Inventor
Audio files: 267
Posted: Fri Jan 09, 2009 7:40 pm Post subject:
That sounds like the way to do it! I suppose you'll want to put an LED on each output, no doubt that was your plan, eh? _________________ "Let's make noise for peace." - Kijjaz |
Posted: Fri Jan 09, 2009 7:51 pm Post subject:
| Inventor wrote: | | That sounds like the way to do it! I suppose you'll want to put an LED on each output, no doubt that was your plan, eh? |
that was the plan. actually i would need an IC like the 4052 that accepted a clock!
the 4052 has to be controlled by i.e. a 4024. no matter how i do it, i always need two ICs, one for switching and one as controller, it seems... _________________
Tech Buddy at Random*Source |
Inventor
Audio files: 267
Posted: Fri Jan 09, 2009 8:17 pm Post subject:
Too bad there isn't an counter with open collector outputs or open drain outputs, then you could just shunt the signals quiet except for the active one. Might get some leakage though.
You could use a PIC to do that in a variety of different ways, perhaps.
I dunno, just thinking out loud. _________________ "Let's make noise for peace." - Kijjaz |
RF
Audio files: 28
Posted: Fri Jan 09, 2009 8:51 pm Post subject:
Is there is a way to initially load one bit into a shift register (ie. 4015) send the output back into the input and use your momentary switch as the clock?
bruce _________________ www.sdiy.org/rfeng
(Herb Deutsch to Bob Moog ~1963) |
Inventor
Audio files: 267
Posted: Sat Jan 10, 2009 3:38 am Post subject:
| RF wrote: | Is there is a way to initially load one bit into a shift register (ie. 4015) send the output back into the input and use your momentary switch as the clock?
bruce |
Probably NANDing all the outputs and putting that into the carry input would work, depending on clocking edge details. But then that's more digital chips.
How abut something funky like sending the control outputs into the oscillator circuits in a creative way that shuts them down or enables them? That would eliminate the analog switch chip. _________________ "Let's make noise for peace." - Kijjaz |
Posted: Sat Jan 10, 2009 6:57 am Post subject:
| Inventor wrote: | | How abut something funky like sending the control outputs into the oscillator circuits in a creative way that shuts them down or enables them? That would eliminate the analog switch chip. |
to say it frankly, i don't know much enough to understand what you are after. i would be glad if you could explain it in plain words for me...
however, i was looking for a general solution i could use anywhere in the prewired synth i want to build (selection of waveforms, speed, on/off). _________________
Posted: Sat Jan 10, 2009 7:09 am Post subject:
Wouldn't a 4024 need a separate B to D for the LED indicators? _________________ What makes a space ours, is what we put there, and what we do there. |
Inventor
Audio files: 267
Posted: Sat Jan 10, 2009 7:17 am Post subject:
| fonik wrote: | | Inventor wrote: | | How abut something funky like sending the control outputs into the oscillator circuits in a creative way that shuts them down or enables them? That would eliminate the analog switch chip. |
however, i was looking for a general solution i could use anywhere in the prewired synth i want to build (selection of waveforms, speed, on/off). |
Oh, well this is a specific solution. Say your oscillator has a capacitor to ground that sets the frequency. Lift that ground connection and hook it up to the digital output. That way, when it is logic 1 the circuit won't oscillate and when it is logic 0 it will. But again that's design specific. If you need a general solution you're back to two chips plus debounce. _________________ "Let's make noise for peace." - Kijjaz |
Inventor
Audio files: 267
Posted: Sat Jan 10, 2009 7:20 am Post subject:
You could also play games with opamps, like this. Sum the digital output into the oscillator signal with gain. Then when the output is one, the opamp will hit the rail and no oscillator signal will get out, and when the output is zero you get your signal. If you have to have an opamp there anyway there are no added parts. _________________ "Let's make noise for peace." - Kijjaz |
Joined: Apr 03, 2004 Posts: 24638 Location: The Netherlands, Enschede
Audio files: 321
Posted: Sat Jan 10, 2009 7:21 am Post subject:
| Uncle Krunkus wrote: | | Wouldn't a 4024 need a separate B to D for the LED indicators? |
Either that or or learn to read B  _________________ Jan
Posted: Sat Jan 10, 2009 7:29 am Post subject:
i'd thought to do it like that:
http://modular.fonik.de/pdf/seq_switch.pdf
however the 4017/switch IC solution would be more versatile... _________________
Audio files: 321
Posted: Sat Jan 10, 2009 7:37 am Post subject:
Smart!
One thingie ... I see you routed both Vee and Vss of the 4052 to GND, yet you do go into the chip with potentially negative voltages. Shouldn't one of (I forgot which one, the data sheet will tell) Vee or Vss go to -8V? _________________ Jan
richardc64
Audio files: 26
Posted: Sat Jan 10, 2009 8:15 am Post subject:
| Blue Hell wrote: | | Shouldn't one of (I forgot which one, the data sheet will tell) Vee or Vss go to -8V? |
Vee.
