Posted: Fri Dec 26, 2008 3:56 am Post subject:
Hey Ryk and Dave,
I'm in the process of wiring up my LHH, and I've noticed that there are pads for pots on the board which lead no-where. They don't need to be connected, as the pots in question only have two connections, so why the third pad? I think we should get rid of them for a production run. _________________ What makes a space ours, is what we put there, and what we do there. |
Rykhaard
Posted: Fri Dec 26, 2008 8:35 am Post subject:
| Uncle Krunkus wrote: | Hey Ryk and Dave,
I'm in the process of wiring up my LHH, and I've noticed that there are pads for pots on the board which lead no-where. They don't need to be connected, as the pots in question only have two connections, so why the third pad? I think we should get rid of them for a production run. |
That is actually, a very good point! I knew the wiring for the pots and connected right away to the correct pads, whilst ASSUMING that the other pads went off to Ground (which was an incorrect assumption as well), there by ignoring them.
Thanks for checking into them, Unc! And yes, they should be removed. They may confuse, some.
Related side note: I received 2 Practice Drums for Christmas and will be building my first actual drum controllers tomorrow! New videos are soon to follow. Once I've come back to speed in playing actual drum objects (having wired the practice pads up, as controllers) I'll be buying enough pads to build myself a kit. (I've had a Slingerland bass drum pedal waiting to be used, for a few years now. FINALLY. ) |
Dragon's Lair
Joined: Dec 29, 2006 Posts: 205 Location: Hope BC, Canada
Posted: Fri Dec 26, 2008 1:05 pm Post subject:
Hi guys, I'm in the process of wiring mine up also.
I use amp headers and IDCs for hooking up all the panel mounted components, so I always use 3 pin for pots and 2 pin for jacks, regardless of whether you need all the connections, it also helps to see which are jacks and which are pots, and also the direction (CCW-W-CW)
I guess we should look into doing up some documentation for it, I can put together a .pdf with the component layout, Andy's schematic, some assembly instructions and a short test and tutorial (I guess that's your department Ryk)
On a side note, I sent the boards out for another test run, to verify the hole sizes, I also rearranged a few components to make more room, deleted a couple of redundant traces, and fixed the trace on CV3, so hopefully, everything should be ok, they should be here by the end of January. |
neandrewthal
Posted: Fri Dec 26, 2008 2:21 pm Post subject:
Ok, here come some dumb questions. Does it really need 8 tuning knobs? I'm a little cramped for space and would like to get rid of some.
What is this drum trigger circuit you speak of? I can't find it. I'm thinking of adding 2 of these with their own own triggers, one for closed hat and one for open. I absolutely must have some kind of evelope and VCA on the same panel, as it is going in a self-contained drum synth in a corner of my modular. Having to interface it with envelopes and VCAs on the other side just to make a hi-hat sound would totally kill the flow of things. _________________ " I went through quite a few trannies til I found one I liked" - Wild Zebra |
Posted: Fri Dec 26, 2008 2:43 pm Post subject:
I actually see it as a tunable noise source rather than a hi-hat (even though I kept the name on mine for posterity )
That's why I don't want any ENV or VCA incorporated. I'm initially going to patch it as an improved noise source on the MPS. _________________ What makes a space ours, is what we put there, and what we do there. |
neandrewthal
Posted: Fri Dec 26, 2008 3:32 pm Post subject:
Oh, god. I am trying to slim this thing down, and you want to add it to the already hulking MPS behemoth
Then what do you do for hi-hats? I just want a no-frills closed-hat, open-hat machine. And the reason I need it to be so compact is because the damn MPS is taking up all my space  _________________ " I went through quite a few trannies til I found one I liked" - Wild Zebra |
Posted: Fri Dec 26, 2008 5:45 pm Post subject:
If I want hi-hats I do them in the DAW.
I'm hanging this off the MPS, which is hanging off the Klee. My analogue setup is more of a specialized noodle machine, come solo instrument. I'm adding modules really to modify what will be more of a one patch freak pony than a way of generating a complete analogue ensemble.
