oootini
 Posted: Mon Sep 29, 2008 12:26 am    Post subject:
hey,
just a pitch shifting effect that adds minor and major harmonies to the signal... |
catweazle
 Posted: Mon Sep 29, 2008 2:42 am    Post subject:
@ootini:
very nice work!! I like that LEGO like case and I'm impressed about that
sound sample, sounds
If you can select more than 4 synths (5..  then you have the newest hex file. Synths 5..8 are not implemented yet.
Why learn C and roll your own? I recommend buying a cheap pic-programmer. Or the WinPIC800 (can prgram AVR and PIC)
If I get my prototype back, then I make a version for the C18 C-Compiler which is free.
Synths 1..4 should work,
synth 3 (step sequencer) :  turn pot4, pitch for each step has to be fetched. |
oootini
 Posted: Mon Sep 29, 2008 5:24 am    Post subject:
cheers catweazle. i do have a pic programmer, so maybe i will try and learn some C. don't hold your breath though   |
 Posted: Mon Sep 29, 2008 3:41 pm    Post subject:
oootini,
I like this. Made me want to add all sorts of sounds FX on top of it and build it up .... A remix perhaps !!!    A chip tune remix ...........
Bill |
oootini
 Posted: Wed Oct 01, 2008 9:21 am    Post subject:
Hey ho. I want to add a power supply connection to my picsynth. I have a couple of 9v effects pedal adapters, so I could use them without having to fuck with the existing pic synth power supply. Basically solder the connection thing in place of the 9v battery clip.
Only thing is, I don’t know what the little thing is called so I can order it. what are those little things called? |
yerpa58
 Posted: Fri Oct 03, 2008 11:17 am    Post subject:
| They are called power jacks. Sometimes called barrel jacks. An example would be Digi-Key (digikey.com) part number CP-055D-ND, manufactured by CUI.  Be sure to check the inside and outside diameters to match your parts. |
oootini
 Posted: Mon Oct 06, 2008 4:54 am    Post subject:
| yep, sorted. thanks |
akorbeti
 Posted: Thu Oct 30, 2008 3:53 am    Post subject:
shoeBox fraktalSynth |
Hi all,
I have been watching this forum for some time but this is my first time
 posting. It's my first time having something to show too
I made the fraktal Synth and put it in a shoebox (hence the title). I have
some samples too.
My next move will be to pass it through MC 909 and actually use it to make
a tune.
for now, the only sample I have made is here:
http://sites.google.com/site/diysynth/Home/CatweazlesFractalSynth.mp3
for more photos you can go to http://synth-diy.blogspot.com/2008/10/shoebox-fractalsynth.html
photos also here: http://picasaweb.google.com/akorbeti/DiySynth
My daughter whined a bit for taking her box but I just gave it some added
value.. It is still hers. I only play with it when she's asleep.  She likes to
play with it! It's so easy! No rules
I might consider making one for giving it as a present to our neighbour's
little boy.!! It's a wonderful idea (well, for children only   )
Thank you Catweazle!!! |
 Posted: Sat Nov 01, 2008 11:33 am    Post subject:
 	  | Quote: | 	 		  I have been watching this forum for some time but this is my first time
posting. It's my first time having something to show too Smile
some samples too. |
Wow, great samples of the synth and thanks for all the pictures !!! Welcome to the forum and hope you are here to stay a while !
Bill ........ |
yerpa58
 Posted: Sat Nov 01, 2008 12:52 pm    Post subject:
 	  | Quote: | 	 		  | Wow, great samples of the synth and thanks for all the pictures !!! Welcome to the forum and hope you are here to stay a while ! |
I agree! That sample covers a lot of ground.  I put up some cad pictures & a photo of my recently-completed fraktal synth.  I added a one-watt amplifier and power switch. Now I have to practice playing  it and see what it can do.
yerpa58http://www.reprolabs.com/fraktal_synth_1.htm
bleep!blorpblipblipblip |
 Posted: Sat Nov 01, 2008 1:01 pm    Post subject:
 	  | Quote: | 	 		  I agree! That sample covers a lot of ground. I put up some cad pictures & a photo of my recently-completed fraktal synth. I added a one-watt amplifier and power switch. Now I have to practice playing it and see what it can do.
Just wondering, with your Eagle .BRD files. Who are you using as your PCB house to process those files. I know that "PCB Pool" works with them but doing a quote with them did not beat EXPRESS PCB at all. Can you recommend any good, cheaper, PCB services that are compatible with the .BRD files?
Thanks and nice work on your end also sir.
Bill |
yerpa58
 Posted: Mon Nov 03, 2008 11:40 am    Post subject:
I haven't used any services that take Eagle files directly.  However, Eagle produces nice Gerber artwork and Excellon drill files, and I have sent these through BatchPCB (found on Sparkfun's site).  I got very nice boards back from them, double-sided, silkscreened, solder-masked and plated through.  Most PC board vendors can read these files.
