Streaming now
Yusynth on Stripboard
Page 1 of 1 [15 Posts]
helix_modular
PostPosted: Thu May 03, 2018 1:00 pm    Post subject: Yusynth on Stripboard
Subject description: A growing collection of stripboard implementations with suggested mods.
Dear EMs,
with permission of Yves Usson I intend to share my stripboard layouts of various Yusynth modules. I am very thankful for Mr. Usson's amazing work and I learned a lot in the process of designing the stripboards. Each layout has links to his homepage, after all there is the reference for wiring and the like.
All posted layouts are tested and verified.
A word on my design guidelines:
I tried to maintain a board format that fits behind a 5u standard panel in 'sandwich' configuration, much as the original designs.
The power section is intentionally very generous to be readily adapted to your needs. For my part I use 2x5 Eurorack connectors but feel free to modify. Just make sure these 10Ohm resistors are in series and the caps in parallel and grounded (!).
The provided PDFs are true to size. Print with a ratio of 1:1 and it fits your standard stripboard perfectly!
Feedback is highly welcome and appreciated. Time to give this amazing community something back!
    CV Generators
      Auto-bend
      Dual Gated Slew
    Signal processors and modifiers
      MinMax
      Saw Animator
    Control/GATE generators and modifiers
      Dual Gate Delay
      Dual Pulse Delay
      Clock Divider
      Comparators
All the best & happy soldering,
helix modular
helix_modular
PostPosted: Thu May 03, 2018 1:02 pm    Post subject: Yusynth Autobend
Subject description: Stripboard
Yusynth Autobend
http://yusynth.net/Modular/EN/AUTOBEND/index.html
Yusynth_Autobend.pdf
 Filename:  Yusynth_Autobend.pdf
 Filesize:  110.63 KB
 Downloaded:  1002 Time(s)
helix_modular
PostPosted: Thu May 03, 2018 1:04 pm    Post subject: Yusynth Pulse Delay
Yusynth Dual Pulse Delay
http://yusynth.net/Modular/EN/PULSEDELAY/index.html
Yusynth_DualPulseDelay.pdf
 Filename:  Yusynth_DualPulseDelay.pdf
 Filesize:  105.77 KB
 Downloaded:  814 Time(s)
helix_modular
PostPosted: Thu May 03, 2018 1:05 pm    Post subject: Yusynth Dual Gate Delay
http://yusynth.net/Modular/EN/GATEDELAY/index.html
Yusynth_DualGateDelay.pdf
 Filename:  Yusynth_DualGateDelay.pdf
 Filesize:  109.63 KB
 Downloaded:  778 Time(s)
helix_modular
PostPosted: Thu May 03, 2018 1:06 pm    Post subject: Yusynth Dual Gated Slew
http://yusynth.net/Modular/EN/DUALSLEW/index.html
Yusynth_DualGatedSlew.pdf
 Filename:  Yusynth_DualGatedSlew.pdf
 Filesize:  126.86 KB
 Downloaded:  828 Time(s)
helix_modular
PostPosted: Thu May 03, 2018 1:13 pm    Post subject: Yusynth Min Max + Inverter Mod
Yusynth Min Max + Inverter (Mod)
http://yusynth.net/Modular/EN/MINMAX/index.html
I've added two simple inverting opamp circuits to 'complete' this module in a sense of analog boolean logic: MIN = AND, MAX = OR, INV = NOT.
Inverter may be easily omitted.
Yusynth_MinMax_Inv.pdf
 Filename:  Yusynth_MinMax_Inv.pdf
 Filesize:  133.68 KB
 Downloaded:  786 Time(s)
PostPosted: Thu May 03, 2018 1:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
Since you're good at making stripboard layouts you might be able to help out here. Very Happy
billsaban
PostPosted: Sun May 06, 2018 1:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanx a lot for this
helix_modular
PostPosted: Mon May 07, 2018 12:21 pm    Post subject: Yusynth Clock Divider
http://yusynth.net/Modular/EN/DIVIDER/index.html
Modification (suggestion) with reset on rising clock (instead of falling, as in original design) included. Please also refer to this thread:
http://electro-music.com/forum/topic-69933.html
Mounting:
As there's a lot of wiring to be done, I suggest to mount the board in L-configuration. This keeps the wires to the rotary switches short and tidy.
Update (2018-06-05): small image of the reset mod included.
Note (2020-03-29): I recommend to reduce R40 (reset pulldown) to 47k. This amends triggering all outputs at high reset inputs (~ +/-15).
Yusynth_Clockdivider-ResetMod-img.pdf
 Filename:  Yusynth_Clockdivider-ResetMod-img.pdf
 Filesize:  208.12 KB
 Downloaded:  954 Time(s)
helix_modular
PostPosted: Mon May 14, 2018 1:06 pm    Post subject: Yusynth Comparators
Yusynth Comparators
http://yusynth.net/Modular/EN/COMPARATORS/index.html
Suggestions for different thresholds included. I think this circuit may be simplified in a few places, too (which makes it possible to avoid hookup wires on the board).
Yusynth_Comparators.pdf
 Filename:  Yusynth_Comparators.pdf
 Filesize:  123.04 KB
 Downloaded:  763 Time(s)
MapacheRaper
PostPosted: Mon Jun 18, 2018 5:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Im loving this thread
artilect99
PostPosted: Wed May 29, 2019 4:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Two questions... are any modifications necessary for the clock divider to run on 12V? And 2) does anyone know the what rotary switch is needed (1p12t)?
helix_modular
PostPosted: Thu May 30, 2019 7:53 am    Post subject: Reply with quote  Mark this post and the followings unread
@artilect99
I think the clock divider would work on 12V without modifications. Running Yusynth on 12V is discussed in this thread:
http://electro-music.com/forum/topic-39693.html
However, the tripping voltages for the discrete Schmitt-trigger (input processing stage) are probably a bit off (read: lower, therefore it will trigger at lower threshold). You could play around with the resistor values (R3-R6) if it does not behave as desired. If you feed it a proper pulse there should be no problem anyways.
For the switch: any one pole with up to 10 throws. The original version provides up to divide by 8, the core chip (CD4017) allows up to divide by 10 (as indicated in my upload). A 1p12t switch can probably be configured to lower throws.
artilect99
PostPosted: Fri May 31, 2019 11:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks helix. I will try it out and see if it triggers as expected.
helix_modular
PostPosted: Sat Jun 29, 2019 8:10 am    Post subject: Yusynth Saw Animator
http://yusynth.net/Modular/EN/SAWANIM/index.html
I've included standard 1k output protection resistors. If you don't want them, replace them with a jumper or change the position of the output pins.
Yusynth_Sawanimator.pdf
Stripboard layout of the Yusynth Sawanimator
 Filename:  Yusynth_Sawanimator.pdf
 Filesize:  157.35 KB
 Downloaded:  571 Time(s)
