frequency shifter
Page 11 of 23 [574 Posts]
Goto page: Previous 1, 2, 3, ..., 9, 10, 11, 12, 13, ..., 21, 22, 23 Next
funkyfarm
PostPosted: Fri May 02, 2008 6:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Are the two letters after "OP-07" are important for a FS1a application ?
OP-07 CP : €0.36 @banzaieffects
http://www.banzaieffects.com/OP07CP-pr-23567.html
OP-07CN :€1.45 @ farnell ?!
http://fr.farnell.com/1094321/semiconducteurs/product.us0?sku=stmicroelectronics-op07cn
First, I guess i could use the 0,36€ version, but, after all, i don't know Cool
guitarfool
PostPosted: Fri May 02, 2008 8:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
According to Mouser (they have both parts), the first one is made by Texas Instruments, the second by STMicroelectronics. Both are PDIP-8. At first glance, both spec sheets seem to have the same values for everything.
Oh, at Mouser, The TI part costs 1 cent more Very Happy
/mr
PostPosted: Sat May 03, 2008 1:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, do it. Smile
It's just the first character C that matters, I think the P or N is just different ways of saying that it's a plastic DIP package.
There's also a D version with almost equally good specifications. I suspect this to perform well enough too, since the differences are really tiny.
jhaible
PostPosted: Sat May 03, 2008 3:21 am    Post subject: Re: Frequency Shifter Reply with quote  Mark this post and the followings unread
fredw wrote:
would be great!
I still have some left - email me. Smile
JH.
jhaible
PostPosted: Sat May 03, 2008 3:27 am    Post subject: Reply with quote  Mark this post and the followings unread
OP-07:
I expect every version of this chip to fit in here. It's a very common part - that's why I used it in the first place. (The important parameters here were: low offset, slow and well-natured response.)
I just checked what brand I have in my prototypes: it's the TI parts, OP07CP.
JH.
/mr
PostPosted: Sat May 03, 2008 3:49 am    Post subject: Reply with quote  Mark this post and the followings unread
Good to know.
What about the TL07x chips? Their Vio differ between versions:
"B" (best), "A" (medium), " " (worst).
I have some different chips, would be nice to put the best ones in the right places - if it matters at all. Smile
jhaible
PostPosted: Sat May 03, 2008 4:36 am    Post subject: Reply with quote  Mark this post and the followings unread
/mr wrote:
Good to know.
Where I specified TL07x, offset is not an issue - so you can use the cheapest version.
JH.
jhaible
PostPosted: Tue May 20, 2008 3:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just being curious - has anybody finished building his Frequency Shifter yet?
JH.
toppobrillo
PostPosted: Wed May 21, 2008 4:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
not yet, scrounging around for parts.. looks like i'm going to have to place an order..
been working on panel designs lately- which i have not yet finalized, by the way. anybody else done a panel?
guitarfool
PostPosted: Wed May 21, 2008 8:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm still struggling with it, along with my panel layout for the Klee, String Filter, and Buchla 281 EG Wink
I've got silkscreens on the way for 9 other panels (including the solina chorus), so I'll also be printing up panels this weekend. I'd like to get all my building done before my eyesight is gone, and have enough time to play with it all before my hearing goes Very Happy Shocked
But I have starting stuffing the Frequency Shifter boards. Since I'm using +/-15V dotcom power, I can leave out U1, U2, D1-D5, C1-C6 and R1-R6 on board 2, right?
jhaible
PostPosted: Thu May 22, 2008 2:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, omit the obvious power supply parts.
And make sure you have a *short* connection to your power supply.
The on-board compander helps to get rid of oscillator bleedthru, and does this quite nicely when everything is well adjusted. But if anything comes in _after_ the compander, coupled by a long GND connection to the PSU, the compander cannot suppress that.
We're talking about rather low bleedthru levels here, and it doesn't matter much when you have large audio signals - but if you have the choice, better plan to place the FS-1a close to the power supply.
Also, when using the on-board PSY, position the two boards such that the sides with the +0- connector (+/-15V) are facing each other, to keep that connection short.
JH.
neandrewthal
PostPosted: Thu May 22, 2008 9:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Uh-oh. What if it is not possible to even put it in the same cabinet as the power supply. Would the bleedthrough be unbearable?
paologatto
PostPosted: Thu May 22, 2008 9:54 am    Post subject: Reply with quote  Mark this post and the followings unread
I finished to buid it some days ago.. here is a picture:
The adjustment procedure was simple and all went as you described.
But I noticed 2 things that make me think that I made some mistakes in the building:
- also when the dry-wet pots are set all to dry in the output the signal is low-pass filtered. Is this by design?
- there is a sort of sublte feedback at the frequency of the oscillator: when a signal in input is stopped there is an oscillation that shortly ends. Is also this normal?
On the use of the frequency shifter I still have to learn. It's a very complicate machine indeed! Currently I don't have external CV source, here is an example of use just moving the frequency controls. Some notes played through the frequency shifter and the same recorded directly from the synth (an A6 Andromeda).
fs-alldry.mp3
 Filename:  fs-alldry.mp3
 Filesize:  3.61 MB
 Downloaded:  798 Time(s)
fs-90wet.mp3
 Filename:  fs-90wet.mp3
 Filesize:  3.63 MB
 Downloaded:  827 Time(s)
jhaible
PostPosted: Thu May 22, 2008 11:12 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't know how bad it will be.
But there's an easy cure: spend 10 dollars for a transformer and fuses.
The PSU is on the board already!
JH.
jhaible
PostPosted: Thu May 22, 2008 11:31 am    Post subject: Reply with quote  Mark this post and the followings unread
No. First thing to check: The small capacitors that are in the feedback of the opamps. They should only roll off the frequency response _above_ the audio range - not do any serious low pass filtering.
