Wogglebug circuit
Page 5 of 14 [332 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7, ..., 12, 13, 14 Next
goldenechos
PostPosted: Sun Nov 04, 2007 5:51 am    Post subject: Re: Adding Disturb Reply with quote  Mark this post and the followings unread
prophei wrote:
stegoman wrote:
I've just finished looking closely at the Disturb circuit on David's schematic (http://www.pugix.com/images/woggle-wog.pdf) versus the WoggleBug #3 circuit (http://diy.czmok.de/fileadmin/wogglebug-schem.pdf) for the current production board. David's disturb circuit can be done as a daughter board that hooks up to pin 3 of the "Smooth Range" pot instead of tying that pin to ground! If you look at the disturb circuit, it will be at ground if no input signals are supplied. Add 12 resistors, 1 pot, 2 diodes, and an IC. Or just use one disturb input and drop the pot and 4 resistors.
Question: How do you properly connect the unused section of the LM324 in order to prevent it's causing any issues?
but how is it powered properly? looking at his schematic, i believe he uses pins 4 & 11, but it doesn't specify what it goes to. i tried to find his email online, but was unsuccessful. Crying or Very sad
any idea's anyone?
Have not looked at the schematic, but the 324 can be operated off single OR dual supply. Pin 4 gets +V while pin 11 gets either -V or GND.
Tony
prophei
PostPosted: Sun Nov 04, 2007 9:29 am    Post subject: Re: Adding Disturb Reply with quote  Mark this post and the followings unread
Tony
hmmm...
i set it up according to the datasheet, which seemed to state it takes +V and GND (not sure where you have the info on the -V).... and this isn't doing anything. the disturb is doing nothing to the woggle from what i can tell.
if you can actually add the -V to pin 11, should i just do so, or if it was intended for GND, could i kill something in the circuit?
other than this stuff, the wogglebug is freaking brilliant! i am getting the wildest stuff out of it... except that i can't get any noticeable change using the "cluster" knob. i wonder why this would be dead and all other things seem to be working perfectly...
stegoman
PostPosted: Mon Nov 05, 2007 11:43 am    Post subject: Re: Adding Disturb Reply with quote  Mark this post and the followings unread
prophei wrote:
But how is it powered properly? looking at his schematic, i believe he uses pins 4 & 11, but it doesn't specify what it goes to. i tried to find his email online, but was unsuccessful. Crying or Very sad
any idea's anyone?
The LM324 can handle a 32v differential. So it is powered off of the +/-15v (30v differential). Thus 4 goes to +15 and 11 goes to -15. That's why the 100k pull downs to ground on the inputs. No input will see 0v, and the output will be 0v, thus not disturbing the Disturb beyond the offset created by the disturb pot.
In the group buy board, the 'woggletone' 4046 has pin 12 tied to ground thru R28, and pin 11 tied to ground via R12 and V2. The mod is the circuit with Dave's LM324 at the end of V2 instead of ground, a pretty easy change to make. Very Happy
prophei
PostPosted: Mon Nov 05, 2007 12:00 pm    Post subject: Re: Adding Disturb Reply with quote  Mark this post and the followings unread
any idea's anyone?
In the group buy board, the 'woggletone' 4046 has pin 12 tied to ground thru R28, and pin 11 tied to ground via R12 and V2. The mod is the circuit with Dave's LM324 at the end of V2 instead of ground, a pretty easy change to make. Very Happy[/quote]
thanks for all the info!!!
i have not been able to get disturb to work at all. ugh. that and the cluter knob from the #3 design do nothing, yet everything else works. so frustrating! Rolling Eyes
=D
stegoman
PostPosted: Mon Nov 05, 2007 12:17 pm    Post subject: Re: Adding Disturb Reply with quote  Mark this post and the followings unread
=D
If the cluster know isn't doing anything, look to see if there is a problem with your Sample&Hold circuit somewhere. U2 pings 6&7, D1, D2, U5A, R6, & R7. Maybe there is a solder bridge or diode inserted wrong?
xpmtl
PostPosted: Mon Nov 05, 2007 1:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
Maybe that could help. Dunno if u already done that :
"a small cap is required. 2.2nF or something close (4.7nF would be
ok) should be connected at one end at the junction between R35
(470ohm) and pin3 (round pad) of the cluster pot. the other end should
be connected to ground. a good place to do this is on the bottom side
of the board near the cluster pot which is also right next to the
lf398 sample/hold chip. this is missing on the original schematic but
some lf398s may work without it. On mine, it would not accept feedback
(the cluster setting) without this change."
