frequency shifter
Page 15 of 23 [574 Posts]
Goto page: Previous 1, 2, 3, ..., 13, 14, 15, 16, 17, ..., 21, 22, 23 Next
lexvortex
PostPosted: Fri Feb 06, 2009 4:37 pm    Post subject:
Subject description: Polyester capacitor help
Hi JH,
I've started building the FS1A and have gotten through most of it Very Happy (I was worried about the SMD stuff but it was surprisingly easy Shocked ) I'm down to the capacitors, I picked up some generic polyester caps (eg, 2A104J, I believe +-5% tolerance) for the list under Wima MKS, Siemens MKT because I don't have easy access to the higher quality ones. Will this have a negative effect on the sound quality? Also I was able to find only BC550B instead of BC550C will that make any difference? Also can I replace the two 10 ohm resistors near MOTM style MTA power connector on the Dome filter board with ferrite beads?
Thanks,
jhaible
PostPosted: Fri Feb 06, 2009 6:01 pm    Post subject:
lexvortex wrote:
Hi JH,
I don't think so. Just make sure the caps in the dome filter, multiplied with the resistor values, have a tight tolerance.
Shouldn't.
Why would you want to do this? It probably won't hurt, but what advantage would you hope to get?
JH.
lexvortex
PostPosted: Sat Feb 07, 2009 10:06 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi JH,
The reason I ask about the ferrite beads has to do with a discussion in a different thread that talks about using ferrite beads instead of low ohm resistors as discussed in this thread
http://electro-music.com/forum/viewtopic.php?highlight=ferrite+beads&t=25712
Good discussion! I've always been unhappy about how people automatically put in the series resistors. What these resistors do is turn your nice hard regulated supply into a soft supply -- IOW the voltage supplied to the circuit depends on how much current it draws. You turn a regulated suppply into an unregulated one.
The combination of the resistor and capacitor does provide lowpass filtering, but if you look at the numbers this filtering usually only goes down to the audio range. Slowly varying signals -- LFOs EGs, etc. -- go through unchanged. So the voltage supplied to the circuit also varies with frequency!
There certainly are situations where the RC decoupling is helpful, but there are also many situations where it is harmful. It is best IMO to use the ferrite beads and a fair amount of capacitance to kill HF garbage and to make sure your power distribution wiring is done carefully to avoid ground loops.
Ian
I thought (maybe wrong Confused ) that the 10 ohm resistors could be replaced by ferrite beads to avoid the situation that Ian was talking about above. I will keep the 10ohm resistors now Smile Sorry for all the newbie questions Embarassed
Thanks again,
jhaible
PostPosted: Sun Feb 08, 2009 9:31 am    Post subject: Reply with quote  Mark this post and the followings unread
lexvortex wrote:
Hi JH,
I remember that thread! And explained my general philosophy about it there, too. Smile
I only decouple *audio* circuits with RC. CV and precision parts have no series resistor in the supplies, of course.
JH.
lexvortex
PostPosted: Sun Feb 08, 2009 10:20 am    Post subject:
Subject description: Another component question
Hi JH,
Thanks for the ferrite bead info Very Happy .
Sorry to bother you again with another question about components Embarassed . I've got a lot invested in this project and what to make sure I get it right Cool . I went to my local electronic store and bought a bunch of BC560s, unfortunately when I got home and tested them they were all nonfunctional Sad . A quick trip back confirmed that his entire supply of BC560s are nonfunctional Shocked , he looked up the data sheet and got me some BC557Bs that were ~ equivalent. If I remember correctly the BC560 are a low noise version of the BC557. Should I try and track down some BC560s or will it make little difference if I use the BC557Bs?
Thanks again,
jhaible
PostPosted: Sun Feb 08, 2009 12:13 pm    Post subject:
lexvortex wrote:
Hi JH,
Thanks again,
No need for low noise transistors here. I guess any small signal pnp with the right pinout will do.
JH.
lexvortex
PostPosted: Sun Feb 08, 2009 7:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks again Very Happy Very Happy Very Happy
davebr
PostPosted: Tue Feb 24, 2009 9:27 pm    Post subject: Frequency Shifter
Subject description: Updated build progress
I've received my FrontPanelExpress panel and made an aluminum bracket to mount the PCBs. I'm just waiting now for my batch of BI Technologies potentiometers to arrive to wire up the front panel. I put updated photos on my site. - Dave
http://modularsynthesis.com/jhaible/shifter/jhshifter.htm
lexvortex
PostPosted: Wed Feb 25, 2009 5:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Hey Dave,
Very nice panel Smile I remember reading about those pots in the Yahoo Oakley group. I'm interested in trying them out, where did you end up getting them from and for how much?
davebr
PostPosted: Wed Feb 25, 2009 6:31 pm    Post subject: Frequency Shifter
Subject description: BI Technologies potentiometers
I couldn't find anyone in the US that distributes BI Technologies P260P series potentiometers. Freight from Rapid in the UK is astronomical. I ended up going direct to the BI Technologies through Arrow. Their minimum order quantity is 240, so I got 5 samples to confirm the physical dimensions and ordered 240. Their leadtime is 7 weeks so I expect them in the last half of March. I don't need 240 but they were reasonably priced and I will not pay the skyrocket prices for Vishay/Spectrol. I think these are similar quality.
