Wogglebug circuit
Page 13 of 14 [332 Posts]
Goto page: Previous 1, 2, 3, ..., 11, 12, 13, 14 Next
6079smith
PostPosted: Thu Mar 26, 2009 2:45 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry, I was thinking of another LED thing I did on the Wogglebug I made - a bicolour on the woggle tone output.
Which version are you using? If it's Richard Brewster's version, I can see there's a transistor inverter just before the output buffer for the clock output... maybe you could take the driver input from just before that?
Audent
PostPosted: Sat May 02, 2009 10:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
looks like Wogglebug PCB's are back in stock at bridechamber- exciting!
http://www.myspace.com/skaneskaneskane
sduck
PostPosted: Tue Mar 16, 2010 3:08 pm    Post subject: Reply with quote  Mark this post and the followings unread
Sorry to resurrect this thread once again (actually I'm not really that sorry)!
I'm having the same problem xpmtl had. Did he ever get it sorted out? I just built 2 more bugs with the group buy pcb's, with the idea of having them behind a dual panel with all the extra features found in the wiard version. With both of the first 2 I built, I didn't wire up the lfo out jack, but I have with these new ones. However, the output seems pretty useless - stuck at 5v, with little dips to about 4v at the clocks (like the diagram xpmtl put up a page back) - seems inverted from what it should be.
And I'd also like to wire up an led from the lfo rate with the cgs pcb, but with that always-on voltage, the led doesn't really do much. I'm going to try some alternate places to connect the sensor wire for the led, but I'd still like to sort out the lfo out problem to make it usable.
Any ideas?
Edit: bump - I hope someone has some ideas about this!
sduck
PostPosted: Wed Mar 17, 2010 2:55 pm    Post subject: Reply with quote  Mark this post and the followings unread
I tried running the lfo out through my cgs inverter and got the behavior I expected - short positive 5v pulses at the clock, 0v in between, and the led behaving correctly. So as the circuit is really simple, I'll just breadboard up 2 of those and hook them up behind the panel.
davebr
PostPosted: Thu Mar 18, 2010 12:35 pm    Post subject: Wogglebug circuit
Subject description: potentiometer taper
What are people using for the 1M potentiometer taper?
I'm thinking log would work best.
sduck
PostPosted: Thu Mar 18, 2010 3:24 pm    Post subject: Reply with quote  Mark this post and the followings unread
I used linear ones, but now that you mention it, log ones might work better - there seems to be lot more change near the top end of the rotation. However, given the random nature of the device, getting a precision setting on the dials is of a low priority for me, so I won't be changing them out to see if it makes a difference.
davebr
PostPosted: Fri Mar 26, 2010 11:48 am    Post subject: Wogglebug
Subject description: Added a web page
I've started building my Wogglebug PCB. I've created a web page with a Mouser part number list, photos, and other information. I'll continue to update it as I complete the module. Since I'm still building the PCB I haven't yet verified all the parts.
I was unable to find a set of schematics with the correct pin and reference information for U5, U6, and U7 so I edited the schematics myself. I also included the stability modification for U3. I posted this update on my web page (let me know if they already exist somewhere on the web).
So far I've only implemented two additional modifications - changing the LFO Out to a Clock Out, and adding a LED indicator for the Clock Out. The LFO Out was a +/- 5 volt 7.4 mS negative pulse that I thought would be more useful as a 0 to +5 volt positive pulse to use as a variable clock / trigger generator.
http://modularsynthesis.com/bridechamber/wb/wb.htm
sduck
PostPosted: Fri Mar 26, 2010 1:49 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very nice! I'm guessing you haven't gotten around to adding the cluster cap cludge to your list of add-ons - I'm pretty sure you know what I mean. Every one of mine has needed it to get the cluster knob working.
Edit - oops, now that you mention it I see you had it there all along. Sorry.
davebr
PostPosted: Fri Mar 26, 2010 5:08 pm    Post subject: Wogglebug Circuit
Subject description: Modifications
I noted that additional modification on my web site.
I'm debating about whether I want to modify the Smooth, Woggle, and Stepped CV outputs to 5 volt range rather than the 10 volt range. I thought I would wait and see how well I like it with 10 volt range but that seems pretty large. Any thoughts?
davebr
PostPosted: Fri Mar 26, 2010 6:33 pm    Post subject: Reply with quote  Mark this post and the followings unread
xpmtl wrote:
hi all,
I'm trying to add the cgs led driver to the clock out but i got into trouble as the pulse seems inverted.