From Ryan Williams paper on wogglebug.
http://sdiy.xpmtl.net
prophei
PostPosted: Mon Nov 05, 2007 4:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
wow, i totally forgot about that... i will try i tonight! thank you =]
prophei
PostPosted: Mon Nov 05, 2007 6:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
this seems to have worked! now on to the disturb function and i am ready to rock. many thanks for pointing me at that data. i had read it and completely forgotten about it. Very Happy
xpmtl
PostPosted: Tue Nov 06, 2007 4:56 am    Post subject: Reply with quote  Mark this post and the followings unread
Glad it worked !
Keep us informed with your progress on the disturb fonction.
cheers
janvanvolt
PostPosted: Wed Nov 28, 2007 8:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
THE PCB ARE ORDERED AS OF TODAY (11/29/07).
I WAS ABLE TO NEGOTIATE A BETTER PRICE, SO WE WILL
HAVE A TOTAL OF 160 BOARDS AVAILABLE.
My dIY - http://diy.czmok.de
Film/Music - http://gfm.me
loss1234
PostPosted: Wed Nov 28, 2007 8:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
am i too late? how much are these boards?
i would like one
thanks
prophei
PostPosted: Wed Nov 28, 2007 9:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
regarding the disturb function, i was never able to find a place to connect it into the design that yielded much of anything. i have decided that the "child tones" of the original are one of the coolest things ever... so i am inclined to build a second woggle and work on getting those instead. seems like a much bigger gain for the effort....
crashlander42
PostPosted: Wed Nov 28, 2007 9:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Holy crap. I missed another Wogglebug group buy?
When they plug me in the lights go down in Hong Kong.
My DIY stuff Flickr
loss1234
PostPosted: Wed Nov 28, 2007 10:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
yeah i cant believe i missed out on this
stegoman
PostPosted: Wed Nov 28, 2007 11:11 pm    Post subject:   Reply with quote  Mark this post and the followings unread
If you check at http://diy.czmok.de/Group-Buys.66.0.html I think you will find that you can still order boards. But I sure would not wait Very Happy
crashlander42
PostPosted: Wed Nov 28, 2007 11:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
woo. Hey you're right. Sweet.
My DIY stuff Flickr
chriswilliams
PostPosted: Thu Nov 29, 2007 12:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Just a quick question - how does the 'cheaper price' work for those who have already ordered (and paid) for their boards?
janvanvolt
PostPosted: Thu Nov 29, 2007 2:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Well. I am just getting 150 boards for the price of 100. It it probably a _minor_ price change, BUT the dollar <-> euro conversion rate is eating it up fully, as i calculated originally with a rate of 1.32 USD/EUR and now it's 1.49 USD/EUR.
Literally it is compensation. Unfortunately Sad I am not gaining anything out of it, just no loss of money.
Groupbuys at such scale are difficult to handle with the current up/downs of the euro/usd conversion rate as i have to pay stuff in euro and many people pay in usd.
janvanvolt
PostPosted: Tue Dec 04, 2007 9:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Boards are in production, just in case somebody might ask Smile
I just bought a silk screen set, so i am (theoretically) should be able to do
designs for dotcom or other panels.
Is there any interest in a dotcom frontpanel for this ?
Not sure yet about the prices.
endif
PostPosted: Tue Dec 04, 2007 2:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ooh that's pretty. =]
Any chance of a frac or euro?
~ !J!
http://www.endif.org
http://www.crunchpod.com
http://www.myspace.com/endif
janvanvolt
PostPosted: Tue Dec 04, 2007 3:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
Well. If you organize the material (black aluminium) i might do that as well.
its no problem doing silkscreens.
sidequestion: any interest for those as well ?
xpmtl
PostPosted: Tue Dec 04, 2007 3:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
Where did u bought ur silk screen set?
Was thinking of getting one..
If u do motm versions, i might me interested.
janvanvolt
PostPosted: Tue Dec 04, 2007 3:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
No. MOTM is out of interest for me because of the lack of front panels for it.
(maybe bridechamber/stoogepanels can help out with that).
6079smith
PostPosted: Tue Dec 04, 2007 3:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Woohoo!
PostPosted: Tue Dec 04, 2007 5:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
An mp3 of two of the circuits feeding a mixer and Knight Kit spring reverb
Okay.
As poor old Dennis already knows, I've got an original Wiard Series 300 (300?) Wogglebug- the very last one ever built I believe? Shocked (and if I ever sell it, Dennis gets first refusal!), but it's a hard bug to part with (which I'm sure Dennis would have great sympathy and understanding for- wouldn't you mate? Embarassed ).
I bought my Wogglebug on the strength of the above mp3 sound. But to be honest, however 'mad sounding' it is, it NEVER sounded like the above mp3 sample. I don't know why, but no. It doesn't. I've emailed Mr Richter, but Grant has never replied with an explanation Sad
So be warned- or more to the point, if you know the tweak that makes a Wogglebug sound like the above 'monster from the ID' sample, please let me know!. I'd love to know!!
PS, the wogglebug sounds mental when wired up to an ms20!
ACHTUNG!
