Nord Electro2 error messages!
Page 1 of 1 [3 Posts]
ClaytonD1
PostPosted: Tue Jan 06, 2009 2:49 pm    Post subject: Nord Electro2 error messages!
Subject description: boots up E7 error then goes to b bank and lots of lights on at same time
says 87, 67 69 makes B3 sounds and no piano unless you hold down the pitch button, low hours on this, never edited a program before lock is still on,this has not left the house since I bought it in august. tried changing one acoustic piano and that went fine then back to error right after boot up.If I take it apart I'm sure the warranty is void, but there is no distributor anymore so have not found warranty service yet.
egregor1
PostPosted: Tue Jan 06, 2009 3:41 pm    Post subject: Re: Error messages Reply with quote  Mark this post and the followings unread
Did you try uploading a fresh set of samples to your Nord?
You can download the sample file from Clavia's website. Then you hook up your computer to your Nord using some kind of USB/MIDI interface, and all the samples on your board are refreshed. There's no way to know that this is the cure, but it sure sounds like your issue is software-related, possibly originating in the instrument samples.
-Evan
Wout Blommers
Audio files: 123
G2 patch files: 12
PostPosted: Tue Jan 06, 2009 3:51 pm    Post subject:
Subject description: Splitting thread
I created a new thread by splitting.
See also http://electro-music.com/forum/post-222993.html#222993
Wout
