today> Twyndyllyngs Chez Mosc
3rd run of PCBs for the PS3100 Resonators & the X-panfader
Page 7 of 14 [349 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7, 8, 9, ..., 12, 13, 14 Next
PostPosted: Mon Mar 16, 2009 9:46 am    Post subject: Reply with quote  Mark this post and the followings unread
boards are in! Very Happy
watch out for PMs concerning your advance-orders these days...
PS3100 DT production PCBs
numbertalk
PostPosted: Mon Mar 16, 2009 10:08 am    Post subject: Reply with quote  Mark this post and the followings unread
fonik wrote:
i didn't quote your name, so you would have been in hiding... Very Happy
Thanks, but there are many other glaring examples on the forum of the gaps in my knowledge, as well as instances of brain freeze Smile
LektroiD
PostPosted: Mon Mar 16, 2009 10:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Smile
LektroiD
PostPosted: Fri Mar 20, 2009 6:49 am    Post subject: Reply with quote  Mark this post and the followings unread
all who placed an advance order should have recieved a PM by now.
BTW the first batch of 10 envelopes has been mailed today (all going overseas)...
LektroiD
PostPosted: Fri Mar 20, 2009 5:01 pm    Post subject: Reply with quote  Mark this post and the followings unread
A quick question about the vactrols: My VTL5C3's have only 4 pins, yet your boards look like they take 5 pin vactrols. How is this, and how can I get around it?
LektroiD
Junk Rhythm
PostPosted: Fri Mar 20, 2009 6:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
This board requires the VTL5C3/2.
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger
PostPosted: Sat Mar 21, 2009 2:57 am    Post subject: Reply with quote  Mark this post and the followings unread
that's it. this way we need only 3 vactrols instead of 6 - saves some money and some board space...
dave_3283
PostPosted: Wed Mar 25, 2009 8:50 am    Post subject: Reply with quote  Mark this post and the followings unread
Hooray! Got my boards this morning. They look great. I can't wait to build this project. Thanks Matthias!
LetterBeacon
PostPosted: Wed Mar 25, 2009 10:47 am    Post subject: Reply with quote  Mark this post and the followings unread
Got mine today too! Thanks a lot!
dave_3283
PostPosted: Wed Mar 25, 2009 11:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Ooh- so already a question. I've got two of the resonator boards and no panner. What would I need to do to use the pads intended to go to the panner to bring the individual outs to the front panel?
PostPosted: Wed Mar 25, 2009 11:48 am    Post subject: Reply with quote  Mark this post and the followings unread
just solder a 1k resistor into each hole (assumed you did not already solder a MTA connector into them) and a wire from each resistor to a socket. don't forget to ground the sockets to the circuits ground, unless you are a bananaman. Wink
hope that helps.
bugfight
PostPosted: Wed Mar 25, 2009 2:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
got mine, thanks
Funky40
G2 patch files: 5
PostPosted: Thu Mar 26, 2009 12:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
got mine, looks nice,
thanks Matthias
TekniK
PostPosted: Thu Mar 26, 2009 1:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
my 45 pcb's are in,thanks Matt!
jojjelito
PostPosted: Thu Mar 26, 2009 1:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
I got my boards in the mail. They sure look lovely enough to scream for some soldering action in case of bad weather during the weekend. Thanks Mattias!
numbertalk
PostPosted: Thu Mar 26, 2009 2:29 pm    Post subject: Reply with quote  Mark this post and the followings unread
Boards made it to Brooklyn - thanks!
PostPosted: Thu Mar 26, 2009 3:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
Laughing
time for action!
johans121
PostPosted: Thu Mar 26, 2009 3:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Just got my boards! Thanks!!!
Don't feed me Indian, you WILL regret it!
-Jim
austrohungaro
PostPosted: Fri Mar 27, 2009 3:39 am    Post subject: +-12v psu Reply with quote  Mark this post and the followings unread
Boards arrived yesterday in Barcelona.
I have a question: I found recommended value changes for PS3100 boards to use with +-12v PSU... Any changes recommended for X-Panner?
Dankeshön!
As reference designators for the v3 board are not the same as on v2, I assume values to change are these:
PSU options, value changes, on PS3100 v3
 Filesize:  12.19 KB
 Viewed:  13530 Time(s)
PostPosted: Fri Mar 27, 2009 4:49 am    Post subject: Re: +-12v psu Reply with quote  Mark this post and the followings unread
Dankeshön!
wow, that's cool. forgot about that! and thank you very much for updating it to the v3 board.
these values are derived from a spice model of the CV circuitry. they are not tested in real live.
recommendations for the x-panfader? no.
i just thought it could be fine to increase the values of R46/R50 to attenuate the center channel of the mixer. or what about attenuators for the inputs anyway?
PostPosted: Fri Mar 27, 2009 5:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Fonik,
I just looked at all you PIX on FlickR and boy I have to hand it to you, your work is astounding. The craftsmanship is absolutely top notch !!!
Keep the fine work coming ... I really enjoyed the pictures. Wink
Bill
Spratty
PostPosted: Sat Mar 28, 2009 4:15 am    Post subject: Reply with quote  Mark this post and the followings unread
Boards arrived the other day Smile
Thanks fonik
Spratty Wink
PostPosted: Sat Mar 28, 2009 4:58 am    Post subject: Reply with quote  Mark this post and the followings unread
thank you so much for the compliment, bill. all the more, considering your professional builds.
PostPosted: Sun Mar 29, 2009 6:40 am    Post subject: Reply with quote  Mark this post and the followings unread
"The world would be a happier place if we stopped to look at others accomplishments in place of our own"
I appreciate great work because I know what energy, time, and thought that must be put into it ........... my pleasure to compliment you .......
Bill
mono-poly
PostPosted: Sun Mar 29, 2009 7:49 am    Post subject: Reply with quote  Mark this post and the followings unread
45???? Shocked
