Posted: Mon Aug 25, 2008 8:09 am Post subject:
| a.b.o.z. wrote: | | fonik wrote: | | sent out the first batch today. i don't have the time to PM everyone today. nevertheless everyone whos PCBs have been sent will receive a PM this weekend... |
didn't get that PM. hmmm
I've sent payment. Did you get it?
Or you didn't had time to send PMs. |
my fault. you are right, i did not have the time, yet, which is not what i wanted... _________________
Tech Buddy at Random*Source |
Peake
Joined: Jun 29, 2007 Posts: 1113 Location: Loss Angeles
Posted: Mon Aug 25, 2008 9:57 am Post subject:
Thank you very much!! Your time and effort are appreciated! _________________ We are selling emotions, there are no emotions in a grid. -mwagener
"IC 741. Sometimes you don't want fidelity." -Small Bear Electronics Catalog |
a.b.o.z.
Joined: Feb 07, 2007 Posts: 351 Location: Zagreb, Croatia
G2 patch files: 4
Posted: Mon Aug 25, 2008 11:21 am Post subject:
| fonik wrote: | | a.b.o.z. wrote: | | fonik wrote: | | sent out the first batch today. i don't have the time to PM everyone today. nevertheless everyone whos PCBs have been sent will receive a PM this weekend... |
my fault. you are right, i did not have the time, yet, which is not what i wanted... |
hei no problemo at all.
thxn |
Danno Gee Ray
Joined: Sep 25, 2005 Posts: 1351 Location: Telford, PA USA
Posted: Tue Aug 26, 2008 9:25 am Post subject:
Received my two boards today. They look great!
Thanks Mathias. |
numbertalk
Posted: Tue Aug 26, 2008 2:10 pm Post subject:
| Got mine too - thanks!!! |
a_guy_called_tom
Posted: Wed Aug 27, 2008 9:10 am Post subject:
| mine arrived too, they look great. Thanks alot! |
a.b.o.z.
G2 patch files: 4
Posted: Thu Aug 28, 2008 10:00 am Post subject:
got mine today.
great!!
thnx M. |
ericcoleridge
Posted: Thu Aug 28, 2008 2:06 pm Post subject:
I also got mine today. Beautiful job.  |
Peake
Posted: Thu Aug 28, 2008 5:49 pm Post subject:
Received! Thank you very much!
Edit: I don't see any 1% resistors indicated in the documetation. I'll thus take it that there are none required or recommended? That the trimpots negate the need? Thanks! _________________ We are selling emotions, there are no emotions in a grid. -mwagener
rjd2
Posted: Fri Aug 29, 2008 12:03 pm Post subject:
so ive got a question here, sorry to be daft about this, but need to confirm something...
do the individual input pots work like this: hard R=full gain, hard L=full gain inverted, 12 oclock=0 gain?
it just popped into my head that if i am reading this right, this would be a hugely utilitarian module for me down the line. if so, are there any spare boards available? thanks. |
Posted: Fri Aug 29, 2008 12:49 pm Post subject:
| Peake wrote: | Received! Thank you very much!
Edit: I don't see any 1% resistors indicated in the documetation. I'll thus take it that there are none required or recommended? That the trimpots negate the need? Thanks! |
you are absolutely right. BTW i am always using 1% resistors since they are not much more expensive at the store i buy them... _________________
Posted: Fri Aug 29, 2008 12:53 pm Post subject:
| rjd2 wrote: | so ive got a question here, sorry to be daft about this, but need to confirm something...
do the individual input pots work like this: hard R=full gain, hard L=full gain inverted, 12 oclock=0 gain? |
correct. the trimmers are needed to calibrate the 0V at 12 o'clock (potentiometers usualy have tolerances about 10-20%)
| Quote: | | it just popped into my head that if i am reading this right, this would be a hugely utilitarian module for me down the line. if so, are there any spare boards available? thanks. |
there are still PCBs left.
just tell me how many you need. _________________
rjd2
Posted: Fri Aug 29, 2008 7:07 pm Post subject:
| question on caps-any of the values should be film or polystyrene or anything? im planning on using these as VCO summers, among other uses. |
crashlander42
Joined: Oct 21, 2006 Posts: 292 Location: Orlando, FL (US)
Posted: Sat Aug 30, 2008 3:33 pm Post subject:
| rjd2 wrote: | | question on caps-any of the values should be film or polystyrene or anything? im planning on using these as VCO summers, among other uses. |
there are no capacitors in the audiopath. using poly for decoupling is a good choice, i think. _________________
Fungitec
Posted: Mon Sep 08, 2008 1:45 pm Post subject:
Still boards available...? |
Is there by any chance boards left here Fonik? If thats the case, I would like a pair of them. Please sign me up for two if you still got any spares... plz. Thanx
/thure |
Posted: Mon Sep 08, 2008 10:48 pm Post subject:
still some boards left. check PM. _________________
loopcycle
Posted: Wed Sep 17, 2008 7:26 pm Post subject:
| received my boards. beautiful work! thanks for this. |
Peake
Posted: Tue Sep 23, 2008 2:39 am Post subject:
I've got a board up and running- great stuff! My first intent is to use it to substitute for a power supply for the Moog Modules, until I get one built: 12V, -6V, and -10V rails are required (the classic power supply does not regulate the -10V). For some reason, I was only getting 1V at the internal/jack normal'd source, so I jumpered R29 to pass the full 15V to the pots. Presto, just set the pots to the desired voltages. I don't know if this will work in powering the modules yet, but it's fun to play with
Thanks a bunch for the second run!! _________________ We are selling emotions, there are no emotions in a grid. -mwagener
loss1234
Posted: Tue Sep 23, 2008 8:26 am Post subject:
| loss1234 wrote: | does anyone think i could get away with using SINGLE TURN 50k trimmers?
i really want to get this built (mainly as an audio mixer) and i have tons of single turn trimmers but NO 50k multi turn.
thanks |
actually you could get away without a trimmer and a fixed resistor instead. the trimmer is just to calibrate the processing potentiometer to OV at 12 o'clock. _________________
Posted: Tue Sep 23, 2008 8:31 am Post subject:
try a single turn trimmer. you could get set it with patience and a tranquil approach... _________________
LektroiD
Joined: Aug 23, 2008 Posts: 1019 Location: Scottish Borders
Posted: Tue Sep 23, 2008 9:53 am Post subject:
| fonik wrote: | | still some boards left. check PM. |
can I take one please?  |
Posted: Tue Sep 23, 2008 1:23 pm Post subject:
| Brainstormer wrote: | can I take one please?  |
sure, check PMs. _________________
LektroiD
