Korg MS-50 filter
Page 1 of 2 [27 Posts]
widdly
PostPosted: Wed Jul 16, 2008 12:34 am    Post subject: Korg MS-50 filter Reply with quote  Mark this post and the followings unread
Anyone know anything about the Korg ms-50 filter?
There is a schematic here..
http://machines.hyperreal.org/manufacturers/Korg/MS-synths/schematics/ms50filt.gif
Looks kinda interesting
PostPosted: Wed Jul 16, 2008 2:21 am    Post subject: Reply with quote  Mark this post and the followings unread
I used to own an MS50- it was a lot of fun, probably more than the MS20 (which I still own), but I don't remember the filter being really remarkable. Personally I would save your energy, and build Ian Frijitz's Threeler instead Smile
widdly
PostPosted: Wed Jul 16, 2008 3:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Of course I should build a Threeler. I should also get the resonance in my late ms20 filter working.
..but you can never have enough filters.
The arrangement of diodes in the schematic just looks strange to me. The rectifier in the middle bit. no quite a ladder.
PostPosted: Wed Jul 16, 2008 3:30 am    Post subject: Reply with quote  Mark this post and the followings unread
I imagine that the rectifier is there to keep the feedback (resonance) in check?- Similar process to the Trancendent 2000 design by Tim Orr?
Everybody in the 70's had a way of trying to get round Moog's then patented transistor ladder- using diodes was just another way- very similar to the EMS synthi filter I suppose? But before you say "Hey that filter was really unique"- think for a moment why it was unique.... because I think the EMS filter was unique because of the way it handled modulation signals, and not necessarily the sound.
If you want a really unique sounding filter, then its gotta be the Threeler or Steiner one etc. Wasn't it a rogue capacitor in the EMS modulation input that gave it that weird response that could sound really nice and bubbly??
bubblechamber
PostPosted: Wed Jul 16, 2008 2:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
i'm finishing up a layout for the ms20 filter and i should be posting it over the weekend, if anyone is interested.
a.b.o.z.
G2 patch files: 4
PostPosted: Wed Jul 16, 2008 3:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
post it in PCB layout sub-forum.
great, thnx!!
Peake
PostPosted: Thu Jul 17, 2008 9:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
I remember MS50 filter as being a bit noisy. It obviously uses the peskily expensive CA3019, but I suppose that one could match diodes in its place.
vtl5c3
PostPosted: Mon Jul 21, 2008 8:07 am    Post subject: Reply with quote  Mark this post and the followings unread
I built a couple of them about 10 years ago. The CV rejection is pretty bad, so it's no good for sequenced CV control (unless you like that clicky sound). For pads it is kinda nice, has sort of a "glassy" type sound that reminds me a bit of things I've heard done with the EMS synthi. I'd say it's not a "must have" VCF...
macumbista
PostPosted: Sun Jun 28, 2009 10:35 am    Post subject: Reply with quote  Mark this post and the followings unread
Bringing this thread back from the dead... I'm actually interested in the VCA in the same schemo (Jessica Rylan raves about this diode bridge VCA!). I won't be using it with sequenced CV, only as AM modulator in dual VCO setup.
So, three questions:
1) Anybody have any impressions good or bad?
2) Anybody try to build it? Looks simple enough (excpet diode IC).
3) Any tips for matching diodes to get rid of 3019 IC?
Thx!
Derek
macumbista.net
PostPosted: Sun Jun 28, 2009 2:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
measure them with your DDM? Wink
macumbista
PostPosted: Sun Jun 28, 2009 2:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah yeah. I found some stuff on Google 10.3 seconds after I posted that question Wink
macumbista.net
PostPosted: Sun Jun 28, 2009 2:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
i have to ask myself: what is a Digital DultiMeter? Laughing
macumbista
PostPosted: Sun Jun 28, 2009 2:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is it something like a Sonic Screwdriver?
macumbista.net
CJ Miller
PostPosted: Mon Jun 29, 2009 11:12 am    Post subject: Reply with quote  Mark this post and the followings unread
I used to work with Jessica in Boston years ago, now I see traces of her on dozens of websites, boards, etc. every day! It's funny!
