today> Twyndyllyngs Chez Mosc
Dim D
Page 6 of 13 [313 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7, 8, ..., 11, 12, 13 Next
What "chipset" would you like to see in a Dim D PCB
Original chips. They are still out there.
76%
 76%  [ 39 ]
Low voltage BBDs - easier to get, probably more noisy. Takes longer to design.
5%
 5%  [ 3 ]
Make a PCB that allows both options. Will be more expensive (more PCB area required!), and will take the longest to design.
13%
 13%  [ 7 ]
Not interested. (Who needs a Dim D? And isn't there another Dim D project on the way?!)
3%
 3%  [ 2 ]
Total Votes : 51
jhaible
PostPosted: Thu Dec 11, 2008 3:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Update:
Series production BBD boards arrived today.
Will start soldering tomorrow, to get that 2nd prototype to verify the production run ASAP.
Got a mail today that Main boards are on the way to me as well.
JH.
numbertalk
PostPosted: Fri Dec 12, 2008 8:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi Juergen,
In preparing for the Dim TD, I'm guessing we'll need 40 LM394s or 20 CA3086s. I'm actually finishing up my Tau now with LM394s since I'd read they sounded a little cleaner. Do you think 3086s will sound ok for the Dim TD to save a little $? If it makes a difference I will gladly use the 394. I like saving money but when investing the time and energy to make something like this I'd rather it sound as much to my liking as possible.
jhaible
PostPosted: Fri Dec 12, 2008 12:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
numbertalk wrote:
Hi Juergen,
I'm building mine with 3046's.
You can use sockets, of course, and simply try what you like better!
(Two SIL sockets insead of a DIL socket per IC - then you can put in either the DIP 8 or the DIP 14 packages. Just be very careful about chip orientation in that case.)
JH.
numbertalk
PostPosted: Fri Dec 12, 2008 1:38 pm    Post subject: Reply with quote  Mark this post and the followings unread
Ah, good to know!
I'd noticed you'd done this in the photos on your site. Nice.
Thanks for the info!
jhaible
PostPosted: Mon Dec 15, 2008 1:34 pm    Post subject: Reply with quote  Mark this post and the followings unread
UPDATE
BBD board from production run: prototype built and tested.
Main boards arrived - will start to solder soon.
Estimated start of shipping: First week of January 2009.
(So yes, I missed my goal by a few days, sorry about that.)
Don't send any money befor you get an invoice, in January.
JH.
jhaible
PostPosted: Fri Dec 19, 2008 4:05 pm    Post subject: Reply with quote  Mark this post and the followings unread
BOMs are online!
http://www.jhaible.heim.at/subtle_chorus/jh_subtle_chorus.html
JH.
Funky40
G2 patch files: 5
PostPosted: Fri Dec 19, 2008 9:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
does it makes a difference between NE570 and NE570N ?
and thanks for the update.
The demos sound really _very_ subtile btw.
jhaible
PostPosted: Sat Dec 20, 2008 1:23 am    Post subject: Reply with quote  Mark this post and the followings unread
No, it's all the same.
On the synthesizer demos, everything goes thru my beloved Quantec reverb, so even the "dry" sound has a lot of "space" already, and switching the Subtle Chorus in isn't as dramatic as it could possibly be.
When I find the time, I'll make demos without reverb - then the effect of the chorus' adding "Dimension" to the sound is really stunning.
On the vocal demos, I think the effect is more pronouced, even though there is some Quantec in these, too. But here I've added reverb to the vocals first, and then run the sound clip thru the first two Dimension modes.
JH.
kokoon
PostPosted: Sat Dec 20, 2008 1:38 am    Post subject: Reply with quote  Mark this post and the followings unread
funny, i thought the demos didn't sound subtle enough Very Happy
jhaible
PostPosted: Sat Dec 20, 2008 1:53 am    Post subject: Reply with quote  Mark this post and the followings unread
I guess that's why the original Dim D is often mixed to the dry signal (or so I've been told).
JH.
jfromel
PostPosted: Sat Dec 20, 2008 2:22 am    Post subject: Reply with quote  Mark this post and the followings unread
Where do all those SMD caps on the BOM go? didn't see them on the layout?
jhaible
PostPosted: Sat Dec 20, 2008 3:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Solder side - beneath each IC.
Best way for low-inductance PSU decoupling of opamps, IMO.
