Wogglebug circuit
Page 2 of 14 [332 Posts]
Goto page: Previous 1, 2, 3, 4, ..., 12, 13, 14 Next
kryptic
PostPosted: Wed Feb 21, 2007 2:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Does anyone have a PCB layout for this? I tried the link towards the beginning of the thread, but it no longer works. Thanks.
vtl5c3
PostPosted: Wed Feb 21, 2007 2:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
I think this is what you're after.
Cleaned up parts placement for the Standard wogglebug 3+ layout.
 Filesize:  470.66 KB
 Viewed:  1446 Time(s)
Traces only.
 Filesize:  229.03 KB
 Viewed:  1057 Time(s)
Fidgit
PostPosted: Thu Feb 22, 2007 7:31 am    Post subject: Reply with quote  Mark this post and the followings unread
vtl: which schematics does this PCB refer to, please? i'd say it's not the original wiard version as linked in the first post of this thread.
vtl5c3
PostPosted: Thu Feb 22, 2007 9:19 am    Post subject: Reply with quote  Mark this post and the followings unread
It's mainly based off the wogglebug #3 schematic ( http://www.musicsynthesizer.com/WoggleBug/WOGGLSCH.GIF ). I added a second RM output and a sync input to the 555. The latter is based off of one of Rene Schmitz VCOs. ( http://www.uni-bonn.de/~uzs159/vco3.html )
Fidgit
PostPosted: Fri Feb 23, 2007 12:50 am    Post subject: Reply with quote  Mark this post and the followings unread
ok, thank you. i asked because on the two PCB pictures above there are e.g. two transistors without any specification. the wiard schematics contains one of them and the other one i guess i'll have to look for in the VCO3 circuit you mentioned.
vtl5c3
PostPosted: Fri Feb 23, 2007 9:31 am    Post subject: Reply with quote  Mark this post and the followings unread
Right. The second transistor (connected to pin 4 of the 555) is for the synch circuit. Not essential, but I thought it would be a fun feature to add.
kryptic
PostPosted: Sat Feb 24, 2007 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks vtl5c3. That is indeed what I was looking for.
numbernone
PostPosted: Mon Feb 26, 2007 8:36 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is my first round of queries on the wogglebug layout:
In the sync in area, is that a diode connecting to ground?
While we are over there, is the second transistor 2N3904?
As far as the capacitor types go i am resonably comfortable that C denotes ceramic, P is poly (-styrene? -ester? -propelyene?), T is tantalum. But what give with the FP and NP designations?
There are 4 pairs of pads left blank, I am imagining that several are for returns to V+/- and ground for some of the pots? Is this correct? There is a pair open just north of the 398, one side grounded the other jumpered to V-.
Does anyone have a handy list of the names for the potentiometers? I have been trying to work it out from the block diagram on the Wiard site to no avail. It would also seem that Grant's production model has a good bit more packed into it than his basic schem shows, such as the disturb CVs and a bunch of lovely LEDs. any leads on these extras??
Any and all light that anyone can shed on these issues is very appreciated. Im sure I forgot something I can bother everyone with later...
vtl5c3
PostPosted: Mon Feb 26, 2007 10:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes. The anode connects to ground. For anyone that's confused about this section, please refer to Rene Schmitz's VCO 3:
I copied the stuff on pin 4 of the 555.
That should work fine.
NP is non-polarized aka bipolar. Never heard of FP.
The 4 blank pads are actually for bypass caps (.1 or .01 uF) for the TL071. Same goes for the two pads north of the LF398.
The Wiard production Wogglebug is a more sophisticated version. I tried working out what was behind the front panel at some point... not sure where my notes are for that. I'm pretty sure a second LF398 is involved. I'll see if I can find my stuff. Obviously, Grant isn't going to give out his secret recipe. Despite the fact that the Wogglebug #3 is simpler than the production version, it is still a fantastic module. You could always start with that and hack other stuff onto it. The Wiardgroup on yahoo groups has some extra add-onn circuits that Dr. Mabuse designed. Might want to check those out.
These are good questions. I never realized that people would be interested in this layout, which is why the parts placement is still in its cryptic format. I'll try to whip up one that's more user friendly.
numbernone
PostPosted: Mon Feb 26, 2007 10:35 am    Post subject: Reply with quote  Mark this post and the followings unread
FANTASTIC!!