1. I got to play with the MS synths years ago. The word which came to my mind about the MS50 VCF was: "brittle". I liked it.
2. I did try to breadboard a version way back based on the nixed EFM clone of it. My breadboarding sucks, but it worked. When I wiggled the wires just so. Didn't have much of a setup to play with it then. My focus has been away from filters but I'll definately come back to it.
3. What does one match them for, forward drop? I didn't bother matching mine, which probably makes the rejection even worse. Now I'd probably use some other diode array or a transistor array connected as diodes.
PostPosted: Mon Jun 29, 2009 11:38 am    Post subject: Reply with quote  Mark this post and the followings unread
CJ Miller wrote:
... or a transistor array connected as diodes.
how does one do that?
frijitz
Audio files: 54
PostPosted: Mon Jun 29, 2009 12:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just connect collector and base for each transistor. The base - emitter junction forms your diode.
Ian
PostPosted: Mon Jun 29, 2009 1:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
thank you very much. i wonder where do you learn such things...
creekree
PostPosted: Mon Jun 29, 2009 4:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
i learned it right here, in this electro-music.com thread Cool
CJ Miller
PostPosted: Tue Jun 30, 2009 6:18 am    Post subject: Reply with quote  Mark this post and the followings unread
IIRC, I learned it on the Synth-DIY list some time ago. But I am a tempermental slowpoke, so I am sure that many have put this knowledge to better use than I have been able! Things are starting to come together..
CJ Miller
PostPosted: Tue Jun 30, 2009 6:34 am    Post subject: Reply with quote  Mark this post and the followings unread
I have been scanning old EFM projects for the archives, and it so happens that this weekend I had found the MS50 clone I was riffing off of. It's a nice starting point.
 Filesize:  87.63 KB
 Viewed:  653 Time(s)
 Filesize:  104.73 KB
 Viewed:  344 Time(s)
 Filesize:  154.07 KB
 Viewed:  348 Time(s)
macumbista
PostPosted: Tue Jun 30, 2009 7:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Did you make a stab at the VCA too?
macumbista.net
CJ Miller
PostPosted: Tue Jun 30, 2009 8:04 am    Post subject: Reply with quote  Mark this post and the followings unread
No, I didn't. In fact, at that stage (1998-2000) I didn't even use VCAs at all! Just lots of inarticulate droning, bleeping nonsense - which was great fun! Then just before I packed my circuits away and moved to NYC, I made a board with six 13600 VCAs. They worked surprisingly well considering how crude the build was.
Ok, I just finally got my first look at this schematic in recent memory, and yes the VCA looks crazy. And looking for this I found an MS20 VCA which is basically the CV through the base of a transistor connected to a vactrol! Ingenious weirdness there.
Got to go get a few hours sleep now
macumbista
PostPosted: Tue Jun 30, 2009 8:20 am    Post subject: Reply with quote  Mark this post and the followings unread
I'm all in for inarticulate droning! I just wanted to use the multiplier in the circuit for rough AM/ringmod action... I have an allergy to sequencers, or maybe that's just to boring, mechanistic repeating patterns in general. Give me chaos and mutation any day Wink
macumbista.net
CJ Miller
PostPosted: Tue Jun 30, 2009 2:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's a later version of Tom's EFM VCF5. Got to split!
 Filesize:  161.23 KB
 Viewed:  679 Time(s)
forbin
PostPosted: Mon Oct 26, 2009 1:13 am    Post subject: Reply with quote  Mark this post and the followings unread
Interesting! Has anybody any experience with the EFM VCF5? It is certainly a bit of a different topology from any of the other VCF's i have looked at. I have done a SPICE simulation and it looks OK. Not super sharp at 12dB/oct but could be worth the effort nevertheless...
SPICE Model of MS50 VCF
 Filesize:  283.78 KB
 Viewed:  478 Time(s)
