Thomas Henry Keyboard & sMs Integrated Keyboard Controller
Page 6 of 8 [182 Posts]
PostPosted: Fri Aug 03, 2007 3:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just for the record, I want to make it perfectly clear that the Fatar group buy suggested by me on page one of this thread is not the same as the Randaleem Fatar group buy. This means that the Randaleem Fatar group buy is not an official electro-music.com community project. I don´t know who Randaleem is, I don´t know where he lives and I wouldn´t know anyone who knows him privately. Randaleem is representing a startup synth manufacturing business I know nothing about. If he wants to sell Fatar mechanisms really cheap, then that´s perfectly OK. This also means that all things Randaleem Fatar group buy should be associated with with his yahoo.com email addie and not the with any of the admins here and certainly not me. Even though I did make a Fatar group buy suggestion at the start of the thread, the current Randaleem Fatar group buy is not it. Will there be an electro-music.com Fatar initiative? I certainly cannot promise that and I wouldn´t completely write it off. Time will tell.
I am making this clear, not in order to make problems for Randal, but rather because I´m getting a fair number of PMs re this group buy from members who think this is my project off page 1 of this thread.
Flickr
PostPosted: Fri Aug 03, 2007 6:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well said, and tactfully written. Thanks very much for that clarification. It clears things up for me Very Happy Now, on to the original business of this thread, however, it was fun to see it get derailed and OT, but only for a little while.
Very Happy Very Happy Very Happy
PostPosted: Sat Aug 04, 2007 9:19 am    Post subject: Reply with quote  Mark this post and the followings unread
Bill, that´s right.. there will be no more diversions in here. Very Happy
elephant
Flickr
PostPosted: Sun Aug 05, 2007 7:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Your good in my book brother Cool Cool Cool
BTW, new developments in the keyboard design arena .... stayed tuned ....
Bill
Dan Lavin
Audio files: 21
PostPosted: Tue Aug 21, 2007 1:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well folks, it's been a little while since the last update, so here goes:
The basic digital and analog portion of the design are complete. We did "clean up" the back end of the analog part as the result of me wiring a bad FET in. Don't worry, it is still very much in keeping with TH designs.
Bill is working on the midi portion which will allow note-on/note-off, midi channel selection and velocity control 0-127...although on a pot, not a true velocity sensitive kbd. Now remember, Bill is a very busy man between the UD-1 kits and the big black hole known as Klee, etc., so "patience" is the word now.
The pcb is about 80% done. Right now it is about 2.75" X 4.50" (70mm X 114mm), although the long dimension may have to get stretched a little bit....we'll see.
Now we've hit a snag because someone fried out the only working CPLD we had before samples could be recorded. Embarassed Bill will be forwarding a new one shortly (probably along with his invoice!). Of all the parts to toast! Mad
Anyway, as soon as the new CPLD arrives, I'll record some samples of the prototype controlling a SN-Voice so the group can get an idea of its operation.
PostPosted: Wed Aug 29, 2007 4:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just to add to Antman's update. I have finished blocking out the MIDI circuitry and it's associated clock generator today and starting the design entry process this weekend. As Antman said, it will output MIDI NOTE ON/OFF messages to control digital gear, the associated note number of the encoded key, and standard 127 level MIDI velocity data. The user will have the option of selecting MIDI channel numbers 1 to 16 upon which to transmit on.
The Velocity A/D chip has been selected and breadboarded with success. The chip used is a ADC0804 and used in a free running configuration and sampling a velocity potentiometer at 5.5 Ksps. More than enough. Very Happy
Each time a key is pressed on this controller, the proper CV will be output by the analog section as well as a standard 3-Byte MIDI NOTE ON message to control digital gear. When a key is released, the MIDI interface shall output the standard 3-Byte MIDI NOTE OFF message with a corresponding velocity of "0".
So, the project is moving along ! Very Happy Very Happy
and YES, Antman is doing a really fantastic job on a spiffy two sided printed circuit board !!! No worries about big IC's to solder either even though the CPLD is 84 pins. A through hole 84 pin socket, with 0.1" spaced pins, is being used and the CPLD chip will just snap into place. Cool
Bill
tomcat
PostPosted: Sun Sep 02, 2007 3:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Some silizium left? Would be nice if the Midi IF gets inputs for two pots, so pitchbend and mod can be implemented. Not a necessarity, but ... Wink
PostPosted: Sun Sep 02, 2007 4:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
That is a nice idea. When I started this project, it was just a challenge to myself to stuff the TH design in a programmable logic device. The device I chose would be more than sufficient for the job at that time. Then a couple other things were added along including the MIDI interface. Unfortunately due to hardware resource issues using the device I chose, the MIDI will be a simple implementation for NOTE ON and OFF messaging with a analog velocity input that would get digitized then sent to the PLD as the velocity data representation. In future generations though, I can port the logic to a larger FPGA and then keep building on that Very Happy Until then, the design, in this hardware configuration, will be frozen. Crying or Very sad
Here is a picture of my controller on my bench. I took it this morning after I added the A/D converter circuitry. It's almost fully populated !
