PIC-based fraktal synth
Page 4 of 8 [195 Posts]
oootini
PostPosted: Mon Sep 29, 2008 12:26 am    Post subject: Reply with quote  Mark this post and the followings unread
hey,
just a pitch shifting effect that adds minor and major harmonies to the signal...
catweazle
PostPosted: Mon Sep 29, 2008 2:42 am    Post subject: Reply with quote  Mark this post and the followings unread
@ootini:
very nice work!! I like that LEGO like case and I'm impressed about that
sound sample, sounds
If you can select more than 4 synths (5..Cool then you have the newest hex file. Synths 5..8 are not implemented yet.
Why learn C and roll your own? I recommend buying a cheap pic-programmer. Or the WinPIC800 (can prgram AVR and PIC)
If I get my prototype back, then I make a version for the C18 C-Compiler which is free.
Synths 1..4 should work,
synth 3 (step sequencer) : turn pot4, pitch for each step has to be fetched.
oootini
PostPosted: Mon Sep 29, 2008 5:24 am    Post subject: Reply with quote  Mark this post and the followings unread
cheers catweazle. i do have a pic programmer, so maybe i will try and learn some C. don't hold your breath though Smile
PostPosted: Mon Sep 29, 2008 3:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
oootini,
I like this. Made me want to add all sorts of sounds FX on top of it and build it up .... A remix perhaps !!! Cool A chip tune remix ...........
Bill
oootini
PostPosted: Wed Oct 01, 2008 9:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey ho. I want to add a power supply connection to my picsynth. I have a couple of 9v effects pedal adapters, so I could use them without having to fuck with the existing pic synth power supply. Basically solder the connection thing in place of the 9v battery clip.
Only thing is, I don’t know what the little thing is called so I can order it. what are those little things called?
yerpa58
PostPosted: Fri Oct 03, 2008 11:17 am    Post subject: Reply with quote  Mark this post and the followings unread
They are called power jacks. Sometimes called barrel jacks. An example would be Digi-Key (digikey.com) part number CP-055D-ND, manufactured by CUI. Be sure to check the inside and outside diameters to match your parts.
oootini
PostPosted: Mon Oct 06, 2008 4:54 am    Post subject: Reply with quote  Mark this post and the followings unread
yep, sorted. thanks
akorbeti
PostPosted: Thu Oct 30, 2008 3:53 am    Post subject: shoeBox fraktalSynth Reply with quote  Mark this post and the followings unread
Hi all,
I have been watching this forum for some time but this is my first time
posting. It's my first time having something to show too Smile
I made the fraktal Synth and put it in a shoebox (hence the title). I have
some samples too.
My next move will be to pass it through MC 909 and actually use it to make
a tune.
for now, the only sample I have made is here:
http://sites.google.com/site/diysynth/Home/CatweazlesFractalSynth.mp3
for more photos you can go to http://synth-diy.blogspot.com/2008/10/shoebox-fractalsynth.html
photos also here: http://picasaweb.google.com/akorbeti/DiySynth
My daughter whined a bit for taking her box but I just gave it some added
value.. It is still hers. I only play with it when she's asleep. She likes to
play with it! It's so easy! No rules Smile
I might consider making one for giving it as a present to our neighbour's
little boy.!! It's a wonderful idea (well, for children only Smile )
Thank you Catweazle!!!
PostPosted: Sat Nov 01, 2008 11:33 am    Post subject: Reply with quote  Mark this post and the followings unread
some samples too.
Wow, great samples of the synth and thanks for all the pictures !!! Welcome to the forum and hope you are here to stay a while ! Very Happy
Bill ........
yerpa58
PostPosted: Sat Nov 01, 2008 12:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
I agree! That sample covers a lot of ground. I put up some cad pictures & a photo of my recently-completed fraktal synth. I added a one-watt amplifier and power switch. Now I have to practice playing it and see what it can do.
yerpa58http://www.reprolabs.com/fraktal_synth_1.htm
bleep!blorpblipblipblip
PostPosted: Sat Nov 01, 2008 1:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just wondering, with your Eagle .BRD files. Who are you using as your PCB house to process those files. I know that "PCB Pool" works with them but doing a quote with them did not beat EXPRESS PCB at all. Can you recommend any good, cheaper, PCB services that are compatible with the .BRD files?
Thanks and nice work on your end also sir. Very Happy
Bill
yerpa58
PostPosted: Mon Nov 03, 2008 11:40 am    Post subject: Reply with quote  Mark this post and the followings unread
I haven't used any services that take Eagle files directly. However, Eagle produces nice Gerber artwork and Excellon drill files, and I have sent these through BatchPCB (found on Sparkfun's site). I got very nice boards back from them, double-sided, silkscreened, solder-masked and plated through. Most PC board vendors can read these files.
