Electro-Music Klee Sequencer Build and Applications Thread
Page 32 of 54 [1348 Posts]
Goto page: Previous 1, 2, 3, ..., 30, 31, 32, 33, 34, ..., 52, 53, 54 Next
etaoin
PostPosted: Fri Nov 16, 2007 7:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Second Klee hits Holland.
 Filesize:  261.76 KB
 Viewed:  337 Time(s)
http://www.casia.org/modular/
PostPosted: Fri Nov 16, 2007 8:05 am    Post subject: Reply with quote  Mark this post and the followings unread
as far as i found out, the following systems work well with 5V gates and triggers:
doepfer
MOTM
cwejman
There are no problems triggering or gating PAIA units also .....
Bill
PostPosted: Fri Nov 16, 2007 8:32 am    Post subject: Reply with quote  Mark this post and the followings unread
finally the zollamt decided to pass it on.
klee unleashed in germany:
 Filesize:  143.25 KB
 Viewed:  9325 Time(s)
Scott Stites
Audio files: 96
PostPosted: Fri Nov 16, 2007 8:33 am    Post subject: Reply with quote  Mark this post and the followings unread
Wow - welcome news about Ray's trigger/gate levels. I was all primed to say oh, no-no-no, but I see his new ADSR board does react to >2V.
The reason? I built a version of Ray's ADSR with the state indicating LEDs (and also, his original AR version) - if you look at those designs, he indicates 0 to +12V, though, IIRC, 10V seemed to work fine.
The reason I say "IIRC" is that, because they wouldn't trigger off of my Thomas Henry +5V Gate/Trigger, I outfitted each EG with a comparator that would pomp-op the volume on the gate/trigger signals so they worked with everything in my system. So - if your Ray Wilson EGs are the old style, 5V won't trigger/gate.
BTW, Music From Outer Space has my vote for the most entertaining/informative SDIY site there is. Ray is king. Very Happy
Thanks for checking the PAiA Bill!
Scott
My Site
Scott Stites
Audio files: 96
PostPosted: Fri Nov 16, 2007 8:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Sneak Klee Drive Through Belgium Shocks Germany! Australia Folds!
Klee Klique Klaims Kurrent Kartography Kaput; EU Now KU; USA now USK; UK Now UK, Only Different; Australia Now Kleestralia; Kaos Ensues in Kleenada, Particularly Kleebec
My Site
Rykhaard
PostPosted: Fri Nov 16, 2007 9:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Hoping today that our province name will change to Kleetario! Very Happy Come ON mailman! Shocked lol
EdisonRex
Audio files: 172
PostPosted: Fri Nov 16, 2007 10:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Here's hoping anything shows up... sigh.
Garret: It's so retro.
etaoin
PostPosted: Fri Nov 16, 2007 10:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Build manual page 75 and 76, the list of 100k resistors is the same as the list of 6k8 resistors...
6k8 list should probably be R32-R47.
Scott Stites
Audio files: 96
PostPosted: Fri Nov 16, 2007 10:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Thank you, Etaoin. Looks like that error also affects Appendix B, Page B1.
I'll post the individual page corrections as well as Issue 3.
Hope that didn't jack anybody up Embarassed
I'm going to put links to all of the current docs in the first post of this thread. That'll create a common place for everyone to be sure they have the latest version.
If anyone else happens across anything like this, please post here or PM me, and I'll correct things as they're brought to my attention.
Scott
My Site
PostPosted: Fri Nov 16, 2007 10:58 am    Post subject: Reply with quote  Mark this post and the followings unread
yesss! i knew it. and gosh! i still have the old boards waiting in my drawer! Shocked
Scott Stites
Audio files: 96
PostPosted: Fri Nov 16, 2007 11:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Here is Build Issue 3, which corrects the 6K8 reference designator error Etaoin pointed out. The corrected pages are also posted here - if you've already printed Build Issue 2, you can replace the erroneous pages with these pages.
I'm now going to work on Post 1 of this thread and create a place you can find all of the links to all of the docs people don't have to skim the thread looking for it all.
Thanks again, Etaoin. That's a biggee.
Edit: Don't Download Issue 3 - Issue 4 will cover some more issues here shortly.
Deleted balloxed Issue 3. Issue 4 posted later in thread. Post 1 of the thread provides link as well.
Scott
Corrected_issue2_page76.pdf
Corrected Page 76 of Issue 2 Build Doc.
 Filename:  Corrected_issue2_page76.pdf
 Filesize:  6.18 KB
 Downloaded:  1600 Time(s)
Corrected_issue2_AppendixB_pageB1.pdf
Corrected page B1 of Issue 2 Build Doc.
 Filename:  Corrected_issue2_AppendixB_pageB1.pdf
 Filesize:  5.81 KB
 Downloaded:  1592 Time(s)
My Site
Scott Stites
Audio files: 96
PostPosted: Fri Nov 16, 2007 11:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Links to all the docs are now and will always be available in the first post of this thread.