You know what I mean?  _________________ What makes a space ours, is what we put there, and what we do there. |
Dragon's Lair
Posted: Fri Dec 26, 2008 6:05 pm Post subject:
| I'm with Uncle Krunkus on this, I also consider this more of a tunable noise source and I don't want a VCA and EG on this, like I've mentioned before, once you start adding everything to a module, you kinda defeat the purpose of having a MODULAR synth, if you just want an open/closed hihat module, look at the Analog Solutions Concussor modules, The HH88 is a dual Hihat module, might be just what your looking for. |
Rykhaard
Posted: Fri Dec 26, 2008 6:28 pm Post subject:
I'll be starting the write up for the Liquid HiHat very soon now. One portion of it that I'd recently realized that I wished to make clear to other users of it:
- not ALL of the Frequencies controls are needed
Each of them is an option. The 4 clocks that they are controlling the speeds of, may be set to 1 frequency with whichever value of resistor is preferred. Ken Stone has (a) certain value(s) listed for his Cynare drum simulator. They (those) could be chosen (from) if the user is not wishing to go with every Frequency control.
Also - each of the CD4046's (VC Clock) in the LHH has a Frequency control. These 2 along with their Frequency Range controls I would leave, at least. In this case, you would still have up to two CV Inputs for each of the VC Clocks. That would still give you 6 options for setting the LHH frequencies if you chose not to use the first 4 frequency controls.
I myself, far prefer to have as much control as I'm able to over my modules and will be sticking with the:
- 2 x Frequency Range
- 2 x VC Clock Frequency
- 4 x Frequency
- 4 x CV Amount
- 4 x CV Input
on my V1.00 units.
(Once I've done a full test configuration / small manual for the unit, shall I post it up here, for everyone.) |
Rykhaard
Posted: Fri Dec 26, 2008 6:38 pm Post subject:
I forgot about the other postings above.
For the V1.00 LHH I myself am sticking with the LHH itself being nothing more than, what it is, as I am building more of Ray Wilson's Drum Triggers. The new ones will be having multiple Decay controls so that I can feed them to VCF's and VCA's for the LHH.
As far as the drum trigger goes, Ray's is at this addy:
I was JUST going to post the addy for it but it's come up as 404 - Not Found. Any other accesses to Ray's web page are also taking a hugely long time.
I chopped off the drum trigger extension, getting into the directory where it used to be and it's not listed there any more.
Does anyone else know of where on Ray's site that it might be? I wishn't to post it here without Ray's permission.
I'm having a great deal of difficulty in delays right now even in getting into Ray's MAIN web page.
If anyone else can find the Drum Trigger circuit there, would you please let me know?
http://www.musicfromouterspace.com/ |
julianw
Dragon's Lair
Posted: Tue Dec 30, 2008 5:03 pm Post subject:
Looks great to me!
Don't worry about the high column. I do my best to make everything spot on, but I like to keep in mind that imperfections will always weasel their way into the final product. That's what makes it DIY! and fun. If there were no stuff ups, it would be made in a factory in China somewhere, and would suffer from chronic build quality issues. I know which I'd prefer.
As for mine, it's half wired, and if I manage to get some time away from all these pesky family and friends wanting to do Christmas type stuff and eat and drink beer and all that, it should be whistling away in a couple of days. _________________ What makes a space ours, is what we put there, and what we do there. |
Rykhaard
Posted: Tue Dec 30, 2008 6:27 pm Post subject:
Wow! It's wild to see someone having built a module that I coughed up!! Where's the samples??
Who cares about the high column? Like Uncle Krukus said - it's part of DIY!
It looks great though! Come on Unc. Get yours fin. and a pic posted as well!
Subject change: if all goes well, there'll be a new video, of a NEW innovated module, posted on my site within a couple of days. I just finished cooking 2 boards for it and shall be wiring and panel building, over the next couple of days. More data on it will be posted in the Layout Factory.  |
Dragon's Lair
Posted: Tue Dec 30, 2008 9:47 pm Post subject:
Thanks guys, I know that the raised column is not a big deal, IT JUST BUGS ME!
