TH-201 "Mankato" PCBs available
Page 4 of 7 [156 Posts]
Tim Servo
PostPosted: Wed Aug 22, 2007 6:23 pm    Post subject: TH-201 "Mankato" PCBs available
Subject description: Face panels?
Hi All,
I know this subject has come up a few times, but we have a new source for face panels and so I'm trying to gauge how many people will be interested. Initially, I'm thinking of getting a 4.5" wide Frac panel made for the "Full Boat" 8-output Mankato. These will be .093" anodized black aluminum with white silkscreen lettering and will go for about $30. We may offer a discount for pre-orders (lead time about 4 weeks), but we're still pondering that. Maybe depends on if enough people really want one. I've attached a low-res version of the artwork so you can get an idea what is on the panel. We're also working on a PCB mount bracket that attaches to the face panel. This will be a "universal" bracket that could be used with any 4.5" Frac panel. It should be about $10, but I don't have a firm price on that one yet.
So... anyone interested?
TH-201/8 Frac Panel
 Filesize:  110.85 KB
 Viewed:  481 Time(s)
PostPosted: Wed Aug 22, 2007 6:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
No dotcom panel in the works yet? Shocked Laughing
Please
Flickr
Tim Servo
PostPosted: Wed Aug 22, 2007 10:11 pm    Post subject: TH-201 "Mankato" PCBs available
Subject description: Panels panels panels
Please
Actually, I have played around a bit with DotCom and MOTM style layouts. If there's enough demand, I'd love to have a "large format" face panel. Here's a real rough shot at a DotCom panel. I haven't quoted on this one yet, so my guess would be $30 to $40. Thoughts?
Tim (just call me "The Panelist") Servo
Proposed Mankato DotCom panel
 Filesize:  120.92 KB
 Viewed:  496 Time(s)
Photon
PostPosted: Thu Aug 23, 2007 6:00 am    Post subject: Reply with quote  Mark this post and the followings unread
I based my panel legends on the rendering at the Magic Smoke site. So my outputs are:
0˚/12dB, 90˚/24 dB, 180˚/-24˚ dB, & 270˚/-12 dB. This doesn't jive with what your showing above Sad . My panel has been etched and is a done deal. Do I need to consider a second go at it?
thanks
Peter
Freq Out
o---------------<>---------------o
flickr
numbernone
PostPosted: Thu Aug 23, 2007 9:48 am    Post subject:
Subject description: WHAT?? where is my trimmer?!?
Assembled the Mankato PCB last night, found that I was shorted my 500 ohm trimmers for the V/Oct. While I am anxious and cant wait for the replacement to show up, which is my best temporary alternative, keeping in mind that the scaling is not of deadly importance right away.
1. Cobble a resistor somewhere around 250 ohms and toss it in for now.
2. Use a 1K multi turn and dial it down to the first 5 turns.
3. If I am just being an idjut, feel free to toss your rotten tomatoes on 3...2...1...
Thanks!!
Tim Servo
PostPosted: Thu Aug 23, 2007 9:14 pm    Post subject: TH-201 "Mankato" PCBs available
Thanks!!
Hey Number,
Actually, I'd recommend changing R42d to 200k and the v/oct trimmer (R43) to a 1k. Makes setting the response easier (this change is in the Rev03 parts list). Also, don't forget to check across a range of frequencies when adjusting the Resonance trim. Set the trimmer too high and the sine from the 6dB output will distort; set it too low and the Mankato will stop oscillating at lower frequencies. Luckily, the "middle ground" is pretty easy to find. Hope this helps!
Tim (normally has rotten tomatoes tossed AT him) Servo
Tim Servo
PostPosted: Thu Aug 23, 2007 10:06 pm    Post subject: TH-201 "Mankato" PCBs available
Subject description: Photon's Phases
thanks
Peter
Hey Peter,
Unfortunately, the render on the Magic Smoke site is very old and doesn't have the output phases right. I really feel bad about that. What you want is
0° / -12dB
90° / -24dB
180° / 12dB
270° / 24dB
I'll see if I can re-render that image and have John update the image. Sorry about that.
Tim (buggered one up) Servo
SolderSmoke
PostPosted: Thu Aug 23, 2007 11:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
I miss my PCB.
Tim Servo
PostPosted: Thu Aug 23, 2007 11:34 pm    Post subject: TH-201 "Mankato" PCBs available
Subject description: Your PCB
SolderSmoke wrote:
I miss my PCB.
