RF
Audio files: 28
Posted: Mon Jan 05, 2009 9:14 pm Post subject:
Wow - That's a really nice one Slacker. What are you using in that patch?
bruce _________________ www.sdiy.org/rfeng
(Herb Deutsch to Bob Moog ~1963) |
slacker
stolenfat
Joined: Apr 17, 2008 Posts: 476 Location: Sunny Oakland California
Posted: Thu Jan 08, 2009 12:19 am Post subject:
| that melody generator makes some cool sounds, would you mind explaining how the 4052 and the 4017 interact together to produce those sounds? |
slacker
Posted: Thu Jan 08, 2009 1:59 pm Post subject:
Basically, the length of the pulses on the 4017 pin 3 (Out) in relation to the clock pulses on pin 14 (In) depend on which number it's counting up to. If it counts to 2 it's twice as long so half the frequency of the clock, if it counts to 3 it's 3 times as long so a third of the frequency and so on.
The outputs of the 4017 connect to the inputs on the 4051, and the output connects back to the 4017's reset pin. The signals on the A,B and C pins set which output gets connected to reset and this sets the number the 4017 will count up to, and therefore what note it will produce.
To make it play tunes you feed an audio speed signal into the 4017 clock Input and feed different clock signals into the ABC inputs. Changing the combination of signals on those pins gives you the different notes and patterns.
The 4017 clock enable (pin13) adds modulation, at slow speeds you get tremolo effects and higher speeds give ring mod type sounds.
Hope that makes sense. |
stolenfat
Posted: Thu Jan 08, 2009 10:30 pm Post subject:
| thanks for the explanation, big help! |
slacker
Posted: Fri Feb 13, 2009 11:39 am Post subject:
Here's another couple of little pieces. I've been listening to the great stuff in the Klee musics thread so these inspired by that.
I whacked the output through a delay pedal into an amp and then recorded that so there's a bit of hum and the odd crackle.
The first one gets a bit loud at the end, so watch your speakers
133.61 KB |
| Viewed: |
792 Time(s) |
 Download (listen) |
| Filename: |
sequence.mp3 |
2.14 MB |
| Downloaded: |
2022 Time(s) |
 Download (listen) |
| Filename: |
growl.mp3 |
728.2 KB |
| Downloaded: |
1809 Time(s) |
cthulu
Joined: Feb 07, 2009 Posts: 56 Location: Göteborg, Sweden
Posted: Fri Feb 13, 2009 12:57 pm Post subject:
| stolenfat wrote: | so with this schematic, you could technically set up 2 ring mods, with 4 inputs using pins 1,2,5,6,8,9,12,13?
If so, best ring mod schematic i've found yet. |
This one is my favourite ring modulator. It's the same one used in the MS20 except that one is realised with
NAND gates. With a 4070 you get 4 (quasi)ring modulators...
ps. these are all nice samples...  |
RF
Audio files: 28
Posted: Fri Feb 13, 2009 2:08 pm Post subject:
Very nice sounds Slacker!
How much knob twisting are you doing on the first one? _________________ www.sdiy.org/rfeng
slacker
Posted: Fri Feb 13, 2009 2:50 pm Post subject:
Thanks.
In the first one the basic pattern's driven by a counter, but the pitch slides to a new pattern are done with a knob. Then the tempo and pitch changes and the filtery sound at the end are knob twiddling.
I need to get some shift registers and gates built to add some more variation and randomness and try some more noisy things. |
telstarmagikistferrari
Joined: Jun 16, 2008 Posts: 280 Location: Indianapolis, Indiana
Audio files: 43
Posted: Fri Feb 13, 2009 9:13 pm Post subject:
| awesome thread, awesome stuff being documented! keep it up slacker.. |
slacker
Audio files: 43
Posted: Sat Feb 21, 2009 3:14 pm Post subject:
very nice slacker! I've been getting some similar jams using RF's 4051 Pattern Generator.. it's a whiz for modifying sequences with the flip of a (choice of eight) switch(es). I love it, thanks (again) RF! REALLY useful module everyone.
Mark |
slacker
Posted: Mon Feb 23, 2009 5:43 pm Post subject:
Cool I'll have to try it.
Here's another clip, bit different this one, sort of an ambient thing. Just the lunetta with a load of reverb. It's a bit long and it doesn't really go anywhere. I might try overdubbing something over it to make it more interesting.
Soundscape.mp3 |
Rykhaard
Posted: Mon Feb 23, 2009 6:10 pm Post subject:
| slacker wrote: | Cool I'll have to try it.
Soundscape.mp3 |
WHOA! That is one of the best Lunetta tracks I've heard yet! Hat's off to ya!  |
Joined: Apr 03, 2004 Posts: 24544 Location: The Netherlands, Enschede
Audio files: 299
Posted: Wed Feb 25, 2009 3:02 pm Post subject:
That's some nice Lunetta stuff Slacker, keep 'm coming ! _________________ Jan
droffset
Joined: Feb 02, 2009 Posts: 515 Location: London area
Posted: Thu Mar 05, 2009 4:25 am Post subject:
Please enjoy this meager sample of my kick ass supercharged hot-n-spicy Lunetta.
http://droffset.com/sound/birthOfALunetta.mp3
No effects, just some editing and fading in and out. I used Audacity for recording.
