Wild Zebra
Posted: Wed Jul 13, 2005 9:13 am Post subject:
Korg X-911 Manual |
Howdy, anyone know where to find this manual hopefully in pdf. format
thanks _________________ "your stripes are killer bro" |
Joined: Apr 03, 2004 Posts: 24670 Location: The Netherlands, Enschede
Posted: Wed Jul 13, 2005 9:29 am Post subject:
I moved this topic to the manuals forum, so it's amongst similar messages.
Jan. |
deknow
Posted: Wed Jul 13, 2005 6:31 pm Post subject:
...i think i have a service manual for that around here somewhere. let me know if that's what you need.
deknow |
Wild Zebra
Posted: Thu Jul 14, 2005 12:34 pm Post subject:
I was wondering where it went. Sorry, didn't see this section. I would like to have the owners manual, but the service manual may be handy also. I'm looking for some specs and details about some of the things on this unit. I.E. what volts the cv outs and triggers put out.
deknow
Posted: Thu Jul 14, 2005 1:24 pm Post subject:
the cv gate stuff on the x911 is the same as the korg ms series. it's v/hz (not the more common v/oct) like the yamaha cs, paia fatman, korg ms. if you are trying to integrate it with roland, arp, moog, or other common synths you will need some kind of conversion.
deknow |
deknow
Posted: Thu Jul 14, 2005 1:26 pm Post subject:
...and the gate is s/trig (shorting), not v/trig (voltage).
deknow |
Wild Zebra
Posted: Fri Jul 15, 2005 7:35 am Post subject:
I don't know if your hip to this soundlab stuff, but I was trying to use
the trigger for external gate(to no avail). Probably because of s\trig
They had to be different didn't they. _________________ "your stripes are killer bro" |
deknow
Posted: Fri Jul 15, 2005 8:06 am Post subject:
yes, if you need a voltage trigger, the x911 won't work without a converter of some kind. on the x911, the trigger shorts tip to sleeve. here is a copy/paste from a synth diy list (found using google). i think this was done by my friend mark. it may take some work to get it all straight. (it seems to distort a little in the pasting), the original can be found here (it's a little clearer).
http://www.retards.org/library/technology/electronics/audio_circuits/synths/diy-synth_list_archive/synth-diy.archive.0105
deknow
This will produce a voltage
trigger in response to an
s-trigger out. The trigger Off
voltage will be 0 or 9 volts. ___o ___________
Close the switch to use, open / | 9-volt |
it to save the battery life. |-----o o---- +| battery |-- ground
________________| On |___________|
10k \ 10k \
| |----------------------- to tip of jack
| | sleeve to ground
| 100k /
___________|___/\/\/\___|/
| |\ 2N3904 or equivalent
1 -|- S-trigger \
_____ in |
2 | |
| ground -
--- ground
deknow
Posted: Fri Jul 15, 2005 8:07 am Post subject:
sorry, i should have previewed it....it's unusable...just go to the link.
deknow |
deknow
Wild Zebra
Posted: Fri Jul 15, 2005 9:41 am Post subject:
Thanks guys thats helps _________________ "your stripes are killer bro" |
deknow
Posted: Fri Jul 15, 2005 11:24 am Post subject:
...i'm not in the soundlab discussion at all, but someone should make sure this thread gets a mention there (perhaps it should be moved there, as the manual was not really needed).
deknow |
joker
joker
Posted: Thu Jan 18, 2007 4:54 pm Post subject:
>You can find the manual here.
>http://www.synthdiy.com/show/showproduct.asp?id=1706
Oops, thats not the owners-manual but the service-manual. _________________ have a nice bend!
Joker
www.klangbureau.de/cb_E.html |
Posted: Thu Jan 18, 2007 4:56 pm Post subject:
Hey Joker, aboard ! _________________ Jan
