<on air> Various Artists March Equinox concert
 Forum index » How-tos
Name that chord
Page 1 of 1 [25 Posts]
Dovdimus Prime
Audio files: 6
PostPosted: Thu Sep 16, 2004 1:06 pm    Post subject: Name that chord Reply with quote  Mark this post and the followings unread
Hi all Very Happy
Can anyone tell me if there is a common name for the chord produced by putting two perfect fourths on top of each other?
It seems to be cropping up in something I'm doing at the moment so I thought we should get better acquainted...
Mucho thankyous
Dovdimus
This message was brought to you from Beyond The Grave.
play
PostPosted: Thu Sep 16, 2004 1:35 pm    Post subject: Reply with quote  Mark this post and the followings unread
I believe chords built out of 4th's are called quartals.
seraph
Editor
Editor
Audio files: 33
PostPosted: Thu Sep 16, 2004 2:01 pm    Post subject: Re: Name that chord Reply with quote  Mark this post and the followings unread
QUARTAL HARMONY
Quartal harmony refers to chords stacked in intervals of a fourth or its inversion, a 5th, sometimes called quintal harmony. It is still a very contemporary sound in jazz writing and occurs frequently on the Alive XV CD. This tutorial will demonstrate other musical examples that use quartal harmony.
arrow http://webpages.charter.net/dbristol4/tutorial/harmquar.htm
zynthetix
Audio files: 10
G2 patch files: 13
PostPosted: Thu Sep 16, 2004 5:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
So a quartal is two perfect fourths stacked on top of eachother that feature the same root pitch? (as in C-F with a C-F in the octave above it?)
aquanaut
PostPosted: Thu Sep 16, 2004 9:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
C-F-Bb-Eb is an inversion on the 9th of a Bb dominant chord and is a substitute for it. The nice thing about those is that you will never encounter the major third of the Bb chord (Bb-D-F-Ab), rather the minor third and it takes a while. The common resolution is Eb maj7, or E7, Bb-7 or Cmaj7( when you go downward with fourth starting with C you get a G dominant chord). If you don't wish to resolve D-7b5 is nice too but a bit of a cliché.
Dovdimus Prime
Audio files: 6
PostPosted: Fri Sep 17, 2004 8:59 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi guys
Thanks for your responses but this is not what I meant.
This:
is what I meant.
Any ideas?
Thanks again
Dovder[/img]
play
PostPosted: Fri Sep 17, 2004 10:10 am    Post subject: Reply with quote  Mark this post and the followings unread
but you're missing the Eb so I'd say it's quartal harmony which just means chords built out of fourths instead of thirds.
Dovdimus Prime
Audio files: 6
PostPosted: Fri Sep 17, 2004 10:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Cool, thanks for this guys.
Audio files: 235
PostPosted: Fri Sep 17, 2004 12:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
When I was studing music theoryand composition back in the 60s, quartal harmony was a popular trend. The music with these chords seems to have a consonant quality, but no strong tonal center. In those days, writing in a sing key was passe, but so was the jagged totally keyless 12 tone music.
seraph
Editor
Editor
Audio files: 33
PostPosted: Fri Sep 17, 2004 3:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
is what I meant.
Any ideas?
Idea C7sus
("sus" stands for suspended Exclamation )
or C4/7
or C7sus4.....
aquanaut
PostPosted: Sat Sep 18, 2004 12:04 am    Post subject: Reply with quote  Mark this post and the followings unread
There is a lot a of possibilities with those chords. If you look at Csus4 as a subV, you can go anywhere:
C,F,Bb-->B,Eb,Bb.
subV/I--->I (In B Major)
C,F,Bb--->Db,F,B--->C,E,B
V---------> SubV/I--->I (In C major)
C,F,Bb--->E,Ab,D--->Eb,G,D
subV/V--->subV/I---->I (In Eb major)
C,F,Bb--->D,G,C---Gb,Bb,F
subV/VI-->subv/vi--->I (in Gb major)
i like this one
C,F,Bb--->D,G,C--->Db,F,C
???VII---->subv/I--->I (in Db major)
Oskar
PostPosted: Sat Sep 18, 2004 3:24 am    Post subject: Reply with quote  Mark this post and the followings unread
It's all dependent on context though, isn't it? Such a chord is ambigious, and you can really only tell what it is by what went on before and after. Like the word "to" can be (grammatically) a preposition in certain contexts, and in others it's a sort of word that goes in front of a verb's infinitive form. Examples:
He went TO Spain
TO be or not TO be.....
Where there are too many policemen, there is no liberty. Where there are too many soldiers, there is no peace. Where there are too many lawyers, there is no justice.
Lin Yutang (1895-1976)
Dovdimus Prime
Audio files: 6
PostPosted: Sat Sep 18, 2004 4:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Really? I thought a chord was named independently of its context. For example, a major triad is a major triad regardless of whether it's I, IV or V within the key.
