lalito
Joined: Sep 26, 2006 Posts: 9 Location: Manchester UK
Posted: Tue Sep 26, 2006 4:07 pm Post subject:
Hello!
I finished my WSG (my first electronics project). It sounds
great! My band mates love it! I would like to add more features
to it.
Is it possible to conect my WSG to the simple 8 step sequencer?
How can I do it?
Could you please post schematics? |
Scirocco
Joined: Dec 11, 2005 Posts: 22 Location: Barcelona/Catalunya
Posted: Thu Dec 14, 2006 3:13 pm Post subject:
You could connect the wires of the pitch control of the WSG to the voltage sequence line like 1st schematic of the post, replacing the +V/-V by the WSG pitch control requeriments and using 4016 bilateral switches too.
I think it should work.
(please correct me if not, I´m new to this too) _________________ Have a nice day
http://www.flickr.com/photos/monocapa/ |
henq
Posted: Sun Feb 04, 2007 9:23 am Post subject:
this is all still a bit above my knowledge of electronics, but does anybody know about this: http://www.geocities.com/thetonegod/vanpoint21/van_point21.html
and, is the sequencer fully functioning yet?
and if so, is somebody going to make a stripboard layout?
(for us dummys) |
sm4tik
Joined: May 25, 2007 Posts: 15 Location: Helsinki, Finland
Posted: Fri May 25, 2007 5:59 am Post subject:
Hey dnny and all the rest ofcourse!
Since there are a lot of people reading this I thought I'd register and ask this one online, but is there a reason why using a 4017 instead of a 4022? a 4022 has 8 outputs and upon jumping back to start it sends a carry pulse which could be used to easily add more chips in series. Any thoughts?
Here's a link to the datasheet
^as
ps.
dnny, I have to come and visit the KoElSe workshop soon to wreck those video mixers  |
sm4tik
Posted: Fri May 25, 2007 6:28 am Post subject:
Thanks for that one, get it now!
Correct me if I'm completely lost, but for a "simple 8 step sequencer for SL" (as the topic says) it could be used?
^as |
Posted: Sat May 26, 2007 12:12 am Post subject:
Yep. _________________ What makes a space ours, is what we put there, and what we do there. |
Coriolis
Joined: Apr 11, 2005 Posts: 616 Location: Stilling, Denmark
Posted: Sat May 26, 2007 3:37 am Post subject:
Coincidentally, I'm trying to splice that design together with the baby10 sequencer (actually, the baby10 isn't much more than the CD4017 part of the Vanishing Point). I believe it is very much a confirmed design - the designer hangs out at Aron's Stompbox Forum, so go there for threads on it.
A stripboard layout is exactly what I'm working on, at this very moment I'm checking an almost finished layout for errors, so if and when I get it built succesfully, I will post a layout.
A thing to notice: The Vanishing Point Sequencer is originally intended as an addon for guitar fx pedals - hence the summing of the cv outs in that optocoupler. I'm going to remove that, and use the output section of the baby10 instead. Also, I'll be running it on 12 or 15VDC probably.
Baby10 on foniks page:
http://www.modular.fonik.de/Page22.html
Aron's forum:
http://www.diystompboxes.com/smfforum/
C |
goodrevdoc
Joined: Sep 11, 2006 Posts: 288 Location: Philadelphia, PA
Posted: Sun May 27, 2007 6:09 pm Post subject:
Hey Coriolis, I built a Van Pt 2.1, and it works. The latout commonly available is not totally accurate, but good enough that you can fix it even after etching. On breadboard though, mine was completely solid. One must take the usual percautiuons seperating the logic and audio portions of course, but this would be less of an issue with higher signal levels. I was having good success with my experiments involving vactrols, but couldn't get a current sink transistor version to work. Reading and thinking about it now, I may give it another shot, but with a 4022 instead.
-justin
EDIT:
here's a pic of the PCB, again it's operation is so-so...
Coriolis
Posted: Thu May 31, 2007 10:46 am Post subject:
Hey, that sounds good - may I ask how exactly the random mode works?
What does it actually do?
