Posted: Sat Sep 15, 2007 12:31 pm Post subject:
| Quote: | | bet that wire is the nice teflon insulated stuff, too, esp if your co does military work. Man, there's just nothing better on the face of this earth than that stuff, other than asparagus. |
asparagus .........
Yes, you got that right Scott. It's the teflon stuff. I love it also since the insulation does not creep up onto the wire when heating the stuff. Admittaly, you do need a good stripper (easy does it, not the dancing kind) to get the insulation off cleanly but its great to work with
I thankfully have access to spools of all different colors. The colors can encode various busses in a backplane when wiring.
Bill
[/quote] |
Scott Stites
Audio files: 96
THeff
Audio files: 33
Posted: Sat Sep 15, 2007 11:43 pm Post subject:
Samples from new Klee |
Wow Scott, Great Stuff!!!
I really like the last one with the CGS Toms. As you said it is amazing that all that sound is coming from a 16 stage shift register with 16 pots!
Keep the samples coming!
Regards,
Tim |
Posted: Sun Sep 16, 2007 4:44 am Post subject:
Very nice sample Scott.
I'm soooo looking forward to firing up my Klee. _________________ What makes a space ours, is what we put there, and what we do there. |
Posted: Sun Sep 16, 2007 5:38 am Post subject:
I reckon it looks fucking awesome Fonik! Extra screw heads and all!
BTW, if you want them to blend in more, you can get countersunk Phillips head screws in black, which would match the knobs etc. _________________ What makes a space ours, is what we put there, and what we do there. |
Posted: Sun Sep 16, 2007 7:02 am Post subject:
| Uncle Krunkus wrote: | | BTW, if you want them to blend in more, you can get countersunk Phillips head screws in black, which would match the knobs etc. |
that would have been nice, since i will use black led holders. i was looking for something like that, but couldn't find any source for black M2x6, at least in germany, and so tended to believe they even don't exist at all... _________________
Tech Buddy at Random*Source |
Posted: Sun Sep 16, 2007 7:15 am Post subject:
Oh, they exits alright. I recently discovered a trade supplies shop in Coffs Harbour, they've got heaps of handy stuff! That's where I got the screws for my slider panel (3mm * 8mm CS) in stainless steel. Great quality stuff. They were only about $8 for a hundred. Shits all over the range and prices for hardware at electronic suppliers like Dick Smith or Jaycar.
The next thing I'm going for are 4mm * 6mm long, Countersunk, Hex head, Black. And I reckon they'll have 'em too. You should have seen the rows of cabinets!
From the looks of the side of your panel, maybe you want some too?  _________________ What makes a space ours, is what we put there, and what we do there. |
bugbrand
Posted: Sun Sep 16, 2007 10:03 am Post subject:
| Quote: | he schaeffer panel arrived and i just started mounting the components. the color tone is actually a little bit darker than the foto suggests, more the famous "british racing green" of the mini cooper (i had one for about ten years). i like it!
can't wait for the PCBs. i am already playing with the sliders! it's the first time used sliders and i wished i had made a mounting PCB to reduce the count of screws on the frontplate, kind of krunkus style! |
Holy shit, I just wet myself !!! Oh, that is very awesome Fonik !!! I was not so sure of the green theme but shit, it really looks snazzy!! Wait a minute here, do I see a MIDI connector? Did I miss something? I also love the mount for the MIDI connector. Where did you get that connector and mount? Am I babbling?
Bill |
Scott Stites
Audio files: 96
Posted: Sun Sep 16, 2007 10:25 am Post subject:
Beautiful panel, indeed Fonik! The green reminds me of those Triumph TR-7s I lusted after when I was in high school (the shape of things to come). Fortunately, I was never able to afford one then....
Here's a re-do of the previous sample. This is a Klee first for me, because normally once I recorded something on the breadboard and turned it off, it was gone for good. There were so many pattern "switch" wires, it was just too big of a pain to trace which one was which and ground/unground the appropriate ones. But, on the panel, the pattern is there if one just "saves" it with the pattern switches.
So, I re-recorded the sample to balance it out and make it a bit clearer. I lowered the mix on the drum voices, raised the "high" voice a bit in the mix, and got rid of the reverb. It's more or less an excericise in repeatibility in the Klee, which I never strived to do on the breadboard. I think it passes that test!