I also used the same caps for smothing the FET swiching on teh main board.
It's all the same value, so you just solder them in without thinking too much.
(I hate DIY with "true" SMT design where you often cannot read component values, once the thngs are out of their box.)
JH.
funkyfarm
PostPosted: Sun Dec 21, 2008 4:23 am    Post subject: Reply with quote  Mark this post and the followings unread
Expensive HA1457 IC !
On one hand, i'd really like to be able to play once with an vintage-in-mind DIMENSION CHORUS, on the other hand, i really wonder if it's worth spending all that money.
I'll surely go for a modern TL version...
Qty SKU Description Price Total
IC HA1457Wx14 $28.00 €20.00
http://www.smallbearelec.com/Cart.php
HA1457 Integrated Circuit
€14.51x14 = €203.08 $283.00
http://www.littlediode.com/components/cart.php
And apart odd value resistors, why going for 1% resistors for this typical 70's gear ?
edit : 12+6 ic are needed (plus 2 as spare) = 20 pieces. 40$ at smallbear.
jhaible
PostPosted: Sun Dec 21, 2008 6:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Good question. But why stock up on 5% carbon resistors at all, when 1% metal film are barely more expensive nowadays? Especially with the price break you usually get for 100 of the same value?
JH.
jfromel
PostPosted: Sun Dec 21, 2008 11:20 am    Post subject: Reply with quote  Mark this post and the followings unread
original looks like 5% metal film
http://www.modezero.com/roland-dimension-D.htm
funkyfarm
PostPosted: Sun Dec 21, 2008 11:39 am    Post subject: Reply with quote  Mark this post and the followings unread
5% carbon resistors are already stocked ! Very Happy
hence the question.
I'll never buy up to 100 resistors anymore...
I can hardly sleep at night with all these little evils sleeping under my bed.
(and i'm fed up with changing money into carbon or metal stock or else)
jhaible
PostPosted: Sun Dec 21, 2008 3:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
hence the question.
Most resistors are 5% carbon in the original, so you can use them in my version as well. As long as you don't ask me to make a list of which resistors! Wink
JH.
funkyfarm
PostPosted: Mon Dec 22, 2008 1:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I'll try.
I'll be cautious.
(and i'm not racist, i've already a huge pile of 1%)
jhaible
PostPosted: Fri Jan 02, 2009 7:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Subtle Chorus shipping has started!
Invoices are sent out.
If you have pre-ordered, but haven't got an invoice email yet, please contact me.
Happy New Year to all of you,
JH.
jhaible
PostPosted: Sat Jan 03, 2009 12:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
Now that I've started shipping the boards, it's high time I finish the documentation.
I just put a component overlay for the Dim T version "Tau" PCBs online; which components to omit, where to place wire bridges:
http://www.jhaible.heim.at/subtle_chorus/tau_dim_t_overlay.pdf
This is for those who bought two Tau boards for building a Dim T or Dim TD effect only.
If you already have two completed Tau phasers, you don't have to change anything - you just use them in Vibrato Mode and without resonance.
Next thing I'll work on: Drawings how to connect everything together.
Project description for the whole thing:
JH.
jhaible
PostPosted: Fri Jan 09, 2009 7:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Update
Most of the wiring information should be up now at:
JH.
whomper
PostPosted: Fri Jan 09, 2009 8:02 am    Post subject: Reply with quote  Mark this post and the followings unread
What are those 6 rows of holes in the attached diagram? Are those wire bridges? Can I just link all holes together?
 Filesize:  117.43 KB
 Viewed:  216 Time(s)
Erez Yaary
Buy my CDs at http://www.mellowjet.de
numbertalk
PostPosted: Fri Jan 09, 2009 8:52 am    Post subject: Reply with quote  Mark this post and the followings unread
Those are for the vintage HA1457W SIP op amps. If you're not using those I think you can leave these disconnected.
jhaible
PostPosted: Fri Jan 09, 2009 9:18 am    Post subject: Reply with quote  Mark this post and the followings unread
No, by all means don't short them together!
Just leave them open.
This is where the HA1457 opamps go, in the "vintage" version. (In that case, don't solder the TL071 and TL072 opamps in.)
JH.
whomper
PostPosted: Fri Jan 09, 2009 9:42 am    Post subject: Reply with quote  Mark this post and the followings unread
JH.
Right, I have not encountered such an enclosure yet Embarassed
Erez Yaary
