Switching Signals using momentaries, sequential switches...
Page 1 of 3 [60 Posts]
Goto page: 1, 2, 3 Next
PostPosted: Fri Jan 09, 2009 7:32 pm    Post subject: Switching Signals using momentaries, sequential switches...
Subject description: final schematics in first post
This is what i'd liked to do: i wanted to have one momentary switch on the frontpanel to step thru i.e. different waveforms or channels or whatever. the active channel would be indicated by a LED. i know this could easily be done using a double pole rotary, but i want a momentary.
my idea was to use a 4017 clocked by the debounced momentary. the outputs of the 4017 would then control SPST ICs (i.e. the MAX313 rom maxims).
for 4 channels with LEDs i would need the 4017 and 2x MAX313.
any ideas how to do it easier or with less ICs?
[EDIT: uploaded the final schematic providing all bells and whistles]
 Filesize:  72.93 KB
 Viewed:  856 Time(s)
Inventor
Audio files: 267
PostPosted: Fri Jan 09, 2009 7:40 pm    Post subject: Reply with quote  Mark this post and the followings unread
That sounds like the way to do it! I suppose you'll want to put an LED on each output, no doubt that was your plan, eh?
PostPosted: Fri Jan 09, 2009 7:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
that was the plan. actually i would need an IC like the 4052 that accepted a clock!
the 4052 has to be controlled by i.e. a 4024. no matter how i do it, i always need two ICs, one for switching and one as controller, it seems...
Inventor
Audio files: 267
PostPosted: Fri Jan 09, 2009 8:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
Too bad there isn't an counter with open collector outputs or open drain outputs, then you could just shunt the signals quiet except for the active one. Might get some leakage though.
You could use a PIC to do that in a variety of different ways, perhaps.
I dunno, just thinking out loud.
RF
Audio files: 28
PostPosted: Fri Jan 09, 2009 8:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is there is a way to initially load one bit into a shift register (ie. 4015) send the output back into the input and use your momentary switch as the clock? scratch
bruce
www.sdiy.org/rfeng
Inventor
Audio files: 267
PostPosted: Sat Jan 10, 2009 3:38 am    Post subject: Reply with quote  Mark this post and the followings unread
bruce
Probably NANDing all the outputs and putting that into the carry input would work, depending on clocking edge details. But then that's more digital chips.
How abut something funky like sending the control outputs into the oscillator circuits in a creative way that shuts them down or enables them? That would eliminate the analog switch chip.
PostPosted: Sat Jan 10, 2009 6:57 am    Post subject: Reply with quote  Mark this post and the followings unread
to say it frankly, i don't know much enough to understand what you are after. i would be glad if you could explain it in plain words for me...
however, i was looking for a general solution i could use anywhere in the prewired synth i want to build (selection of waveforms, speed, on/off).
PostPosted: Sat Jan 10, 2009 7:09 am    Post subject: Reply with quote  Mark this post and the followings unread
Wouldn't a 4024 need a separate B to D for the LED indicators?
Inventor
Audio files: 267
PostPosted: Sat Jan 10, 2009 7:17 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh, well this is a specific solution. Say your oscillator has a capacitor to ground that sets the frequency. Lift that ground connection and hook it up to the digital output. That way, when it is logic 1 the circuit won't oscillate and when it is logic 0 it will. But again that's design specific. If you need a general solution you're back to two chips plus debounce.
Inventor
Audio files: 267
PostPosted: Sat Jan 10, 2009 7:20 am    Post subject: Reply with quote  Mark this post and the followings unread
You could also play games with opamps, like this. Sum the digital output into the oscillator signal with gain. Then when the output is one, the opamp will hit the rail and no oscillator signal will get out, and when the output is zero you get your signal. If you have to have an opamp there anyway there are no added parts.
Audio files: 321
PostPosted: Sat Jan 10, 2009 7:21 am    Post subject: Reply with quote  Mark this post and the followings unread
Either that or or learn to read B Cool
PostPosted: Sat Jan 10, 2009 7:29 am    Post subject: Reply with quote  Mark this post and the followings unread
i'd thought to do it like that:
http://modular.fonik.de/pdf/seq_switch.pdf
however the 4017/switch IC solution would be more versatile...
Audio files: 321
PostPosted: Sat Jan 10, 2009 7:37 am    Post subject: Reply with quote  Mark this post and the followings unread
Smart!
One thingie ... I see you routed both Vee and Vss of the 4052 to GND, yet you do go into the chip with potentially negative voltages. Shouldn't one of (I forgot which one, the data sheet will tell) Vee or Vss go to -8V?
richardc64
Audio files: 26
PostPosted: Sat Jan 10, 2009 8:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Vee.
Also, aren't those LEDs pointing the wrong direction? You can eliminate 3 resistors by connecting the LEDs directly (in the right direction,) to the 4052 pins and have a single resistor to +8V at "x."
And regarding -8V, there are LM7908s available, which should be more reliable than a resistive voltage divider. But, if a voltage divider is good enough to create -8V, why wouldn't it be good enough for +8V?
What makes this thing "VC"?