CJ Miller
PostPosted: Tue Feb 27, 2007 8:28 am    Post subject: Reply with quote  Mark this post and the followings unread
I am certainly interested! Even though I am backed up for about a month finishing old projects here... When I am more or less caught up I'm wanting to build a few low-pass gates and try some Wogglebug action. I was recently thinking of starting a layout - and here's one already! Looks good to me. But I'll likely be adapting it to perfboard. Thanks for showing us!
toppobrillo
PostPosted: Tue Feb 27, 2007 11:44 am    Post subject: Reply with quote  Mark this post and the followings unread
LOYAL ORDER OF THE WOGGLE-BUGS!
vtl5c3
PostPosted: Sun Mar 18, 2007 8:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Richard Brewster posted his take on the Wogglebug yesterday. Looks very nice.
Here's the URL:
http://www.pugix.com/wogglebug.htm
janvanvolt
PostPosted: Mon Mar 19, 2007 6:25 am    Post subject: Reply with quote  Mark this post and the followings unread
I am about to get my PCB etched for the wogglebug, but still i am puzzled on how it should be connected to the frontpanel ( i used the panel design from pugix.com for my MOTM, but that similar to the other one.
Is this correct ??????????
Pots:
STEP LIMIT -> R8A,R8B, R8C -> Value 50K
WOGGLE ->
S RANGE ->
W RANGE ->
DISTURB ->
RATE -> between GND/+15V and middle pot to jack RATE CV and then to CV Inputs
Jacks:
CLK OUT ->
STEP CLK ->
RATE CV ->
STEP IN ->
DISTURB A ->
DISTURB B ->
S TONE -> Smooth Tone on PCB
W TONE -> Woggle Tone on PCB
SMOOTH ->
STEPPED -> Stepped on PCB
WOGGLED -> Woggle Out on PCB
RINGMOD ->
I am completely puzzled about the Pots and the other connections on the PCB like "R13, R21B" ... and such (which are pad's on the PCB, NOT Resistors)
Any help appreciated.
vtl5c3
PostPosted: Mon Mar 19, 2007 8:20 am    Post subject: Reply with quote  Mark this post and the followings unread
The PCB that I posted is based on the schematic at:
If you based your front panel off Richard Brewster's design... there's stuff in his version of the wogglebug that's not in the PCB that I posted.
janvanvolt
PostPosted: Mon Mar 19, 2007 8:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Well. Brewster's design is just an idea, i'd like to get a fitting one for the
one here:
Let's see if i get the connections right :
R8 = 50K = STEPPED
R9 = 50K = CV IN
R13 = 1M = ?????
R19 = 1M = ?????
R21 = 1M = ?????
J2 = RINGMOD IN
J4 = WOGGLE OUT
J5 = WOGGLETONE OUT
J6 = TONE OUT
J7 = SMOOTH CV IN
Anything else i missed ?
vtl5c3
PostPosted: Mon Mar 19, 2007 9:02 am    Post subject: Reply with quote  Mark this post and the followings unread
Ah. Sorry. Keep forgetting that the pots aren't labelled on Grant's schematic. Here's the updated list:
R8 = 50K = Correlation
R9 = 50K = CV IN
R13 = 1M = Smooth Range
R19 = 1M =Woggle Range
R21 = 1M = Woggle Time
J2 = RINGMOD Out
J4 = WOGGLE OUT
J5 = WOGGLETONE OUT
J6 = Smooth TONE OUT
J7 = SMOOTH CV Out
I think that's it, unless you plan on adding the Sync input and second RM output.
janvanvolt
PostPosted: Fri Apr 20, 2007 2:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
I have built the Wogglebug#3 with the PCB posted here. But -- it does not sound like it should be.
There's only a high pitch one some, lower pitch on other, but it does not sound like it should be (according to the examples).
Can somebody provide me debugging tips on how i can nail down the problems ?
sneakthief
PostPosted: Fri Apr 20, 2007 3:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
i ran across mark v's dual-wogglebug schematic again and thought i'd throw it into the diy-pool here:
PDF's:
http://sneak-thief.com/modular/woggle_bug_etch.pdf
http://sneak-thief.com/modular/woggle_bug.pdf
Mark's notes:
(these matter because this one is funky)
1. both PDFs are fromt he solder side. You are looking
at a reversed image of the parts.