Thanks everyone for helping me get started in this.  |
Joined: Jan 31, 2003 Posts: 18272 Location: Durham, NC
Audio files: 232
Posted: Thu Mar 05, 2009 10:26 am Post subject:
These are all excellent sound examples. I wish I could comment on all of them. I love these sounds for some reason.
For my taste, no effects is the best. Just a matter of taste though of course.
Droffset, nice one. it has the feel of a musical composition as its sound evolves. _________________ --Howard
my music and other stuff |
Rykhaard
Posted: Thu Mar 05, 2009 10:38 am Post subject:
| mosc wrote: | These are all excellent sound examples. I wish I could comment on all of them. I love these sounds for some reason.
Droffset, nice one. it has the feel of a musical composition as its sound evolves. |
That, as you said Howard, is what had impressed me so much about Droffset's 'tune'. More organized than random - mood evoking through the entire piece. How it were done though, brought me to the point of deciding on it being a 'keeper'.
Why don't you bring your wonderful looking machine back to life, Howard? I'd imagine everything in it is still functioning. Hook'er up and record away for all of us!  |
Audio files: 232
Posted: Thu Mar 05, 2009 12:03 pm Post subject:
| Rykhaard wrote: |
Thanks for the encouragement. My life is a vessel constantly being filled with things undone. Still, I would really like to get it going again.
I feel, in some way, that all the wonderful instruments and music being generated by you and the others in this community are somehow descendants of my Lunetta.
Still, there's nothing sadder than an instrument in disrepair. _________________ --Howard
Rykhaard
Posted: Thu Mar 05, 2009 12:45 pm Post subject:
| mosc wrote: |
Still, there's nothing sadder than an instrument in disrepair. |
Then all together, as I see it, that's all the more encouragement to bring the beast out, give a good going over. After making sure everyone inside her is ok, just flipping on the recorder and joining as!
Afterall, thanks to you intially Howard, this huge interest has taken off! It'd be cool to hear your knob twiddlings as well.
Off I am now with my RCA CMOS Databook, to shop in the CMOS isle at my local supplier.  |
RF
Audio files: 28
Posted: Thu Mar 05, 2009 1:51 pm Post subject:
| mosc wrote: |
I feel, in some way, that all the wonderful instruments and music being generated by you and the others in this community are somehow descendants of my Lunetta. |
Indeed they are, mosc!
Rykhaard
Posted: Thu Mar 05, 2009 1:59 pm Post subject:
| RF wrote: | | mosc wrote: |
bruce |
Oooo. I forgot to reply to that part.
Definitely Howard. In that aspect: great thanks and respect for it, to yourself as well as Stanley Lunetta, as well as the originator from the earlier 1900s that I have a photo of, with his machines that he'd built then. (Still trying to find his name. ) |
Rykhaard
Posted: Thu Mar 05, 2009 7:36 pm Post subject:
Otay boys and girls! (The latter, I THINK! LOL)
Here's my 2nd mp3 from my Lunetta machine that I'm building. I took a new photo of it, whilst I were recording the 4:44 long piece as well.
The modules that were used for this mp3 were:
- 40106 Osc. #1 (47 to roughly 4700HZ) that's hooked up to the input of 1 of my 3 Voltage Controllable / Manually Controllable SPDT switches
- 40106 Osc. #4 (47 to roughly 4700HZ) that's hooked up to the 1 of 3, 3 input audio mixers that I completed tonight
- 40106 Osc. #6 (2 to roughly 250HZ) that's first hooked up to a multiple. From there it feeds the Clock Input of 1 of my 2 4015 4 bit Shift Registers. The other multiple connection is going to the Voltage Control of the SPDT switch
- 4023 Pulse Width Osc. #1's output is being fed into the 3 input audio mixer; Modulation Input #1 is coming from Shift Register Output #3; Modulation Input #2 is coming from Shift Register Output #2
- VC SPDT Switch #1: Output A is going to the 3rd input of the 3 Input Audio Mixer; Output B is going to the Data Input of the Shift Register
And that, is the entire patch. (I have another photo of it that I can include if anyone's curious.) I hope y'all enjoy the track! I myself after listening to it at least 10 times, wished that I had continued recording!
Oh yeah - it's recorded in Mono, and the ONLY effect, is a long reverb time, from my 8 bit Korg reverb unit. |
Audio files: 232
Posted: Thu Mar 05, 2009 11:00 pm Post subject:
TheModularDeathlehemMachineNumber8-BackIn1965-Mar0509
That's a very catchy title.
I like it. _________________ --Howard
droffset
Posted: Fri Mar 06, 2009 2:47 am Post subject:
Thanks Mosc, having a very good time with the project. It's meant to feel like a composition, but it was a bit more 'wrangled' than composed.