For single-sided art, we plot quarter-panels full of PC boards onto clear film and send this film to Electronic Industries. (http://electronicindustries.net/. They charge about $125 for a 17" x 23" panel of PC boards. These are single-sided and drilled, sheared to size. No solder mask, no silkscreen. The company I work for sends in about a dozen of these per month, so I just snuck the fraktal synth on one of these orders. I have to convert to Auto-Cad to get it into our plot queue. This step is kind of labor-intensive and redundant. I use Eagle's DXF ulp, then tweak it by hand in AutoCad. If you want the Auto-Cad file for the fraktal synth, you can have it.
akorbeti
PostPosted: Mon Nov 03, 2008 3:24 pm    Post subject: babyBotte repackaged Reply with quote  Mark this post and the followings unread
Hi there again,
I just made a new shell for the fraktalSynth I posted about above.
The name still remains babyBotte because I liked it so much.
Its shelter now is an IKEA container which I processed accordingly.
The panel was made on photographic paper and was stuck on the lid.
The knob's background is color coded . Green for function, yellow
shades for parameters, red for output (volume/filter). The main
pushbutton is the top right so while pressing this with your left
thumb, you can use the same thumb to press another key.
and a small description at http://synth-diy.blogspot.com/2008/11/babybotte-repackaged.html
For more shots there is always the pool.
http://picasaweb.google.gr/akorbeti/DiySynth#
(BTW Should I move to flickr?)
Now it is VERY easy to play with it because it has a very solid
feeling. I might make a video sometime..
Thanks again for the synth catweazle..
hanley
PostPosted: Wed Nov 05, 2008 4:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
okvern wrote:
PICSynthBoards.zip: The main board and filter board, as 600ppi bilevel TIFFs. You'll need to look at the Eagle layouts for parts placement.
hey okvern
does your pcb image work off catweasles schematic or is it changed a bit?
my breadboarded picsynth is on its last legs so doin up a pcb for it
cheers
edit: nevermind, found the eagle file of the board
thanks
yerpa58
PostPosted: Sat Dec 06, 2008 12:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hello peoples
I added a plucked-string preset to the fraktal synth. Still having fun with this one. Code and sample at http://www.reprolabs.com/fs7.htm.
santa
nofrets
PostPosted: Sun Dec 14, 2008 6:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi folks -
Any recommendation on what programmer to use to burn this chip? Or, alternately, anyone willing to burn one for me?
Thanks,
Patrick
Gotta kick at the darkness 'til it bleeds daylight.
oootini
PostPosted: Sun Dec 14, 2008 10:29 am    Post subject: Reply with quote  Mark this post and the followings unread
nofrets
PostPosted: Mon Dec 15, 2008 4:17 am    Post subject: Reply with quote  Mark this post and the followings unread
oootini wrote:
http://cgi.ebay.ie/40-ZIF-USB-9-PIN-Interface-Microchip-PIC-Programmer_W0QQitemZ330294364858QQcmdZViewItemQQptZLH_DefaultDomain_3
will do the trick for ya.
Really? It doesn't say it supports the 18F4620 - are any mods/updates required to make it work?
Patrick
oootini
PostPosted: Mon Dec 15, 2008 6:03 am    Post subject: Reply with quote  Mark this post and the followings unread
yerpa58
PostPosted: Mon Dec 15, 2008 9:08 am    Post subject: Reply with quote  Mark this post and the followings unread
I've been using an old Microchip Picstart Plus to program the chip. I think there is a lot more this chip can do - this code only uses 4% of the program area. Catweazle's code makes it easy to add more modules. I'd like to add a third control knob function to the plucked strings so that the other two knobs control pitch in more interesting sequences.
I have also been looking through my old copy of Hal Chamberlin's "Musical Applications of Microprocessors" for ideas. Hmmmmm...
catweazle
PostPosted: Mon Jan 05, 2009 4:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
First of all happy new year everyone !
I'm impressed about the news going on here. New Algorithm and so on Wink
Maybe it's a bit off-topic but I have some news ...
A Nintendo DS Version of the PIC Fraktal Synth
- in a very very basic alpha state but it makes some noise -
Only one Algorithm (the first one) with 2 Parameters controlled by the
touchscreen. Cool
You need a a flash-card (I use R4DS) and of course a NintendoDS ...
but runs in the No$GBA Emulator too
FraktalSynth_alpha.zip
Zip File contain the .nds file
 Filename:  FraktalSynth_alpha.zip
 Filesize:  74.01 KB
 Downloaded:  553 Time(s)
PostPosted: Mon Feb 09, 2009 5:41 am    Post subject: Reply with quote  Mark this post and the followings unread
Sure, PM me .... I just updated my Promate II programmer with the latest firmware so it's good to go to program the 18F4620. Cool I believe the latest Picsynth firmware is at a Ver 1.1 ?? Not sure. PM me with the latest PS "HEX" file and we will work the on the arrangements offline ....
Bill
catweazle
PostPosted: Mon Feb 09, 2009 9:34 am    Post subject: Reply with quote  Mark this post and the followings unread
This should be the last (known) Version ...
thanks to yerpa58 who included a new algorithm (very cool stuff!)
http://www.reprolabs.com/picsynth5.zip
PostPosted: Mon Feb 09, 2009 12:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
Nice ... Thanks CAT !!! Wink
Bill
cthulu
PostPosted: Wed Feb 11, 2009 5:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks guys. Wonderful project and I just love the sounds... I didn't even need to hear it. I was caught allready by this line:
My neighbor came downstairs to see if something was wrong with the washing machine.
