TH-201 "Mankato" PCBs available
Page 2 of 7 [156 Posts]
Tim Servo
PostPosted: Thu Jul 05, 2007 2:32 pm    Post subject:
Subject description: LED Drivers
bugbrand wrote:
..is this right for BiColour Leds?
Hey Tom,
Sorry, made my last message before I saw your schemo.
I'm pretty sure this will work okay. The impedance of the non-inverting input on an 074 (or just about any FET input op amp) is pretty high, so you shouldn't be pulling too much current off the Mankato. You can also experiment with a higher value current-limiting resistor. Try 2K or even 4.7K and see if you still get nice status lights.
The biggest test would be to run this for a while at a high frequency and make sure that the Mankato's ICs don't get hot. ICs 1 and 3 (the 074s) are the output buffers. They may be a bit warm (should be just barely noticeable) but hot means that too much current is being pulled.
Thanks for sharing. Now we need a YouTube video with blinky lights and multi-modulation going on Wink
Tim (not the brightest blinky light) Servo
bugbrand
PostPosted: Thu Jul 05, 2007 3:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey thanks Tim - thats some good advice, especially the 'trying-it-fast' - > I'll have a go with that.
But, yeah, I figured the opamp input impedence would be high, thus suitable. Well, actually, the initial idea came off a Grenader circuit from his old site -- but then his idea didn't seem to work out when bread-boarding, but a bit of swapping and I came up with this simple way..
I oughta check the current draw too.. They're not hi-effic LEDs unfortunately.. And, hey, the flash a bit when passing audio through - and did a quick bit of feedback cross-routing and got them flashing a-rhythmic crazy!
Tomorrow I will play (gotta practice) and will try to do some YouTubes too.. Mmm, flashing lights.
(making a touch-controller / wierdy modulation router tomorrow that'll also be benefiting from these bi-directional leds)
http://www.bugbrand.co.uk
prophei
PostPosted: Tue Jul 10, 2007 7:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
any more of these around? Very Happy
prophei
PostPosted: Tue Jul 10, 2007 7:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
Tim Servo
PostPosted: Tue Jul 10, 2007 8:13 pm    Post subject: TH-201 "Mankato" PCBs available
Subject description: Any more?
Hey Del,
Yeah, a whole new batch of Mankato PCBs are on their way as we speak. I ordered a pretty big batch, and there are still over a dozen left 'unreserved.' I'll have to order another batch before too long I think
Smile
I did make a few changes to this new batch, so I guess we'll call them Rev03s. I moved the silkscreen legends on the output connectors so they're easier to see when the connectors are installed, and I turned the output connectors around so the orientation is consistent (like the DotCom layout). None of this will matter if you don't use the .100 MTA connectors or you wire directly to the board (the proper connector wiring is shown in the documentation for each board). Electrically, the Rev02 and Rev03 boards are exactly the same.
Anyway, yes, there's a few left out of the next shipment. We take PayPal at magsmoke@gmail.com Thanks!
Tim (moving the silkscreen? yeah, I'm a perfectionist) Servo
numbernone
PostPosted: Thu Jul 12, 2007 10:55 am    Post subject: Reply with quote  Mark this post and the followings unread
My pair of Mankati just arrived...these are seriously NICE boards.
Nice nice nice work!!!
Cant wait for what comes next.
Tim Servo
PostPosted: Thu Jul 12, 2007 12:19 pm    Post subject: TH-201 "Mankato" PCBs available
Subject description: Mankati are arriving
Thanks! glad you like them. I put a lot of effort into making the layout clean (ALWAYS lay down the power tracks first, then all the other stuff), and using nice thick tracks. I'm also diggin' the legibility of the white silkscreen on the blue soldermask. Hopefully you'll like the finished product just as much Wink
BTW, we ordered a big batch of boards this month (due to arrive in about a week) and they're sold out already! We have to order ANOTHER batch and hopefully we'll have these in stock around the beginning of August. If you've placed an order early enough to get in on the "July" batch, you should have received an email from Magic Smoke confirming this. If you have questions, shout out to John or myself at MSE.
What's next? AS21C and a 566 VCO PCB to go along with Thomas' 566 book and some other stuff. Smile
Thanks again to everyone!
Tim (the short half of MSE) Servo
PostPosted: Thu Jul 12, 2007 12:44 pm    Post subject: Re: TH-201 "Mankato" PCBs available
Tim Servo wrote:
What's next?
That TH synth for the 21st century?!? Razz Very Happy Wink
ACHTUNG!
Tim Servo
PostPosted: Thu Jul 12, 2007 2:56 pm    Post subject: Re: TH-201 "Mankato" PCBs available
v-un-v wrote:
Tim Servo wrote:
What's next?
Sorry, I got carried away with our acronyms. "AS21C" is the term we're using for Thomas' new book "An Analog Synthesizer for the 21st Century." Smile That'll be out this month.
Tim (should be carried away) Servo
PostPosted: Thu Jul 12, 2007 3:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
and an accompanying PCB?? Wink Very Happy
ACHTUNG!
Tim Servo
PostPosted: Thu Jul 12, 2007 3:40 pm    Post subject: TH-201 "Mankato" PCBs available
Subject description: What's next?