[Shows ignorance.] Embarassed
Audio files: 235
PostPosted: Sat Sep 18, 2004 7:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Paul "Happy" Hindemith
Music analysis can be pretty subjective. There are several ways to analyze a chord. Sure, you can analyze them out of context. In that case there are no I, IV or V chords, but when the music is in a key centered tonal context, then these key relationships makes sense and are of great value.
Paul Hindemith came up with a very clever harmonic chord analysis system that is very flexible and useful for non-tonal music. It attempts to provide number values for the tension in chords based on the constituent intervals. I think Hindemith is given credit for formalizing quartal harmony.
I spent a bit of time on Google trying to find a good summary of his theory of analysis, but couldn't find anything.
seraph
Editor
Editor
Audio files: 33
PostPosted: Sat Sep 18, 2004 9:17 am    Post subject: Reply with quote  Mark this post and the followings unread
that's the way IT is
seraph
Editor
Editor
Audio files: 33
PostPosted: Sat Sep 18, 2004 9:23 am    Post subject: Reply with quote  Mark this post and the followings unread
at Berklee they devised a way to determine if a chord was a "ambichord".
Simply stated it is a chord built without the use of thirds and their inversions (sixths). So, those chords are built stacking 2nds, 4ths, 5ths and 7ths like that chord Dovder asked to name Idea
Oskar
PostPosted: Sat Sep 18, 2004 10:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Anyway, I like that type of chord; It tells you to go further. Very Happy
arcticbeard
PostPosted: Fri Oct 22, 2004 12:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
just play what sounds good, dont analyse it too much
C E G, = c major, or is it an e minor with aug 5th, inversion????
thats my point.
http://www.arcticbeard.co.uk
http://www.psychoacoustics.moonfruit.com
http://www.myspace.com/arcticbeard
Chill Out |: )>
PostPosted: Fri Oct 22, 2004 4:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Music theory is a troubling science. It is a mix of consistent and interesting factual information.. and then it suddenly drops out into acidic dreams.
Learning some music theory can be REALLY smart. -But at some point traditional music theory kinda falls short and it resembles physics before Einstein hit the stage.
seraph
Editor
Editor
Audio files: 33
PostPosted: Fri Oct 22, 2004 11:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
elektro80 wrote:
...at some point traditional music theory kinda falls short and it resembles physics before Einstein hit the stage.
I remember at the end of my studies at Berklee that after learning all the rules etc. one of my teachers came up saying that a dominant chord could resolve to ANY other chord. First you learn what you can or can not do then, once you know, you can do whatever you want. That seems to be the only rule Very Happy
arcticbeard
PostPosted: Sat Oct 23, 2004 12:52 am    Post subject: Reply with quote  Mark this post and the followings unread
My Idea on music theory is learn it if you want, but only to realise what not to play, ie dont play what youve learnt. I got heavily into scales & chords & trying to name this & that, I found I was spending more time doing that than making music.
When you walk thro' the woods, you see a beautiful flower, is it any more beautiful because you know its name?????????
(wow I just made that up!!!!!!!)
btw way do bears really do that????
Chill Out |: )>
PostPosted: Sat Oct 23, 2004 4:16 am    Post subject: Reply with quote  Mark this post and the followings unread
Yeah, well said.
The obvious thing here is that traditional music theory and modern music psychology are both extremely interesting and very useful.
Audio files: 235
PostPosted: Sat Oct 23, 2004 8:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Interesting thought. I'd have to say that in many cases, the answer is yes. A couple of years ago we put up bird feeders around our house. I couldn't tell a finch from a chickadee. I enjoyed the birds a great deal though.
Over the years, we got some field guides and I learned how to identify the different birds. Learning to identify them made me more sensitive to seeing subtile differences I wouldn't have noticed before. I appreciate them more now.
So, in the case of birds, learning their names did make them more beautiful. I suspect it is the same with flowers, and music too.
arcticbeard
PostPosted: Sat Oct 23, 2004 11:25 am    Post subject: Reply with quote  Mark this post and the followings unread
oh balls, I knew someone would say something like that, I guessed it would either be mosc or elektro, for a minute there I thought you were gonna agree with me LOLOLOOOLOLOL. Very Happy
mosc are you really Gandalf the wise ?????
Chill Out |: )>
arcticbeard
PostPosted: Sat Oct 23, 2004 11:30 am    Post subject: Reply with quote  Mark this post and the followings unread
isn't it bizarre that most modern music contains only 12 tones & we can express so many emotions with just these 12 tones, it kinda makes it a more efficient communication than writing, so.....
cmajor, gmajor, fsharp major, bdominant
(im happy with sad undertones)
Chill Out |: )>