The led is bright all the time and goes off for a micro-second. Anyone got the same results?
Do I have to use an inverter or is there a simplier way to solve that?
Pulse looks like the first one in the image attached, for correct operation it should be like the second i think.
thanks
A CMOS 555 can sink quite a bit of current, so it can drive the LED directly. Connect the anode to +15 volts, and the cathode through a 3K3 resistor to pin 3 of U4. It will turn on the LED only for those short pulses and behave exactly as you want.
Sorry for the late response. I just got my wogglebug PCB so I am now just getting familiar with it.
sduck
PostPosted: Fri Mar 26, 2010 7:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I've never considered the range of the cv outs to be too much. I'd leave them at 10v - you can always attenuate them down if desired.
davebr
PostPosted: Fri Mar 26, 2010 9:11 pm    Post subject: Wogglebug
Subject description: Output levels
I decided to add jumpers for either 0 - 5 volts or 0 - 10 volts. That way I can easily change it. I've finished the module and have photos on my web page.
davebr
PostPosted: Tue Apr 06, 2010 4:05 pm    Post subject: Wogglebug
Subject description: 50% duty clock out
After using my Wogglebug for a bit, I decided I wanted the clock out to be a 50% duty cycle. The rate is plenty fast so I decided to divide the output of the 555 by two to generate a square wave. I made a module using an 8 pin DIP header, a LM555C, and a 74C74 that plugs right in place of U4 so there are no modifications to the PCB. Three of the 74C74 pins line up with the LM555C so there are just a few pins to hand wire.
I added the details to my Wogglebug page.
slacker
PostPosted: Wed Apr 07, 2010 10:13 am    Post subject: Reply with quote  Mark this post and the followings unread
That's brilliant Dave Smile
xpmtl
PostPosted: Wed Apr 07, 2010 11:10 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi sduck,
i solved the problem experimenting on the breadboard. IIRC, I just used a pnp tranny instead of a npn.
If u need more info i'll gladly take the module off the cabinet and try to redraw something.
Edit : i've redrawn the circuit I think I used. If you gonna use it, please check it on breadboard before.. I'm not an expert at those things Wink
 Filesize:  32.31 KB
 Viewed:  431 Time(s)
http://sdiy.xpmtl.net
sduck
PostPosted: Wed Apr 07, 2010 7:21 pm    Post subject: Reply with quote  Mark this post and the followings unread
Thanks! But I went ahead and made a little inverter board and hard wired it back there, and it works great. I only discovered the problem after I had installed everything, and using the addon board made a little more sense than taking the whole thing apart. I knew the addon board was going to work, and I wasn't so sure about the other kind of fix, so the choice wasn't too hard. However, I'm sure your fix will help someone else down the road, so it's all good!
tommi
PostPosted: Thu May 06, 2010 9:32 am    Post subject: Reply with quote  Mark this post and the followings unread
Since i am waiting for a PCB from bridechamber i am documenting myself for all possible modifies for the wogglebug. I 've seen different solutions for the clock rate led. The simplest seems to be the one from davebr: 3k3 resistor from pin3 of U4 (lm555) to cathode, +V to anode. I think i 'll try this one.
Also, as written by sduck on the top of this page:
I would like to have an lfo out jack on my panel to use as trigger out for ADSRs, drum modules or even to clock sequencers. Anybody can point me to a circuit i can use?
On this scheme posted by xpmtl is the 10k supposed to be linked to pin3 of U4?
http://tideofsound.net
davebr
PostPosted: Thu May 06, 2010 9:53 am    Post subject: Reply with quote  Mark this post and the followings unread
I inverted my LFO output so it would be a positive pulse instead of a negative pulse to use it as a trigger output. It is a fixed 7.4 mS pulse and there is a scope image on my site.
After doing this and playing with it a while, I later changed it to a 50% duty cycle square wave. I left the inversion since it was already done but this would be unnecessary with the 50% duty cycle mod. It did, however, make the green LED indicate the positive portion of the waveform (LED=on when the 555 timer output is low).
Details of my mods are on my site.
