today> Twyndyllyngs Chez Mosc
Living VCOs
Page 6 of 21 [520 Posts]
Goto page: Previous 1, 2, 3, 4, 5, 6, 7, 8, ..., 19, 20, 21 Next
Would you prefer one PCB with 3 VCOs a la JH-5A, or 1 VCO per PCB with more features
One PCB with Oscillator Driver and 3 VCO cores (like JH-5A - cheap!)
60%
 60%  [ 62 ]
1 PCB = 1 VCO (with many waveforms and inputs)
39%
 39%  [ 41 ]
Total Votes : 103
jhaible
PostPosted: Wed Apr 08, 2009 10:23 pm    Post subject: Reply with quote  Mark this post and the followings unread
TekniK wrote:
Juergen,is this the design where a part of the 3046 is used already to have a temp compensation inside,but u just add an xtra tempco on it?
You need three 1k tempco resistors, one for each VCO.
JH.
TekniK
PostPosted: Thu Apr 09, 2009 2:48 am    Post subject: Reply with quote  Mark this post and the followings unread
Yes i know u need 3 tempcos,but my Q is that i wander if its the known 1v/oct exponential generator circuit design where the 3046 self is acting as a temp compensator and warms up where u just added an extrnal tempco on it?
Spratty
PostPosted: Thu Apr 09, 2009 3:30 am    Post subject: Reply with quote  Mark this post and the followings unread
Hi JH,
I really enjoyed the demo of these oscillators. You really have quite a knack for putting together toys that appeal Smile I could quite happily see myself building this one and spending hours messing with the VCO's.
From looking at the BOM for this project a lot of the parts are very common. What I do however ponder about as an Aussie is sourcing those 10 turn pots and verniers. Quotes I have gotten so far for these things have been stupidly expensive, unless I want to buy a lot of the things (and trust me, I wouldn't know what to do with 20+ of each of these). Does anyone know of a place that will sell these items for a reasonable price for small quantities (USD?) without a huge shipping fee or high minimum order quantity?
Spratty Wink
2thick4uni
PostPosted: Thu Apr 09, 2009 3:38 am    Post subject: Reply with quote  Mark this post and the followings unread
Farnell do a good range of pots and counting dials, not sure how much they charge for postage to Oz ............You don't have to build it with ten turn pots, I'd guess you could build it with standard 1 turn course and 1 turn fine pots with a minor circuit alteration.
jhaible
PostPosted: Thu Apr 09, 2009 8:37 am    Post subject: Reply with quote  Mark this post and the followings unread
No need for heating the chip when I'm using a tempco resistor.
JH.
jhaible
PostPosted: Thu Apr 09, 2009 8:39 am    Post subject: Reply with quote  Mark this post and the followings unread
Spratty wrote:
Hi JH,
Spratty Wink
I think Tobias will offer a part kit for this project.
It probably doesn't make sense to just ship 3 multiturn pots across the world, but a whole kit makes sense, IMO. (Not speaking for Tobias, though.)
JH.
/mr
PostPosted: Thu Apr 09, 2009 9:15 am    Post subject: Reply with quote  Mark this post and the followings unread
jhaible wrote:
...3 multiturn pots...
Do you have any convincing argumentation about choosing multiturn pots here, aside from being EMS-ish?
Personally (I think! Wink ) I would prefer either Coarse+Fine pots, or Octave selector + Fine pot. Please enlighten us about any mischievous drawbacks if you have found any. In the Frequency Shifter, you had quite good reasoning about preferring Coarse+Fine pots in that particular application, which makes me curious here. Smile
jhaible
PostPosted: Thu Apr 09, 2009 10:34 am    Post subject: Reply with quote  Mark this post and the followings unread
You can always use coarse/fine pots if you add the extra resistors.
But I like the multiturn pots:
They allow 10 Octaves range with a single knob!
BTW, there is some simple octave switching in the driver section (one oct up, normal, one oct down) so you can quickly transpose the whole set of 3 oscillators. Also, a fine tune pot that works on all 3 oscillators in common. But for setting intervalls, I love these multiturn pots. No hitting the end of the fine tune pot's travel, and re-adjusting the coarse tune, and so on ...
Better than the EMS solution as well, IMO. (EMS used single turn pots and vernier dials.)
JH.
synthetic
PostPosted: Thu Apr 09, 2009 4:41 pm    Post subject: Reply with quote  Mark this post and the followings unread
Can you talk a little about the "Living" section of the VCOs yet? Your linear detune circuit?
2thick4uni
PostPosted: Thu Apr 09, 2009 4:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Is it possible to add sync to two of the VCO's? I understand that a lot of design effort has gone into getting it so the VCO's free run when very close in frequency, but if I could add a sync switch too it would be very useful.
I know that schematic hasn't been posted yet, just need a yes or no at this stage as I'm not sure if the VCO core follows usual integrator / comparator sawtooth design............
jhaible
PostPosted: Thu Apr 09, 2009 11:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
It's not on-board, but it should be easy to add.