C |
goodrevdoc
Posted: Sun Jun 10, 2007 10:35 am Post subject:
IIRC, the random mode puts a really high freq signal on the enab pin. That mixed with the clock signal gives the appearance of randomness. Or maybe I just made that up...
-justin |
Aircoholic
Joined: Aug 02, 2007 Posts: 18 Location: Berlin, Germany
Posted: Wed Aug 15, 2007 2:57 pm Post subject:
So, does anyone have a PCB or Stripboard Layout he could share?
8 Steps would be okay, but 16 would be great
Unfortunately I'm still not really good at transferring schematics to any board  |
Anarchia
Posted: Fri Aug 31, 2007 5:29 am Post subject:
Baby10, Baby10... someone posted about this previously here but it's buried and takes forever to find the post and I swear the post is only for Rev.1 of the Baby10 which doesn't have as many features. I ended up just scaling down to what I wanted. In Rev. 2 of the Baby10 there are 2 CV and Gate outs, I only used one of each and I skipped the "manual trigger". Obviously there are 10 steps on the 4017 chip but I only use 4 (pots and switches can be expensive, and there's only so much room in my case) and for the clock I use the 555 clock from Daniel Vera's original post (thank you). I like the 555 timer cause it can also double as a square wave LFO. I hardwired the CV out to both VCO's individual, the VCF cut-off, and the VCA. I tried wiring it up to the Res. and Noise but it didn't work out as well. Then I add 1/4" jacks for the CV and Gate outs, along with a clock out (the square wave LFO) and a clock in for syncing purposes. I played around with Daniels original schematic for a while but to no avail. Eventually I found the Baby 10 post but still had some issues, but when I finally found the Rev. 2 of the Baby 10 it all came together a worked about as good as it can considering it was built by someone with no real electronics training (me).
So if your having troubles, the Baby 10 rev. 2 would be the way to go. Simple yet oh so fun
15 KB |
| Viewed: |
64696 Time(s) |
247.41 KB |
| Viewed: |
1160 Time(s) |
831.56 KB |
| Viewed: |
3041 Time(s) |
synthetic
Joined: Jun 02, 2007 Posts: 76 Location: Glendale, CA
Posted: Sun Sep 09, 2007 4:19 pm Post subject:
I've seen many versions of this circuit over the years, the first was in a book called "Sound Synthesis" by Terence Thomas. I'm thinking about finally building the sequencer in that book/this one/Baby 10. My concept is one module to act as the clock, then a 8-step sequencer(s) module. First question: Will any NPN transistor work for the clock input? The schematic I have says to use a 2N3365, but neither Mouser nor Digikey has those.
I can scan the article for this sequencer if it's legal and there is interest. It is a very good synth DIY book with many schematics and board layouts. It looks to be out of print. Thanks. |
synthetic
Posted: Mon Sep 10, 2007 12:47 pm Post subject:
| I just noticed the text in that Baby 10 article, "Even a lame duck like the SH-101 becomes a monster under the control of this." Shows you how taste changes over the years... |
loss1234
Posted: Fri Sep 21, 2007 5:34 am Post subject:
synthetic |
please post that article!!
i am trying to build this so it would really help
thanks |
synthetic
synthetic
synthetic
synthetic
bubblechamber
Posted: Tue Sep 25, 2007 10:23 pm Post subject:
| thanks |
Danno Gee Ray
Joined: Sep 25, 2005 Posts: 1351 Location: Telford, PA USA
Posted: Wed Sep 26, 2007 7:58 am Post subject:
| What book was that from please. |
Joined: Jan 31, 2003 Posts: 18283 Location: Durham, NC
Audio files: 235
Posted: Wed Sep 26, 2007 1:06 pm Post subject:
| Danno Gee Ray wrote: | | What book was that from please. |
Yes, please identify the author and publisher. I figure this is ok to reproduce as fair use for educational purposes, but we should give a reference. _________________ --Howard
my music and other stuff |
loss1234
Posted: Wed Sep 26, 2007 3:06 pm Post subject:
| he said in his post before he printed it. terrence thomas...... |
Danno Gee Ray
Posted: Wed Sep 26, 2007 3:51 pm Post subject:
| Yep, went right by that one. Thanks fior pointing that out. |
