<on air> Various Artists March Equinox concert
Interested in Tau Pipe Phaser / Flanger boards ?
Page 20 of 26 [640 Posts]
Goto page: Previous 1, 2, 3, ..., 18, 19, 20, 21, 22, 23, 24, 25, 26 Next
jhaible
PostPosted: Fri Oct 24, 2008 1:07 am    Post subject: Reply with quote  Mark this post and the followings unread
Funky40 wrote:
How about the modulation depth, how can i close this to Zero or minimise it.
Now i have by default allways a Modulation.
Perfect for common Phaser use, but not for modularsynth experiments.
Ah, now I understand the question.
Well, modulation depth *should* be zero when the the OSC_LEVEL potentiometer is in ccw end position.
See http://www.jhaible.heim.at/tau/jh_tau_sch_page3_control.pdf .
Looking at that diagram myself, I see what might be wrong: The ccw end of that pot is routed via the CV_IN jack, normalized to the manual control circuitry around U5B. If you have no normalized jack connected there, you have to put a jumper on the CV_IN onboard-connector (connecting the two non-grounded pins).
JH.
Funky40
G2 patch files: 5
PostPosted: Sat Oct 25, 2008 7:53 am    Post subject: Reply with quote  Mark this post and the followings unread
ok, i understand now:
Both Taus are wired correct. The CV input has a normalization,
but: i added a muteswitch to the CV input.
when the muteswitch is set to on, but nothing is pateched to the CV input,
then the Modulation depth can be set to zero, indeed .
Is the mute switch set to mute and the normalisation broken, then not........that was the Problem !
Only the attenuation behave of the extern CV is not 100% to my taste as it is a crossfade between internal LFO and the external source.
I asssume that this behave is correct ?
Unfortunately i have not made the external CV input with an attenuator.
I would recommend this, and i will change it on one Module that anyway must be repaneled.
Thank you Jürgen !
Your help is very appreciated.
jhaible
PostPosted: Sat Oct 25, 2008 8:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes, it's a sort of crossfade between manual setting and the internal LFO, just as in the original.
I think it makes a lot of sense that way, as all this is connected to the 1/x branch of the CV circuitry, where you get the "typical" 1/x sweep that evokes a feeling of thru-zero modulation (despite not being a thru zero modulation), only with a certain amount of modulation CV. The "CV crossfade" approach is an easy way to keep the CV level in the "interesting" range for any mix of manual and LFO sweep.
The CV input that breaks the path from the manual sweep pot to this 1/x modulation circuit, is not the recommended input for general-purose external CVs. I have copied this from the original Tau effect, too, and I think it was mainly meant for combining two effect boxes in a master-slave configuration.
For general-purpose external modulation, there is always the exponential (V/oct) input, which works independent from the internal modulation.
JH.
Funky40
G2 patch files: 5
PostPosted: Sat Oct 25, 2008 12:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
ahhh, ok, i understand.
then i will add a attenuator to the 1v/oct input if repaneling.
thanks
ericcoleridge
PostPosted: Fri Nov 21, 2008 12:15 am    Post subject: Reply with quote  Mark this post and the followings unread
I've had my Tau Pipe up and running for several months now, and it's indeed my very favorite phaser ever. I'm really glad that I had a chance to build this wonderful circuit! Thanks Juergen!
I've had it in tupperwear initially, but before I make a proper panel I have been thinking of a few simple mods and I'm just wondering if anyone else has tried these already:
1. tapping outputs from various stages (8, 12, 16, 20?? Something like this?) with a switch to choose between them.
2. Incorporating a VC sine/tri wave LFO. It would probably be useful to have VC control over the modulation rate, but I'm wondering, is there anything integral to the final phaser sound of the Tau that is specific to the onboard LFO?
3. Incorporating a dual VCA, to voltage control the LFO depth and the Resonance amount. I guess a Linear VCA for Rez and an Exponential VCA for LFO depth?
Does anyone have any suggestions about these add-ons for someone not too experienced in electronics (me)?
numbertalk
PostPosted: Mon Nov 24, 2008 8:51 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Jürgen,
Could you please advise on properly setting the Pitch, Resonance and V/Oct trimmers?
Thanks.
jhaible
PostPosted: Mon Nov 24, 2008 10:29 am    Post subject: Reply with quote  Mark this post and the followings unread
numbertalk wrote:
Hi Jürgen,
Thanks.
Pitch : by ear.
Resonance: Maximum; then reduce until you like it.
V/Oct: Connect a V/Oct CV and calibrate it for best keyboard tracking.
JH.
numbertalk
PostPosted: Mon Nov 24, 2008 11:17 am    Post subject: Reply with quote  Mark this post and the followings unread
I guess I'm not clear on what the pitch trimmer is exactly. I understand the external manual "pitch" pot is for manual sweeping of the phaser, but what exactly does the pitch trimmer do?
jhaible wrote:
numbertalk wrote:
Hi Jürgen,
Thanks.
Pitch : by ear.
JH.
jhaible
PostPosted: Mon Nov 24, 2008 12:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Don't think too much about it.
Turn up the Modulation to maximum, at a low sweep rate, and adjust the pitch trimmer for the most pleasant sweep sound.
You'll have that done within a few sweep cycles.
JH.
numbertalk
PostPosted: Mon Nov 24, 2008 12:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Cool, thanks.
JH.
numbernone
PostPosted: Wed Dec 03, 2008 3:37 pm    Post subject: Reply with quote  Mark this post and the followings unread
OK, finally gonna start building the TAU tonite.