2. There needs to be a jumper from the hole at pin 3
of the 555 to the one above the label "tri stepped".
This label is actually for the pad below it. I made
the board so that you could tap in your own clock to
the sample and hold if you wanted to. If you want it
to be hard wired, just jumper it.
3. The labeling was done in a senseless way. The
labels on the right side are in the margina nd the
left side are near the pads. It can confuse in the
middle, but you should be able to figure it out, since
the two halves are duped.
4. The power is set up for the standard MOTM
connector. +15 GND GND -15
5. the 3 pads next to the 398 are for the 50k pot that
controls correlation.
6. the "ring' jack is mis-labelled "rin"
7. the red rectangles are trim pots.
Sneak-Thief - raw electrofunk
vtl5c3
PostPosted: Fri Apr 20, 2007 4:35 pm    Post subject:   Reply with quote  Mark this post and the followings unread
Fantastic! Where the heck did you get that from?
Cool Idea Cool
PDF's:
Mark's notes:
8. the unmarked 3 holes next to the 398 are for the Cluster pot (150k)
fluxmonkey
PostPosted: Fri Apr 20, 2007 7:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've built this version, and many thanks to mark for sending it. Warning: there are a number of errors on the traces. I got it fixed, nothing too bad, but I'll have to pull it out and look. from memory the TL071 is missing it's power lines, and the 100K between pin 2 & 5 of the same chip should be between 2 & 6. I think there were one or two minor issues... i'll pull it from the rack this weekend and check.
bbob
sneakthief
PostPosted: Sat Apr 21, 2007 12:08 am    Post subject: Reply with quote  Mark this post and the followings unread
as a guardian of the loyal order of the wogglebug, i can't reveal my 2 sources Wink
bbob - thanks for the heads-up! it would be greatly appreciated if you could let us know about any other issues with this board.
sneakthief
PostPosted: Sat Apr 21, 2007 7:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Here are my notes on this schematic:
Code:
- Jacks -
Wogglebug #3           Mark V.
J1 - Stepped           Stepped
J2 - Ringmod Out       Rin
J3 - Woggle Rate Pot   CV IN
     and Rate CV In
J4 - Woggle Out        Woggle Tone (Right)
J5 - Woggle Tone Out   Woggle Tone (Left)
J6 - Smooth Tone Out   Tone
N/A - LFO Out          Tri
N/A - Clock In         Clock
J7 - Smooth CV Out     Smooth
- Pots -
R8  50K Correlation    Right of LF398
        (aka Cluster)
R9  50K CV             CV ins (either one)
N/A 50K CV Input       CV ins (either one)
R13 1M Smooth Range    smooth
R19 1M Woggle Range    Pin 11 of bottom 4046
R21 1M Woggle Time     Pin 13 of bottom 4046
And my ghetto frac panel:
CTONE = Child tone = smooth tone
fluxmonkey
PostPosted: Sat Apr 21, 2007 12:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
pulled out my woggglebug and notes, i think these are all the corrections i made (Red=cut trace; Green=added trace; blue=added jumper):
* added power connections to TL072
* re-routed 100k from pin 5 to pin 6 of TL072
* rerouted pin 8 of both 4042s to ground instead of neg
* grounded pin 1 of 555
these changes need to be made to both halves, i only drew them on one side (stupid paint).
happy woggling!
bbob
www.fluxmonkey.com
 Filesize:  33.73 KB
 Viewed:  43514 Time(s)
janvanvolt
PostPosted: Sat Apr 21, 2007 6:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Given the "Original" PCB design on the first page of the thread here:
- I built the circuit
- on "W-Tone" i get a high pitch waveform.
- on "S-Tone" i get a low (maybe around 440 Hz) waveform.
- on Ring i get an output like "digital"
This is definitely not right. I already checked the PCB for obvious errors or solder where it should not been... found some, fixed all. still the same problem...
for the NPN's i use 2N3904, the rest is default. Resistor values are according to the diagram.
Just to get everything right: can somebody verify if the pots are done correctly or post me a short list ?
*sigh*
Anybody able to help me and giving me ideas where to look for (or measure).
