DrJustice
Joined: Sep 13, 2004 Posts: 2112 Location: Morokulien
Posted: Sat Jan 17, 2009 8:26 pm Post subject:
It occurs to me that I have no idea anymore of what Electroacoustic Music is. E.g. the Wikipedia article (a bad wiki article IMO) and its discussion is very confusing, basically asserting that anything can be Electroacoustic Music, which would render the term meaningless.
Can anyone point me to THE authorative defintion of it?
DJ
Perejil
Posted: Sat Jan 17, 2009 9:19 pm Post subject:
In the academic world, electroacoustic is used to refer to what might otherwise be termed 'contemporary classical' whereas electronic music or electronica usually refers to electronic styles of popular music.
But I suppose it could also be used to refer simply to a combination of acoustic and electronic instruments (which is what I meant in my previous post, regarding the electronic oscillations acoustically altered by specially designed loudspeakers).[/i] _________________ "In the context of Philip, hair is dissonant." - An explanation of Schenkerian theory by Dr. J. P. E. Harper-Scott |
DrJustice
Posted: Sun Jan 18, 2009 9:01 am Post subject:
Thank you Perejil.
I have now spent some time trying to clarify this. Unfortunately, the more I research it, the greater the confusion. I can't find a clear consensus; some claim that it's in the style, often refering to 'classical'. Others claim that's in the technique, often refering to either 'acoustic sources' and/or 'electronic treatment'. Yet other claim that it's simply another term for electronic music. And there are all sort of claims that are extrapolations and interpolations of these. One that is in tune with my previous, uneducated, intuitive definition, found here, says "Genre of composition that uses acoustic sound sources augmented or transformed with electronic technology."
Right, I'm not going to change this thread into a discussion of the definition. Perhaps I should make another thread for that, or split this one at my first posting. For now I have to consider myself incompetent to name any Electroacoustical Music Pioneers
DJ
DrJustice
x_x
Joined: May 05, 2008 Posts: 215 Location: mother earth
Posted: Sun Jan 18, 2009 11:31 am Post subject:
As I understand electro-acoustic comes from pieces that involve both sounds produced by acoustic instruments and electronic instruments.
Ex.
Gargoyles for Violin and Electronics by Luening is electro-acoustic.
but I'm no musicologist.  |
Posted: Sun Jan 18, 2009 11:34 am Post subject:
Well, it isn´t really that hard to make sense of this. Basically the concept of electroacoustic music comes out of the pre-moog world and the age when composers needed the help from assistants impeccably dressed in white lab coats to make sense of the goodies offered by the electroacoustic music studios.
That being said, it is completely valid to define electroacoustic music as a hybrid consisting of acoustic sound sources being treated and processed by electronic means. It was a fair disagreement way back wether the BBC Radiophonic Workshop had any credibility at all because some sounds on some "tunes" had been produced by electronic oscillators.
I guess the term is best understood within the context of 50s and early 60s experimental music. Thus it is just as much a cultural phenomenon as it is a consistently definable type of music. _________________ A Charity Pantomime in aid of Paranoid Schizophrenics descended into chaos yesterday when someone shouted, "He's behind you!"
Flickr |
Perejil
Posted: Mon Jan 19, 2009 10:05 am Post subject:
It just occured to me that it could also apply to electronic music made out of recorded sound clips, ie recordings of acoustic sound stuck together (essentially what a DJ does, but also some types of contemporary classical) as opposed to electronically generated music like synths and so on. I think this is implied in some of our other definitions but I felt it needed clarification. _________________ "In the context of Philip, hair is dissonant." - An explanation of Schenkerian theory by Dr. J. P. E. Harper-Scott |
x_x
Posted: Mon Jan 19, 2009 12:03 pm Post subject:
| Perejil wrote: | | It just occured to me that it could also apply to electronic music made out of recorded sound clips, ie recordings of acoustic sound stuck together (essentially what a DJ does, but also some types of contemporary classical) as opposed to electronically generated music like synths and so on. I think this is implied in some of our other definitions but I felt it needed clarification. |
Musique Concrete? |
dewdrop_world
Joined: Aug 28, 2006 Posts: 858 Location: Guangzhou, China
Posted: Mon Jan 19, 2009 12:35 pm Post subject:
Personally I think the term doesn't have much intrinsic meaning. By common use, it most likely refers to "composer music" (tending toward academia) using electronic sound sources and optionally non-electronic ones. But I don't think this is because "electroacoustic" as a term really means anything... more that nobody wants to call their music "electroacoustic" except academic composers
James _________________ ddw online: http://www.dewdrop-world.net
sc3 online: http://supercollider.sourceforge.net |
zynthetix
Audio files: 10
G2 patch files: 13
Posted: Mon Jan 19, 2009 1:54 pm Post subject:
| DrJustice wrote: | It occurs to me that I have no idea anymore of what Electroacoustic Music is. E.g. the Wikipedia article (a bad wiki article IMO) and its discussion is very confusing, basically asserting that anything can be Electroacoustic Music, which would render the term meaningless.
DJ
You're not going to find an authoritative definition of it in the same way you aren't going to find an absolute definition of what music is (or isn't).
You will find a general consensus of what the term electronic-acoustical music or electro-acoustical music means. It's even beginning to happen in this thread.
Generally speaking, electro-acoustical music is the utilization of electricity with instruments involved in making music.
