New gear!
Page 26 of 74 [1832 Posts]
Goto page: Previous 1, 2, 3, ..., 24, 25, 26, 27, 28, ..., 72, 73, 74 Next
Oskar
PostPosted: Mon Feb 09, 2009 4:46 am    Post subject: Reply with quote  Mark this post and the followings unread
v-un-v wrote:
Oskar wrote:
SLX Audio Par 56 LED light...
I thought I shouldn't bore you, but since you insist...
Shocked
They have these at my local fave venue. They swapped the original lights for these. Okay I can understand why (cheap to run, no heat, last forever etc), but the light these things give off look more like that of a TV set- ie cold (IMO). Just like energy saving lightbulbs, I personally don't like them at all Sad
I see wot you mean! I would NOT like to do anything spectacular with them, as they're not up to it, but as I mostly do acoustic solo stuff I don't need more than an indication that there's someone up on stage. And if the punters can't see me all that clearly, so much the better - I'm not pretty, y'know? Cool
Where there are too many policemen, there is no liberty. Where there are too many soldiers, there is no peace. Where there are too many lawyers, there is no justice.
Lin Yutang (1895-1976)
Oskar
PostPosted: Mon Feb 09, 2009 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
I might be doing some ensemble recording soonish, so I went and got a Focusrite Saffire Pro 40.
 Filesize:  137.63 KB
 Viewed:  243 Time(s)
DrJustice
PostPosted: Mon Feb 09, 2009 2:53 pm    Post subject: Reply with quote  Mark this post and the followings unread
Oskar wrote:
DrJustice wrote:
Oskar wrote:
...SLX Audio Par 56 LED light...
DJ
Thank you! That's so much better. What a neat lamp. Must be for your glam act, no? Very Happy
Here's a new gadget for my glam act (Rolling Eyes)...
DJ
Audio files: 281
PostPosted: Mon Feb 09, 2009 4:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
v-un-v wrote:
modulator_esp wrote:
Boss RE-20 Space Echo, to add a bit of grunge to my delays. Has nice reverb too, but it's a bit fiddly to get tempo delays in time
Yes I'd like an RE-20 too Smile
As for the tempo delay stuff, I think that this unit would loose its charm, or even its likeness to the original if it were to gain tempo lock.
Hey Jez, listen to Lee Scratch Perry's "Clock and Dagger Horns (Dub Mix)" - IMO, the best dub track EVER!! . Probably not entirely up your street- but hey it's reggae- the stuff where TD and all those other Krautrockers got their dub influence from Wink
http://www.youtube.com/watch?v=S1lrqekwh10
It sounds like that horn section is also feeding a Shulte Compact A- judjing by that nice slow sweep Very Happy Very Happy Very Happy
btw, to keep it on-topic, I just got an ancient (!!) Boss SP-505 'groovestation' thingie which has got the RE-20 built into it. I'll probably still have to get the real deal though. Smile
Funny that, I got mine because I was having fun with the tape delay built in my SP-404. It's a fair bit different. The reverb is nice
It has tap for getting in time with stuff, which is OK I suppose, but not great for using with sequences, where it's nice to time the delay to fit in the gaps
The dub thing was interesting, but the delay sounded in time to me
PostPosted: Tue Feb 10, 2009 7:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Laughing
Me thinks that the band was tempo locked rather than the delay!! Wink
But I bet you can't do that 'yanked tape' effect with the RE20 - like when the horn section breakdown comes- I live for that moment! Cool
Audio files: 281
PostPosted: Wed Feb 11, 2009 10:15 am    Post subject: Reply with quote  Mark this post and the followings unread
I recently started taking my evolver to work and have been digging into programming in my lunch break after not really using it for a long time.
I have decided I like it so much I have just purchased another Smile
They should come in handy for drones/sequences and effects stuff for my compact live rig with the Nord G2 and Repeater
EdisonRex
Audio files: 172
PostPosted: Wed Feb 11, 2009 1:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yeah I use my PEK for that sort of thing. They're actually very capable instruments. And much more portable than a lot of my stuff...
Garret: It's so retro.
