281 clone project- taking orders now for last run of these..
Page 22 of 38 [926 Posts]
Goto page: Previous 1, 2, 3, ..., 20, 21, 22, 23, 24, ..., 36, 37, 38 Next
interested in a PCB or 4?
yep
98%
 98%  [ 151 ]
nope
1%
 1%  [ 2 ]
Total Votes : 153
numbertalk
PostPosted: Sun Aug 24, 2008 9:25 am    Post subject: Reply with quote  Mark this post and the followings unread
You haven't sent invoices yet have you? I got a message with a template for an email request which I sent off - just making sure you got it and I haven't missed anything.
toppobrillo
PostPosted: Sun Aug 24, 2008 1:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
What is GATE Priority in cycle mode ?
hey it just means that with this diode installed, a gate at the input is able to hold the FG high as in ASR mode. without it, you can only retrigger the FG as it decays.
hope that makes sense...
funkyfarm
PostPosted: Tue Aug 26, 2008 4:25 am    Post subject: Reply with quote  Mark this post and the followings unread
I guess I understand ; but this a preliminary choice you make before building the unit ; no gate priority ON/OFF switch is required.
I'll test with my ears.
Thank you.
julianw
PostPosted: Tue Aug 26, 2008 1:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just populating the boards at the moment, there seem to be 2 x D6 marked on the silkscreen, I think one must be D2.
I'm putting the peak circuitry components onto board A (R43-R47 & Q5-Q6) and leaving them off board B.
Also I am not soldering C4 (47uF) onto board B, as it says in the BOM only one per pair is recommended.
I'd appreciate it if anyone could let me know if it sounds like I'm doing anything wrong here,
Cheers, Julian
toppobrillo
PostPosted: Tue Aug 26, 2008 2:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
yep it was a mistake
it is ok
good too
julianw
PostPosted: Wed Aug 27, 2008 7:27 am    Post subject: Reply with quote  Mark this post and the followings unread
it is ok
good too
Thanks for the advice and the boards, Very Happy sorry for being such a noob.
I am going to attempt to put 4 of these behind a 2U MOTM panel (powered from a single T0-220 regulator as you suggested in one of the PDFs.)
I'll post back with a fpd panel layout once I've figured it out.
a.b.o.z.
G2 patch files: 4
PostPosted: Wed Aug 27, 2008 7:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Same here.
I suppose boards didn't arrived from manufacturer.
sduck
PostPosted: Wed Aug 27, 2008 11:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Please do - I'd love to see how you make it fit! I've been toing with various ideas - 2 behind a 2u panel, or 4 behind a 3u panel, but haven't made any decisions yet.
303monkey
PostPosted: Wed Aug 27, 2008 2:57 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Josh.
I placed an order for 8 boards. I thought I would confirm my order.
toppobrillo
PostPosted: Wed Aug 27, 2008 3:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
ok, i got it.
i ran into a little [well not that little] financial setback, so i plan to place the order early next week. sorry! shit happens. but they are going to be on a 12-day turnaround which isn't too bad.
anyways i will post here when there are status updates so don't worry.
thanks!
a.b.o.z.
G2 patch files: 4
PostPosted: Wed Aug 27, 2008 3:49 pm    Post subject:   Reply with quote  Mark this post and the followings unread
i'm in financial setback at the moment also. it will get better Smile
funkyfarm
PostPosted: Fri Aug 29, 2008 5:39 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here is my layout, in my hybrid 4U "MOTM pot spacing/Eurorack sockets" format ?!
i'm drooling, it's such an attractive piece you offer us !
BUCHLA 281 15.PDF
 Filename:  BUCHLA 281 15.PDF
 Filesize:  152.45 KB
 Downloaded:  585 Time(s)
loss1234
PostPosted: Sun Sep 07, 2008 9:06 am    Post subject: Reply with quote  Mark this post and the followings unread
anyone on here have a FPD file for a DUAL version (frac preferred but ANY format would help) of this module?
i have been studying the designs on here but i am having trouble getting them to print in actual size, which is why i thought a FPD would be good because i could measure the distances between things...
i want to get this thing built!!!
thanks
oh and just a question, there is a definite advantage to building it as a dual right? (as opposed to just making 2 singles?)