JH.
jhaible
PostPosted: Fri Apr 10, 2009 11:37 am    Post subject: Reply with quote  Mark this post and the followings unread
I've written something about it here:
http://www.jhaible.de/living_vcos/jh_living_vcos.html
(updated a few minutes ago)
JH.
delayed
PostPosted: Fri Apr 10, 2009 1:03 pm    Post subject: Reply with quote  Mark this post and the followings unread
where do you get the Tempco's ? Perhaps a part number or link? I am in the US and the Farnell number says they do not stock them. Is there a company that ships these within the US? Also perhaps a place to get the 3 10 turn pots?
Thanks,
vtl5c3
PostPosted: Fri Apr 10, 2009 1:51 pm    Post subject: Reply with quote  Mark this post and the followings unread
Check with Bridechamber:
http://www.bridechamber.com/bridechamber.com/Hard%202%20Find%20ICs.html
Thanks,
numbertalk
PostPosted: Fri Apr 10, 2009 5:17 pm    Post subject: Reply with quote  Mark this post and the followings unread
I second Bridechamber for the Tempcos.
This is what I got for the 10-turn pots:
http://www.mouser.com/Search/ProductDetail.aspx?R=3590S-2-103Lvirtualkey65210000virtualkey652-3590S-2-103L
Hopefully that one will work!
Thanks,
dingebre
PostPosted: Fri Apr 10, 2009 7:47 pm    Post subject: Reply with quote  Mark this post and the followings unread
Bridechamber, Magic Smoke Electronics, and Precision Resistor all sell through hole tempcos of different values.
Tobias is selling two kinds of kits, if you didn't see his post. One with all PCB parts and the 10 turn pots, dials, and panel trimmers, one with just the PCB parts. I just bought the parts kit from Tobias (well, two actually, thank Tobias).
I'm doing a FracRack version so I wanted to choose my own -small- dials and pots.
I bought these dials:
https://www.alliedelec.com/Search/ProductDetail.aspx?SKU=6640008&MPN=412&R=6640008&SEARCH=6640008&DESC=412
and these pots:
http://www.mouser.com/Search/ProductDetail.aspx?R=534-1-1-103virtualkey59400000virtualkey594-53411103
I bought these holders for panel mounting of 3/4 inch PCB mount multi-turn trim pots (I needed them for other projects, too.):
http://www.mouser.com/Search/ProductDetail.aspx?R=006-1-0virtualkey59400000virtualkey594-610
I'll put them on a small piece of pad-per-hole vero board and hook up to that.
Got the pots and knobs today and they look/work great.
Can't wait for all the stuff.
dingebre@3dphysics.net
jhaible
PostPosted: Sat Apr 11, 2009 1:46 am    Post subject: Reply with quote  Mark this post and the followings unread
These look beautiful!
JH.
jhaible
PostPosted: Sat Apr 11, 2009 5:11 am    Post subject: Reply with quote  Mark this post and the followings unread
I've just put some wiring options up on my web site:
These are just some ideas - it's up to you what you really want to implement, and what to omit.
JH.
jhaible
PostPosted: Sat Apr 11, 2009 2:13 pm    Post subject: Reply with quote  Mark this post and the followings unread
... and here is a demo of a *single* VCO with PWM-overmodulation in CS-80 style:
http://www.jhaible.de/living_vcos/living_vcos_single_vco_pwm.mp3
(One VCO thru wide open filter + VCA + reverb)
JH.
synthetic
PostPosted: Sun Apr 12, 2009 7:11 pm    Post subject: Reply with quote  Mark this post and the followings unread
Bridechamber may be doing a kit as well.
davebr
PostPosted: Mon Apr 13, 2009 9:17 pm    Post subject: Living VCOs
Subject description: Front Panel Designs
I was planning on passing this project by but decided to put my order in for a PCB. I have only 5U of space remaining in my modular so I was going to try and hold off for a while - it can't be done!
I played around with a 5U module design but just don't want to use that much space. I simplified the design a bit to fit in a 4U module with 6 knobs per VCO with a horizontal organization. I shrunk this down to a 3U by eliminating the VCO out mix knobs. I ended up changing the 3U design to a vertical format that I like the best. All the designs use the smaller knobs as do my other JH modules.
The various concept panels are on a new page at
http://modularsynthesis.com/jhaible/lvcos/jhlvcos.htm
Here is the 3U design that I like the best. - Dave
TekniK
PostPosted: Wed Apr 15, 2009 7:53 am    Post subject: Reply with quote  Mark this post and the followings unread
funny store,first u have to give them access to ur creditcard account,then a day later they send u a mail with the shipping costs,ofcource then u already have buyed the items.
ach_gott
PostPosted: Wed Apr 15, 2009 9:08 am    Post subject: Reply with quote  Mark this post and the followings unread
Mouser works like this, too. It can be quite frustrating.
etaoin
PostPosted: Wed Apr 15, 2009 12:31 pm    Post subject: Reply with quote  Mark this post and the followings unread
How critical is the exact value of the 2n7 polystyrene cap? I only have a single 2n7 in stock but loads of 3n3. If it is critical, does it pay to order 1% polystyrene?
http://www.casia.org/modular/
jhaible
PostPosted: Wed Apr 15, 2009 1:18 pm    Post subject: Reply with quote  Mark this post and the followings unread
I don't think it's critical. Haven't tested either, but I'd go for 2n2 instead of 3n3, if 2n7 is hard to get.
No need for 1%.
JH.