PostPosted: Sun Jan 11, 2009 5:29 am    Post subject: Reply with quote  Mark this post and the followings unread
Smart!
dieter's idea!?
you got a sharp eye, jan. yes, VEE should go to -8V. that's actually the idea of the circuit. this way the switch could handle both audio and CVs.
this is actually a doepfer circuit. you can download it from his site. since +8V (envelope) is the higher limit in a doepfer system, he wanted to be sure to cover this exactly, i suppose. the lower limit would be -5V IIRC. therefor he used just a divider.
however you are right. i will have to do a new PCB and will consider the usage of a 2nd regulator.
maybe it would even be a good idea to incorporate a switch to choose from -8V to +8V and GND to +15V powering of the circuit.
it is a 4pos switch not controlled manually, but from a voltage (clock).
good idea. when i built this thing i did not know what i was doing. just copying a circuit - and making errors!
so thank you very much, friends. i will redo the whole thing. i experienced some problems with the reset, too. i will have to incorporate a debouncing.
however, for my prewired synth i will go the 4017/switch IC route...
Audio files: 321
PostPosted: Sun Jan 11, 2009 5:33 am    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
dieter's idea!?
I meant the way to connect up the LEDs, but I now know it could be done even smarter Wink
PostPosted: Sun Jan 11, 2009 10:08 am    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
dieter's idea!?
Laughing
(the LEDs are reversed even on the original doepfer schematic)
Scott Stites
Audio files: 96
PostPosted: Sun Jan 11, 2009 4:16 pm    Post subject: Reply with quote  Mark this post and the followings unread
Playing the feature creep for a moment. Oh, hell, who's pretending? Very Happy
Why use that counter? The CD4516 was built to make stuff like this much more versatile.
I know you said "simple", but it wouldn't take a whole lot of surgery to make this really kick.
A CD4516 would allow you to count up and count down. You could also jam an input in, so you wouldn't have to work sequentially. Each channel could have its own momentary - you could jump from channel 2 to channel 4, for example, or 3 to 2, just by pushing the associated switch. Creeping forward from that, each channel could have its own pulse input so you could automate that process. Forward/reverse could be a switch.
I'd use a diode matrix for the momentary inputs for the jamming, but you could use a priority encoder, too, which is, of course, another IC.
Back under the rock....
Cheerios,
Scott
My Site
Scott Stites
Audio files: 96
PostPosted: Sun Jan 11, 2009 5:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's what I'm thinking about - it's a rough draft of the concept. Dunno if it works exactly as drawn (capacitor value might need played with) and debouncing would need to be addressed. I think reverse would be gilding the lily, but individual selection would be great - you could pre-patch stuff and select among things. Especially the way you patch up things like that (I'm thinking of those Klee videos and samples).
Cheerios,
Scott
 Filesize:  11.53 KB
 Viewed:  272 Time(s)
My Site
Scott Stites
Audio files: 96
PostPosted: Sun Jan 11, 2009 5:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
Here's an implementation that would allow external signals to select any of the four channels arbitrarily.
 Filesize:  20.89 KB
 Viewed:  326 Time(s)
My Site
PostPosted: Mon Jan 12, 2009 10:13 am    Post subject: Reply with quote  Mark this post and the followings unread
scott, you are driving me crazy! first i had an idea how to do something i want - then do you taking this far beyond with such nice ideas, and now i am thinking of how to use this for my synth Shocked
Laughing
honestly a great idea. i will see how this fits in my UI concept (big words Embarassed ).
Scott Stites
Audio files: 96
PostPosted: Mon Jan 12, 2009 12:09 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hey! You started it by posting that juicy schematic. Laughing
Sorry about that - there's something about CMOS that is just so endless. It's the true Tinkertoys of Synth DIY. I never know where/when to stop....
Anyway, whatever you come up with, I bet it'll be awesome.
Cheerios,
Scott
My Site
Inventor
Audio files: 267
PostPosted: Tue Jan 13, 2009 10:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
You know, this isn't schmooze, but I just thought I'd mention that I once had a cat named CMOS. CMOS was black and white and a very smart cat. I once observed her watching a geometry show on public television with fascination.
I think if CMOS were still with us, she'd be watching the LED's and wondering what made them blink! Haha, now back to your design fun, folks...
PostPosted: Wed Jan 14, 2009 4:45 am    Post subject: Reply with quote  Mark this post and the followings unread
actually OT, however:
here is the updated schematic of the VC sequential switch. i simplified and corrected the LED circuitry as mentioned, and added two switches:
SW1 selects the powering of the 4052. when powered from -8V to +8V it is in bipolar mode for audio and LFO, when powered from GND to +15V it is for clock and envelopes. you could process clock and envelopes in bipolar mode, too, as long as you assure not to exceed the limits (however there are protecting diodes on the I/O's).
SW2 routes the 8V from the LEDs to the reset of the CD4024, thus allowing to change the number of steps (2, 3 or 4). is the diode really needed (a proposal from peter grenader)?
i am now thinking about a manual reset switch (momentary). would it be sufficient to wire the momentary to +8V?
 Filesize:  92.71 KB
 Viewed:  426 Time(s)
Audio files: 321
PostPosted: Wed Jan 14, 2009 6:25 am    Post subject: Reply with quote  Mark this post and the followings unread
I see a small problem Wink
When Q2 conducts and IC4 happens to be in such a state that LED3 or LED4 are on and SW2 is in the right position too ... there is a short circuit from +V8 to GND .. maybe move R11 to the other side of IC4?