/mr
PostPosted: Sun Sep 07, 2008 9:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Definitely.
Why not a quad? I feel sorry for all the duals. Laughing
numbertalk
PostPosted: Sun Sep 07, 2008 10:06 am    Post subject: Reply with quote  Mark this post and the followings unread
An FPD file for a quad panel would be great too.
/mr wrote:
Definitely.
toppobrillo
PostPosted: Thu Sep 11, 2008 2:54 am    Post subject: Reply with quote  Mark this post and the followings unread
hey wahts up everyone- an update: i am about to send files off for manufacture, emailing those who have not confirmed now. if you have not confirmed at the yahoo email i emailed you, then i can't guarantee i will have PCBs for you... maybe but maybe not...
anyways, i got the full version of the PCB software and thus have made quite a few changes to the board. i posted a list at my website, most of which are very minor, but a couple things will be more significant, especially to those who ordered before and possibly perhaps made/laid out panels.
here is the list and a little explanation:
added wire pads for control pots for convenience if you choose to wire your pots instead of using PCB mt. pots.
added R47 [1K at 'po']- was MIA on original
added pads for 4-pin .156" power header- love it or leave it, it's there, but the .1" pwr connector remains at nearly the same position it was on V2 pcb.
added 10V trace that eliminates flying wire [requires 2 jumpers tho.. still singlesided]
added extra 10V pad near 4016
added 2 gnd pads at PWR header
added 47K [now called R48] that was previously wired off-board
fixed R35 boo boo- now PCB reflects schematic. mode switch wiring is simple.
spaced all 4 mounting holes at 1/8" from edge bothways
moved pots in- VR2 ['outermost' PCB mt. pot] now at 1/2" center to edge- still spaced at 1" center to center.
i think that's it for the more significant stuff. i think i am going to make these new board soldermasks a new color as well.. not sure which yet. they are all the same amt. extra.
will make new docs in the meanwhile...
any comments? questions?
 Filesize:  35.81 KB
 Viewed:  9259 Time(s)
Rykhaard
PostPosted: Thu Sep 11, 2008 6:55 am    Post subject: Reply with quote  Mark this post and the followings unread
I had never received anything asking that I confirm my request for 3 of them, to a Yahoo address. ? I just sent my request to a PM.
So, here's my request for 3 of them - in public. Smile
a.b.o.z.
G2 patch files: 4
PostPosted: Thu Sep 11, 2008 8:40 am    Post subject:   Reply with quote  Mark this post and the followings unread
oh boy oh boy oh boy
great news.
can't wait for it.
woohoo
zthee
PostPosted: Thu Sep 11, 2008 9:11 am    Post subject: Reply with quote  Mark this post and the followings unread
I just discovered I need 4 new boards..
Is there a chance there might be a set to spare..?
toppobrillo
PostPosted: Thu Sep 11, 2008 5:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
ryk- got it
zthee- PM'd you
ringer
PostPosted: Thu Sep 11, 2008 7:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Topp,
Same with the confirmation for 8 from me, thanks.
Regards,
Ringer
zthee
PostPosted: Thu Sep 11, 2008 11:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
topp wrote:
zthee- PM'd you
Ooops, I totaly missed that. Sorry!
numbertalk
PostPosted: Fri Sep 12, 2008 10:18 am    Post subject: Reply with quote  Mark this post and the followings unread
Great - pretty certain I'm squared away with you for 4 boards.
lexvortex
PostPosted: Fri Sep 12, 2008 1:52 pm    Post subject: 4 PCBs
Subject description: did not receive confirmation
I did not receive a confirmation email for the 4 PCBs I reserved. I will PM again the order Smile
Thanks,
phdinfunk
PostPosted: Sun Sep 14, 2008 9:03 am    Post subject: PM'ed Reply with quote  Mark this post and the followings unread
Hey I PM'ed to see if you've got any of these left...
haven't heard from ya. It looks like you had 'em on the 11th... I want six if you have them.
--Jonathan
