Tim Servo
Joined: Jul 16, 2006 Posts: 924 Location: Silicon Valley
Posted: Thu Jul 05, 2007 2:32 pm Post subject:
Subject description: LED Drivers |
bugbrand wrote: | ..is this right for BiColour Leds? |
Hey Tom,
Sorry, made my last message before I saw your schemo.
I'm pretty sure this will work okay. The impedance of the non-inverting input on an 074 (or just about any FET input op amp) is pretty high, so you shouldn't be pulling too much current off the Mankato. You can also experiment with a higher value current-limiting resistor. Try 2K or even 4.7K and see if you still get nice status lights.
The biggest test would be to run this for a while at a high frequency and make sure that the Mankato's ICs don't get hot. ICs 1 and 3 (the 074s) are the output buffers. They may be a bit warm (should be just barely noticeable) but hot means that too much current is being pulled.
Thanks for sharing. Now we need a YouTube video with blinky lights and multi-modulation going on
Tim (not the brightest blinky light) Servo |
bugbrand
Posted: Thu Jul 05, 2007 3:14 pm Post subject:
Hey thanks Tim - thats some good advice, especially the 'trying-it-fast' - > I'll have a go with that.
But, yeah, I figured the opamp input impedence would be high, thus suitable. Well, actually, the initial idea came off a Grenader circuit from his old site -- but then his idea didn't seem to work out when bread-boarding, but a bit of swapping and I came up with this simple way..
I oughta check the current draw too.. They're not hi-effic LEDs unfortunately.. And, hey, the flash a bit when passing audio through - and did a quick bit of feedback cross-routing and got them flashing a-rhythmic crazy!
Tomorrow I will play (gotta practice) and will try to do some YouTubes too.. Mmm, flashing lights.
(making a touch-controller / wierdy modulation router tomorrow that'll also be benefiting from these bi-directional leds) _________________ http://www.bugbrand.co.uk
prophei
Joined: Jan 27, 2007 Posts: 234 Location: san francisco, ca
Posted: Tue Jul 10, 2007 7:34 pm Post subject:
any more of these around?  |
prophei
Posted: Tue Jul 10, 2007 7:35 pm Post subject:
Tim Servo
Posted: Tue Jul 10, 2007 8:13 pm Post subject:
TH-201 "Mankato" PCBs available Subject description: Any more? |
prophei wrote: | any more of these around?  |
Hey Del,
Yeah, a whole new batch of Mankato PCBs are on their way as we speak. I ordered a pretty big batch, and there are still over a dozen left 'unreserved.' I'll have to order another batch before too long I think
I did make a few changes to this new batch, so I guess we'll call them Rev03s. I moved the silkscreen legends on the output connectors so they're easier to see when the connectors are installed, and I turned the output connectors around so the orientation is consistent (like the DotCom layout). None of this will matter if you don't use the .100 MTA connectors or you wire directly to the board (the proper connector wiring is shown in the documentation for each board). Electrically, the Rev02 and Rev03 boards are exactly the same.
Anyway, yes, there's a few left out of the next shipment. We take PayPal at magsmoke@gmail.com Thanks!
Tim (moving the silkscreen? yeah, I'm a perfectionist) Servo |
numbernone
Joined: Aug 16, 2006 Posts: 477 Location: new york city
Posted: Thu Jul 12, 2007 10:55 am Post subject:
My pair of Mankati just arrived...these are seriously NICE boards.
Nice nice nice work!!!
Cant wait for what comes next. |
Tim Servo
Posted: Thu Jul 12, 2007 12:19 pm Post subject:
TH-201 "Mankato" PCBs available Subject description: Mankati are arriving |
numbernone wrote: | My pair of Mankati just arrived...these are seriously NICE boards.
Thanks! glad you like them. I put a lot of effort into making the layout clean (ALWAYS lay down the power tracks first, then all the other stuff), and using nice thick tracks. I'm also diggin' the legibility of the white silkscreen on the blue soldermask. Hopefully you'll like the finished product just as much
BTW, we ordered a big batch of boards this month (due to arrive in about a week) and they're sold out already! We have to order ANOTHER batch and hopefully we'll have these in stock around the beginning of August. If you've placed an order early enough to get in on the "July" batch, you should have received an email from Magic Smoke confirming this. If you have questions, shout out to John or myself at MSE.
What's next? AS21C and a 566 VCO PCB to go along with Thomas' 566 book and some other stuff.
Thanks again to everyone!
Tim (the short half of MSE) Servo |
Posted: Thu Jul 12, 2007 12:44 pm Post subject:
Re: TH-201 "Mankato" PCBs available Subject description: Mankati are arriving |
Tim Servo wrote: |
What's next? |
That TH synth for the 21st century?!?  _________________ ACHTUNG!
Tim Servo
Posted: Thu Jul 12, 2007 2:56 pm Post subject:
v-un-v wrote: | Tim Servo wrote: |
What's next? |
That TH synth for the 21st century?!?  |
Sorry, I got carried away with our acronyms. "AS21C" is the term we're using for Thomas' new book "An Analog Synthesizer for the 21st Century." That'll be out this month.
Tim (should be carried away) Servo |
Posted: Thu Jul 12, 2007 3:07 pm Post subject:
and an accompanying PCB??  _________________ ACHTUNG!
Tim Servo
Posted: Thu Jul 12, 2007 3:40 pm Post subject:
TH-201 "Mankato" PCBs available Subject description: What's next? |
v-un-v wrote: | and an accompanying PCB??  |
Oh yeah, I'm already working on an AS21C LFO PCB. (you'd think I was making alphabet soup)
Anyway, yes, we're working on the PCBs, although those won't be ready when the book premiers later this month!