This would be a great opportunity for someone to resell to the DIY community. I approached a couple of folks but got no interest. I am not interested in selling them in small quantities but if someone wanted to buy half I certainly have a lifetime supply.
davebr
PostPosted: Sat Mar 21, 2009 3:10 pm    Post subject: Frequency Shifter
Subject description: I'm Done !!!
I got my shipment of BI Technologies potentiometers and finished up my frequency shifter. This is one nice module! Updated photos at
jhaible
PostPosted: Sat Mar 21, 2009 3:45 pm    Post subject: Re: Frequency Shifter
Very nice documentation page!
JH.
funkyfarm
PostPosted: Sat Mar 21, 2009 4:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
Amazing !
so professionnal.
I have a PCBset i've bought for my old days Very Happy
Audio files: 226
PostPosted: Sat Mar 21, 2009 5:36 pm    Post subject: Re: Frequency Shifter
wow!
Beautiful work.
sduck
PostPosted: Sun Mar 22, 2009 5:36 pm    Post subject: Reply with quote  Mark this post and the followings unread
Dave, that is really awesome. So much so, that it's kick-started my plan to build one - I hope you don't mind if I copy your front panel design!
davebr
PostPosted: Sun Mar 22, 2009 8:08 pm    Post subject: Frequency Shifter
Subject description: Front Panel
Go ahead, that's why I post them. I could have done the Manual control legends in a -5 to +5 instead of 0 to 10. I thought about it but wasn't sure if that control was really centered (which it is). I figured it didn't make much difference. - Dave
funkyfarm
PostPosted: Mon Mar 23, 2009 3:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
You've put IC sockets only for 13700 ic ?
davebr
PostPosted: Mon Mar 23, 2009 5:18 pm    Post subject: Frequency Shifter
Subject description: Sockets
I rarely use sockets. I find over time that they cause more problems then they solve. I haven't had to replace many ICs but I sure have had to reseat lots of them over the years.
In this case I used sockets for the two 13700 ICs and the two MC1496 ICs. Generally I also don't use connectors for all the offboard wires but I did in this case since it was a dual board setup with lots of wires.
funkyfarm
PostPosted: Tue Mar 24, 2009 1:19 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thank you.
connectors are not luxury here. (hmm or all this is luxury)
I've checked Jurgen's site for a pcb for this impressive project till 2002, or maybe it was 2001 Very Happy
Thanks for the preview.
zthee
PostPosted: Tue Mar 24, 2009 1:26 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've been trying to make a new front panel for my Frequency Shifter. I think I've got it kinda correct. Though I'm, as always, confused about how to bundle the range, tune, manual and fine knobs..? Any ideas?
I've got a few more components to go - and then my boards are finished. Hope to get it all up and running before summer!
 Filesize:  25.76 KB
 Viewed:  13792 Time(s)
mono-poly
PostPosted: Sat Mar 28, 2009 4:24 am    Post subject: Reply with quote  Mark this post and the followings unread
Amazing man!
lexvortex
PostPosted: Tue Mar 31, 2009 10:34 am    Post subject: My panel design Reply with quote  Mark this post and the followings unread
Here is my panel design. It's based off Marc B's beautiful design Cool with a few changes. So far I've just got the panel stuffed and the PCBs fully stuffed and now all I need is a little time to wire it up!
 Filesize:  154.54 KB
 Viewed:  202 Time(s)
jhaible
PostPosted: Tue Mar 31, 2009 10:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Beautiful!
You can also post pictures like this in the "gallery thread":
http://electro-music.com/forum/topic-24079.html
(Pictures are *welcome* here in *this* thread, too, of course.)
JH.
sduck
PostPosted: Sat Apr 04, 2009 6:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
I seem to have hit a problem in the construction of my FS1a.
The caps for the dome filter. I bought the 2% tolerance ones Dave Brown has in his BOM. I've just discovered that my fluke 115 only reads capacitance to the single digits in the nanofarad range - not the one or two decimal points that the spreadsheet uses.
Do I need to worry about this? Should I get a better dmm for this purpose? Any other ideas?
jhaible
PostPosted: Sun Apr 05, 2009 6:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Having caps with higher tolerance doesn't meant the FS will stop working - it just may have a bit less sideband rejection. Which probably won't hurt too much. You could simply try the caps you have, see (hear) if you like the results, and you can still upgrade to tighter spec'ed caps later.
If you like it the way you have it, don't search for faults.
(Pragmatical approach.)
JH.
