Korg X-911 Manual
Page 1 of 1 [16 Posts]
Wild Zebra
PostPosted: Wed Jul 13, 2005 9:13 am    Post subject: Korg X-911 Manual Reply with quote  Mark this post and the followings unread
Howdy, anyone know where to find this manual hopefully in pdf. format
thanks
"your stripes are killer bro"
PostPosted: Wed Jul 13, 2005 9:29 am    Post subject: Reply with quote  Mark this post and the followings unread
I moved this topic to the manuals forum, so it's amongst similar messages.
Jan.
deknow
PostPosted: Wed Jul 13, 2005 6:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
...i think i have a service manual for that around here somewhere. let me know if that's what you need.
deknow
Wild Zebra
PostPosted: Thu Jul 14, 2005 12:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
I was wondering where it went. Sorry, didn't see this section. I would like to have the owners manual, but the service manual may be handy also. I'm looking for some specs and details about some of the things on this unit. I.E. what volts the cv outs and triggers put out.
thanks
deknow
PostPosted: Thu Jul 14, 2005 1:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
the cv gate stuff on the x911 is the same as the korg ms series. it's v/hz (not the more common v/oct) like the yamaha cs, paia fatman, korg ms. if you are trying to integrate it with roland, arp, moog, or other common synths you will need some kind of conversion.
deknow
deknow
PostPosted: Thu Jul 14, 2005 1:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
...and the gate is s/trig (shorting), not v/trig (voltage).
deknow
Wild Zebra
PostPosted: Fri Jul 15, 2005 7:35 am    Post subject: Reply with quote  Mark this post and the followings unread
I don't know if your hip to this soundlab stuff, but I was trying to use
the trigger for external gate(to no avail). Probably because of s\trig
They had to be different didn't they.
deknow
PostPosted: Fri Jul 15, 2005 8:06 am    Post subject: Reply with quote  Mark this post and the followings unread
yes, if you need a voltage trigger, the x911 won't work without a converter of some kind. on the x911, the trigger shorts tip to sleeve. here is a copy/paste from a synth diy list (found using google). i think this was done by my friend mark. it may take some work to get it all straight. (it seems to distort a little in the pasting), the original can be found here (it's a little clearer).
http://www.retards.org/library/technology/electronics/audio_circuits/synths/diy-synth_list_archive/synth-diy.archive.0105
deknow
This will produce a voltage
trigger in response to an
s-trigger out. The trigger Off
voltage will be 0 or 9 volts. ___o ___________
Close the switch to use, open / | 9-volt |
it to save the battery life. |-----o o---- +| battery |-- ground
________________| On |___________|
10k \ 10k \
| |----------------------- to tip of jack
| | sleeve to ground
| 100k /
___________|___/\/\/\___|/
| |\ 2N3904 or equivalent
1 -|- S-trigger \
_____ in |
2 | |
| ground -
--- ground
deknow
PostPosted: Fri Jul 15, 2005 8:07 am    Post subject: Reply with quote  Mark this post and the followings unread
sorry, i should have previewed it....it's unusable...just go to the link.
deknow
PostPosted: Fri Jul 15, 2005 8:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Made a screen dump of the schematic.
Jan.
schematic for s to v trigger conversion
 Filesize:  23.61 KB
 Viewed:  26466 Time(s)
deknow
PostPosted: Fri Jul 15, 2005 8:48 am    Post subject: Reply with quote  Mark this post and the followings unread
thanks jan, that makes it a little more helpful. here is a page from some moog documentation (i hope there isn't a serious copyright issue) with the opposite....vtrig to strig.
deknow
 Filesize:  46.25 KB
 Viewed:  26461 Time(s)
Wild Zebra
PostPosted: Fri Jul 15, 2005 9:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks guys thats helps
deknow
PostPosted: Fri Jul 15, 2005 11:24 am    Post subject: Reply with quote  Mark this post and the followings unread
...i'm not in the soundlab discussion at all, but someone should make sure this thread gets a mention there (perhaps it should be moved there, as the manual was not really needed).
deknow
joker
PostPosted: Thu Jan 18, 2007 4:49 pm    Post subject: here´s the x-911 manual Reply with quote  Mark this post and the followings unread
You can find the manual here.
http://www.synthdiy.com/show/showproduct.asp?id=1706
It´s a bad scan from a bad copy, but the it might help. Schematic-Services charge 15 $ + delivery for a good copy:
http://www.schematicconnection.com/store/asp/product.asp?product=284&ph=search&keywords=x-911&recor=1&SearchFor=any&PT_ID=all
best,
Joker
have a nice bend!
Joker
www.klangbureau.de/cb_E.html
joker
PostPosted: Thu Jan 18, 2007 4:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oops, thats not the owners-manual but the service-manual.
have a nice bend!
Joker
PostPosted: Thu Jan 18, 2007 4:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey Joker, welcome aboard !