Have not ordered the chips yet, and am wondering if a few folks might chime in regarding the chips they are using.
I was gonna go with the 2210's, having not really realized it will cost a hell of a lot less to do the ca3046s.
Any big difference between the 2? I know the docs mention low noise but I am not really worried about all of that jazz.
thanks!
Luka
PostPosted: Wed Dec 03, 2008 5:12 pm    Post subject: Reply with quote  Mark this post and the followings unread
there is a sound comparison on bridechamber tau page
the 2210 is a bunch cleaner
it just depends if you want a really clean phaser
i think there are reasons to go for both versions
i think ill go with the clean option as i will have a compact clone sitting next my tau
problemchild
melbourne australia
numbertalk
PostPosted: Fri Dec 12, 2008 8:26 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Juergen,
I'm finishing up my Tau and had a couple questions - I'm building to a Bridechamber panel which does not include a space for the Colour/Inv switch. I think they intend the circuit to be hardwired in the "up" position, since they say to wire the single LED to the "Up" connector - just checking that to hardwire for Up I'd leave this Inv connection open - it looks like when closed it grounds the non-inverting input, which causes the output of that op amp to be inverted, right?
Bridechamber also doesn't include a spot on the panel for the Smooth switch - do you know which they intend to have hardwired - hard or smooth? What is more "typical" for a phaser?
jhaible
PostPosted: Fri Dec 12, 2008 12:54 pm    Post subject: Reply with quote  Mark this post and the followings unread
numbertalk wrote:
Hi Juergen,
You can use jumpers - they fit nicely in the PCB connectors. So just try what you like better, and either put in a jumper (same as closed switch) or omit the jumper (same as open switch).
If you want a switching for something that doesn't have room on th efront panel, you can always use a Pull-Pot.
JH.
numbertalk
PostPosted: Fri Dec 12, 2008 1:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
This is one of those forehead slapping "of course" moments.
Thanks for the help!
numbertalk
PostPosted: Sun Dec 14, 2008 2:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hi Juergen,
Just completed my Tau and had a couple questions.
First, when I turn the Osc Level pot all the way down and turn the Pitch pot (the one on the panel) all the way up, about 85-90% of the way up the signal drops significantly - is this normal? Tried adjusting the pitch trimmer but the range got way too limited before this improved.
Second, with slew limiting off (smooth set to "hard"), I'm getting clicking - I'm guessing it's happen where the signal "crosses zero"/fades a bit before sweeping back up. Setting it to smooth eliminates this, but is this normal and how could I eliminate this when using "hard" mode? To be clear it's not like LFO bleedthrough clicking - it's at the end/beginning of each sweep cycle.
jhaible
PostPosted: Sun Dec 14, 2008 3:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
numbertalk wrote:
Hi Juergen,
Hard to say - I never had any clicking.
A slight change in amplitude may occur with extreme settings of the pitch trimmer (because the ladder is not perfect all pass filter), but should only be a few dBs ...
JH.
numbertalk
PostPosted: Sun Dec 14, 2008 4:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm. I think the clicking has to do with the same thing I'm asking about with the pitch.
Just to give me some point of reference, how do you have the pitch trimmer set on yours - about what percent of the way CW?
Thanks for the help.
numbertalk
PostPosted: Sun Dec 14, 2008 5:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
Plus is there supposed to be a volume drop when you switch to vibrato mode? I'm starting to wonder if it's one of my chips.
jhaible
PostPosted: Sun Dec 14, 2008 11:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
Should be no volume drop in vibrato mode.
JH.
jhaible
PostPosted: Sun Dec 14, 2008 11:44 pm    Post subject: Reply with quote  Mark this post and the followings unread
Rather close to the cw end. Like 80 or 90%.
JH.
numbertalk
PostPosted: Mon Dec 15, 2008 7:53 am    Post subject: Reply with quote  Mark this post and the followings unread
I think this might be an issue with the TL072 that I'm using for the LFO. I had a similar problem with a Dim-C clone I built recently - when the input resistance got too low I'd get similar behavior. Also when there's too little resistance - osc level all the way down and pitch all the way down - when I start to turn the pitch knob I get a weird sound right at the start on the way up. Also I'm only getting the clicks on hard mode when the osc level is cranked all the way up.
For the Dim-C it was recommend to try a TL062 or TLC2272 - I tried a TL062 but same problems so I just ended up putting enough resistance in series before and after the LFO pots tied to the 072 input. I'd rather not do that here - would replacing the TL072s with 2134s or TLC2272s possibly help to resolve this - is it an overrstable rail to rail op amp?
Thanks again for the help. It sounds fantastic otherwise.
jhaible
PostPosted: Mon Dec 15, 2008 10:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Should work perfectly with a (undamaged) TL072.
JH.
numbertalk
PostPosted: Mon Dec 15, 2008 10:57 am    Post subject: Reply with quote  Mark this post and the followings unread
Hmm. I wonder if it's the batch of TL072s I'm pulling from. It works, just like I said, at the extremes of min/max resistance I get some weirdness, similar to that other project. I'm using a +/-15VDC power supply hook up ala Bill & Will (with the ferrite beads, caps & jumpers).
numbernone
PostPosted: Mon Dec 15, 2008 12:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Speaking of Bill and Will...where have they gone?
All the links are dead, and I cannot find any further info by googling.
I would love to revisit their info prior to finalizing these babies.