Sorry Ryk, no sound samples, I don't have the studio hooked up to my computer any more, and my laptop is in the basement running the pic programming software, besides, remember that I'm on dialup out here and it takes forever to upload audio and video, maybe next year when we get cable out here. |
Rykhaard
Posted: Wed Dec 31, 2008 1:33 am Post subject:
| Dragon's Lair wrote: | Thanks guys, I know that the raised column is not a big deal, IT JUST BUGS ME!
Oh bugger, that's right. Me ol' timer'ness and my short memory or'd've remembered that you're on dialup.
Well then - post any thoughts you have of your own unit once she's up'n' runnin'.  |
Posted: Thu Jan 01, 2009 4:52 am Post subject:
The power connector is a bit too close to the filter caps. Even with tiny ones, the 3.96mm pitch 4-way tries to push the caps over when you connect the plug. _________________ What makes a space ours, is what we put there, and what we do there. |
Rykhaard
Posted: Thu Jan 01, 2009 10:22 am Post subject:
Excellent to hear, Uncle Krunkus!! More more! With multiple CV's activating! As a hihat; as a cymbal; as a snare; as an egg being broken in a metal sink ......
(I have a distant hope of finishing 1 of my 2 x Triple Drum Triggers, today. If I have enough time to, I'll hook 1 up to my beta LHH to shoot a video of it, being played from my electronic Remo practice pad. That'd give another example of possibilities from it.  |
mono-poly
Joined: Jul 07, 2004 Posts: 937 Location: Rotterdam, Netherlands
Posted: Fri Jan 02, 2009 6:32 am Post subject:
| Nice example Uncle! |
Dego
Posted: Fri Jan 02, 2009 11:11 am Post subject:
Twisted sample! Even more anxious now. Great work guys! |
Dragon's Lair
Posted: Sat Jan 10, 2009 10:26 pm Post subject:
Well I managed to get a sample of my Liquid Hi Hat recorded into my laptop.
This is just the LiquidHH being modulated by my VC-Clock and XR-LFO modules. I had to run the output of the LiquidHH through a preamp pedal, to get the levels up high enough to record.
I don't have video capabilities at the moment, but here's a pic of the setup.
This sample is meant to demonstrate that the module is capable of sounds other than hi hats, Ryk did a fine job demonstrating those in his videos.
| Description: |
| Filesize: |
123.34 KB |
| Viewed: |
431 Time(s) |
| Description: |
 Download (listen) |
| Filename: |
LiquidHH.mp3 |
| Filesize: |
1.81 MB |
| Downloaded: |
667 Time(s) |
Last edited by Dragon's Lair on Mon Feb 09, 2009 11:26 am; edited 1 time in total |
Dragon's Lair
Posted: Mon Feb 09, 2009 11:23 am Post subject:
The second batch of prototypes are in, so far everything looks good, the resistor holes are still a bit small, my 1% resistors fit fine, but the 5% don't, so I made the drill 1 size larger, so they should be fine for the next batch, same thing with the MOTM connector, it's fine if you use the headers with round pins, but the square pins don't fit, so I upped it also, that one was my fault, I measured the pins on the flats, when I should have measured on the diagonal.
I'll try to get one assembled this week, just to make sure there are no other errors. Last edited by Dragon's Lair on Sat Mar 07, 2009 12:14 pm; edited 3 times in total |
fluxmonkey
Posted: Mon Feb 09, 2009 2:42 pm Post subject:
| Dragon's Lair wrote: | Well I managed to get a sample of my Liquid Hi Hat recorded into my laptop.
I don't have video capabilities at the moment, but here's a pic of the setup...
PIGNOSE!!! +1!!!
b _________________ www.fluxmonkey.com |
ach_gott
Posted: Wed Feb 11, 2009 10:47 am Post subject:
| I would be interested in 3 boards. |