Audio files: 281
PostPosted: Wed Feb 11, 2009 1:46 pm    Post subject: Reply with quote  Mark this post and the followings unread
I really fancy a PEK or PER, but I'm not sure whether you can really use them like 4 separate distinct evolvers.
Could you have the PEK set up so you can switch between editing one voice doing a drone, 2 voices playing layered sequences and the fourth a lead played from the keyboard?
PostPosted: Wed Feb 11, 2009 1:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
Yes. It's not totally intuitive, but you can treat each voice as a distinct evolver (called "combo mode" on the poly), or you gather all of them together to make up four voice polyphony. If you have an extra evolver desktop, you can hook that in for a fifth voice, or another poly evolver for eight voice polyphony (no hooking in when in combo mode though).
/Stefan
Audio files: 281
PostPosted: Wed Feb 11, 2009 2:04 pm    Post subject: Reply with quote  Mark this post and the followings unread
/Stefan
'not totally intuitive' Wink
that sounds like it might be quite difficult then
Anyway, thanks for the answer, I shall have to do some more research Smile
PostPosted: Wed Feb 11, 2009 2:10 pm    Post subject: Reply with quote  Mark this post and the followings unread
Actually, I may be overreacting a bit... I've been having some trouble with the knobs on my PEK, so there are a lot of things that don't react in an intuitive way. Wink It works pretty well compared to a lot of other unintuitive things in synths, I think that there are some global settings that confused me a bit in the start, concerning the sequencers and how the voices react to the keyboard.
/Stefan (meaning to carry the thing to the shop - still have my warranty - but I don't own a car and it's such a pain to carry stuff around...)
Audio files: 281
PostPosted: Wed Feb 11, 2009 2:43 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just read the manual for the PEK and it looks like what I want should be possible. Time to start saving Smile
PostPosted: Wed Feb 11, 2009 3:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
I want the new MicroKorg! Very Happy
bachus
PostPosted: Wed Feb 11, 2009 3:52 pm    Post subject: Reply with quote  Mark this post and the followings unread
Hmmm, I'm in the market for a 'puter/audio interface. Please let me/us know how you like it.
ark
G2 patch files: 31
PostPosted: Wed Feb 11, 2009 3:59 pm    Post subject: Reply with quote  Mark this post and the followings unread
Why?
PostPosted: Wed Feb 11, 2009 4:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Why?
Shocked
Flickr
PostPosted: Wed Feb 11, 2009 4:28 pm    Post subject: Reply with quote  Mark this post and the followings unread
For the money ( over here at least ) it doesn´t seem too evil. It does however lack sync in and out connectors, so it obviously doesn´t scale too well.
Flickr
Audio files: 281
PostPosted: Wed Feb 11, 2009 5:22 pm    Post subject: Reply with quote  Mark this post and the followings unread
which colour?
Wink
PostPosted: Wed Feb 11, 2009 5:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
Right, does it come with a redneck Barbie?
Flickr
PostPosted: Thu Feb 12, 2009 1:56 am    Post subject: Reply with quote  Mark this post and the followings unread
which colour?
Why cream of course! Cool
Why do I want one? er- its small, looks fun, runs on batteries! What more could a man ask for? Wink
PostPosted: Thu Feb 12, 2009 1:58 am    Post subject: Reply with quote  Mark this post and the followings unread
Oh yes- forgot (thanks for pointing that one out elektro!), you dorks don't have kids!! Wink Laughing
bachus
PostPosted: Thu Feb 12, 2009 6:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks, right, but some of their other models do have sync. It's just that I'm not familiar with Focusright. Higher powers have recommended RME but they're not really in my price range. Need to keep it as far below $1000 as I can.
Audio files: 281
PostPosted: Thu Feb 12, 2009 7:03 am    Post subject: Reply with quote  Mark this post and the followings unread
which colour?
I've got the original mK and it is all of these things and sounds pretty good too
EdisonRex
Audio files: 172
PostPosted: Thu Feb 12, 2009 1:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
This dork does, and they're bigger than me! And now they play my instruments as well as their own. They do leave the modulars alone for now.
PostPosted: Thu Feb 12, 2009 5:02 pm    Post subject: Reply with quote  Mark this post and the followings unread
whoops Embarassed Laughing