Bill
 Filesize:  366.41 KB
 Viewed:  441 Time(s)
PostPosted: Thu Nov 15, 2007 4:35 am    Post subject: Reply with quote  Mark this post and the followings unread
i am still in the planning phase for my wildcat based performance synth. since it will be a performance synth it should incorporate a keyboard, i guess.
the fatar keyboard is diode matrix wired (two switches for each key):
diode matrix
i wonder if these diodes would do any harm used together with the TH keyboard controller circuit? if not, the fatar keyboard would be perfect.
Dan Lavin
Audio files: 21
PostPosted: Thu Nov 15, 2007 8:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Matthias,
The terminology is a little different. For TH's design, MK0, Mk1, MK2, etc. would be called row 1, row 2, row 3, etc. Then, T0, T1, T2 would be called Column1, column2, column3, etc. You would not use BR0, BR1, etc.
But to answer your question, the diodes are fine in that orientation. I had an old keyboard with the diodes reverse or the Fatar unit and those do not work, but you are fine with yours.
PostPosted: Thu Nov 15, 2007 11:12 am    Post subject: Reply with quote  Mark this post and the followings unread
antman49443 wrote:
Matthias,
yes, the terminology: whenever you press a key actually the BR (break) switch is closed first, then the MK (make). the delay one gets between the closing of both switches indicates the velocity. so one would use the BR switches, i think.
anyway. good news for me - thank you very much, mr antman.
Dan Lavin
Audio files: 21
PostPosted: Thu Nov 15, 2007 12:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Matthias:
Sorry, you are right. I was thinking of the first velocity kbds which used a rest buss bar that the circuit would break then the keyswitch would make contact with an active buss bar, like a SPDT switch. This is how the old D510/E510 midi keyboard chips worked. Fatar now uses 2 parallel switches with one closing before the other, like a DPST switch.
PostPosted: Thu Nov 15, 2007 5:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Glad there is some activity on this thread. I will be completing all the Klee parts orders by the weekend and I have got the "Integrated Keyboard Controller" board back up on the workbench Very Happy It's been a while and sorry for all the delay but I was real busy over the past couple of months Shocked
The base digital design is completed and now the enhancements are being designed in.
So, expect more activity over the next month with this project Very Happy
Bill
goodrevdoc
PostPosted: Fri Nov 16, 2007 10:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
Excellent news! I had almost given up the ghost on looking for a suitable keyboard. Glad to hear this project is still being pursued. Now, if I could only actually play the keyboards worth a hoot...
-justin
PostPosted: Sat Nov 17, 2007 5:06 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oh, you need to play those ..... Wink
Bill
PostPosted: Mon Nov 19, 2007 11:24 am    Post subject: Reply with quote  Mark this post and the followings unread
i just wanted to let you know that i ordered a fatar keyboard today. dieter doepfer sells them as spare parts so i had to pay something...
and then i am just curious about the controller...
PostPosted: Mon Nov 19, 2007 6:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK I spent time on Sunday designing in the MIDI engine in the keyboard controller and would have to say the design session was a success. One thing I feared after deciding to put a MIDI interface in this project was that I would run out of room in the CPLD before finishing completely. After about 3 hours of tweaking the device fitter properties I finally got the extra circuitry to fit with 99% macrocell utilization Shocked
The work is not done yet. I need to get the external 8-Bit A/D data into the device for the velocity portion of the message and the NOTE data, generated internally, into the message as well. I will need to pull off all the tricks in the book to get this to route to the right places in the chip.
The pictures shown here show the MIDI test setup consisting of a laptop computer with MIDI-OX software running in the role of MIDI data analyzer, a MIDI interface and the Keyboard Controller prototype.
Another photo shows a closeup of the controller with the MIDI connection to the interface.
The last photo shows a closeup of the data analyzer displaying the MIDI data coming from the controller as I simulate a pressing of a key with a jumper. The screen shows two message types. One is a NOTE ON event when the key is pressed and the other is a NOTE OFF event when the key is released. Each message consists of three bytes of data. The first byte of the message is the MIDI channel and message type (80h, 90h). Actually the "8" and "9" specify the message type and the "0" means MIDI channel 1. You want to consult the MIDI specification to refresh your memory of the MIDI word structure.
