Jim Patchell's Vocal Filter
Page 4 of 6 [126 Posts]
zthee
PostPosted: Wed Mar 18, 2009 8:01 am    Post subject: Reply with quote  Mark this post and the followings unread
Aha, BP1 means Break Point 1 ! That kinda threw me off, thinking - why does he have like 24 band pass filters Wink
But now I get it!
Looks great!
PostPosted: Thu Mar 19, 2009 6:32 am    Post subject: Reply with quote  Mark this post and the followings unread
there is one thing i am still not sure about. it is the wiring of the shapers gain potentiometers: as i understand it now for each shaper the summed vowel CVs are fed into the negative input of an OpAmp, whereas the positive input is fed by the vowel CVs that went through a potentiometer. The Opamp will compare and cancel out the original CVs!? the output of the OpAmp is mixed with the shaped CV anyways, so how could this influence the gain of the shaper?
i am still not sure, just because i don't understand it, and i don't see the connection from the pot to the vowel CVs for two of the gain potentiometers.
andrewF
PostPosted: Thu Mar 19, 2009 8:11 am    Post subject: Reply with quote  Mark this post and the followings unread
Vowel Out, pin15 of JP5 connects to all 3 Master Gain pots, although only one connection is shown.
are these the 2 gain pots you are unsure of?
PostPosted: Thu Mar 19, 2009 8:21 am    Post subject: Reply with quote  Mark this post and the followings unread
exactly. so i am right about the connection - i still don't understnd the gain functionality...
andrewF
PostPosted: Thu Mar 19, 2009 3:42 pm    Post subject: Reply with quote  Mark this post and the followings unread
you are right, the gain pots are dividing the CV signal and feeding it to the inv inputs.
Originally I had assumed they were differential amp stages with adjustable gain, but now after your question and a closer look, not so sure Question
Maybe it is worth setting one of these stages up in Pspice or on a breadboard to see how it works.
Or contact Jim, for the definitive answer.
knarleybass
PostPosted: Sun Mar 22, 2009 2:27 pm    Post subject: Reply with quote  Mark this post and the followings unread
it's one crazy filter, I built one about 5 years ago.
PostPosted: Mon Mar 23, 2009 4:20 pm    Post subject: Reply with quote  Mark this post and the followings unread
so you like it? i hope it is worth the effort. would it be insolent to ask you for some sound samples?
i found a little company that will print on a front panel i send them. i ordered the cabinet and will then send them the panel to print my graphics on (one color/black). it will cost less than a schaeffer panel, i will have to do all the drilling, though.
VocalFilter_panel2
PostPosted: Mon Mar 23, 2009 4:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
if you wonder about the CV/potentiometer combination on the break points: i plan to wire the jacks normalled to the +10V reference. this way i could use the pot as manual control with no CV plugged in. as soon as the CV in socket is used, the pot would work as attenuator...
knarleybass
PostPosted: Mon Mar 23, 2009 4:56 pm    Post subject: Reply with quote  Mark this post and the followings unread
sadly, where I live now I don't have room for my modular, it's in storage.
PostPosted: Tue Mar 24, 2009 2:15 am    Post subject: Reply with quote  Mark this post and the followings unread
a real pitty, isn't it? great work, knarleybass.
knarleybass
PostPosted: Wed Mar 25, 2009 11:45 am    Post subject: Reply with quote  Mark this post and the followings unread
Someday I will get it out again.
ach_gott
PostPosted: Wed Mar 25, 2009 12:58 pm    Post subject: Reply with quote  Mark this post and the followings unread
If you ever decide you don't want to store it anymore, drop me a PM. I'll still build one though... more vocal sounds! babble
PostPosted: Mon Mar 30, 2009 1:12 am    Post subject: Reply with quote  Mark this post and the followings unread
some progress here. now i am waiting for the frontpanel...
Vocal Filter waiting for the front panel
andrewF
PostPosted: Mon Mar 30, 2009 1:32 am    Post subject: Reply with quote  Mark this post and the followings unread
lookin' good
*just* the wiring to go
Very Happy Very Happy Wink
knarleybass
PostPosted: Mon Mar 30, 2009 1:42 am    Post subject: Reply with quote  Mark this post and the followings unread
it is going to be amazing!
PostPosted: Mon Mar 30, 2009 1:44 am    Post subject: Reply with quote  Mark this post and the followings unread
i am Klee2-proven. so no concerns on my side Laughing
or at least no big concerns.
TekniK
PostPosted: Mon Mar 30, 2009 4:11 am    Post subject: Reply with quote  Mark this post and the followings unread
andrewF wrote:
lookin' good
yes,and from then he can post his own demo's cheesy
PostPosted: Fri Apr 03, 2009 3:30 pm    Post subject: Reply with quote  Mark this post and the followings unread
the frontpanel arrived today. the result is amazing, IMHO at least. actually i am a littlebit overwhelmed and i must show it to you, even though i still have to drill the holes. Without the holes it ahs been less than a schaeffer panel. i will ahve to contact the company about the drilling (what do they need, how does it fit with the print (offset tolerances).
a little bit blurry, sorry:
Vocal Filter Frontpanel
close-up:
Vocal Filter Frontpanel close-up
Sine
PostPosted: Fri Apr 03, 2009 3:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Very nice fonik !
Now the trick is to drill it without damaging the print.
PostPosted: Fri Apr 03, 2009 3:50 pm    Post subject: Reply with quote  Mark this post and the followings unread
the "printing" is actually black anodized. i drilled black anodized panels before without any issues!?
do you have some experiences with this kind of print and drilling? what should i be aware of? i wanted to start tomorrow...
TekniK
PostPosted: Fri Apr 03, 2009 4:14 pm    Post subject: Reply with quote  Mark this post and the followings unread
noting,just drill
seriously
zthee
PostPosted: Sat Apr 04, 2009 9:25 am    Post subject: Reply with quote  Mark this post and the followings unread
Looks awesome!
Happy drilling!
knarleybass
PostPosted: Wed May 06, 2009 1:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
I can't wait to see more progress on your filter.
PostPosted: Wed May 06, 2009 1:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
me too Laughing
i mounted all front panel components and made the ground star configuration. this all goes alongside with my other projects. i hope it will be finished end of month for the german modular meeting.
ryktnk
PostPosted: Wed May 06, 2009 1:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
hello
That's a great design for your panel, very cool
Do you mind me asking who made it ?
Is it not Schaeffer ?
Thanks
-ryk
