Solina or Onmi ensemble board?
Page 10 of 16 [394 Posts]
Goto page: Previous 1, 2, 3, ..., 8, 9, 10, 11, 12, 13, 14, 15, 16 Next
If I'd make a string chorus PCB, what kind of multi-BBD circuit would you prefer?
Solina style (also: Crumar Performer, Böhm Phasing Rotor, and others)
62%
 62%  [ 28 ]
ARP Omni style
13%
 13%  [ 6 ]
Elka Synthex 4 BBD circuit
11%
 11%  [ 5 ]
other (please name in thread)
6%
 6%  [ 3 ]
I would want neither - it's old fashioned and overused, and if I need it, there are digital FX boxes
6%
 6%  [ 3 ]
Total Votes : 45
guitarfool
PostPosted: Fri Dec 07, 2007 5:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
I got mine today - woohoo!
jhaible
PostPosted: Fri Dec 07, 2007 5:44 pm    Post subject: Re: JH. Triple Chorus – Connections Diagram with 1p2t switch Reply with quote  Mark this post and the followings unread
Stavros wrote:
The Roll off switch is the one that selects between the ‘Solina’ mode, when ON, (12 kHz filter – slightly darker sound?) and the Linear mode, when OFF (16 kHz Filter – broadband sound?).
Right.
The EQ switch selects, when ON, the equalization mode. The position of the Roll off switch ON or OFF, plays no role in this situation.
Right.
The Modulation switch when ON brings towards the ‘Main Output’ the modulated signal ‘Wet’.
The modulated- ‘wet’ signal will reach the ‘Main Output’ only if the FX (what FX stands for please?) switch is ON.
When the FX switch is OFF then at the Main Output exists the ‘Dry’ signal no matter what other switch combinations exist.
If the Modulation Switch is OFF and the FX switch is ON then at the Main Output we have the unmodulated but filtered signal.
Right!
Could we eliminate the FX switch thus having always the Modulated or the Filtered signal on the Main output and have the ‘Dry’ signal on an output of its own?
Yes of course you can. These are just ideas / suggestions how you can wire and switch the hole thing.
The idea is to have a buffered but otherwise unaltered signal when "FX" ("effects") switch is off. Or a filtered, but not chorused signal, when "Modulation" is off. But if you don't need any one of these options, just omit the switch and hard wire it.
You can even omit all the switches, go into th ecircuit at the In connector, get out of the circuit at the Out connector, and always have a chorused signal.
Is the Modulation trimmer, the trimmer for choosing between Dr. Boehm and Solina way?
... and anything in between.
What kind of signal could be directed to the ‘Input’ e.g. VCF, Mixer out, VCO wave?
Whatever you like, if you have that 50k log input level potentiometer, as shown here http://www.jhaible.heim.at/triple_chorus/jh_triple_chorus_connections_1p2t_switches.pdf
If you don't want to have that potentiometer, you can adjust the input gain by altering R34 (refering to http://www.jhaible.heim.at/triple_chorus/jh_triple_chorus_sch_page1.pdf):
47k means roughly 6dB gain. 100k would mean roughly unity gain.
But due to the operation of the 3 delay lines, which will increase the peak-to-peak amplitude of the signal without increasing its perceived loudness, you can not expect really high level output signals from the board.
JH.
Stavros
PostPosted: Sat Dec 08, 2007 4:07 am    Post subject: Re: JH. Triple Chorus – Connections Diagram with 1p2t switch Reply with quote  Mark this post and the followings unread
Many Thanks Jurgen
SG
softfin
PostPosted: Mon Dec 10, 2007 8:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Received my boards today, thanks Jurgen!
pdub
PostPosted: Mon Dec 10, 2007 11:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Got mine today! Thanks!
Charles.
numbernone
PostPosted: Wed Dec 12, 2007 2:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
My board arrived today YAY!!
Cant wait to put it the JH envelope at home with my Tau, and wait for its friends the Compact A and Frequency shifters. Ultimately they will all end up in one nice high quality unit. I aint even thinking about starting on any of these until I can clear some serious space and time. Tho I do like looking at the boards becasue they are dense gorgeous monsters.
eframp
PostPosted: Thu Dec 13, 2007 8:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Stavros
PostPosted: Thu Dec 13, 2007 2:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
I also got mine today,
many thanks and Regards
SG
The Alison Project
PostPosted: Fri Dec 14, 2007 2:55 am    Post subject: Reply with quote  Mark this post and the followings unread
My boards arrived today, thank you.
The Alison Project
www.thealisonproject.com
numbernone
PostPosted: Fri Dec 14, 2007 12:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
YAY got my TDAs from Grandata today
NOT SO YAY they are definitely pulled from something else!!! Many bent pins!!! That I can deal with...BUT one pin has snapped off completely!!! There is the upper half of the pin still intact. anyone have a great idea about how to utilise it?? I imagine that I can stick a bit of resistor lead into the socket before hand and then solder it to the remaining nub on the chip??? Or am i up the creek without a pin1??
whomper
PostPosted: Sat Dec 15, 2007 10:27 am    Post subject: A newbe Q re power supply Reply with quote  Mark this post and the followings unread
I am sorry for such a basic question Embarassed but will want to power both the Tau and Solina using one power supply in a parallel feed.
