281 clone project- taking orders now for last run of these..
Page 20 of 38 [926 Posts]
Goto page: Previous 1, 2, 3, ..., 18, 19, 20, 21, 22, ..., 36, 37, 38 Next
interested in a PCB or 4?
yep
98%
 98%  [ 151 ]
nope
1%
 1%  [ 2 ]
Total Votes : 153
PostPosted: Wed Jul 23, 2008 2:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
zthee wrote:
Any ideas?
At what frequency did you look at the wave forms, and was it the same frequency in both cases?
zthee
PostPosted: Wed Jul 23, 2008 3:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
zthee wrote:
Any ideas?
Yes, and yes.
To me it's confusing and wierd.. I still belive it's a power supply issue, but I don't know how to solve it..
PostPosted: Wed Jul 23, 2008 4:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes Hz of yes kHz? Laughing
It looks like the wave got flattened due to capacitive coupling, but for a 5 kHz wave this could be acceptable, not so for a 50 Hz wave though.
toppobrillo
PostPosted: Wed Jul 23, 2008 4:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
you checked that the CMOS is getting 10V?
Rykhaard
PostPosted: Wed Jul 23, 2008 9:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't know if this could be the case but since you're using 1/4" connectors, they're all Grounding to your aluminiunium (Sp?? Wink ) panel. I wonder if you could have a Ground short, from something??
(Still having to build mine. (sigh))
Peake
PostPosted: Thu Jul 24, 2008 12:00 am    Post subject: Reply with quote  Mark this post and the followings unread
Wait a second! Ryk Thekreator?! I've been wondering where you've been for years, and there you are! Dude! So glad to see you around, and staying busy with the synth stuff!
zthee
PostPosted: Thu Jul 24, 2008 2:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
Blue Hell, Very Happy It looks the same in both Hz and KHz..
Topp, I'll doublecheck it!
Thanks guys!
PostPosted: Thu Jul 24, 2008 2:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
That's bad Laughing
toppobrillo
PostPosted: Thu Jul 24, 2008 5:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
update: we are a little over 1/2 way to a 2nd run..
so if you want any/more, now is the time to speak up....
Rykhaard
PostPosted: Thu Jul 24, 2008 9:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Wait ...... is it Mike Peake?? As soon as I read what you just writ above, the first name came back to me - I THINK. Please rem'ber - me gettin' old. Wink Smile
Now, are we speaking Synth-DIY or ...... I think Analogue Heaven, wasn't it??? Very Happy I don't think as far back as rec.music.synth in '92 or so .... ?
Aye. Disappeared in '98 or '99 from just about everywhere. (Bad 'no get up and go' time in life, for a few years. Moved to Propellerheads Reason from '01 to '06; started building again finally in middle of '05, fully waking up and dumping Reason in early '06 and DAMN glad to be back! Smile
Still trying to find a couple of people also. Have been since coming back to building, with no luck. Sad Roy Tate - know where he might be, by chance? Smile
What YOU up ta? Very Happy
Peake
PostPosted: Thu Jul 24, 2008 10:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ryk, check your PM.
Josh, I'd take yet another six boards. Thanks!
funkyfarm
PostPosted: Sat Jul 26, 2008 4:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'm sorry but i didn't understand why you went for separate GATE/TRIG sockets...you can't patch them both at the "same" time (for retriggering)
that's the function switch that matters ?
loopcycle
PostPosted: Sat Jul 26, 2008 11:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
i would like to get on the list for four pcbs.
numbertalk
PostPosted: Mon Jul 28, 2008 3:32 pm    Post subject: Reply with quote  Mark this post and the followings unread
We there yet? Smile
toppobrillo
PostPosted: Mon Jul 28, 2008 4:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
josh, where do you get your switch caps?
sorry i didn't see this.. the switch caps i aquired with some old junk i can't remember where.. aren't theybasically the same as the ones available through mouser? maybe less glossy.
We there yet? Smile
not quite.. maybe a dozen more or so?
a_guy_called_tom
PostPosted: Tue Aug 05, 2008 10:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi all,
i'm having a problem with my env, the attack and decay times seem to be very very short. In cycle mode i can hear that the cycle is very short (audio frequency) and seems to change only very slightly when i turn VR2 or VR1. Since i dont understand really much about the circuit, does anyone have an idea what could cause this or give me a pointer at which parts to look?
Another thing, if i dont attach the LEDs, is it still necessary to have R33 and R30? I inserted the resistors but dont have any LEDs yet and i'm not quite sure about how to calculate the right values for the Resistors.
Any help would be much appreciated,
Tom
toppobrillo
PostPosted: Tue Aug 05, 2008 3:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
hi, when you turn the trim pot, does the frequency change? do you have an oscilloscope? are you 100% certain you have all wires connected properly?
ericcoleridge
PostPosted: Tue Aug 05, 2008 4:07 pm    Post subject: Reply with quote  Mark this post and the followings unread
I also have question--haven't finished my boards, but:
I installed my quadrature circuitry on my "A" boards by accident-- I wasn't reading carefully enough, I guess.
Is there any reason why they wouldn't work correctly here? They are my "A" boards, because besides the quad circuit, they're assembled according to "A" parts list.
Obviously, it wouldn't be too much to change this, or to add the quad circuitry to "B" boards, but if there's no reason to--I rather not.
Any suggestions? Thanks
toppobrillo
PostPosted: Tue Aug 05, 2008 4:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
no no difference, just wire it up as it's shown.
ericcoleridge
PostPosted: Wed Aug 06, 2008 8:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks Topp. I'm glad to know this...
a_guy_called_tom
PostPosted: Wed Aug 06, 2008 9:55 am    Post subject: Reply with quote  Mark this post and the followings unread
when i turn the trim pot, the frequency changes, but not as much as i'd expect (maybe from 800Hz to 850Hz in cycle mode or something like this, just guessing). Unfortunately i dont have an oscilloscope here, but i'll certainly doublecheck my wires again and also the caps values.
Thanks for helping!
toppobrillo
PostPosted: Wed Aug 06, 2008 3:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok, it looks like we have enough preorders for a 2nd run. i am emailing everyone for confirmation, as soon as i have that, i can place the order...
@ a_guy_called_tom:
it sounds like something could be up around the current source. what FET and zener did you use? do you have a DMM? double check resistor values and all solder joints.
ok good luck, it's probably something simple.
a_guy_called_tom
PostPosted: Wed Aug 06, 2008 10:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
For the zener i use a BZX85B10 and the MPF-102 is replaced with a BF245B. Yeah, i have a DMM. Will check the joints and values again. Thanks for the hints!
toppobrillo
PostPosted: Thu Aug 07, 2008 2:50 am    Post subject: Reply with quote  Mark this post and the followings unread
you realize the pinout is reverse, right?
a_guy_called_tom
PostPosted: Thu Aug 07, 2008 10:07 am    Post subject:   Reply with quote  Mark this post and the followings unread
Topp, you've hit the nail on the head. Now that the FET sits in there correctly, all works fine and dandy. Now its time to improve the design of the frontpanel.Thanks a bunch!
 Filesize:  49.06 KB
 Viewed:  10225 Time(s)