For single-sided art, we plot quarter-panels full of PC boards onto clear film and send this film to Electronic Industries. (http://electronicindustries.net/. They charge about $125 for a 17" x 23" panel of PC boards.  These are single-sided and drilled, sheared to size. No solder mask, no silkscreen.  The company I work for sends in about a dozen of these per month, so I just snuck the fraktal synth on one of these orders.  I have to convert to Auto-Cad to get it into our plot queue.  This step is kind of labor-intensive and redundant.  I use Eagle's DXF ulp, then tweak it by hand in AutoCad.  If you want the Auto-Cad file for the fraktal synth, you can have it. |
akorbeti
 Posted: Mon Nov 03, 2008 3:24 pm    Post subject:
babyBotte repackaged |
Hi there again,
I just made a new shell for the fraktalSynth I posted about above.
 The name still remains babyBotte because I liked it so much.
 Its shelter now is an IKEA container which I processed accordingly.
The panel was made on photographic paper and was stuck on the lid.
The knob's background is color coded . Green for function, yellow
shades for parameters, red for output (volume/filter). The main
pushbutton is the top right so while pressing this with your left
thumb, you can use the same thumb to press another key.
and a small description at http://synth-diy.blogspot.com/2008/11/babybotte-repackaged.html
For more shots there is always the pool.
 http://picasaweb.google.gr/akorbeti/DiySynth#
(BTW Should I move to flickr?)
Now it is VERY easy to play with it because it has a very solid
feeling. I might make a video sometime..
Thanks again for the synth catweazle.. |
hanley
 Posted: Wed Nov 05, 2008 4:47 pm    Post subject:
 	  | okvern wrote: |
PICSynthBoards.zip: The main board and filter board, as 600ppi bilevel TIFFs. You'll need to look at the Eagle layouts for parts placement.
hey okvern
does your pcb image work off catweasles schematic or is it changed a bit?
my breadboarded picsynth is on its last legs so doin up a pcb for it
cheers
edit: nevermind, found the eagle file of the board
thanks |
yerpa58
 Posted: Sat Dec 06, 2008 12:27 pm    Post subject:
Hello peoples
I added a plucked-string preset to the fraktal synth.  Still having fun with this one.  Code and sample at http://www.reprolabs.com/fs7.htm.
nofrets
  Joined: May 10, 2008 Posts: 29 Location: Hills of West Virginia
 Posted: Sun Dec 14, 2008 6:39 am    Post subject:
Hi folks -
Any recommendation on what programmer to use to burn this chip?  Or, alternately, anyone willing to burn one for me?
Thanks,
Patrick _________________ Gotta kick at the darkness 'til it bleeds daylight. |
oootini
 Posted: Sun Dec 14, 2008 10:29 am    Post subject:
nofrets
 Posted: Mon Dec 15, 2008 4:17 am    Post subject:
Really?  It doesn't say it supports the 18F4620 - are any mods/updates required to make it work?
oootini
 Posted: Mon Dec 15, 2008 6:03 am    Post subject:
yerpa58
 Posted: Mon Dec 15, 2008 9:08 am    Post subject:
I've been using an old Microchip Picstart Plus to program the chip.  I think there is a lot more this chip can do - this code only uses 4% of the program area.  Catweazle's code makes it easy to add more modules.  I'd like to add a third control knob function to the plucked strings so that the other two knobs control pitch in more interesting sequences.
I have also been looking through my old copy of Hal Chamberlin's "Musical Applications of Microprocessors" for ideas.  Hmmmmm...
catweazle
 Posted: Mon Feb 09, 2009 5:41 am    Post subject:
 	  | Quote: | 	 		  | Any recommendation on what programmer to use to burn this chip? Or, alternately, anyone willing to burn one for me?  |
Sure, PM me .... I just updated my Promate II programmer with the latest firmware so it's good to go  to program the 18F4620.   I believe the latest Picsynth firmware is at a Ver 1.1 ?? Not sure. PM me with the latest PS "HEX"  file and we will work the on the arrangements offline ....
Bill |
catweazle
 Posted: Mon Feb 09, 2009 9:34 am    Post subject:
This should be the last (known) Version ...
thanks to yerpa58 who included a new algorithm (very cool stuff!)
http://www.reprolabs.com/picsynth5.zip |
 Posted: Mon Feb 09, 2009 12:28 pm    Post subject:
 	  | Quote: | 	 		  This should be the last (known) Version ...
thanks to yerpa58 who included a new algorithm (very cool stuff!)  |
Nice ... Thanks CAT !!!
Bill |
cthulu
  Joined: Feb 07, 2009 Posts: 56 Location: Göteborg, Sweden
 Posted: Wed Feb 11, 2009 5:09 am    Post subject:
Thanks guys. Wonderful project and I just love the sounds... I didn't even need to hear it. I was caught allready by this line:
 	  | Quote: | 	 		  | My neighbor came downstairs to see if something was wrong with the washing machine. |