What power supply should I use, AC or DC? What's the recommended amp?
Thanks,
Whomper
jhaible
PostPosted: Sat Dec 15, 2007 10:49 am    Post subject: Re: A newbe Q re power supply Reply with quote  Mark this post and the followings unread
whomper wrote:
Thanks,
Whomper
If you want to feed parallel, you *must* go for +/-15V DC on both boards.
(Build the MOTM version in that case, without the rectifiers and bic electrolytic storage caps.
Do *not* feed them both from the same AC source!
But really, if you don't have a +/- 15V supply _already_, it's easier to just use two 16 ... 18V AC wallwarts, by far.
JH.
whomper
PostPosted: Sat Dec 15, 2007 2:31 pm    Post subject: Re: A newbe Q re power supply Reply with quote  Mark this post and the followings unread
jhaible wrote:
whomper wrote:
Thanks,
Whomper
JH.
It seems like I only find VDC around. Can I connect 15VDC 1.5A to both boards? Is it enough amper?
Whomper
jhaible
PostPosted: Sat Dec 15, 2007 4:01 pm    Post subject: Re: A newbe Q re power supply Reply with quote  Mark this post and the followings unread
whomper wrote:
jhaible wrote:
whomper wrote:
Thanks,
Whomper
JH.
Whomper
You need +/-15V (= two 15V DC sources) for the Tau, and just a single -15V DC source for the Triple Chorus. You can only connect DC when the boards are modified as documented on my web site. (Look for "MOTM version".) 1.5A is plenty. What you need is more in the 0.1A range.
JH.
vtl5c3
PostPosted: Sun Dec 16, 2007 10:56 am    Post subject: Reply with quote  Mark this post and the followings unread
For those who still need them, Chipforbrains is selling TDA 1022s on ebay. Reasonable price (US $4.89). Ordered 5 for myself. Looks like theres around 85 units left.
RF
Usine Karate
PostPosted: Sun Dec 16, 2007 11:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the heads up Vtl5c3, ordered mine. I did a little search on Chipforbains, I'm guessing they are a reputable dealer?
On another topic, has anyone designed any panel layouts for their triple chorus? I'm roughing one out at the moment and it'd be good to see what others are doing.
Usine
jhaible
PostPosted: Sun Dec 16, 2007 1:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've designed a 1U rackmount panel.
And I know of someone who is working on a MOTM panel.
JH.
jh_triple_chorus_1HE.pdf
50% sized PDF of my 1HE Schaeffer panel.
The original is white lettering on blue backround.
 Filename:  jh_triple_chorus_1HE.pdf
 Filesize:  29.59 KB
 Downloaded:  310 Time(s)
Usine Karate
PostPosted: Sun Dec 16, 2007 2:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks JH,
I'm working on a Blacet design and I'm not sure what to include (ie. bringing all the trimmers to the front) So it's good to see what others are doing.
Is the knob next to the modulation switch R337 ?
Also wondering how to calibrate this to get the 'Solina' sound (R173, R294), will I need an oscilloscope? Or is 'by ear' the best fashion?
Thanks
Usine
vtl5c3
PostPosted: Sun Dec 16, 2007 3:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've heard that he is good to do business with. As for personal experience, I bought a batch of 6 SSM2044s from CFB and got 6 good chips for a very reasonable price. Smile
it's HK SuperSeller that I'm wary of. Confused
prophei
PostPosted: Sun Dec 16, 2007 7:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
got mine too! thanks jurgen
The Alison Project
PostPosted: Sun Dec 16, 2007 8:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've done two orders with Chipforbrains and both orders went smoothly, one even included some extras... I would order from again.
The Alison Project
germaniac
PostPosted: Mon Dec 17, 2007 12:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey JH, got my PCBs--top notch! sunny Thanks!
Hey vtl5c3, thanks for the 1022 head's up! I got some extras, so I'll be ready for more JH BBD projects, or have some spares in case somebody's really desperate. . . .
Regards,
Joe
vtl5c3
PostPosted: Mon Dec 17, 2007 12:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Got my board today! Can't wait to stuff and solder this bad boy!
whomper
PostPosted: Mon Dec 17, 2007 1:43 pm    Post subject: Power Supply Reply with quote  Mark this post and the followings unread
I am having trouble finding a 16VAC power supply for the board that works at 220V.
Anyone with a good online shop that carries 220V 16VAC power supply?
Thanks,
Whomper
norman phay
PostPosted: Tue Dec 18, 2007 10:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Boards arrived today. Tons of thanks, JH.
