Peake
Joined: Jun 29, 2007 Posts: 1113 Location: Loss Angeles
Posted: Wed Oct 10, 2007 11:07 pm Post subject:
[quote="Nosferatu"] | Peake wrote: | | Quote: |
This allowed for the choice between very predictable, hard sounds and more analog free-running sounds. Interesting when you mixed partials with reset on and off in a single sound. |
Thats right, but its good for hard balls basses. |
Exactly! I'd really like to see reset on this TZO for the same reason. I'll bet that even a single saw or square would make for great bass this way.
And thanks for the history on the feature, I didn't know any of that!
Speaking of great bass, I'd also like to request both positive and negative-going saw wave outputs, if possible. If not, an inverter is just as easy to use. Both types seem to "excite" filter resonance differently and are both useful as a result. |
Randaleem
Joined: May 17, 2007 Posts: 456 Location: Northern CA, USA
Nosferatu
Joined: Jul 27, 2007 Posts: 234 Location: Planet Rock.
Posted: Thu Oct 11, 2007 6:56 am Post subject:
| Quote: | | And thanks for the history on the feature, I didn't know any of that! |
Just my 5 cent of old and outdated knowledge that still occupy
a part in my brain.No idea why i cant clear things like that out!  Last edited by Nosferatu on Thu Oct 18, 2007 1:17 pm; edited 1 time in total |
Dave Kendall
Posted: Thu Oct 11, 2007 1:00 pm Post subject:
| Quote: | So for the latest models TG77, SY77/99 they had osc phase restart and even phase start position as a programmable parameter.
However i don't remember if this was implemented in the DX7S, and DX7II |
The DX7IID has an osc sync parameter, on or off. (per patch).
Dave |
Funky40
G2 patch files: 5
Posted: Sat Feb 16, 2008 8:59 am Post subject:
as anybody heard anything from Randal ?
was he at Namm ?
I'm looking forward for thru Zero VCOs in DIY.
Another small DIY Boards supllier mentioned in a mail that he has planned also a thru Zero VCO,
but that might take time as there are other things first to come. |
funkyfarm
Posted: Fri Feb 29, 2008 10:25 am Post subject:
"as anybody heard anything from Randal ?
I'm looking forward for thru Zero VCOs in DIY", me too... |
philpeery
Joined: Nov 08, 2006 Posts: 137 Location: new jersey, usa
Posted: Fri Feb 29, 2008 12:46 pm Post subject:
I emailed him directly asking the same question. I would kill for a bank of TZO's right now! I haven't heard back yet, so I am not sure if he's still in the game or not. Sure would be nice though, because his QFG pcb design is top notch!
Phil |
numbernone
Joined: Aug 16, 2006 Posts: 477 Location: new york city
Posted: Fri Feb 29, 2008 3:53 pm Post subject:
I may be the only one, but Randal owes me a bunch of VCA boards. Have not heard back in around 2 weeks now. The emails used to be long and filled with info and chat, the last was short and barely committal.
This is sad, as I think Randal is probably very qualified to be pulling off things like the TZO. I wish he had someone else handle the front end, taking orders and making sure they go out in a timely fashion. I still have great hope, first cuz I NEED VCAs BADLY, secondly because I really think the guy has a lot to offer.
Fingers crossed. |
philpeery
Posted: Fri Feb 29, 2008 3:59 pm Post subject:
Have you looked at the TH ASF21C ssm2164 based VCA yet? Fonik created a dual VCA press and peel single sided layout for it. I've mod'ed the layout a bit to match my power connection type (MOTM style MTA156), have etched a few, and am getting ready to test the board out. If the design is anything like TH's other designs, it ought to be a killer VCA!
Phil |
numbernone
Posted: Fri Feb 29, 2008 5:20 pm Post subject:
| Yes I have, actually have a pretty much done layout for a quad. Its just that I have already doled the dough, and wanna get the Randal boards if I can (THEY WILL BE BETTER). I suppose I will want a couple dozen of them in the "end" so... |
toppobrillo
Joined: Dec 10, 2005 Posts: 766 Location: oakland, ca
Posted: Fri Feb 29, 2008 5:54 pm Post subject:
i don't want to spread too thin, but i already started a layout a while ago based on the EN-129 TZO, it's about 1/2 done. the amalgamation [sp?] i have has been spread out on 3 bread-boards for like 6 months now and i am anxious to build it.. knowing that i will want to build more than one and how big a project it is, it is much smarter to do a PCB. i don't know really where randal left off but i suppose if it is based on the 129 i should seek the same permission[s] as randal to do it. obviously there is alot of interest here.
one thing that i did with my prototype is set up a local +/-5V supply- the CMOS is powered off of this. the current draw is pretty evenly distributed between the + and - rail. i added sync- although it is not "vari-sync" as in the ZO. the Bias control is a 3-position switch, not a pot. there is range-switching, there is a switch that allows the Sawtooth to reverse or not reverse upon reversals. the linear FM input can be AC or DC coupled [i felt that was important with this] i used comparators where applicable. oh and i would like to include a variable waveshape output too- still experimenting with that one.
umm i think that's it basically it. it works really well i have tested it at some length [although i'm sure improvements could be made in terms of tracking and whatnot. i really need to borrow a good frequency counter and fine tune it as best i can]. it is in a box still since i moved cause i have been busy with other stuff, but it is scheduled to return to the worktable this weekend cuz i finally finished [not in a box yet] a project i was working on for my girlfriend, a really cool 'voice changer' with an instrument preamp, gain compensation, modulator and things.