Oh yeah, I'm already working on an AS21C LFO PCB. (you'd think I was making alphabet soup)
Anyway, yes, we're working on the PCBs, although those won't be ready when the book premiers later this month!
Tim (great, now I'm hungry for soup) Servo
fluxmonkey
PostPosted: Fri Aug 03, 2007 4:53 pm    Post subject: Re: TH-201 "Mankato" PCBs available
any updates? i was in line for a couple from the second batch (projected for the middle of last month?) but haven't heard...
bbob
para
PostPosted: Fri Aug 03, 2007 6:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
me too, i even received a confirmation that i made it in that batch?
steven
Tim Servo
PostPosted: Fri Aug 03, 2007 8:50 pm    Post subject: TH-201 "Mankato" PCBs available
Subject description: When?
steven
Hi Steven and everybody else!
We've been shipping Mankato PCBs, and all of the boards in the current batch will be shipped by this weekend. If you've received a confirmation that you got in on the current batch of boards, you should get your board(s) within a week or so. The next batch of boards is on the way, so we'll send a confirmation for that batch soon.
Thanks to everybody who has ordered, we're approaching selling 100 boards! Please yell at us if you have any questions or want more info.
Tim (got my shipping dept. hat on) Servo
para
PostPosted: Sat Aug 04, 2007 4:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
cool
guitarfool
PostPosted: Mon Aug 06, 2007 5:18 pm    Post subject: Re: TH-201 "Mankato" PCBs available
Woo - got my 2 Mankato boards today!
Umm, is there any documentation to go with them? Shocked
para
PostPosted: Mon Aug 06, 2007 5:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
me too. easily thee most beautiful boards i have ever seen. they look like you polished them. too bad they will live behind a panel.
and yes, no docs? is there a .pdf link i missed
steven
kryptic
PostPosted: Mon Aug 06, 2007 6:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Me three. Arrived today and they look great! Smile
philpeery
PostPosted: Mon Aug 06, 2007 8:49 pm    Post subject: Mankato! Reply with quote  Mark this post and the followings unread
My four beautiful blue boards arrived today as well! Can't wait to start building! I have the parts list, but don't seem to be able to find the doc for the project. Did I miss a post???
Phil
Tim Servo
PostPosted: Mon Aug 06, 2007 10:39 pm    Post subject: Re: Mankato!
Subject description: What's up, docs?
Phil
Hi Everyone! Glad you like the boards. Part of the "polished" look might be the fact that I've run a protective ground plane over most of the board. It's a little extra shielding, it makes the board a bit stiffer, and it looks kinda cool too. Wink I also like the blue color, as I feel it gives better contrast and makes the silkscreen easier to read.
Documentation for Rev03 boards goes out tonight! I've just finished checking the doc package and all customers will get an email.
Thanks again and again to everyone who has grabbed a board (or four!). More boards are on their way, and will be here next week! Also, I'll be at the Nor Cal AH meeting (Sunday, September 9th @ "21 Grand" in Oakland) with a few Mankati to play with, some TH books and some blank PCBs to sell. As always, give a shout out to magsmoke@gmail.com if you have ANY questions, problems, complaints, suggestions, donations, etc.
Cheers!
Tim (Mankateer) Servo
endif
PostPosted: Tue Aug 07, 2007 7:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, there's docs too? Sweet. =]
My magnificent blue slab arrived a few days ago, and I'm currently knee deep in building it, just gotta find me a 2k tempco.. pesky things.
~ !J!
http://www.endif.org
http://www.crunchpod.com
http://www.myspace.com/endif
Dan Lavin
Audio files: 21
PostPosted: Wed Aug 08, 2007 11:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Thomas Henry,
If you are out there........
I'm also a 19" rack panel head. Have you designed a 19" rack panel for the Mankato filter? I'd be curious to see your design as I imagine others on the forum would. Gotta milk as much input before you're back to class!
bambam
PostPosted: Wed Aug 08, 2007 6:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wow 4 days to get my pcbs to oz Wink great looking boards!
I was wondering has anyone bought ssm2164's that they might want to onsell? am having trouble finding them in australia so figured id ask. happy to pay airmail of course and have paypal.
cheers
Bertt
bambam
PostPosted: Wed Aug 08, 2007 7:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi tim
Is it essential to use the polystyrene caps or are there other options? I'm guessing not as they are in a critical area but if i dont have to order them it would be great as i have pretty much everything else.
cheers
Brett
Tim Servo
PostPosted: Thu Aug 09, 2007 1:15 am    Post subject: TH-201 "Mankato" PCBs available
Subject description: Polystyrene caps
bambam wrote:
Hi tim
cheers
Brett
Hey Brett,
Polystyrene caps are used in most VCO and VCF designs primarily because of their temperature stability. They're also very resistant to humidity, so they are very consistent over a wide range of conditions. You can use other types of caps, but the performance will suffer. Next best choice would probably be polyester, and then mylar or other "film" caps. Worst would be ceramic. Ceramic disk caps are fine for decoupling and other non-critical tasks, but shouldn't be used for frequency setting caps.
BTW, Magic Smoke is working on a purchase of tempcos and 2164 chips, so we'll be able to supply those parts soon!
Happy soldering!
Tim (also resistant to humidity, but not as stable) Servo
