jhaible
Posted: Sun Feb 17, 2008 3:06 pm Post subject:
Photos of what you've built with JH PCBs |
One pleasant aspect of just selling boards, and not finished products, is that you all surprise me with so many different ways how you build your effect. I love variety
If you want to show me what you've built, and be an inspiration to others, here's where you can put up your photos.
I just got the idea when I saw the latest post in the Triple Chorus thread, with a clever way to improvise standoffs for PCB mounting. And while you're also welcome to post directly in the respective threads, I thought I just start an extra thread especially for pictures. Make this thread your gallery!
JH. _________________ "I tell you the truth, if anyone says to this mountain, 'Go, throw yourself into the sea,' and does not doubt in his heart but believes that what he says will happen, it will be done for him. Therefore I tell you, whatever you ask for in prayer, believe that you have received it, and it will be yours." (Mk 11,23f) |
jhaible
Posted: Sun Feb 17, 2008 3:17 pm Post subject:
I guess I just start posting pictures.
Sorry for the low resolution.
JH.
76.45 KB |
| Viewed: |
274 Time(s) |
123.27 KB |
| Viewed: |
262 Time(s) |
markusw
Joined: Jun 16, 2007 Posts: 23 Location: Vienna/Austria
Posted: Tue Feb 19, 2008 2:47 pm Post subject:
Once the Krautrock phaser PCB is populated, both the Krautrock and the Tau Pipe will be put in sloped Hammond enclosures.
Will take a while though.
However, as soon as they are done I will post pics.
Regards,
Markus |
yusynth
The Alison Project
Posted: Wed Feb 27, 2008 6:28 pm Post subject:
I will upload new photos when I get FPE panels made. The Triple Chorus will be soon but I am holding off on the Tau incase the Debounce circuit comes to life.
Here are my previous pics I posted in the Tau amd Chorus topics.
84.31 KB |
| Viewed: |
14421 Time(s) |
173.38 KB |
| Viewed: |
189 Time(s) |
_________________ -
The Alison Project
www.thealisonproject.com
www.myspace.com/theyakuzacowboys |
Usine Karate
Joined: Jun 09, 2007 Posts: 64 Location: Hackney Wick
funkyfarm
jhaible
Posted: Mon Mar 17, 2008 4:44 am Post subject:
| funkyfarm wrote: | Big caps tau !
Polystyrene?
funkyfarm
Posted: Mon Mar 17, 2008 4:50 am Post subject:
surely...1% type...the last forth row is under the pcb  |
alain6870
jhaible
Posted: Mon May 05, 2008 2:37 pm Post subject:
Nice to see somebody else combining a wooden enclosure with a metal front panel. I did this a lot myself - it's unexpensive, and in the rack , you only see the front panel anyway.
Keep those pictures coming, of what you've built!
riku
Posted: Mon May 12, 2008 3:52 am Post subject:
Compact clone |
Hi all. Here my 1U rack version of Compact clone and first post to the board.
I've added some extra features here. The manual switch is done with the same relay + CD4007 circuit as in the bypass switch. Mainly for looks of the front panel...
On the back there is two extra jacks for CV IN to drive lamps with sequencers etc. (as JH mentioned over here) and CV OUT from the oscillator to use it with other gear. These are not tested yet and I think some sort of buffering (opamp as voltage follower) would be good idea to use with the CV OUT.
The sound of this phaser is awesome! Thanks for sharing this project.
177.07 KB |
| Viewed: |
199 Time(s) |
170.64 KB |
| Viewed: |
220 Time(s) |
jhaible
Posted: Mon May 12, 2008 10:58 am Post subject:
Looks great.
Very clean, and you're using good potentiometers!
But tell me please: how do you fit the lamps and LDRs into 1U height?
riku
Posted: Wed May 14, 2008 12:27 am Post subject:
| jhaible wrote: | Looks great.
But tell me please: how do you fit the lamps and LDRs into 1U height? |
I cutted the lamp sockets legs so the bottom of the socket touches to PCB. This made those about 3mm shorter. Secondly the studs are the shortest ones which I founded. 40mm inner height of case height helps alot too.
I had a plan b to drill holes big enough to mount lamp sockets trough the PCB. |
bridechamber
Joined: Oct 06, 2007 Posts: 64 Location: Saint Paul, MN
whomper
jhaible
Posted: Sun Jun 08, 2008 2:54 am Post subject:
| whomper wrote: | Hi,
This is my "DIY" panel for the great sounding Schulte Phaser
Whomper |
Glad to see this working!
whomper
Posted: Sun Jun 08, 2008 4:19 am Post subject:
| jhaible wrote: | | whomper wrote: | Hi,
Whomper |
JH. |
Yeah, learned a lesson while building the kit; never trust a component supplier on resistor values. Always check!
I had the 2.43K labeled as such but replaced with a 243K. Spent days on this until a run a complete resistor value check of the board to find the error.
Whomper |
austrohungaro
Joined: Dec 23, 2006 Posts: 42 Location: Barcelona (Spain)
jhaible
Posted: Sun Jul 20, 2008 4:28 pm Post subject:
My 2008 Scanner Vibrato Prototype.
http://www.jhaible.heim.at/interpolating_scanner_and_scanvib/jh_scanvib_proto_1.jpg
(just finished a couple of hours ago)
austrohungaro
Posted: Sun Jul 27, 2008 3:39 am Post subject:
Two Phasers in a Box |
Both Phasers are finished and working.
58.91 KB |
| Viewed: |
12434 Time(s) |
64.11 KB |
| Viewed: |
12434 Time(s) |
riley smith
Joined: Sep 04, 2008 Posts: 9 Location: santa cruz, ca
Luka
jhaible
Posted: Thu Sep 04, 2008 11:53 pm Post subject:
Re: JH Frequency Shifter Subject description: Pic of Freq Shifter |
| riley smith wrote: | I had the front panel ecthed at Front Panel Express up in Seattle Washington. Nice folks and they did a great job. The panel is based on Jurgen's orginal hand drawn design with a few small mods. I'm happy with the control layout.
- Riley |
This looks beautiful!
I wish I'd found the time to put mine into such an enclosure; my FS-1a prototypes are still bare PCBs mounted on a piece of plywood ...
