<on air> Modulator ESP Adventures In Sound
The GM Voice
Page 7 of 13 [305 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13 Next
David Jackson
PostPosted: Wed Oct 01, 2008 7:40 pm    Post subject: troubleshooting Reply with quote  Mark this post and the followings unread
I built a GM Voice using Thomas' schematic and PCBs but I'm having trouble getting it working. The activity light flashes when I press a key on my keyboard, but I don't get any sound out of it except for some 60Hz buzz.
Also the LM7805 gets very hot after I leave it on for 20-30sec. However, I checked the voltages on all of the pins of the connector and are correct whether or not I connect the daughter board. The LM7805 only gets hot if I connect the daughter board.
I tried two of those NEC clone boards I bought on Ebay from the guy in Shanghai and the same thing happens. Does anybody have any suggestions?
Dan Lavin
Audio files: 21
PostPosted: Thu Oct 02, 2008 5:56 am    Post subject: Reply with quote  Mark this post and the followings unread
David,
I know a number of people on this forum have bought daughterboards from the gent in Shanghai and have had good luck, including some of our "heavy hitters" , so it's unlikely 2 boards wouldn't work, but not impossible.
To give yourself confidence in the daughterboards, I'd suggest you breadboard up the circuit and get that working with each board. It's such a simple circuit, it should only take about 15 minutes.
The only other thing I can suggest to check is the orientation of the daughterboard. The ground side of the daughterboard connector is towards the card's edge. I think I've seen some boards with reversed pin numbering.
assuming none of that helps, pls get a voltage reading from input and output of the 7805....that might tell us something.
regards, Dan
David Jackson
PostPosted: Wed Oct 08, 2008 6:15 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the suggestions Antman. I tried building the circuit on a breadboard but still had the same problem. I took things apart until I just had +5V and ground connected to the midi board and still had the same problem. 5V was connected to 6, 10 and 14, and ground connected to pins 1,3,5,7,9, and 11. I checked to make sure the pin numbers were right.
I actually bought one board, but they sent me five of them. I measured the current from the power supply for all five boards and it ranged from 182mA to 205mA. Thomas said in an earlier post that the draw on the 5V supply should be 40mA, but I'm getting 5x that much with only the midi board connected. Sad
Does this mean all of the boards are bad? I wonder if they sent me five boards because they know they have quality problems?
David Jackson
PostPosted: Wed Oct 08, 2008 6:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Also I checked the input and output of the LM7805. Input was 12V and output was 5V.
Dan Lavin
Audio files: 21
PostPosted: Fri Oct 10, 2008 5:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
David,
Well TH's 40mA was on a much smaller daughterboard...not a Yamaha compatible one. The Yamaha ones are much larger and it's not inconceivable that they could draw 5X the amount of current, although I think that's a little high because 200mA would make the regulator warm and I don't remember my Yamaha's regulator getting warm at all.
It seems really odd they would ship you 5 of these. I would offer to test one for you but I know US/Canada customs can be a hassle, (you wouldn't know we were friends based on those guys!)
I traded my Yamaha daughterboard off to someone on this forum so I can't help with measurements. Perhaps someone can help David with current measurements on their units? Fonik?
Regards, Dan
PostPosted: Fri Oct 10, 2008 5:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
the power consumption is about 120mA on the 5V rail and about 270mA on the 12V rail...
that's what i measured for the motherboard AND the daughterboard between the PSU and the GMvoice.
the LM7805 is getting warm, just a little bit, the LM7812 is getting very warm, i use a heatsink.
BTW i bought 3 boards from shanghai and they all work (and i payed for 3 Laughing ). i am currently building a triple unit Shocked
PostPosted: Fri Oct 10, 2008 5:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
just to be sure, maybe i just misunderstood you or missed it entirely: you did connect pins 15, 17, 19, 21, 23, 25 to GND as well, didn't you?
David Jackson
PostPosted: Wed Oct 22, 2008 5:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks for the measurements fonik. Yes I connected the other pins to ground too, but when I did the current measurements I only had the digital ground pins connected. I fiddled around with it some more, assuming that the currents are ok, but still no luck.
antman: If you PM me your address, I'll send you a board. I don't need all 5 anyways. If I mark it as a "gift" I don't think they'll charge you duty on it.