Tim (great, now I'm hungry for soup) Servo |
fluxmonkey
Posted: Fri Aug 03, 2007 4:53 pm Post subject:
Tim Servo wrote: | BTW, we ordered a big batch of boards this month (due to arrive in about a week) and they're sold out already! We have to order ANOTHER batch and hopefully we'll have these in stock around the beginning of August. If you've placed an order early enough to get in on the "July" batch, you should have received an email from Magic Smoke confirming this. If you have questions, shout out to John or myself at MSE.
any updates? i was in line for a couple from the second batch (projected for the middle of last month?) but haven't heard...
bbob |
para
Posted: Fri Aug 03, 2007 6:54 pm Post subject:
me too, i even received a confirmation that i made it in that batch?
steven |
Tim Servo
Posted: Fri Aug 03, 2007 8:50 pm Post subject:
TH-201 "Mankato" PCBs available Subject description: When? |
para wrote: | me too, i even received a confirmation that i made it in that batch?
steven |
Hi Steven and everybody else!
We've been shipping Mankato PCBs, and all of the boards in the current batch will be shipped by this weekend. If you've received a confirmation that you got in on the current batch of boards, you should get your board(s) within a week or so. The next batch of boards is on the way, so we'll send a confirmation for that batch soon.
Thanks to everybody who has ordered, we're approaching selling 100 boards! Please yell at us if you have any questions or want more info.
Tim (got my shipping dept. hat on) Servo |
para
Posted: Sat Aug 04, 2007 4:47 pm Post subject:
cool |
guitarfool
Posted: Mon Aug 06, 2007 5:18 pm Post subject:
Re: TH-201 "Mankato" PCBs available Subject description: When? |
Tim Servo wrote: | Please yell at us if you have any questions or want more info.
Woo - got my 2 Mankato boards today!
Umm, is there any documentation to go with them?  |
para
Posted: Mon Aug 06, 2007 5:40 pm Post subject:
me too. easily thee most beautiful boards i have ever seen. they look like you polished them. too bad they will live behind a panel.
and yes, no docs? is there a .pdf link i missed
steven |
kryptic
Posted: Mon Aug 06, 2007 6:17 pm Post subject:
Me three. Arrived today and they look great!  |
philpeery
Joined: Nov 08, 2006 Posts: 137 Location: new jersey, usa
Posted: Mon Aug 06, 2007 8:49 pm Post subject:
Mankato! |
My four beautiful blue boards arrived today as well! Can't wait to start building! I have the parts list, but don't seem to be able to find the doc for the project. Did I miss a post???
Phil |
Tim Servo
Posted: Mon Aug 06, 2007 10:39 pm Post subject:
Re: Mankato! Subject description: What's up, docs? |
philpeery wrote: | My four beautiful blue boards arrived today as well! Can't wait to start building! I have the parts list, but don't seem to be able to find the doc for the project. Did I miss a post???
Phil |
Hi Everyone! Glad you like the boards. Part of the "polished" look might be the fact that I've run a protective ground plane over most of the board. It's a little extra shielding, it makes the board a bit stiffer, and it looks kinda cool too. I also like the blue color, as I feel it gives better contrast and makes the silkscreen easier to read.
Documentation for Rev03 boards goes out tonight! I've just finished checking the doc package and all customers will get an email.
Thanks again and again to everyone who has grabbed a board (or four!). More boards are on their way, and will be here next week! Also, I'll be at the Nor Cal AH meeting (Sunday, September 9th @ "21 Grand" in Oakland) with a few Mankati to play with, some TH books and some blank PCBs to sell. As always, give a shout out to magsmoke@gmail.com if you have ANY questions, problems, complaints, suggestions, donations, etc.
Cheers!
Tim (Mankateer) Servo |
endif
Dan Lavin
Joined: Nov 09, 2006 Posts: 649 Location: Spring Lake, Mi, USA
Audio files: 21
Posted: Wed Aug 08, 2007 11:59 am Post subject:
Thomas Henry,
If you are out there........
I'm also a 19" rack panel head. Have you designed a 19" rack panel for the Mankato filter? I'd be curious to see your design as I imagine others on the forum would. Gotta milk as much input before you're back to class! |
bambam
Posted: Wed Aug 08, 2007 6:49 pm Post subject:
Wow 4 days to get my pcbs to oz great looking boards!
I was wondering has anyone bought ssm2164's that they might want to onsell? am having trouble finding them in australia so figured id ask. happy to pay airmail of course and have paypal.
cheers
Bertt |
bambam
Posted: Wed Aug 08, 2007 7:58 pm Post subject:
Hi tim
Is it essential to use the polystyrene caps or are there other options? I'm guessing not as they are in a critical area but if i dont have to order them it would be great as i have pretty much everything else.
cheers
Brett |
Tim Servo
Posted: Thu Aug 09, 2007 1:15 am Post subject:
TH-201 "Mankato" PCBs available Subject description: Polystyrene caps |
bambam wrote: | Hi tim
cheers
Brett |
Hey Brett,
Polystyrene caps are used in most VCO and VCF designs primarily because of their temperature stability. They're also very resistant to humidity, so they are very consistent over a wide range of conditions. You can use other types of caps, but the performance will suffer. Next best choice would probably be polyester, and then mylar or other "film" caps. Worst would be ceramic. Ceramic disk caps are fine for decoupling and other non-critical tasks, but shouldn't be used for frequency setting caps.
BTW, Magic Smoke is working on a purchase of tempcos and 2164 chips, so we'll be able to supply those parts soon!
Happy soldering!
Tim (also resistant to humidity, but not as stable) Servo |