Hey Solder,
It'll be on it's way to you by this weekend. Just got them in, so we're checking them and packing them up to go winging their way around the world!
Tim (bringing PCBs and their owners together since 2007) Servo
SolderSmoke
PostPosted: Fri Aug 24, 2007 5:34 am    Post subject: Reply with quote  Mark this post and the followings unread
I´m already drooling!!! Very Happy
PostPosted: Mon Aug 27, 2007 2:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
just finished wiring up my mankato. powered it up on the workbench and: hey, what a nice creature has come to live? love on the very first sight.
thank you thomas, thank you tim. great work.
i hooked it up to the PS3100 resonators and i think this is what they have waited for!kiss
i then tried the audiorange. mixed different outputs and was surprised by the different timbres. will have to check them on the scope these days.
finally used the mankato as a filter for the sn voice modulated by the baby10 seq and that even sounded very nice, due to the range, and due to the nice sounding resonance, i guess.
3in1 transformer and i am happy...
PostPosted: Tue Aug 28, 2007 1:37 am    Post subject: Reply with quote  Mark this post and the followings unread
my eurorack front panel (schaeffer) will arrive this week.
i decided to have all outputs and omitted some of the inputs...
janvanvolt
PostPosted: Tue Aug 28, 2007 8:53 am    Post subject: Reply with quote  Mark this post and the followings unread
i am 80% done with the mankato soldering; i got my frontpanel already done.
more pics here
fluxmonkey
PostPosted: Tue Aug 28, 2007 10:36 am    Post subject: Re: TH-201 "Mankato" PCBs available
Tim Servo wrote:
Hi All,
my $.02 on the layout: much as i like having controls visually associated to their jacks, i'd much prefer to move the inputs down below the controls... otherwise the patchcords interfer with the knobs. also, what' that little hash-thingy above the coarse control? looks like a leftover section of a serge swoosh.
all that said, i would probably buy at least one. yay frac!
bbob
kryptic
PostPosted: Tue Aug 28, 2007 11:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I would also be interested in at least one frac panel.
etaoin
PostPosted: Tue Aug 28, 2007 12:13 pm    Post subject: Re: TH-201 "Mankato" PCBs available
Like my Rev 01 Mankato Frac panel Wink
http://electro-music.com/forum/post-126821.html#126821
http://www.casia.org/modular/
fluxmonkey
PostPosted: Tue Aug 28, 2007 12:55 pm    Post subject: Re: TH-201 "Mankato" PCBs available
yes! very elegent solution....
PostPosted: Tue Aug 28, 2007 10:46 pm    Post subject: Re: TH-201 "Mankato" PCBs available
bbob wrote:
..., what' that little hash-thingy above the coarse control? looks like a leftover section of a serge swoosh.
it indicates the audio range...
Tim Servo
PostPosted: Fri Aug 31, 2007 1:01 pm    Post subject: Re: TH-201 "Mankato" PCBs available
bbob wrote:
Tim Servo wrote:
Hi All,
bbob
Hey BBob (and others),
I kind of see your reasoning for wanting the patch points at the bottom of a module, but once you have more than one row of modules, the cords drape over the modules below anyway. I was thinking of making up something that would go between module rows and act a little like the "finger" racks that many labs use to store test leads. The rack would keep the cords from draping below, and even allow you to keep cords at the top of a module from draping over the module (by wrapping the cords over the rack above). Kinda hard to explain...
ANYway, so I've been thinking of alternate layouts. I love the layout that STG Sound Labs has done (I'll have some of those to show at the AH Cali show and I'll probably end up getting one for myself), but I'm trying to come up with a "Magic Smoke" style that will also be consistent across several different module types. To that end, I present the first annual MSE Mankato Beauty Pageant. Wink The attached pic shows three different layouts. Starting at the left, the first is the present ARP-inspired layout. I really like this one, even with the patchcord drape problem. It's pretty easy to understand, it's logical (at least to me) and it is very easy to make it consistent across different types of modules.
The layout to the far right is copied from our own Etaoin. It's a nice, compact layout, and the grouping is very clean and consistent. The "jack field" is a little crowded, but this shouldn't be a problem in most cases (very rarely would you use all eight outs and the inputs simulataneously). I like this one too, but I think this one isn't as easy to adapt to other modules.