Scott
My Site
etaoin
PostPosted: Fri Nov 16, 2007 11:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Spotted another one. Page 78, U1 and U8. it says LM358 in the list but LM356 in the placement guide.
Scott Stites
Audio files: 96
PostPosted: Fri Nov 16, 2007 12:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks again, and might I add - aaaarrrggghhh Very Happy
My Site
etaoin
PostPosted: Fri Nov 16, 2007 12:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Page 87, R29 is missing from the list.
RF
Audio files: 28
PostPosted: Fri Nov 16, 2007 1:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
New title for this thread.... Exclamation
"In which Scott S. Says "DOh!""
Hang in there Scott...
etaoin
PostPosted: Fri Nov 16, 2007 1:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Last one for today; P89, R34-R41 are actually 7 or 8 trimmers, (doc says 5 or 6).
Scott Stites
Audio files: 96
PostPosted: Fri Nov 16, 2007 1:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
"Doh" is one letter short of the word I'm actually saying Very Happy
Thanks Etaoin - I'm keeping track here - looks like R29 ain't in the appendix either.
Formatting on Issue 3 got corked up on a few pages as well.....
My Site
Scott Stites
Audio files: 96
PostPosted: Fri Nov 16, 2007 1:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
hobo drinking
Issue 3 will soon be supplanted. Issue 4 will be known as the Etaoin version. I imagine, as quick as he was finding them, he was probably building at the same time.....
Sorry guys, you're going to have to spin your hard drives and modems again here in a bit.
And thanks Etaoin.
My Site
Scott Stites
Audio files: 96
PostPosted: Fri Nov 16, 2007 1:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
For the day?
hobo drinking
My Site
abis
PostPosted: Fri Nov 16, 2007 2:25 pm    Post subject: Reply with quote  Mark this post and the followings unread
Please don't Kleep me waiting!
My parts kit came the other day (thanks Bill!) Now I am anxiously waiting for that big red and white truck to pull up in front of my house.
a.b.o.z.
G2 patch files: 4
PostPosted: Fri Nov 16, 2007 2:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
woohooo
made it just in time
klee is on it's way to croatia
jupi jei
kleeatia Very Happy
cheers
Scott Stites
Audio files: 96
PostPosted: Fri Nov 16, 2007 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Issue 3 was too hastily issued, and the formatting on a few pages got screwed up as well. After Issue 3 was put out, Etaoin uncovered some more issues.
I'll write up a decent errata (erotica?) sheet between issues 2 and 4, with mention that issue 3 was just tossed. In the meantime, these additional pages will correct issue 2.
These pages cover the missing R29 in the build section and Appendix A, the erroneous depiction of an LM356 instead of LM358 on the IC placement illustration, and the miscount of the number of 10K trimpots on the Analog Board.
Issue 4 incorporates all of the corrections to Issue 2.
Sorry to all and thank you Etaoin for spotting and pointing out the mistakes. If any others pop up, please let me know.
Scott
Corrected_issue2_page88_thru_89.pdf
Replace Issue 2 pages 88 and 89 with this. Corrects deletion of R29 and miscount of 10K trimpots in analog board build section.
 Filename:  Corrected_issue2_page88_thru_89.pdf
 Filesize:  8.38 KB
 Downloaded:  2650 Time(s)
Corrected_issue2_page78.pdf
Replace page 78 of Issue 2 build doc with this. Displays LM358 instead of LM356 in IC placement guide.
 Filename:  Corrected_issue2_page78.pdf
 Filesize:  39.29 KB
 Downloaded:  1688 Time(s)
Corrected_1ssue_2_AppendA_pageA1.pdf
Replace Issue 2 page A1 with this. Mentions missing R29 of Analog Board in BOM.
 Filename:  Corrected_1ssue_2_AppendA_pageA1.pdf
 Filesize:  6.47 KB
 Downloaded:  1295 Time(s)
em_klee_build_issue4.pdf
Issue 4 of Build Doc. Incorporates all fixes from Issue 2. Get rid of Issue 3 if you have it.
 Filename:  em_klee_build_issue4.pdf
 Filesize:  2.51 MB
 Downloaded:  5279 Time(s)
My Site
Rykhaard
PostPosted: Sat Nov 17, 2007 1:02 am    Post subject: Reply with quote  Mark this post and the followings unread
When they get there, please remind them to stop at mine in Kitchener! ShockedShockedShocked I .... can't stop .... ttthththhis shshsaking!
Very Happy ROFL
Pehr
PostPosted: Sat Nov 17, 2007 6:04 am    Post subject: Reply with quote  Mark this post and the followings unread
*correction pen is starting to glow* Shocked Laughing
YouTube channel
flickr photostream
http://loxodrom.blogspot.com