aaannnyyywaaayssss
whaty'allthink?? maybe someone else who is into PCB design can help with
the remainders? should it all be on one board??
josh |
toppobrillo
Posted: Fri Feb 29, 2008 6:27 pm Post subject:
oh by the way, what is up with "Nosferatu" deleting all his/her posts???
thats weird.. |
Joined: Apr 03, 2004 Posts: 24652 Location: The Netherlands, Enschede
Audio files: 326
Posted: Fri Feb 29, 2008 6:43 pm Post subject:
| topp wrote: | | thats weird.. |
It was quite a while ago already, but in short : he was unhappy with how the thread went, and I haven't seen him since. _________________ Jan
Posted: Sat Mar 01, 2008 9:06 am Post subject:
| topp wrote: | obviously there is alot of interest here.
There sure is! I bet everyone would like to see what you have come up with
However, I should point out that since the QFG boards, new guidelines have been made - Fonik kindly being the architect of many of these. They just cover everybody's backs etc. Making sure that no one gets into any trouble.
But yes Josh, bring em on!  _________________ ACHTUNG!
toppobrillo
Posted: Mon Mar 03, 2008 8:45 pm Post subject:
| Quote: | | However, I should point out that since the QFG boards, new guidelines have been made - Fonik kindly being the architect of many of these. They just cover everybody's backs etc. Making sure that no one gets into any trouble. |
i'm sorry, i don't know to what exactly you are referring here?
[/quote] |
Posted: Tue Mar 04, 2008 2:27 am Post subject:
| topp wrote: |
If you intend to do a run of new boards (which we'd/ I'd love you to do btw), then you need to email Scott Stites beforehand, and tell him your proposals. These are new electro-music.com DIY forum rules. Okay?
regards,
Tom  _________________ ACHTUNG!
frijitz
Audio files: 54
Posted: Tue Mar 04, 2008 2:49 am Post subject:
| v-un-v wrote: | | If you intend to do a run of new boards (which we'd/ I'd love you to do btw), then you need to email Scott Stites beforehand, and tell him your proposals. These are new electro-music.com DIY forum rules. Okay? |
Huh? I have to get permission before I make boards? If that's true, don't you think you should give us a link?
Ian |
toppobrillo
Posted: Tue Mar 04, 2008 4:39 am Post subject:
i guess i must have missed something- odd, too, cause i check in here almost daily. where did all this go down?
edit: the randaleem thing right? if there were official guidelines laid down, they were lost on me- all i saw was that Jan had made some clear recommendations to folks offering PCBs. |
Posted: Tue Mar 04, 2008 5:08 am Post subject:
| Scott Stites wrote: |
So all of you Ian's, JH's, Foniks, Mooseapatomi, etc. that have active PCB projects (or even inactive) that you would like to announce, list, or discontinue, please PM me.
http://electro-music.com/forum/topic-20290.html
Posted: Tue Mar 04, 2008 5:16 am Post subject:
| topp wrote: | i guess i must have missed something- odd, too, cause i check in here almost daily. where did all this go down?
yes
Yes It's still rather misleading. I read the sticky only. Yes I do remember that Jan said something- I'd simply forgotten- so I'm sorry for any misunderstanding caused. _________________ ACHTUNG!
RF
Joined: Mar 23, 2007 Posts: 1502 Location: Northern Minnesota, USA
Audio files: 28
Posted: Tue Mar 04, 2008 6:35 am Post subject:
| v-un-v wrote: |
regards,
Tom  |
'So all of you Ian's, JH's, Foniks, Mooseapatomi, etc. that have active PCB projects (or even inactive) that you would like to announce, list, or discontinue, please PM me. ' (Scott)
Umm - That looks like a suggestion for IF you want your project listed in the handy, easy to find PC Bard project thread. Not to get PERMISSION.
Guidelines are great - and a reasonable idea...but lets not get nuts.
"Mommy, Daddy....Can I make a Board"
bruce |
Scott Stites
Audio files: 96
Posted: Tue Mar 04, 2008 7:26 am Post subject:
Oh, it's true, it's true, though it's not really a mommy/daddy thing, but rather it's more of a kneel before the all-powerful maniacal-PCB-monarch moment.
(of course I jest, knock yerself out on the PCBs - you don't need my permission. Just follow the em guidelines).
Cheerios,
Posted: Tue Mar 04, 2008 7:30 am Post subject:
| RF wrote: |
¨Yes as long as you don't drink that caustic etchant like you did before. Those hospital bills ain't cheap y'know¨  _________________ ACHTUNG!
Audio files: 326
Posted: Tue Mar 04, 2008 2:24 pm Post subject:
| topp wrote: | | Jan had made some clear recommendations to folks offering PCBs. |
I'm just the messenger here, we had quite some discussion behind the scenes about it before it was put up. So it's a reflection really of what all the "moms and dads" thought would be good for you ... so shoot us all please and not just "someone" . _________________ Jan
Danno Gee Ray
Joined: Sep 25, 2005 Posts: 1351 Location: Telford, PA USA
Posted: Tue Mar 04, 2008 3:40 pm Post subject:
| I think you all should be applauded. |