Dan Lavin
Audio files: 21
PostPosted: Wed Oct 22, 2008 7:00 pm    Post subject: Another good daughterboard on UK ebay Reply with quote  Mark this post and the followings unread
To my friends in the UK that wish to do this project, please check out the following auction for a Yamaha DB50XG, probably the best daughterboard you can find.
http://cgi.ebay.com/Yamaha-DB50XG-Daughterboard_W0QQitemZ380074246690QQcmdZViewItem?hash=item380074246690&_trksid=p3286.m63.l1177
Dan Lavin
Audio files: 21
PostPosted: Fri Oct 24, 2008 11:32 am    Post subject: Reply with quote  Mark this post and the followings unread
David,
OK, I PMed my address. If I get good results I can post photos of what I've done.
-Dan
THeff
Audio files: 33
PostPosted: Tue Oct 28, 2008 12:27 pm    Post subject: Yamaha DB60XG audio inputs Reply with quote  Mark this post and the followings unread
The web says that the Yamaha DB60XG is the same as the DB50XG with additional audio inputs that pass through the on-board effects. Does anybody know which pins are these input pins? I have searched many web sites and cannot find any info on that.
Thanks,
Tim
THeff
Audio files: 33
PostPosted: Tue Oct 28, 2008 6:56 pm    Post subject: External inputs on the DB60XG Reply with quote  Mark this post and the followings unread
After further investigation it looks like pins 12 & 14 are the inputs. On other daughter cards these pins are N.C., but on the DB60XG they go to the AK-4510-VS IC. This may be the mixer IC. I have tried inputting a signal on these pins but the signal is not passed to the output.
I'm thinking it probably requires a SYSEX command to open this path. This link http://www.studio4all.de/htmle/main96.html has a lot of SYSEX info.
If anyone has any ideas, I would welcome them.
I think adding the inputs to the DB60XG would be nice so that my synth modules could utilize the nice Yamaha processor effects.
Tim
Dan Lavin
Audio files: 21
PostPosted: Wed Oct 29, 2008 5:42 am    Post subject: Reply with quote  Mark this post and the followings unread
Tim,
Thanks for the heads up on the analog inputs! I've been meaning to look into that for some time, but never had the chance. I used to own a Yamaha MU80 which is basically a db60xg with a user interface and I loved the effects. They're geared for both voice and guitar. The idea was a one-man-band would use the XG for backing parts and one AD channel for microphone and the other for his/her guitar. Obviously synths can use any of these effects. They're all very good, low noise and tweakable.
I think you're right about the SYSEX opening the channels. I recall I had to do something with the user interface before the analog ins got mixed with the MU80's output.
Keep us posted with any progress. I think the majority of people that took this project on are using the db60xg clones and this is opening up a whole new chapter to the story.
regards, Dan
PostPosted: Wed Oct 29, 2008 5:51 am    Post subject: Reply with quote  Mark this post and the followings unread
as i read it, there are only two additional sysex commands for the db60xg: A/D 1/2 PART ON/OFF and KARAOKE LOCK (ON/OFF ). so there are at most 4 logical cases to try.
the Mixing Block commands seem to apply to the SW60XG only?
Dan Lavin
Audio files: 21
PostPosted: Wed Oct 29, 2008 7:12 am    Post subject: Reply with quote  Mark this post and the followings unread
Matthias,
As far as I could research, the SW60XG is an ISA bus version of the db60xg, so the SYSEX commands for SW60XG should pertain to the db60xg as well......or maybe it is wishful thinking on my part?
I thought that Yamaha's MU50 also had analog ins but it would only mix to the output without use of the internal effects unit. That's why I bought the MU80 instead of the MU50. This could be the same with the db60xg.
Perhaps Tim can experiment and let us know.
-Dan
Dan Lavin
Audio files: 21
PostPosted: Wed Oct 29, 2008 7:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Tim,
Can you check those pin numbers again? Pin 14 is normally tied to +5V. I'm guessing Pin 12 and Pin 16 are the correct analog inputs. This would follow the precedent set with the outputs (pins 20 and 24).
regards, Dan
THeff
Audio files: 33
PostPosted: Wed Oct 29, 2008 7:29 am    Post subject: DB60XG external inputs... Reply with quote  Mark this post and the followings unread
Hey Dan & Matthias,
I did connect a constant signal source to one of these inputs and tried sending the two DB60XG specific SYSEX commands with not luck. Since I have seen several references to the analog input capabilities of the DB60XG, I feel confident that there must be a way to use these.