Also, aren't those LEDs pointing the wrong direction? You can eliminate 3 resistors by connecting the LEDs directly (in the right direction,) to the 4052 pins and have a single resistor to +8V at "x."
And regarding -8V, there are LM7908s available, which should be more reliable than a resistive voltage divider. But, if a voltage divider is good enough to create -8V, why wouldn't it be good enough for +8V?
What makes this thing "VC"? _________________ Revenge is a dish best served with a fork... to the eye |
Posted: Sun Jan 11, 2009 5:29 am Post subject:
dieter's idea!?
| Quote: | | One thingie ... I see you routed both Vee and Vss of the 4052 to GND, yet you do go into the chip with potentially negative voltages. Shouldn't one of (I forgot which one, the data sheet will tell) Vee or Vss go to -8V? |
you got a sharp eye, jan. yes, VEE should go to -8V. that's actually the idea of the circuit. this way the switch could handle both audio and CVs.
| richardc64 wrote: | | And regarding -8V, there are LM7908s available, which should be more reliable than a resistive voltage divider. But, if a voltage divider is good enough to create -8V, why wouldn't it be good enough for +8V? |
this is actually a doepfer circuit. you can download it from his site. since +8V (envelope) is the higher limit in a doepfer system, he wanted to be sure to cover this exactly, i suppose. the lower limit would be -5V IIRC. therefor he used just a divider.
however you are right. i will have to do a new PCB and will consider the usage of a 2nd regulator.
maybe it would even be a good idea to incorporate a switch to choose from -8V to +8V and GND to +15V powering of the circuit.
| richardc64 wrote: | | What makes this thing "VC"? |
it is a 4pos switch not controlled manually, but from a voltage (clock).
| richardc64 wrote: | | Also, aren't those LEDs pointing the wrong direction? You can eliminate 3 resistors by connecting the LEDs directly (in the right direction,) to the 4052 pins and have a single resistor to +8V at "x." |
good idea. when i built this thing i did not know what i was doing. just copying a circuit - and making errors!
so thank you very much, friends. i will redo the whole thing. i experienced some problems with the reset, too. i will have to incorporate a debouncing.
however, for my prewired synth i will go the 4017/switch IC route... _________________
Audio files: 321
Posted: Sun Jan 11, 2009 5:33 am Post subject:
| fonik wrote: | | dieter's idea!? |
I meant the way to connect up the LEDs, but I now know it could be done even smarter  _________________ Jan
Posted: Sun Jan 11, 2009 10:08 am Post subject:
| Blue Hell wrote: | | fonik wrote: | | dieter's idea!? |
I meant the way to connect up the LEDs, but I now know it could be done even smarter  |
(the LEDs are reversed even on the original doepfer schematic) _________________
Scott Stites
Audio files: 96
Posted: Sun Jan 11, 2009 4:16 pm Post subject:
Playing the feature creep for a moment. Oh, hell, who's pretending?
Why use that counter? The CD4516 was built to make stuff like this much more versatile.
I know you said "simple", but it wouldn't take a whole lot of surgery to make this really kick.
A CD4516 would allow you to count up and count down. You could also jam an input in, so you wouldn't have to work sequentially. Each channel could have its own momentary - you could jump from channel 2 to channel 4, for example, or 3 to 2, just by pushing the associated switch. Creeping forward from that, each channel could have its own pulse input so you could automate that process. Forward/reverse could be a switch.
I'd use a diode matrix for the momentary inputs for the jamming, but you could use a priority encoder, too, which is, of course, another IC.
Back under the rock....
Cheerios,
Scott Stites
Audio files: 96
Scott Stites
Audio files: 96
Posted: Mon Jan 12, 2009 10:13 am Post subject:
scott, you are driving me crazy! first i had an idea how to do something i want - then do you taking this far beyond with such nice ideas, and now i am thinking of how to use this for my synth
honestly a great idea. i will see how this fits in my UI concept (big words ). _________________
Scott Stites
Audio files: 96
Posted: Mon Jan 12, 2009 12:09 pm Post subject:
Hey! You started it by posting that juicy schematic.
Sorry about that - there's something about CMOS that is just so endless. It's the true Tinkertoys of Synth DIY. I never know where/when to stop....
Anyway, whatever you come up with, I bet it'll be awesome.
Cheerios,
Inventor
Audio files: 267
Posted: Tue Jan 13, 2009 10:10 pm Post subject:
You know, this isn't schmooze, but I just thought I'd mention that I once had a cat named CMOS. CMOS was black and white and a very smart cat. I once observed her watching a geometry show on public television with fascination.
I think if CMOS were still with us, she'd be watching the LED's and wondering what made them blink! Haha, now back to your design fun, folks... _________________ "Let's make noise for peace." - Kijjaz |
Audio files: 321
Posted: Wed Jan 14, 2009 6:25 am Post subject:
I see a small problem
When Q2 conducts and IC4 happens to be in such a state that LED3 or LED4 are on and SW2 is in the right position too ... there is a short circuit from +V8 to GND .. maybe move R11 to the other side of IC4? _________________ Jan