For a fixed pulse-width trigger, modify U6A to the circuit modification #6.
For a 50% duty cycle, just do the circuitry in modification #10. You can connect the LED to the /Q output (LED=on when /Q low, which makes Q high, and with standard U6A circuit makes LFO out high).
tommi
PostPosted: Thu May 06, 2010 11:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks davebr, i think i 'll do the inverter modification, it will do the job of triggering out short pulses for sequencers, etc.
The 555 will still be clocking U3(LF398) thru R27. In place of R40 (49,9K) there will be a 300k resistor. Another 300k resistor from +in to -V. One 100k on the feedback path and the -in to ground. Is that right?
Is it tricky to do? How many traces to cut?
davebr
PostPosted: Thu May 06, 2010 4:15 pm    Post subject: Wogglebug LFO modifications Reply with quote  Mark this post and the followings unread
Correct
Correct
I just noticed that I got the + and - inputs backwards for the mod on my website. The 300K is to the - input and you should be able to use R8.
I swapped the + and - inputs so the + input is grounded. Take a look at the updated modification and I think it will be clear.
I'm afraid I didn't take very good notes. I made 3 cuts but in looking at it, I think you only need to make 2.
You have to cut the feedback loop from pin 1 to 2. That is on the top layer. R27 [error - should be R26] stays connected to pin 1.
You have to cut the input to pin 3. I did so under R8.
Then you have to connect the junction of R40/R8 to pin 2. You have to add a 100K feedback resistor (on the back) between pins 1 and 2. You have to ground pin 3.
That should do it. I think I used R8 as the feedback resistor so the third cut was the -15V . Using R8 as the other 300K resistor eliminates one cut. I didn't take a photo of the modification.
tommi
PostPosted: Fri May 07, 2010 1:43 am    Post subject: Reply with quote  Mark this post and the followings unread
Thanks dave,
Looking at your picture of the populated board ( i was searching for details of your mod) it seemed to me that this modification wasn't yet done.
Anyway, in your answer it's all clear for me except for you said that R27 stays connected to pin 1.
On your WB's schematic R27 is linked to the 555's out on pin 3, not to pin1 of U6 (this is what i thought you was saying?).
I guess you was meaning that R26 stays linked to U6, pin1?
davebr
PostPosted: Fri May 07, 2010 7:18 am    Post subject: Wogglebug modification Reply with quote  Mark this post and the followings unread
Correct.
tommi wrote:
In your answer it's all clear for me except for you said that R27 stays connected to pin 1. On your WB's schematic R27 is linked to the 555's out on pin 3, not to pin1 of U6 (this is what i thought you was saying?).
Yes, sorry.
tommi
PostPosted: Fri May 07, 2010 8:27 am    Post subject: Reply with quote  Mark this post and the followings unread
Dave,
Since the led it's directly linked to the out of U4 (pin3), i think that in case of external clocking it will still indicate the rate of the internal clock. This would be distracting...
I thought i could add an led circuit (cgs led driver?) to pin7 of U6B (the amp stage of clock in) to indicate the actual rate at wich the circuit is clocked.
Maybe i am wrong on the interpretation of how your led is ment to behave?
davebr
PostPosted: Fri May 07, 2010 8:40 am    Post subject: Reply with quote  Mark this post and the followings unread
tommi wrote:
Dave,
You have two choices - have the LED follow the internal clock or the wogglebug clock. I wanted to use the LFO for a clock generator for my CVS modules (that is why there are three LFO outputs) so I had the LED follow the internal generator. If I am driving the Wogglebug from an external clock source, that source will have an LED indicating the rate.
You can wire it up after U6B so it will follow the Wogglebug rate whether it is internally or externally generated. There are a couple of different ways to do that. One way would be to add a LED in series with D3 and change R20 to set the appropriate current (you could replace D3 with a LED if it had a 15 volt reverse voltage spec).
tommi
PostPosted: Fri May 07, 2010 8:53 am    Post subject: Reply with quote  Mark this post and the followings unread
One way would be to replace D3 with a LED and change R20 to set the appropriate current.
You ment that I could change R32(20K), maybe lowering it to make the led brighter? Are you sure that lowering the value of that resistor wouldn't affect some way the clocking of the S&H chip, i mean that it maybe could lower the level of the square wave?