The second byte contains the NOTE number (08h) representing "G#" and the last byte contains the MIDI velocity, (55h). I hard coded a 32 bit message in the device just to prove out all the shifter logic and interface timing. I also wanted to prove out that the computer would recognize the data from the controller. It was a success as you can see. Cool
Things have worked quite well and now to put the real data onto the MIDI message. That will be my next session. Very Happy
My big fear is that I just wont be able to fit the rest into my device which means I will have to move it to the XC95144/256 instead of the 95108.
There about three other options of which I will discuss if I am not successful in fitting the remaining logic. I will see .....
Bill
 Filesize:  87.78 KB
 Viewed:  422 Time(s)
 Filesize:  90.84 KB
 Viewed:  383 Time(s)
 Filesize:  222.86 KB
 Viewed:  398 Time(s)
PostPosted: Wed Dec 05, 2007 10:21 am    Post subject: Reply with quote  Mark this post and the followings unread
I managed to fit everything into the XC95108 device without too much more trouble. I simplified the cloking logic that generates the keyscan and MIDI clocks. That left me enough room in the part to bring in the 8 bit A/D data and interrupt line for the velocity function, of which only 7 bits are actually used. The NOTE NUMBER data has also been successfully routed to the MIDI section via the chips I/O pins just in case someone wants to break into this data.
For now, the MIDI channel selection will be accomplished using a 4 position DIP switch with 4 bits representing the 16 MIDI channels for a single port.
After this goes through final checkout, the chips and parts will be shipped over to Antman for testing using his keyboard.
Bill
Dan Lavin
Audio files: 21
PostPosted: Wed Dec 05, 2007 3:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
State Machine,
I'll be ready to roll! I'll try it on a number of sound modules from Emu, Yamaha, Roland, etc. to look for any anomalies. Oh yeah, and the GM Voice as well!
PostPosted: Wed Dec 05, 2007 4:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Great, that would be very good. I know the MIDI functionality is a bit limited but hell, it's about the best that can be done due to limited resources in silicon. I will work tonight on the finishing touches as they say and then I will let you know when I am sending you the programmed parts.
Please let me know how much you want for the Yamaha board. I took a peek at the specifications and am very impressed with it's functionality.
Also, that keyboard you sent me, where can I find the sockets for the flex connectors on it?
I have attached a PDF of the functional block diagram of the MIDI portion of the design. I will describe the circuit more fully in the next post.
I will post more complete documentation on the project as you progress through the final stages of testing.
Thanks,
Bill
MIDI_ENGINE.pdf
 Filename:  MIDI_ENGINE.pdf
 Filesize:  35.13 KB
 Downloaded:  532 Time(s)
Audio files: 297
PostPosted: Wed Dec 05, 2007 4:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
It looks simple almost ...
... but indeed a little help to get into the details would be appreciated Very Happy
PostPosted: Thu Dec 06, 2007 2:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Your right. When I complete all the block diagrams of the entire chip, I will post and provide details. I am very sorry for the spotty technical details ....
Bill
PostPosted: Tue Dec 11, 2007 5:48 pm    Post subject: Reply with quote  Mark this post and the followings unread
The "Integrated Keyboard Controller" is working perfectly. I was controlling my Nord G2 Modular demo software synthesizer sending note scales and various velocities into it with no problems !!!! It's rock solid Cool The MIDI works spot on as they say and proves out the A/D converter interface and all the internal MIDI circuits ! I had also controlled my "Jack Dark" soft synthesizers with Abelton LIVE as "VSTi" host without any problems.
Last evening, I had to fit one last change in there because of a minor problem with note data capture in the MIDI section and I also stomped out a bug in the design that caused the "NOTE NUMBER" byte "2" MSB's (D6 and D7) to intermittently latch a logic "1"'s when they shouldn't have been! I cleaned that problem up with count truncation logic in the key scan state machine. Glad I caught that as this would have cause an intermittent "bad" note! I had to to modify the TRIGGER logic to produce a 2.5 millisecond pulse when a key is pressed just so I can gain some resources to fix these design issues.
I will send Dan "Antman" Lavins the new chips and he will do some testing for me. He will control some of his analog gear and his General MIDI sound modules that he and Thomas henry have been posting about. The results shall be reported.
After that, we will decide if and when a PC board will be done. One will most likely be developed. Very Happy The design will also be released to the DIY forum on this thread in case anyone wants to build one. It can easily be breadboarded as you can see from my photo. I will supply the JEDEC configuration file for the CPLD device or I can supply a programmed CPLD chip for a small cost if you don't want to get involved with the configuration.
More to come ! Very Happy
Bill
PostPosted: Wed Dec 12, 2007 2:53 am    Post subject: Reply with quote  Mark this post and the followings unread
wow!
that sounds amazing! i am really excited! thank you so much for your hard work.
Scott Stites
Audio files: 96
PostPosted: Wed Dec 12, 2007 3:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool
My Site
