since there are 2 unused analog lines in the second multiplexer. Shameless plug: https://hackaday.io/project/10113-project-72-korg-dw-6000-wave-memory-expansion
PostPosted: Thu Jan 21, 2021 2:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
welcome party!
I am looking forward to seeing your version, you might be able to improve the code too.
The wave memory expansion looks very interesting Shocked , I might even have the correct chips for it already but I don't have a proper programmer.
I'll read the blog a couple of times untill I fully grasp it and might give it a try. It would definitely be great to have some more/different waveforms.
zgba
PostPosted: Fri Jan 22, 2021 12:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool, let me know if you need any support. Tomorrow I will probably power the controller for the first time, but since it's a rat's nest I need to double check the wiring. Once I started messing around with wires I instantly regretted, that I didn't design the PCBs. Lesson learned:)
craigbarnes
PostPosted: Sat Sep 23, 2023 11:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Along similar lines, Ive just built my own editor into the DW6000, I need to add some features, but it basically does everything.
 Filesize:  223.27 KB
 Viewed:  173 Time(s)