I'll have to write this one down on Theff's patch sheet.
Cheerios,
Scott Last edited by Scott Stites on Sun Sep 16, 2007 11:47 am; edited 1 time in total |
Posted: Sun Sep 16, 2007 10:47 am Post subject:
| Scott Stites wrote: | | The green reminds me of those Triumph TR-7s.... | oh yesss. and their green was just this british racing green! _________________
Posted: Sun Sep 16, 2007 10:56 am Post subject:
| State Machine wrote: | | Wait a minute here, do I see a MIDI connector? Did I miss something? I also love the mount for the MIDI connector. Where did you get that connector and mount? |
well, i intend to implement marc bareilles midi2gate converter mc628 first. and then, maybe later, i will try on a modified midibox cv circuit. sneakthief works on that. the midibox based circuit would have CV PW, the MIDI indicator led will then have to be replaced by a CV in socket...
i was happy to find this MIDI socket myself! no additional screws or cheap tin...
Reichelt (germ) _________________
THeff
Audio files: 33
Joined: Apr 03, 2004 Posts: 24493 Location: The Netherlands, Enschede
Posted: Sun Sep 16, 2007 11:52 am Post subject:
Nice tracks Tim and Scott, beautiful panel Matthias !
Good to see so much progress and so many different approaches; it will not be long before even this build thread will have 20 pages  _________________ Jan
Scott Stites
Audio files: 96
Posted: Sun Sep 16, 2007 12:29 pm Post subject:
Tim, that is freakin' awesome! My favorite yet! Did you start out at audio rate then flip to LFO rate? Perfectly named, too, though I notice you didn't go for the alliteration this time (Klee Kommand)
And, oh, yes - JH's Tau Pipe - oh......my......GAWD!
Edit: Ah, crap, still page 19  _________________ My Site |
THeff
Audio files: 33
Posted: Sun Sep 16, 2007 1:06 pm Post subject:
Bulletin from Klee Command (Patch Cable City) |
Hey Scott,
Thanks, your samples are subtle, warm, and planned. My samples are "brute force" with a sledge hammer. I just keep hooking things up until it stops being annoying.
I did not start with it running at an audio rate. The VCO for the bass track takes two paths: Through a Moog filter and VCA, and also through a 2040 filter straight to the mixer. For the beginning and end of the song the LFO (Klee clock) is stopped and you are hearing the VCO at a fixed pitch going straight to the mixer. I just single stepped the Klee till it stopped on the note that I wanted to start with.
The VC clock (Roland 182 clone) that I mentioned on the "Super Klee" thread works great for starting and stopping at will.
Tim |
Posted: Sun Sep 16, 2007 1:40 pm Post subject:
| Quote: | | I'll have to write this one down on Theff's patch sheet. |
Great tracks guys !!! Nice ..... Oh, Is there a copy of this "Patch Sheet" that can be made public domain ???
Thanks .... I am gathering all the Klee tracks into one folder on my laptop here so I can make a CD for myself I will be adding my own stuff soon I hope ............
Bill |
THeff
Audio files: 33
Luka
Posted: Sun Sep 16, 2007 8:03 pm Post subject:
| that looks mad fonik |
THeff
Audio files: 33
creekree
Joined: Mar 30, 2006 Posts: 192 Location: Morgenland Neukölln
Posted: Mon Sep 17, 2007 12:28 am Post subject:
| i like your panel fonik! |
mono-poly
Joined: Jul 07, 2004 Posts: 937 Location: Rotterdam, Netherlands
Posted: Mon Sep 17, 2007 2:17 am Post subject:
| Nice sound examples |
a.b.o.z.
Joined: Feb 07, 2007 Posts: 351 Location: Zagreb, Croatia
G2 patch files: 4
Posted: Mon Sep 17, 2007 5:03 am Post subject:
boards interconnections question |
How many straight interconnections are there between two boards?
I'm crimping headers right now. so many wires, huh... spaghetti
On Bills picture of back side I see two 8pin and one 2 pin.
Thnx |
Posted: Mon Sep 17, 2007 6:29 am Post subject:
That's it. 8pin*2, 2pin*1(power) _________________ What makes a space ours, is what we put there, and what we do there. |