A folk singer and a classical guitarist performing a song together would be acoustical music. Giving the classical guitarist an electric guitar and performing the same song would make it electro-acoustical music. Give the guitarist his acoustic back, but making them perform it yet again with the singer using a microphone and a PA would also make it electro-acoustical music.
The vast majority of music in the twentieth century was electro-acoustical music. Originally, the term was invented / applied to suit the utilization of oscillators, tape recorders, or electric amplification in musical performance. The term is often associated with the pioneers of doing such (e.g. the avant garde and academics), but when Les Paul was first using magnetic pick-ups on a 2x4 piece of wood to make one of his first electric guitars, he was technically making electro-acoustical music as well. It just so happened that what he was playing also was country and blues.
I think the reasoning behind using a name like 'electro-music' for the name of this forum was a throwback to the term 'electro-acoustical music.' The real idea behind referencing the term is that this site is about using electronic instruments to make music. Beyond that, I don't think anybody here really cares _what_ kind of music you are making, nor the specific tools, just that they are electronic. We all use a lot of different electronic instruments and all listen to a lot of different musics - this diversity is one of the things that makes the site great as opposed to making a "Trance only" web site or one that only cares about music that uses the 808 drum machine, etc. |
zynthetix
Audio files: 10
G2 patch files: 13
DrJustice
Posted: Mon Jan 19, 2009 3:34 pm Post subject:
Thanks everyone for your contributions. My horizon has been broadened - although I actually wanted the subject narrowed down
As I suspected, even here, the views will vary. If one is to take a fully inclusive approach of the disparate views, then the only thing that is not electroacoustic, is music performed purely on acoustic instruments in a live setting with no amplification - in part because one of the often touted meanings of the term is 'amplification of instruments'; there was an age where the idea of electronic mic/amplifier/speaker was considered a pretty radical treatment, after all.
That would make sense in purely technical terms, but then again there is the cultural/historic/stylistic perspectives which is maintained by many.
Unlike the term 'music', which is understandably not to well pinned down, I'd say that 'electro(nic)' and 'acoustic' has fairly well understood and agreed upon meanings by themselves.
So far then, I wouldn't say that this question is resolved to the degree that a certain composer, composition, musician or performance can be labelled electroacoustic and non-electroacoustic with absolute certainty. At least, I still don't feel up to that
DJ
Jyoti
Posted: Tue Jan 20, 2009 3:04 am Post subject:
Wow - very interesting discussion! Thanks, everyone! _________________ My music: here! |
Perejil
Posted: Tue Jan 20, 2009 7:08 am Post subject:
How about those pieces that are composed using computers and algorithms and so forth (ie, electronically) but then written down for- and played on- acoustic instruments? (I think Milton Babbitt did some of that but don't quote me on it). Could they be considered electroacoustic? _________________ "In the context of Philip, hair is dissonant." - An explanation of Schenkerian theory by Dr. J. P. E. Harper-Scott |
Posted: Tue Jan 20, 2009 11:14 am Post subject:
The "All Music Guide to Electronica" that I keep on my shelf has a section called "Brief Style Descriptions", where there is an entry on "Electro-Acoustic":
| Quote: | | Electro-Acoustic music thrives in more unfamiliar territory: the styles that emerge are often dictated by the technology itself. Rather than sampling or synthesizing acoustic sounds to electronically replicate them, these composers tend to mutate the original timbres, sometimes to an urecognizable state. True artists in the genre also create their own sounds (as opposed to using the preset sounds that come with modern synthesizers). In progressive electro-acoustic music, the electronics play an equal if not greater part in the overall concept. Acoustic instruments performed in real time are usually processed through reverb harmonizing, an so on, which adds an entirely new dimension to the player's technique. At best, this music opens up new worlds of listening, thinking, and feeling. At worst, progressive electric artists worship technology for its own sake, relinquishing the heart and soul of true artistic expression. |
x_x
Posted: Tue Jan 20, 2009 1:39 pm Post subject:
The diagram taken from the attachment above :
| Code: |
Electro-Acoustic Music
Tape Music Live/Electronic Music
Musique Electronic Music for Music Music for
Concrete Music live for tape Electronics
| electronics and and
------------ Instrument Instruments
Synthetizer Computer
Music Music
_________________ Jan
Wayne Higgins
Joined: Aug 16, 2007 Posts: 270 Location: Greenville, FL
Lux_Seeker
Posted: Wed Jan 28, 2009 5:31 pm Post subject:
I would have to echo many of the responses here. First, while I have not done extensive research on the topic, I suspect the term would have come about in the days of early electronic music. A great deal of music today is electronic or at least electric and sometimes computer generated so the term has lost much of its original meaning.
However, there is a kind of music that continues today that I would say is more along the lines of classical music. If you follow the development of the early greats, many of which appear in the books mentioned here, you will find they have their roots in the avante gard.
Today, you can still find traditional classical music being played with natural instruments but you can also find the music that developed from the early EM or electro-acoustical music composers. You might call this art music or serious music or classical music, take you pick. drawing arbitrary lines does not really make all that much sense these days but clearly there is a difference between what many people do who post to this board (and I do to) and pop music. I would like to believe that some of the old EM spirit is still out there.
One final caveat. Electro-acoustic music is not just computer music, that would exlcude a lot of music that is definitely part of this genre is that is what you want to call it.
John M. |
