dioioib
Posted: Mon Jun 16, 2008 6:10 am Post subject:
Is the G2 expansion board worth buying? |
| Is the G2 expansion board worth buying. I'm not overly concerned with polyphony but I am interested in making more complex patches. I can not find much detail on the additional features this board will give me. Can anyone make a suggestion. |
Joined: Apr 03, 2004 Posts: 24489 Location: The Netherlands, Enschede
Posted: Mon Jun 16, 2008 10:24 am Post subject:
And personally I think the expansion to be useful for making larger patches, this due to the possibility to exchange information between patch parts through audio buses and the internal MIDI communications. Anyway, that's the way how I use the expansion mostly. _________________ Jan
dioioib
Posted: Mon Jun 16, 2008 3:29 pm Post subject:
Wow thanks for the links.
I'm seriously considering buying it.
Would you suggest getting it professionally installed or is it something I can do myself? I read the tech docs on install and it looks easy but I dont want to void the warranty. |
Posted: Mon Jun 16, 2008 3:53 pm Post subject:
When I was searching for the above links I also found a couple about the installation & wondered if I should include those I used the forum search function for that with the phrase "g2 AND expansion" selectivly on the Nord modular forum - in case you would want to search yourself.
It boils down to : it's not hard to do it yourself.
When you encounter problems you can post a question here & will likely get a response to it. Most people here having an expansion installed it themselves. Even when I order my engines with expansion I got the expansions delivered separately. _________________ Jan
BobTheDog
Posted: Tue Jun 17, 2008 12:18 am Post subject:
It is very easy to fit in the keyboard as well.
Andy |
dioioib
Posted: Tue Jun 17, 2008 5:32 am Post subject:
| I have been reading that some people are missing the spacers for the expansion board. Is there a suitable replacement? Are they metric hex spacers, plastic, etc? |
Flevo
Posted: Tue Jun 17, 2008 12:01 pm Post subject:
| i just discovered that with an expansion board you can also use the vocoder!! |
Fozzie
Joined: Jun 04, 2004 Posts: 875 Location: Near Wageningen, the Netherlands
G2 patch files: 49
Posted: Tue Jun 17, 2008 2:38 pm Post subject:
| Flevo wrote: | | i just discovered that with an expansion board you can also use the vocoder!! |
Well, yes, you can. But you can use the vocoder module as well without the expansion. It doesn't matter which modules you use with the expansion, you just get a net doubling of processing power. _________________ Spinning at ~0.0000115740740741 Hz |
Joined: Jan 31, 2003 Posts: 18253 Location: Durham, NC
Audio files: 227
Posted: Tue Jun 17, 2008 3:33 pm Post subject:
To me, the expansion board is essential. Get it.  _________________ --Howard
my music and other stuff |
ark
G2 patch files: 31
Posted: Mon Jun 30, 2008 12:57 pm Post subject:
| If you have not already purchased a G2, I suppose it's worth mentioning that novamusik.com is selling a G2 plus an expansion board and gig bag for the same price that most people are charging for a G2 alone. |