In the middle we have sort of a "hybrid" approach. The love child of the far left and the far right (it should run for Congress, but that's another story). This one appeals to me in that it more consistently groups the jacks and the associated attenuators / modifiers. The outputs are kept away from the audio and FM inputs, and having the outputs on the right edge cuts down on (practically eliminates) the patchcord drape problem. I think this layout can be fairly easily adapted to other types of modules, and I also think it looks good. Almost has a Moog-ish look to it. Sort of.
Of course, the finished panels would be black anodized with white silkscreen legends.
And the judges say... ?
Oh, and the "swoosh" mark is a racing stripe. It makes the Mankato go faster (adds about 25MPH to the top end). Seriously? Okay, Fonink is right, it roughly indicates the Audio Range.
Thanks as always for everybody's feedback!
Tim (goes faster by loosing hair and becoming more aerodynamic) Servo
(cue Rod Serling voice) Submitted for your approval... More Mankato panels from the Servo Zone
 Filesize:  205.76 KB
 Viewed:  522 Time(s)
suitandtieguy
PostPosted: Sat Sep 01, 2007 3:13 am    Post subject: Re: TH-201 "Mankato" PCBs available
Tim Servo wrote:
the "swoosh" mark is a racing stripe. ... It roughly indicates the Audio Range.
i _did_ try to incorporate that in my layout, however when i implemented it the already busy coarse tuning region on my highly-literal layout became a complete mess.
i do think it's a good idea though, and i'm glad you worked it into your layouts.
fluxmonkey
PostPosted: Sat Sep 01, 2007 12:48 pm    Post subject:
Subject description: mankato beauty pagent
i like the addition of the ac/dc swithches on the new layouts.
a big plus of the right-most design is the additional room between pots. blacet is able to space his pots very tight vertically, because there's plenty of room to the sides, so you can still get your fingers in there.
only downside is the one 1v/oct input jack that is visually associated w/ the outputs... but as they say "consistancy is the hobgobblin of small minds" (my own included)...
thanks for playing around with these...
b
Coriolis
PostPosted: Sun Sep 02, 2007 7:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Tim, just wanted to hear if you've started shipping the latest run of boards?
C
Tim Servo
PostPosted: Sun Sep 02, 2007 12:20 pm    Post subject: TH-201 "Mankato" PCBs available
Subject description: has it shipped yet?
C
Hey C,
Your board (and six tempcos) have shipped and should be to you sometime this week or early next. Monday is a holiday in the US, so that may slow things a teeny bit, but you should be getting your stuff soon! Thanks!
Tim (always a little slow on holidays) Servo
fluxmonkey
PostPosted: Sun Sep 02, 2007 1:22 pm    Post subject:
Subject description: mouser-importable BOM
I had to fiddle a bit to extract Mouser part numbers from the PDF BOM... figured I'd save you the trouble... you should be able to copy this list and past it directly into mousers BOM tool...
581-BQ014D0224J 3
140-50N5-100J-RC 6
23PS156 4
23PS133 4
140-HTRL35V10-RC 2
140-50Z5-103M-RC 10
1N4148-TR 1
512-1N4001 2
595-TL074BCN 2
595-TL072BCP 2
271-100K-RC 12
271-7.5K-RC 1
271-30K-RC 8
271-510-RC 4
271-49.9K-RC 1
271-1K-RC 9
271-66.5K-RC 1
271-2.7K-RC 1
271-2K-RC 1
271-137K-RC 1
271-47K-RC 3
271-18K-RC 1
271-150K-RC 1
271-200K-RC 2
291-3.3M-RC 1
313-1210F-100K 9
72-T93YB-10K 1
72-T93YB-1K 1
527-3006-25V50/60C 2
16PJ012 15
108-0001-EVX 3
535-08-3518-10 2
535-14-3518-10 2
535-16-3518-10 1
571-6404562 17
571-6404563 11
571-6404566 1
571-6445632 17
571-6445633 11
571-6445636 1
note that there are a couple of additional items (like the ssm 2164) that are not available from mouser, you'll need to source them elsewhere.
b
Tim Servo
PostPosted: Sun Sep 02, 2007 2:43 pm    Post subject: TH-201 "Mankato" PCBs available
<snip>
b
Hey Bbob,
Nice work! However, I've got the original BOM as an Excel spreadsheet and I'll post that here if anybody still needs it. From that, you'll be able to extract whatever info you need. Interest?
Tim (the Infonator) Servo