If you follow the traces to pins 12 & 14 they go to a 47K shunt resistor, through some 0 ohm jumpers and then through some caps to the AK IC. This would make sense that they are 50K inputs.
If someone had the driver SW that came with a new DB60XG maybe they could monitor the MIDI data stream as the ext. inputs are enabled...I know that is asking a lot!
A copy of the owners manual would be helpful also, I could only find the DB50XG manual.
Do you guys know if the MU-50 had external inputs?
Tim
THeff
Audio files: 33
PostPosted: Wed Oct 29, 2008 7:38 am    Post subject: MU-50 Inputs Reply with quote  Mark this post and the followings unread
I just did a quick web search on the MU-50 and it does have inputs on the front panel. Maybe the MU-50 SYSEX commands would be the same for the external input features?
Tim
PostPosted: Wed Oct 29, 2008 7:41 am    Post subject: Reply with quote  Mark this post and the followings unread
i found some information of the (missing!) mixer on the db50xg at this g00gle group: comp.sys.ibm.pc.soundcard.music
The 3D/XG gets its XG support by adding a Yamaha DB60XG daughtercard to
the AudioTrix 3D sound board. Yes, that's correct, I said DB60XG. Not
to be confused with the DB50XG daughtercard, or the SW60XG standalone
MIDI-only soundcard. I've already been through the ropes with the tech
support and programming folks to clarify this. The DB60XG is basically
a DB50XG with the SW60XG's additional capabilities to add
(individually-programmable) effects processing to each mixer source
(wave, line-in, mic, cd, as well as midi). The SW60XG's AD Mixer
section is removed from the DB60XG, and instead connected (through the
waveblaster connector) to the 3D's mixer. That makes sense if you really
think about it, there is no need to have the SW60XG's AD mixer on the
daughtercard since all soundboards I know of already have a mixer.
if this was true, there would be no need to send a sysex message controlling an onboard mixing block? not quite sure.
i am curious. i am just building my triple GM voice with the db50xg board. maybe i could incorporate an db60xg to my next years project of a keyboard synth? using the FX for external signals would be great.
THeff
Audio files: 33
PostPosted: Wed Oct 29, 2008 10:59 am    Post subject: Ext DB60XG inputs Reply with quote  Mark this post and the followings unread
Dan,
I believe your are right about the pin numbering being 12 & 16. I was multitasking last night and had a brain lapse that the skipped pin was 13 instead of 14. I was also wondering if these inputs are mic/line with adjustable gain, or just line inputs and rely on a mic preamp on the main soundcard?
Tim
THeff
Audio files: 33
PostPosted: Wed Oct 29, 2008 2:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Dan,
I totally missed your comments about the MU-50 audio inputs...Doh! The manual states that you just plug in the external device and adjust the volume with the control on the front. It shows a guitar plugged in so I guess it is a low level high gain input.
Matthias,
From the quote you mentioned in your post it would seem that a SYSEX is not needed, but no audio is heard on these inputs on power-up. It's amazing how little information is available on the web for the DB60XG!
One DB60XG reference said it was only sold in Japan.
Tim
PostPosted: Wed Oct 29, 2008 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
THeff wrote:
Matthias,
there are still these two sysex commands stdio4all mentioned for the db60xg.
THeff
Audio files: 33
PostPosted: Wed Oct 29, 2008 3:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Matthias,
I did try sending both of those SYSEX messages and there was no response at all from the DB. I had the card setup and played a MIDI song using Cakewalk just before sending the messages, so I know everything was working at the time. I'm still puzzled Sad
Tim
Dan Lavin
Audio files: 21
PostPosted: Wed Oct 29, 2008 7:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmmmm. I wonder if one of the other pins could be a VCA control for the analog inputs? Can you see any traces from the other "unused" pins?
I could understand how that would work for the MU50, 80, etc. with a front panel knob, but on an internal soundcard? I think I'm getting desperate!
-Dan
THeff
Audio files: 33
PostPosted: Wed Oct 29, 2008 8:10 pm    Post subject: Analog audio inputs on the DB60XG Reply with quote  Mark this post and the followings unread
Hey Dan,
I thought maybe you were on to something. I found that pin #8 goes to the H8 uC and is pulled high to +5v. I tried grounding this through a 1k resistor to see if it would enable the inputs...no luck!
I don't see any other connections to the unused pins 2 & 13.
I'm not giving up!
Tim