Double check if they have the requred value. Example: 33pF
There are ceramics marked "330" that have 33pF (33 * 10^0), and some where 330 reads as 330pF.
Sounds like remaining bleedthru from the oscillator. This should be quite small even *before* the compander closes down (that's what you hear ending, when it's suppressed). With the specified resistor values, the compander has a very slow release tail. You can speed this up by decreasing R147 (near U21 on PCB 1) from 4.7M to something smaller. Connect a 1M or 470k in parallel with R147.
You can even connect a 5Meg audio taper pot + 100k series resistor in parallel with R147 to have an adjustable release time.
For first experiments, I recommend this:
Mix fully on wet. Modulation frequency a couple 100 Hz.
Play percussive notes thru this. (piano or clavinet-like tones)
Try upshift and downshift.
Listen to it in stereo with both outputs in upshift, then switch *one* to downshift while playing on.
JH.
paologatto
PostPosted: Thu May 22, 2008 12:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
JH.
Thank you for the help Jurgen! As soon as I finish the "Jurgen Box" Smile I'll check what's wrong with the frequency shifter..
BTW all your other 3 effects I've built work and sound perfectly!
PS: here is a preview of the Jurgen Box, when finished I'll post some more pictures
/mr
PostPosted: Fri May 23, 2008 5:09 am    Post subject: Reply with quote  Mark this post and the followings unread
All PCB components now arrived & sorted and component kits are sent out to 3 of my friends who also bought PCBs. The last one who finishes it will have to pay for the other ones... Wink
No soldering yet, but I've made a first preliminary frontpanel sketch with the Super-Duper Home-Made Fridge-Magnet Modular Frontpanel Design System Cool and it looks like it's gonna be a reeeally beautiful module! Can't wait to see it & hear it! Just have to build it and try out the different connections and possibilities before I decide exactly what [extra] features will be included on the panel.
preliminary fs-1a frontpanel sketch
 Filesize:  187.39 KB
 Viewed:  15287 Time(s)
Audio files: 235
PostPosted: Fri May 23, 2008 10:55 am    Post subject: Reply with quote  Mark this post and the followings unread
Please don't include any more links to imageshack.us because there are ugly pop up ads. If you want to share photos, please just post them here as an attachment. Your photos are good, it's just that site that's ugly.
Thanks.
toppobrillo
PostPosted: Fri May 23, 2008 4:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
what a great motivator to finish projects! i'd like to try that sometime!
i really still can't decide whether to put this in it's own 2U rack or try a 4U x say 6" panel. i think i'd like to bring the VCO outputs out to the front and also perhaps the dome filter out too. i am really excited at the fact that this filter covers such a wide range- seems like it could be useful on it's own as well.
synth_ollie
PostPosted: Sat May 31, 2008 12:30 am    Post subject: Reply with quote  Mark this post and the followings unread
well, that will propably be me then, havent had time to even take a closer look at the boards yet... Wink
/mr
PostPosted: Wed Jun 18, 2008 6:34 am    Post subject: Decoupling caps, different methods Reply with quote  Mark this post and the followings unread
I notice that supply decoupling caps are placed between (+) and (-) supplies instead of the perhaps more common supply-to-ground.
Can you give a good short explanation of the pros and cons in different situations?
jhaible
PostPosted: Wed Jun 18, 2008 11:16 am    Post subject: Re: Decoupling caps, different methods Reply with quote  Mark this post and the followings unread
Oh, how do you call this in English - opening a can of worms ? Laughing
There are different philosophies for placing decoupling caps, and there are different goals to achieve.
One possible goal is to keep the supply noise low, even when an opamp is driving rather heavy loads. In that case, you have to follow your load current with your decoupling caps: If the opamp drives low impedance to GND, you need to decouple the + and - supply rails to GND; and not to just any GND point either, but to the point where your load is grounded.
If you have one opamp driving the virtual GND node of a second, inverting, amplifier via a small resistance, you'd have to decouple the positive supply of the first opamp to the negative supply of the second opamp, and vice versa. Just closing the current loop with a part as short as possible with capacitors.
IMO, this (last paragraph) is an exotic case, however. Important for power amplifiers with ultro low distortion, most likely.
For all my low-current audio opamp circuits, there is just a single design goal for the bypass caps: Make the circuit stable. Prevent it from ringing. Staying clear from self oscillation. And here, in most cases, decoupling +vb to -vb does the job.
I got this advice from a TI opamp specialist (former Burr Brown specialist): Decouple +vcc to -vee on every opamp, and just make sure there are a _few_ extra caps from -vee to GND, spread over the board.
I do it that way ever since, and never had oscillation problems.
JH.
Fetafarmer
PostPosted: Wed Jun 18, 2008 11:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Jürgen,
I was considering using a 10-turn pot for linear control from the panel (leaving the Fine pot away). Is the purpose of the LEDs at DirLD to provide orientation within the linear frequency range in such a configuration?
thanks!
kevin
jhaible
PostPosted: Wed Jun 18, 2008 11:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Fetafarmer wrote:
Hi Jürgen,
thanks!
kevin
Yes, this will work, and yes, the Dir Led will be helpful in th eway you describe it.
JH.
Audio files: 235
PostPosted: Wed Jun 18, 2008 1:02 pm    Post subject: Re: Decoupling caps, different methods Reply with quote  Mark this post and the followings unread
I have been building circuits for years. Every good designer I've spoken to has different rules of thumb. It's not an exact science, but closer to a craft or art. This practice seems very sound to me. My suggestion to everyone is pick a methodology and stick to it rigorously. Then, down the road, if you have some problems the time you spend correcting them will be not just to improve a particular circuit or layout, but to improve your method.
